Is there a way to plot critical values of the Pearson Correlation Coefficient r?  See attached worksheet.  Thanks!
Les    ect4_critical_value_of_r.mw
Maple does not solve the equation:
-144*z-44+12*sqrt(-12*z^3+96*z^2+24*z-15) using the solve command. I am writting exactly
solve(-144*z-44+12*sqrt(-12*z^3+96*z^2+24*z-15=0)) and it does nothing. Do you have any idea for why that happens?
Thank you in advance for your time
I would like to symbolically determine the rank of a jacobian matrix. In the help, I have seen that the Rank function of the LinearAlgebra can be used for this purpose. However, when I use this function, the function doesn't allow to find the different singularities that can occur on my jacobian matrix.
Here a exemple of a jacobian matrix that I obtain on a slidercrank mechanism:
Phi := Matrix(2, 3, {(1, 1) = -l1*sin(theta(t)), (1, 2) = -1, (1, 3) = l2*cos(beta(t)), (2, 1) = l1*cos(theta(t)), (2, 2) = 0, (2, 3) = l2*sin(beta(t))})
The rank of this jaobian (Phi) gives 2 whatever the values of theta(t) and beta(t). However, if the values of  theta(t) and beta(t) are :theta(t)=Pi/2,beta(t)=0. The rank shouldn't be 2 but 1.
Is a way to obtain the symbolic calculation of the rank of a jacobian matrix which can distinguish different cases following the values of the parameters ? In others words, my dream will be to have a Rank function (or another algorithm) which can gives :
the rank is 2 if theta(t) different of Pi/2 [Pi] and beta(t)=0 [Pi]
and otherwise 1 if ...
and perhaps 0 if ...
Thanks a lot for your help.
I let a piece of code with an example of calculation of the rank
RankMatrix.mw
I am trying to solve the folowing ODE with initial conditions t0=0,v0=0 and tf =80 with step 0.01 but the matrix that appears is not having the values!please help
f := proc (t, V) options operator, arrow; -9.81+0.563e-3*(0.1832e-2*abs(V)+0.51702e-1*(abs(V)^(3/2))+.4*V^2) end proc
V0 := 0:
t0 := 0:
tf := 80:
n := 1000
h := evalf((tf-t0)/n):
t := t0:
V := V0:
rk := proc (x0, tf, V0, n) local t, V, h, i, k1, k2, k3, k4, k, R; t := t0; V := V0; R := t, V; h := evalf((tf-t0)/n); for i to n do k1 := f(t, V); k2 := f(t+(1/2)*h, V+(1/2)*h*k1); k3 := f(t+(1/2)*h, V+(1/2)*h*k2); k4 := f(t+h, V+h*k3); k := (1/6)*k1+(1/3)*k2+(1/3)*k3+(1/6)*k4; V := V+h*k; t := t+h; R := R, t, V end do end proc:
R := rk(0, 80, 0, 300):
0, 0
.2666666667, -2.615998110
.5333333334, -5.231986045
.8000000001, -7.847954569
1.066666667, -10.46389463
1.333333334, -13.07979725
1.600000001, -15.69565351
1.866666668, -18.31145452
2.133333335, -20.92719143
2.400000002, -23.54285541
2.666666669, -26.15843764
2.933333336, -28.77392932
3.200000003, -31.38932166
3.466666670, -34.00460588
3.733333337, -36.61977321
4.000000004, -39.23481490
4.266666671, -41.84972219
4.533333338, -44.46448634
4.800000005, -47.07909861
5.066666672, -49.69355027
5.333333339, -52.30783259
5.600000006, -54.92193685
5.866666673, -57.53585433
6.133333340, -60.14957632
6.400000007, -62.76309410
6.666666674, -65.37639897
6.933333341, -67.98948223
7.200000008, -70.60233518
7.466666675, -73.21494912
7.733333342, -75.82731536
8.000000009, -78.43942520
8.266666676, -81.05126996
8.533333343, -83.66284095
8.800000010, -86.27412949
9.066666677, -88.88512689
9.333333344, -91.49582448
9.600000011, -94.10621358
9.866666678, -96.71628551
10.13333334, -99.32603160
10.40000001, -101.9354432
10.66666668, -104.5445116
10.93333335, -107.1532281
11.20000002, -109.7615841
11.46666669, -112.3695709
