I would like to export some plots from a worksheet as vectorial picture.
However, I didn't find how to export plots as .svg ou .emf files. These files are accepted by visio which is the software I use for the creation of my figures.
Is it possible to export picture as a vectorial picture and yes, how ?
Moreover, I would like these kind of extensions that is to say .svg and .emf
Thanks a lot for your help.
I thought I'd try the latest version of the physics package. I am trying to look at a "simple" function with quantum operators, Taylor expand it, and write terms in normal order (i.e. Dagger(a) terms before a, and Dagger(b) before b), but am having no luck at all. Not sure if this is possible with the current version.
I am also having a couple of weird "interface issues" after loading the package:
1) See the printout from Setup() command - here Dagger(a) and Dagger(b) is sometimes displayed with a bar above the names, but other times (i.e. during other runs) with daggers.
2) Maple gets "stuck" on one of the lines - meaning I press enter, but it does not jump to the next execution block.
Both of these issues are outlined with "NOTE" in the worksheet.
Ultimately, the interface issues are of no concern to me, but I am pretty curious if the current version of the physics package can do what I need?
Worksheet:  commutator_stuff.mw
I'm trying to solve a 2nd order system of pde's with couplded BC but it gives me the following error
Error, (in pdsolve/numeric) initial/boundary conditions must be defined at one or two points for each independent variable
Here is the code
> T01 := 273; T02 := 26; L1 := .1; L2 := .2; h1 := 100; h2 := 200; k1 := 1; k2 := 2; rho1 := 1000; rho2 := 2000; c1 := 0.1e6; c2 := 0.2e6; alpha1 := 1; alpha2 := 2
> PDE := {diff(T1(x, t), t) = (diff(T1(x, t), x, x))/alpha1, diff(T2(x, t), t) = (diff(T2(x, t), x, x))/alpha2}
> IBC:={k1*(D[1](T1))(L1, t) = k2*(D[1](T2))(L1, t), T1(L1, t) = T2(L1, t), T1(x, 0) = T02, T2(x, 0) = T02, (D[1](T1))(0, t) = -h1*(T1(0, t)-T01)/k1, (D[1](T2))(L1+L2, t) = h2*(T2(L1+L2, t)-T02)/k2}
> pds := pdsolve(PDE, IBC, numeric)
Its basically a 1D heat equation in a 2 layers plate with conduction BC on both sides
Coding in key generation of RSA Cryptosystem
message :=123456;
u := nextprime(RandomTools[Generate](integer(range = 10^100 .. 10^(110-1))));
v := nextprime(RandomTools[Generate](integer(range = 10^100 .. 10^(110-1))));
N := u*v;
phi := (u-1)*(v-1);
In RSA cryptosystem, the encryption or decryption of message only can be existed between range 1<=message<=N. This means that if the value of message bigger than N value then we can't get back the original value when performing decryption.Thus, wanna to ask that how can we create a coding so that the system will recognise the random integer u and v whether lie between range 1<=message<=N, means wanna crete a coding that if  N>=message then it will continue to the phi step whereas if message>=then the system need to regenerate the u and v until it satisfy the condition  1<=message<=N .Thus please help as i am a beginner in Maple.Thanks.
>M1:=146996733613391:
>M2:=1348471408813:
>teks:=numtheory[cfrac](M1/M2,'quotients');
tekssifer:=[109,101,115,115,97,103,101]
Hi, how should i rewrite my command to decrease the execution time?
Thank you~=]]
 For solving polynomial systems I used RootFinding[Isolate]. But after discussing the question http://www.mapleprimes.com/questions/211774-Roots-Of--Expz--1
I decided to compare Isolate and evalf(solve ([...], [...])). It seemed to me that solve some convenient. The only if in the equation there are integers as a real, they should be recorded with a decimal point. (For real solutions of this procedure should be used with (RealDomain).)  Examples:
SOLVE_ISOLATE.mw
I wonder why then the need Root Finding [Isolate]?
