The following code is part of my attempt to answer the recent Question about the bifurcation of the map f:= x-> exp(x^2*(a-x)). Two very weird things are happening. They can be seen by applying trace to f. The first is that the input argument to f seems to be changed to a very large integer. The second is that for some real values of a and x, I get imaginary results from this obviously real-valued function. Why are these things happening?
f:= x-> exp(x^2*(a-x)):
trace(f):
Iterate:= proc(a, x0:= 1., n:= 2000)
local A:= hfarray(1..n, [x0]), f:= subs(:-a= a, eval(:-f));
     #evalhf(
          proc(f, A, n)
          local k;
               for k from 2 to n do A[k]:= f(A[k-1]) end do
          end proc
          (f, A, n);
     evalf[4]~(convert(A[1000..], set))
Iterate(1.05);
{--> enter f, args = 4607182418800017408
HFloat(1.0512710963760241)
<-- exit f (now in unknown) = 4607413323290551347}
{--> enter f, args = 4607413323290551347
HFloat(0.9985962074909431)
<-- exit f (now in unknown) = 4607169774561176020}
{--> enter f, args = 4607169774561176020
HFloat(1.0525960836530153)
Iterate(.75);
.754589752755861+.192678397202388*I
<-- exit f (now in unknown) = HFloat(0.7545897527558614)+HFloat(0.19267839720238844)*I}
Error, (in unknown) unable to store 'HFloat(0.7545897527558614)+HFloat(0.19267839720238844)*I' when datatype=float[8]
Download bifurcation.mw
How to show what class of bifurcation is in this function :   exp(x2*(a-x)) ?
I have a long list of two element lists, for example,
A := [ [2,3], [4,5] ,[6,7]];
I want apply '/' to the elements of each sublist.
The result will be
R := [2/3, 4/5, 6/7];
I do not need the list, I could use vectors or matrices.
Is it possible to do this other than by iteration?
Tom Dean
I want to set up a couple of tables. One problem I have is setting up the list of names for the columns.  u0 etc are actual variables. Being trying to use  ` ` and ' ' to stop them evaluating. I have even more problems with  h6 as a name and symbols Sigma etc.
How do you do this so it looks neat and the name preferably doesn`t display the  ` ` or " " or '  '?
"Names:=[`u0`,`u1`,`u2`,`u3`,`Px`,`Py`,`Pz`,`-`,`'g0'`,`'g1'`,`'g2'`,`'g3'`,`-`,`\`&sum;u`^(2)`,`-`\`,&sum;p`^(2)`,`-`,` &sum;g^(2)`]"
Error, unable to delimit strings/identifiers
"Names:=[`u0`,`u1`,`u2`,`u3`,`Px`,`Py`,`Pz`,`-`,`'g0'`,`'g1'`,`'g2'`,`'g3'`,`-`,`\`&sum;u`^2`,`-`\`,&sum;p`^2`,`-`,` &sum;g^2`]"
Download Table_Headers.mw
greatings all,
I want to calculate energy momentum tensor for a given metric. is it possible to calculate it in the physics package?
thanks.
Please find the attached file
The command PolynomialInterpolation doesn't work, I will be appreciate if you can help me
Question.mw
hi.i am a problem for solving this non linear algebric equation.
please help me...thanks
FSOLVE.mw
FSOLVE.mw
With the RationalFunctionTutor generated then modified code (see egn2.mw attached).  Is it possible to make linestyle=spacedash for the two vertical asymtotes?  By selecting the graph and choosing from the plot menu the linestyle can be changed, but is there a way to do this with commands in the program code?
egn2.mw
When I was editing the head of the question (? instead of .), its body disappeared. Please, insert it again.
Regard,
Markiyan Hirnyk
Maple 15.
I have a set of equations I can solve manually, but, solve fails.
eq1 := tgtX[1] = 0;
eq2 := tgtY[2] - y[2]    = m[2]*(tgtX[2]-x[2]);
eq3 := tgtY[3] - y[3]    = m[3]*(tgtX[3]-x[3]);
eq4 := tgtY[4] - y[4]    = m[4]*(tgtX[4]-x[4]);
eq5 := tgtY[2] - tgtY[1] = vy*t[2];
eq6 := tgtY[3] - tgtY[1] = vy*t[3];
eq7 := tgtY[4] - tgtY[1] = vy*t[4];
eq8 := tgtX[2]           = vx*t[2];
eq9 := tgtX[3]           = vx*t[3];
eq10:= tgtX[4]           = vx*t[4];
# solve the equations
eqs  := {eq1,eq2,eq3,eq4,eq5,eq6,eq7,eq8,eq9,eq10};
solvx := solve(eq10,vx);
solvy := solve(eq7,vy);
sol1  := subs(vx=solvx,{eq8,eq9});
sol2  := subs(vy=solvy,{eq5,eq6});
soln  := subs(sol1,{eq2,eq3});
soln  := subs(tgtY[2]=solve(sol2[1],tgtY[2]),soln);
soln  := subs(tgtY[3]=solve(sol2[2],tgtY[3]),soln);
soln  := subs(tgtY[1]=solve(soln[1],tgtY[1]),soln[2]);
soln  := solve({eq4,soln},{tgtX[4],tgtY[4]});
# this returns empty solution
solve(eqs,{tgtX[4],tgtY[4]});
Any ideas?