11.73333336, -114.9771799
12.00000003, -117.5844024
12.26666670, -120.1912297
12.53333337, -122.7976532
12.80000004, -125.4036642
13.06666671, -128.0092541
13.33333338, -130.6144142
13.60000005, -133.2191358
13.86666672, -135.8234103
14.13333339, -138.4272290
14.40000006, -141.0305833
14.66666673, -143.6334645
14.93333340, -146.2358640
15.20000007, -148.8377732
15.46666674, -151.4391834
15.73333341, -154.0400859
16.26666675, -159.2403334
16.53333342, -161.8396611
16.80000009, -164.4384465
17.06666676, -167.0366810
17.33333343, -169.6343560
17.60000010, -172.2314629
17.86666677, -174.8279930
18.13333344, -177.4239376
18.40000011, -180.0192882
18.66666678, -182.6140360
18.93333345, -185.2081725
19.20000012, -187.8016890
19.46666679, -190.3945769
19.73333346, -192.9868275
20.00000013, -195.5784322
20.26666680, -198.1693824
20.53333347, -200.7596694
20.80000014, -203.3492846
21.06666681, -205.9382194
21.33333348, -208.5264652
21.60000015, -211.1140133
21.86666682, -213.7008550
22.13333349, -216.2869818
22.40000016, -218.8723850
22.66666683, -221.4570560
22.93333350, -224.0409862
23.20000017, -226.6241669
23.46666684, -229.2065895
23.73333351, -231.7882454
24.00000018, -234.3691260
24.26666685, -236.9492226
24.53333352, -239.5285266
24.80000019, -242.1070294
25.06666686, -244.6847224
25.33333353, -247.2615969
25.60000020, -249.8376443
25.86666687, -252.4128560
26.13333354, -254.9872234
26.40000021, -257.5607378
26.66666688, -260.1333906
26.93333355, -262.7051732
27.20000022, -265.2760770
27.46666689, -267.8460934
27.73333356, -270.4152137
28.00000023, -272.9834293
28.26666690, -275.5507316
28.53333357, -278.1171120
28.80000024, -280.6825619
29.06666691, -283.2470726
29.33333358, -285.8106356
29.60000025, -288.3732422
29.86666692, -290.9348838
30.13333359, -293.4955517
30.40000026, -296.0552374
30.66666693, -298.6139322
30.93333360, -301.1716276
31.20000027, -303.7283149
31.46666694, -306.2839855
31.73333361, -308.8386307
32.00000028, -311.3922420
32.26666695, -313.9448108
32.53333362, -316.4963284
32.80000029, -319.0467862
33.06666696, -321.5961756
33.33333363, -324.1444880
33.60000030, -326.6917148
33.86666697, -329.2378474
34.13333364, -331.7828772
34.40000031, -334.3267955
34.66666698, -336.8695937
34.93333365, -339.4112633
35.20000032, -341.9517956
35.46666699, -344.4911820
35.73333366, -347.0294139
36.00000033, -349.5664827
36.26666700, -352.1023797
36.53333367, -354.6370964
36.80000034, -357.1706242
37.06666701, -359.7029544
37.33333368, -362.2340784
37.60000035, -364.7639877
37.86666702, -367.2926736
38.13333369, -369.8201275
38.40000036, -372.3463408
38.66666703, -374.8713049
38.93333370, -377.3950112
39.20000037, -379.9174511
39.46666704, -382.4386159
39.73333371, -384.9584971
40.00000038, -387.4770861
40.26666705, -389.9943742
40.53333372, -392.5103529
40.80000039, -395.0250135
41.06666706, -397.5383474
41.33333373, -400.0503461
41.60000040, -402.5610009
41.86666707, -405.0703032
42.13333374, -407.5782444
42.40000041, -410.0848159
42.66666708, -412.5900091
42.93333375, -415.0938154
43.20000042, -417.5962262
43.46666709, -420.0972329
43.73333376, -422.5968269
44.00000043, -425.0949996
44.26666710, -427.5917424
44.53333377, -430.0870466
44.80000044, -432.5809037
45.06666711, -435.0733051
45.33333378, -437.5642421
45.60000045, -440.0537062
45.86666712, -442.5416888
46.13333379, -445.0281812
46.40000046, -447.5131749
46.66666713, -449.9966612
46.93333380, -452.4786316
47.20000047, -454.9590775