Hello evrey one , I need help for solve these equation with boundary conditions
 Boundary Conditions
My COde + equation
restart; with(plots); with(PDEtools)
eq := diff(g(Y), `$`(Y, 4))+diff(g(Y), `$`(Y, 2))+g(Y);
diff(diff(diff(diff(g(Y), Y), Y), Y), Y)+diff(diff(g(Y), Y), Y)+g(Y)
cis := g(1/4) = 0, (D(g))(1/4) = 0, g(0) = 0, (D[2](g))(0) = 0
Error, (in evalapply) too few variables for the derivative with respect to the 2nd variable
solut := dsolve([eq, cis], numeric)
Download mp.mw
ANALYSIS AND DESIGN OF MACHINE FOUNDATION
Loading Optimization
Loading LinearAlgebra
Loading plots
with(ScientificConstants):
Loading DynamicSystems
with(Units:-Standard)
with(Units:-Natural)
with(StringTools)
FormatTime("%m-%d-%Y, %H:%M")
Introduction
This document deals with vibration analysis and design of machine foundations subjected to dynamic load.
GetConstant(g);
standard_acceleration_of_gravity, symbol = g, value = 9.80665, uncertainty = 0, units = m/s^2
g__SI := evalf(Constant(g, system = SI, units))
9.80665*Units:-Unit(('m')/('s')^2)
Richart and Lysmer's Model
Richart et al. (1970) idealised the foundation as a lumped mass supported on soil which is idealised as frequency independent springs which he described in term of soil parameter
dynamic shear modulus or shear wave velocity of the soil for circular footing when footings having equivalent circular radius. The Tables below shows the different values of spring and damping vlaues as per Richart and Lysmer.
In which, G = dynamic shar modulus of he soil and is given G = `&rho;__s`*V__s^2 ; ν = Piosson's ratio of the soil; ρs = mass density of the soil; Vs = shear wave velocity of the soil obtained
from soil testing; g = acceleration due to gravity; m = mass of the machine and foundation; J = mass moment of inertia of the machine and foundation about the appropriate axes; K = equivalent spring stiffness of the soil; C = damping value of the soil; B = interia factor contributing to the damping factor; D = damping ratio of the soil; r = equivalent radius of a circular foundation; L = length of foundation, and B = width of the foundation.
Sketch
nu := .25
Table : Values of soil springs as per Richart and Lysmer (1970) model
SI No.
Direction
Spring value
Equivalent radius
Remarks
Vertical
K__z = 4*G*r__z/(1-nu)"(->)"
r__z = sqrt(L*B/Pi)"(->)"
This is in vertical Z direction
Horizontal
K__x = (32*(1-nu))*G*r__x/(7-8*nu)
r__x = sqrt(L*B/Pi)"(->)"
This induce sliding in horizontal X
2.1
Horizontal
K__y = (32*(1-nu))*G*r__y/(7-8*nu)
r__y = sqrt(L*B/Pi)"(->)"
This induce sliding in horizontal Y
Rocking
`K__&phi;x` = 8*G*`r__&phi;x`^3/(3*(1-nu))"(->)"
`r__&phi;x` = (L*B^3/(3*Pi))^(1/4)"(->)"
This produces roxking about Y axis
3.1
Rocking
`K__&phi;y` = 8*G*`r__&phi;y`^3/(3*(1-nu))"(->)"
`r__&phi;y` = (L^3*B/(3*Pi))^(1/4)"(->)"
This produces roxking about X axis
4
Twisting
`K__&psi;` = 16*G*`r__&psi;`^3*(1/3)"(->)"
`r__&psi;` = ((B^3*L+B*L^3)/(6*Pi))^(1/4)
This produces twisting about vertical Z axis
Table : Values of soil damping as per Richart and Lysmer (1970) model
SI No.