Tom Dean
Is there an option/ or a way so as to ask pointplots to plot a interpolated curve for the points defined ?
Thank you for you help.
I have a complex set of non linear diff eqns in the form :
y1'' = f(y1',y1,y2'',y2',y2,y3'',y3',y3,y4'',....,y6'',y6',y6,u1,u2,u3,u4) ;
y2'' = f(y1'',y1',y1,y2',y2,y3'',y3',y3,y4'',....,y6'',y6',y6,u1,u2,u3,u4)
and so on ... y6''=(...)
As I want to resolve this coupled systeme in matlab using @ODE45... I wanted the equations in the form : y1''=f(y1',y1,y2',y2,....) and so on ... => X'[] = f(X[],U[])
How can I force maple to rearrange a system of coupled eqns with only the variables i want ?
I know this is possible beacause it is a nonlinear state space model but maple do not work with nonlinear state space model... It give me error when I tried to create statespace model with my non linear diff eqns.
Thanks a lot !
Introduction
I have a matrix (named DC on the piece of code below) all the elements of which are complex numbers a+b*I with a and b floating point numbers.
I want to obtain the real part of DC.
Obviously, if you do something like :
DC := Matrix(2,2, [1.0+1.0*I, 1.0-1.0*I, -1.0+1.0*I, -1.0-1.0*I];
Re~(DC);
the result corresponds to the desired matrix
Context
In fact this matrix DC comes from some computations  described in the piece of code below
# Purpose :
# Given N points in a plane (here  in [0,1]X[0,1]), compute the matrix DX of distances between these points
# Example : if Pi and Pj are two such points, DX[i,j]=DX[j,i] denotes the Euclidian distance between Pi and Pj
# As I did not be able to find any single function in MAPLE that would construct DX , I proceed that way :
#   1/ let X the (N,2) matrix that contains the coordinates of the N points
#   2/ I represent these  N points as N complex numbers (vector C)
#   3/ I construct the (N,N) matrix MC = <C | C …..| C>
#   4/ I put MC = C – Transpose(C) :
#   5/ I take the norm DX of each elements of DC : DX := abs~(DC)
#       At this point, DX should contain the desired distances
#       But, due to floating point arithmetics, each element of DX writes a+0.*I where a is some floating point number)
#   6/ Last stage : execute Re~(DX)
with(Statistics):
N := 4:
X := Matrix(N,2, convert(Sample(Uniform(0,1), 2*N), list)):  #just an example
C   := X[..,1] +~ X[..,2] *~I;
MC := Multiply(C, Vector[row](N, 1));
DC := MC - Transpose(MC);
DX := abs~(DC);
Re~(DX)
 My observations :
1/ Maple 2015, Windows XP, 64 bytes
Re~(DX) returns DX and does not remove the imaginary (0.*I) part
But  Matrix(N, N, Re~(convert(DC, list))) does (which is a satisfactory, even if not clever, stopgap)
Why (it is just a question to help me to understand correctly how MAPLE proceeds) Re~(DC) does not (seem) to work here ?
2/ Maple 2015.2, Mac OS X El Capitan
DX := abs~(DC) gives me this strange result :
If (for instance) DC[i, j] = -1 – 2*I, DX[i, j] = +1 + 2*I
According to the compatibility problems between Maple 2015.1 and “El Capitan” (fixed from February), could it remain a few other problems ?
Last but not lesat : Did I do any syntax error ?
 I look forward to your responses
I have a little question about the property "local" or not of a index in a for loop.
I notice that when I make "for loop" the index i is not local. In the small example, when I ask to evaluate i after having done this loop, the answer is 5 and not i.
Example :
for i from 1 to 4 do
i^2
od;
i; --> 5
How can I do to ask Maple to use index as local ?
Thanks a lot for your help.
I have a question: how to compute the roots of exp(z) = -1 with z in C?
I tried:
fsolve( exp(z) = -1, z, complex );
But it only gives one root (0.1671148658e-3+4.934802220*10^9*I) which does not even seem to be correct. I would prefere smth like z_n = I*(2*n-1)*pi or at least multiple roots...
By using
solve(exp(x) = -1, x);
it returns I*Pi.
MATLAB MuPAD gives the desired result:
(PI*I + 2*PI*k*I, k in Z)
First 1162 1163 1164 1165 1166 1167 1168 Last Page 1164 of 2463