47.46666714, -457.4379902
47.73333381, -459.9153612
48.00000048, -462.3911818
48.26666715, -464.8654435
48.53333382, -467.3381376
48.80000049, -469.8092556
49.06666716, -472.2787888
49.33333383, -474.7467287
49.60000050, -477.2130666
49.86666717, -479.6777940
50.13333384, -482.1409022
50.40000051, -484.6023827
50.66666718, -487.0622268
50.93333385, -489.5204260
51.20000052, -491.9769716
51.46666719, -494.4318551
51.73333386, -496.8850678
52.00000053, -499.3366012
52.26666720, -501.7864466
52.53333387, -504.2345955
52.80000054, -506.6810393
53.06666721, -509.1257693
53.33333388, -511.5687770
53.60000055, -514.0100537
53.86666722, -516.4495909
54.13333389, -518.8873800
54.40000056, -521.3234124
54.66666723, -523.7576794
54.93333390, -526.1901725
55.20000057, -528.6208831
55.46666724, -531.0498026
55.73333391, -533.4769224
56.00000058, -535.9022339
56.26666725, -538.3257285
56.53333392, -540.7473976
56.80000059, -543.1672326
57.06666726, -545.5852249
57.33333393, -548.0013659
57.60000060, -550.4156470
57.86666727, -552.8280597
58.13333394, -555.2385953
58.40000061, -557.6472452
58.66666728, -560.0540009
58.93333395, -562.4588537
59.20000062, -564.8617951
59.46666729, -567.2628164
59.73333396, -569.6619091
60.00000063, -572.0590645
60.26666730, -574.4542741
60.53333397, -576.8475293
60.80000064, -579.2388215
61.06666731, -581.6281420
61.33333398, -584.0154823
61.60000065, -586.4008338
61.86666732, -588.7841879
62.13333399, -591.1655361
62.40000066, -593.5448697
62.66666733, -595.9221801
62.93333400, -598.2974587
63.20000067, -600.6706970
63.46666734, -603.0418863
63.73333401, -605.4110181
64.00000068, -607.7780837
64.26666735, -610.1430746
64.53333402, -612.5059822
64.80000069, -614.8667979
65.06666736, -617.2255130
65.33333403, -619.5821190
65.60000070, -621.9366073
65.86666737, -624.2889694
66.13333404, -626.6391966
66.40000071, -628.9872803
66.66666738, -631.3332119
66.93333405, -633.6769829
67.20000072, -636.0185846
67.46666739, -638.3580085
67.73333406, -640.6952460
68.00000073, -643.0302885
68.26666740, -645.3631274
68.53333407, -647.6937540
68.80000074, -650.0221599
69.06666741, -652.3483364
69.33333408, -654.6722749
69.60000075, -656.9939668
69.86666742, -659.3134036
70.13333409, -661.6305766
70.40000076, -663.9454773
70.66666743, -666.2580971
70.93333410, -668.5684273
71.20000077, -670.8764594
71.46666744, -673.1821848
71.73333411, -675.4855950
72.00000078, -677.7866813
72.26666745, -680.0854351
72.53333412, -682.3818479
72.80000079, -684.6759110
73.06666746, -686.9676159
73.33333413, -689.2569539
73.60000080, -691.5439165
73.86666747, -693.8284951
74.13333414, -696.1106811
74.40000081, -698.3904660
74.66666748, -700.6678411
74.93333415, -702.9427978
75.20000082, -705.2153276
75.46666749, -707.4854218
75.73333416, -709.7530719
76.00000083, -712.0182693
76.26666750, -714.2810054
76.53333417, -716.5412716
76.80000084, -718.7990593
77.06666751, -721.0543600
77.33333418, -723.3071650
77.60000085, -725.5574658
77.86666752, -727.8052537
78.13333419, -730.0505202
78.40000086, -732.2932567
78.66666753, -734.5334546
78.93333420, -736.7711053
79.73333421, -743.4686884
Download runge_kutta4.mw
What's the best way to get the eigenvector associated with a certain eigenvalue?
Specifically, given the nature of my matrix A, I know that there ALWAYS exists an eigenvector with eigenvalue 1.  Is there a quick way to extract this without looping through the output of Eigenvectors() and checking each one?