Direction
Mass ratio (B)
Damping ratio and Damping values
Remarks
Vertical
B__z = .25*m__U*(1-nu)*g__SI/(`&rho;__s`*r__z^3)
`&zeta;__z` = .425/sqrt(B__z)"(->)"C__z = 2*`&zeta;__z`*sqrt(K__z*m__U)"(->)"
This damping value is in vertical Z direction
Horizontal
B__x = (7-8*nu)*m__U*g__SI/((32*(1-nu))*`&rho;__s`*r__x^3)
`&zeta;__x` = .288/sqrt(B__x)"(->)"
C__x = 2*`&zeta;__x`*sqrt(K__x*m__U)"(->)"
This damping value is in lateral X direction
2.1
Horizontal
B__y = (7-8*nu)*m__U*g__SI/((32*(1-nu))*`&rho;__s`*r__y^3)
`&zeta;__y` = .288/sqrt(B__y)"(->)"
`&zeta;__y` = .288/((2.145204688-2.451662500*nu)*m__U*Units:-Unit(('m')/('s')^2)/((1-nu)*`&rho;__s`*(L*B/Pi)^(3/2)))^(1/2)
(5.1)
NULLError, invalid left hand side in assignmentError, invalid left hand side in assignment
`&zeta;__&psi;` = .5/(1+117.6798000*`J__&psi;`*Units:-Unit(('m')/('s')^2)*6^(1/4)/(`&rho;__s`*((B^3*L+B*L^3)/Pi)^(5/4)))
(5.2)
C__y = 2*`&zeta;__y`*sqrt(K__y*m__U)"(->)"
This damping value is in lateral Y direction
Rocking
`B__&phi;x` = (.375*(1-nu))*`J__&phi;x`*g__SI/(`&rho;__s`*`r__&phi;x`^5)
`&zeta;__&phi;x` = .15/((1+`B__&phi;x`)*sqrt(`B__&phi;x`))
`&zeta;__&phi;x` = .15/((1+11.03248125*(1-nu)*`J__&phi;x`*Units:-Unit(('m')/('s')^2)*3^(1/4)/(`&rho;__s`*(L*B^3/Pi)^(5/4)))*((11.03248125-11.03248125*nu)*`J__&phi;x`*Units:-Unit(('m')/('s')^2)*3^(1/4)/(`&rho;__s`*(L*B^3/Pi)^(5/4)))^(1/2))
(5.3)
Error, invalid left hand side in assignmentError, invalid left hand side in assignmentNULLError, invalid left hand side in assignment
.15/((1+11.03248125*(1-nu)*`J__&phi;x`*Units:-Unit(('m')/('s')^2)*3^(1/4)/(`&rho;__s`*(L*B^3/Pi)^(5/4)))*((11.03248125-11.03248125*nu)*`J__&phi;x`*Units:-Unit(('m')/('s')^2)*3^(1/4)/(`&rho;__s`*(L*B^3/Pi)^(5/4)))^(1/2)) = .15/((1+11.03248125*(1-nu)*`J__&phi;x`*Units:-Unit(('m')/('s')^2)*3^(1/4)/(`&rho;__s`*(L*B^3/Pi)^(5/4)))*((11.03248125-11.03248125*nu)*`J__&phi;x`*Units:-Unit(('m')/('s')^2)*3^(1/4)/(`&rho;__s`*(L*B^3/Pi)^(5/4)))^(1/2))
(5.4)
`C__&phi;x` = 2*`&zeta;__&phi;x`*sqrt(`K__&phi;x`*`J__&phi;x`)"(->)"
This damping value is for rocking about Y direction
3.1
Rocking
`B__&phi;y` = (.375*(1-nu))*`J__&phi;y`*g__SI/(`&rho;__s`*`r__&phi;y`^5)
`&zeta;__&phi;y` = .15/((1+`B__&phi;y`)*sqrt(`B__&phi;y`))
.15/((1+`B__&phi;y`)*`B__&phi;y`^(1/2)) = .15/((1+`B__&phi;y`)*`B__&phi;y`^(1/2))
(5.5)
`C__&phi;y` = 2*`&zeta;__&phi;y`*sqrt(`K__&phi;y`*`J__&phi;y`)"(->)"
This damping value is for rocking about X direction
4
Twisting
`B__&psi;` = `J__&psi;`*g__SI/(`&rho;__s`*`r__&psi;`^5)"(->)"