I'm modeling the simple DC motor system in Maple.
The equations describing the system;
eq1:=J*diff(theta(t),t,t)+b*diff(theta(t),t)=K*i(t):
eq2:=L*diff(i(t),t)+R*i(t)=V(t)-K*diff(theta(t),t):
DCMotor:=[eq1,eq2];
First, I create the system using DiffEquation:
Sys:=DiffEquation(DCMotor,[V(t)],[theta(t)]);
And now I have problem. The input var is V(t) (input voltage) and the output var is theta(t) (position of the rotor).
But I wont to have in output var not position of the rotor but speed of the fotor - diff(theta(t),t)
How to set output var for diff(theta(t),t) (the speed of the motor)?
Best
Rariusz
I'd like to create a graded drag and drop exercise so that my students can click on an item and place it into various places (one of which is the correct place). I don't think any of the Question types support this though .. is there a way to build such a quesiton in Maple TA ?
Thank you for your help!
Elisabeth
Dear All
I want to use subs command to replace products in expression with entries from matrix. When I use "subs" command it returns same result as original without any substitution. But when I use "algsubs", it works fine, but is complicated to apply if there are large number of substitutions.
Please see followings:
M := Matrix([[U[1], U[2], -epsilon*U[1]+U[3], U[4], U[5], U[6]], [U[1], U[2], -epsilon*U[2]+U[3], epsilon*U[1]+U[4], epsilon*U[2]+U[5], U[6]], [e^epsilon*U[1], e^epsilon*U[2], U[3], U[4], U[5], U[6]], [U[1], -epsilon*U[1]+U[2], U[3], U[4], -epsilon*U[4]+U[5], U[6]-epsilon*(U[3]+2*U[5])+epsilon^2*U[4], U[1], e^(-epsilon)*U[2], U[3], e^epsilon*U[4], U[5], e^(-epsilon)*U[6]], [U[1], e^(-epsilon)*U[2], U[3], e^epsilon*U[4], U[5], e^(-epsilon)*U[6]], [epsilon*U[2]+U[1], U[2], U[3], U[4]+epsilon*(U[3]+2*U[5])+epsilon^2*U[6], epsilon*U[6]+U[5], U[6]]])
M := Vector(4, {(1) = ` 6 x 12 `*Matrix, (2) = `Data Type: `*anything, (3) = `Storage: `*rectangular, (4) = `Order: `*Fortran_order})
M[5, 1]; 1; M[5, 3]
U[1]
U[3]
expand((w*T[5]+z*T[4]+T[6])*(U[1]*a[1]+U[2]*a[2]+U[3]*a[3]+U[4]*a[4]+U[5]*a[5]+U[6]*a[6]))
w*T[5]*U[1]*a[1]+w*T[5]*U[2]*a[2]+w*T[5]*U[3]*a[3]+w*T[5]*U[4]*a[4]+w*T[5]*U[5]*a[5]+w*T[5]*U[6]*a[6]+z*T[4]*U[1]*a[1]+z*T[4]*U[2]*a[2]+z*T[4]*U[3]*a[3]+z*T[4]*U[4]*a[4]+z*T[4]*U[5]*a[5]+z*T[4]*U[6]*a[6]+T[6]*U[1]*a[1]+T[6]*U[2]*a[2]+T[6]*U[3]*a[3]+T[6]*U[4]*a[4]+T[6]*U[5]*a[5]+T[6]*U[6]*a[6]
subs(T[5]*U[1] = M[5, 1], T[5]*U[2] = M[5, 2], T[5]*U[3] = M[5, 3], w*T[5]*U[1]*a[1]+w*T[5]*U[2]*a[2]+w*T[5]*U[3]*a[3]+w*T[5]*U[4]*a[4]+w*T[5]*U[5]*a[5]+w*T[5]*U[6]*a[6]+z*T[4]*U[1]*a[1]+z*T[4]*U[2]*a[2]+z*T[4]*U[3]*a[3]+z*T[4]*U[4]*a[4]+z*T[4]*U[5]*a[5]+z*T[4]*U[6]*a[6]+T[6]*U[1]*a[1]+T[6]*U[2]*a[2]+T[6]*U[3]*a[3]+T[6]*U[4]*a[4]+T[6]*U[5]*a[5]+T[6]*U[6]*a[6])
Why this command subs in not replacing  products  T[5]*U[1], T[5]*U[2], T[5]*U[3] from matrix (1)NULL?????