`&zeta;__&psi;` = .5/(1+2*`B__&psi;`)"(->)"NULLError, invalid left hand side in assignmentError, invalid left hand side in assignmentNULLError, invalid left hand side in assignmentNULLError, invalid left hand side in assignment
.5/(1+117.6798000*`J__&psi;`*Units:-Unit(('m')/('s')^2)*6^(1/4)/(`&rho;__s`*((B^3*L+B*L^3)/Pi)^(5/4))) = .5/(1+117.6798000*`J__&psi;`*Units:-Unit(('m')/('s')^2)*6^(1/4)/(`&rho;__s`*((B^3*L+B*L^3)/Pi)^(5/4)))
(5.6)
`C__&psi;` = 2*`&zeta;__&psi;`*sqrt(`K__&psi;`*`J__&psi;`)"(->)"NULL
This damping value is valid for twisting about vertical Z axis
NULLNULL
Vertical Motion Considering damping of the Soil
For vertical direction the equation becomes that of a lumped mass having single degree of freedom when
deq := m__U*(diff(z(t), t, t))+'C__z'*(diff(z(t), t))+'K__z'*`#mi("z")` = P__0*sin(`&omega;__m`*t)
m__U*(diff(diff(z(t), t), t))+C__z*(diff(z(t), t))+K__z*`#mi("z")` = P__0*sin(`&omega;__m`*t)
(6.1)
t1 := subs(P__0*sin(`&omega;__m`*t)/m__U = F, expand(deq/m__U));
diff(diff(z(t), t), t)+1.085721853*(G*(L*B/Pi)^(1/2)*m__U/(1-nu))^(1/2)*(diff(z(t), t))/(m__U*(m__U*Units:-Unit(('m')/('s')^2)/(`&rho;__s`*(L*B/Pi)^(3/2))-m__U*Units:-Unit(('m')/('s')^2)*nu/(`&rho;__s`*(L*B/Pi)^(3/2)))^(1/2))+4*G*(L*B/Pi)^(1/2)*`#mi("z")`/(m__U*(1-nu)) = F
(6.2)
By algebraically manipulating the expression, the form traditionally used by engineers is derived:
t2 := algsubs('C__z'/m__U = 2*zeta*omega, t1)
diff(diff(z(t), t), t)-(-1.085721853*(-G*(L*B/Pi)^(1/2)*m__U/(nu-1))^(1/2)*(diff(z(t), t))*nu+1.085721853*(-G*(L*B/Pi)^(1/2)*m__U/(nu-1))^(1/2)*(diff(z(t), t))+4.*G*(L*B/Pi)^(1/2)*`#mi("z")`*(-Units:-Unit(('m')/('s')^2)*(nu-1)*m__U/(`&rho;__s`*(L*B/Pi)^(3/2)))^(1/2))/((nu-1.)*(-Units:-Unit(('m')/('s')^2)*(nu-1)*m__U/(`&rho;__s`*(L*B/Pi)^(3/2)))^(1/2)*m__U) = F
(6.4)
t3 := algsubs('K__z'/m__U = omega^2, t2)
(6.5)
This form includes the damping ratio , the natural frequency , and the external forcing term .  Consider only free vibration by setting
gen3 := subs(F = 0, t3)
diff(diff(z(t), t), t)-(-1.085721853*(-G*(L*B/Pi)^(1/2)*m__U/(nu-1))^(1/2)*(diff(z(t), t))*nu+1.085721853*(-G*(L*B/Pi)^(1/2)*m__U/(nu-1))^(1/2)*(diff(z(t), t))+4.*G*(L*B/Pi)^(1/2)*`#mi("z")`*(-Units:-Unit(('m')/('s')^2)*(nu-1)*m__U/(`&rho;__s`*(L*B/Pi)^(3/2)))^(1/2))/((nu-1.)*(-Units:-Unit(('m')/('s')^2)*(nu-1)*m__U/(`&rho;__s`*(L*B/Pi)^(3/2)))^(1/2)*m__U) = 0
(6.6)
sol1 := dsolve({gen3, z(0) = P, (D(z))(0) = V}, z(t))
z(t) = -(1000000000/1178791942081753609)*Pi*m__U*exp(-(1085721853/1000000000)*Units:-Unit(('s')/('m')^(1/2))*t/(Pi*((nu-1)^2/(`&rho;__s`*L^2*B^2*G))^(1/2)*m__U))*(1085721853*V*Units:-Unit(('s')/('m')^(1/2))*((nu-1)^2/(`&rho;__s`*L^2*B^2*G))^(1/2)*`&rho;__s`*L^2*B^2-4000000000*(L*B/Pi)^(1/2)*Pi*nu*`#mi("z")`+4000000000*`#mi("z")`*Pi*(L*B/Pi)^(1/2))/(Units:-Unit(('s')/('m')^(1/2))^2*B^2*L^2*`&rho;__s`)+(4000000000/1085721853)*`#mi("z")`*G*Pi*(L*B/Pi)^(1/2)*((nu-1)^2/(`&rho;__s`*L^2*B^2*G))^(1/2)*t/((nu-1)*Units:-Unit(('s')/('m')^(1/2)))+(1/1178791942081753609)*(1085721853000000000*V*Units:-Unit(('s')/('m')^(1/2))*Pi*((nu-1)^2/(`&rho;__s`*L^2*B^2*G))^(1/2)*m__U*`&rho;__s`*L^2*B^2+1178791942081753609*Units:-Unit(('s')/('m')^(1/2))^2*P*`&rho;__s`*L^2*B^2-4000000000000000000*(L*B/Pi)^(1/2)*Pi^2*m__U*nu*`#mi("z")`+4000000000000000000*`#mi("z")`*Pi^2*(L*B/Pi)^(1/2)*m__U)/(B^2*L^2*`&rho;__s`*Units:-Unit(('s')/('m')^(1/2))^2)
(6.7)
Download Analysis_and_Design_of_Machine_Foundations_1.mw
Good Morning Mapleprime Community,
Would anybody please help in the attached worksheet. I'm trying to use the new function in Maple that is the clicable method, but I was having problem in some of my output such as zeta_y and zeta_phi as this two equations are generating an error message.
Moses
Like there is key shortcut ctrl+T for text mode in Maple, is there any key shortcut for math mode ???
H, how i need to write my command to get n times of the sentences i insert.
For example,
>teksbiasa:= `Hello Bob`;
Hello Bob
So, if i want 5 times of `Hello Bob` like
Hello Bob Hello Bob Hello Bob Hello Bob Hello Bob
What should i write?
Thank you ~=]]
I would like to add threads to this code that compiles cleanly:
RECTmatrixSEQ :=  (FD,m, n, xw, yw, tr, k, rho, dmax) ->
   [seq
     (seq
        # A return of 0 means there is no choice - no digit possible
        # result of a 4 means there is a choice of (-1 or 0)
        (add(RECTpred(m, n, i, j, iter1, k, rho)*(2*abs(iter1)+1), iter1 = -dmax .. dmax)
        + (2*dmax+1)*(RECTpredR(m, n, i, j, dmax, k, rho)+
        RECTpredL(m, n, i, j, -dmax, k, rho))+
        .5*RECTpredOR(m, n, i, j, dmax, k, rho)+
        .5*RECTpredOL(m, n, i, j, -dmax, k, rho),
      i = -ceil(2*dmax+2*rho)*2^m .. ceil(2*dmax+2*rho)*2^m-1),
    j = 0 .. 2^(n-yw)-1)]:
I've added thead calls like this, still no syntax errors:
   CodeTools:-Usage( Threads:-Wait(
   [seq (Threads:-Create
     (seq
        + (2*dmax+1)*(RECTpredR(m, n, i, j, dmax, k, rho) +
    j = 0 .. 2^(n-yw)-1)) ] )
I do get a runtime error:
                 "PROC:feasibilitycheckproONCE
Error, (in CodeTools:-Usage) invalid input: too many and/or wrong type of arguments passed to Threads:-Create; first unused argument is j = 0 .. 3
Any help spotting this problem would be appreciated. Thanks in advance.