algsubs(T[5]*U[1] = M[5, 1], w*T[5]*U[1]*a[1]+w*T[5]*U[2]*a[2]+w*T[5]*U[3]*a[3]+w*T[5]*U[4]*a[4]+w*T[5]*U[5]*a[5]+w*T[5]*U[6]*a[6]+z*T[4]*U[1]*a[1]+z*T[4]*U[2]*a[2]+z*T[4]*U[3]*a[3]+z*T[4]*U[4]*a[4]+z*T[4]*U[5]*a[5]+z*T[4]*U[6]*a[6]+T[6]*U[1]*a[1]+T[6]*U[2]*a[2]+T[6]*U[3]*a[3]+T[6]*U[4]*a[4]+T[6]*U[5]*a[5]+T[6]*U[6]*a[6])
z*T[4]*U[2]*a[2]+z*T[4]*U[3]*a[3]+z*T[4]*U[4]*a[4]+z*T[4]*U[5]*a[5]+z*T[4]*U[6]*a[6]+T[6]*U[2]*a[2]+T[6]*U[3]*a[3]+T[6]*U[4]*a[4]+T[6]*U[5]*a[5]+T[6]*U[6]*a[6]+(w*U[2]*a[2]+w*U[3]*a[3]+w*U[4]*a[4]+w*U[5]*a[5]+w*U[6]*a[6])*T[5]+(z*T[4]*a[1]+w*a[1]+T[6]*a[1])*U[1]
It worked !!!! But If I try "algsubs" like :
algsubs(T[5]*U[1] = M[5, 1], T[5]*U[2] = M[5, 2], T[5]*U[3] = M[5, 3], w*T[5]*U[1]*a[1]+w*T[5]*U[2]*a[2]+w*T[5]*U[3]*a[3]+w*T[5]*U[4]*a[4]+w*T[5]*U[5]*a[5]+w*T[5]*U[6]*a[6]+z*T[4]*U[1]*a[1]+z*T[4]*U[2]*a[2]+z*T[4]*U[3]*a[3]+z*T[4]*U[4]*a[4]+z*T[4]*U[5]*a[5]+z*T[4]*U[6]*a[6]+T[6]*U[1]*a[1]+T[6]*U[2]*a[2]+T[6]*U[3]*a[3]+T[6]*U[4]*a[4]+T[6]*U[5]*a[5]+T[6]*U[6]*a[6])
Error, invalid input: algsubs expects its 3rd argument, x, to be of type {name, function, list({name, function}), set({name, function})}, but received T[5]*U[3] = U[3]
See it is giving error !!! but still I can use "algsubs" as follow:
expand(algsubs(T[6]*U[6] = M[6, 6], expand(algsubs(T[6]*U[5] = M[6, 5], expand(algsubs(T[6]*U[4] = M[6, 4], expand(algsubs(T[6]*U[3] = M[6, 3], expand(algsubs(T[6]*U[2] = M[6, 2], expand(algsubs(T[6]*U[1] = M[6, 1], expand(algsubs(T[5]*U[6] = M[5, 6], expand(algsubs(T[5]*U[5] = M[5, 5], expand(algsubs(T[5]*U[4] = M[5, 4], expand(algsubs(T[5]*U[3] = M[5, 3], expand(algsubs(T[5]*U[2] = M[5, 2], expand(algsubs(T[5]*U[1] = M[5, 1], expand(algsubs(T[4]*U[6] = M[4, 6], expand(algsubs(T[4]*U[5] = M[4, 5], expand(algsubs(T[4]*U[4] = M[4, 4], expand(algsubs(T[4]*U[3] = M[4, 3], expand(algsubs(T[4]*U[2] = M[4, 2], expand(algsubs(T[4]*U[1] = M[4, 1], expand(algsubs(T[3]*U[6] = M[3, 6], expand(algsubs(T[3]*U[5] = M[3, 5], expand(algsubs(T[3]*U[4] = M[3, 4], expand(algsubs(T[3]*U[3] = M[3, 3], expand(algsubs(T[3]*U[2] = M[3, 2], expand(algsubs(T[3]*U[1] = M[3, 