Bonnie
Hi, here is the code I used to try to generate all invertible 4x4 matrices over the finite field F_2 = {0.1}. However, when I look at the elements of GROUP (see below) all the elements are 4x4 matrices with a 2 in each entry. I don't know why this is?
Also, I need help converting all of the invertible 4x4 matrices in the following way: I want the 4x4 matrices to each be written as a string of length 16 with no spaces, commas or brackets. So for example the matrix
a b c d
e f g h
i j k l
m n o p
becomes abcdefghijklmnop
PRIME := 2;
# the group of invertible 4 x 4 matrices over the field F_p
GROUP := []:
M := Matrix([[a,b,c,d],[x,f,g,h],[y,j,k,l],[m,n,o,p]]):
for a from 0 to PRIME-1 do
for b from 0 to PRIME-1 do
for c from 0 to PRIME-1 do
for d from 0 to PRIME-1 do
for x from 0 to PRIME-1 do
for f from 0 to PRIME-1 do
for g from 0 to PRIME-1 do
for h from 0 to PRIME-1 do
for y from 0 to PRIME-1 do
for j from 0 to PRIME-1 do
for k from 0 to PRIME-1 do
for l from 0 to PRIME-1 do
for m from 0 to PRIME-1 do
for n from 0 to PRIME-1 do
for o from 0 to PRIME-1 do
for p from 0 to PRIME-1 do
if Determinant(M) mod PRIME <> 0 then
GROUP := [ op(GROUP), M ]
fi
od od od od od od od od od od od od od od od od:
nops(GROUP);
20160
GROUP;
Is it possible to subscript within a plot?
for example I have
this in principle is what I want but, the N is cursive while is O is not (and it's a bit shifted to the right, not right next to the [2] !???
Also I didnt find the meanings of mi(),mn(),mo(),mfenced()... in the help documentation which I stumbled across while googling.
for example in this case:
what do I need them for since without the mi it doesnt work?!
Is it possible to use latex notation within the plot options for more convenience?
BTW: When plotting a .ps or .eps the plotting device takes over all the features (like the examples above) but when using png instead it just prints the code behind it ( for example the `#mover(mi("x"),mi("~"))` ) and not would it should lead to
How long will MAPLE 16 and future versions of MAPLE will support running on Windows 7?
MRB
(I hope to defer transferring to Windows 10 until MS stop supporting for Windows 7.)
I am unable to use subs() command when using subscript : I'd like to replace YP__1 with dGx in the equation :
"Eq:= YP__1 = Y__2" (Eq:= YP1=Y2)
 so I have tried : subs({YP__1=dGx},Eq)
But it doesn't work... It give me : YP__1 = Y__2 and I would like to have dGx = Y__2
I have tried also with subs({YP[1]=dGx},Eq) but doesn't work too.
If I am not using subscript, for exemple : Eq:= YP1 = Y2
And do : subs({YP1=dGx},Eq)
That works great...
But I must use subscript __ because Eq is a result from ODEtools (convertsys).
Can you help me please ?
Thanks you very much.
Regards.
First 1161 1162 1163 1164 1165 1166 1167 Last Page 1163 of 2463