1], expand(algsubs(T[2]*U[6] = M[2, 6], expand(algsubs(T[2]*U[5] = M[2, 5], expand(algsubs(T[2]*U[4] = M[2, 4], expand(algsubs(T[2]*U[3] = M[2, 3], expand(algsubs(T[2]*U[3] = M[2, 3], expand(algsubs(T[2]*U[2] = M[2, 2], expand(algsubs(T[2]*U[1] = M[2, 1], expand(algsubs(T[1]*U[6] = M[1, 6], expand(algsubs(T[1]*U[5] = M[1, 5], expand(algsubs(T[1]*U[4] = M[1, 4], expand(algsubs(T[1]*U[3] = M[1, 3], expand(algsubs(T[1]*U[2] = M[1, 2], expand(algsubs(T[1]*U[1] = M[1, 1], w*T[5]*U[1]*a[1]+w*T[5]*U[2]*a[2]+w*T[5]*U[3]*a[3]+w*T[5]*U[4]*a[4]+w*T[5]*U[5]*a[5]+w*T[5]*U[6]*a[6]+z*T[4]*U[1]*a[1]+z*T[4]*U[2]*a[2]+z*T[4]*U[3]*a[3]+z*T[4]*U[4]*a[4]+z*T[4]*U[5]*a[5]+z*T[4]*U[6]*a[6]+T[6]*U[1]*a[1]+T[6]*U[2]*a[2]+T[6]*U[3]*a[3]+T[6]*U[4]*a[4]+T[6]*U[5]*a[5]+T[6]*U[6]*a[6]))))))))))))))))))))))))))))))))))))))))))))))))))))))))))))))))))))))))))
a[5]*epsilon*U[6]+a[1]*epsilon*U[2]+U[6]*a[6]+U[2]*a[2]+U[3]*a[3]+U[4]*a[4]+U[5]*a[5]+z*a[1]*U[1]+epsilon^2*U[6]*a[4]+epsilon*U[3]*a[4]+2*epsilon*U[5]*a[4]+U[6]*w*a[6]/e^epsilon+U[4]*e^epsilon*w*a[4]+w*a[1]*U[1]+U[2]*w*a[2]/e^epsilon+epsilon^2*z*U[4]*a[6]-epsilon*z*U[3]*a[6]-2*epsilon*z*U[5]*a[6]+w*U[3]*a[3]+w*U[5]*a[5]-z*a[5]*epsilon*U[4]-z*a[2]*epsilon*U[1]+z*U[2]*a[2]+z*U[3]*a[3]+z*U[4]*a[4]+z*U[5]*a[5]+z*U[6]*a[6]+a[1]*U[1]
But this procedure is complex, I want to use "subs" only. I know it complexity of terms in (3) might me creating problem.
collect(a[5]*epsilon*U[6]+a[1]*epsilon*U[2]+U[6]*a[6]+U[2]*a[2]+U[3]*a[3]+U[4]*a[4]+U[5]*a[5]+z*a[1]*U[1]+epsilon^2*U[6]*a[4]+epsilon*U[3]*a[4]+2*epsilon*U[5]*a[4]+U[6]*w*a[6]/e^epsilon+U[4]*e^epsilon*w*a[4]+w*a[1]*U[1]+U[2]*w*a[2]/e^epsilon+epsilon^2*z*U[4]*a[6]-epsilon*z*U[3]*a[6]-2*epsilon*z*U[5]*a[6]+w*U[3]*a[3]+w*U[5]*a[5]-z*a[5]*epsilon*U[4]-z*a[2]*epsilon*U[1]+z*U[2]*a[2]+z*U[3]*a[3]+z*U[4]*a[4]+z*U[5]*a[5]+z*U[6]*a[6]+a[1]*U[1], [U[1], U[2], U[3], U[4], U[5], U[6]])
(-epsilon*z*a[2]+w*a[1]+z*a[1]+a[1])*U[1]+(a[1]*epsilon+a[2]+w*a[2]/e^epsilon+z*a[2])*U[2]+(-epsilon*z*a[6]+epsilon*a[4]+w*a[3]+z*a[3]+a[3])*U[3]+(epsilon^2*z*a[6]+e^epsilon*w*a[4]-z*a[5]*epsilon+z*a[4]+a[4])*U[4]+(-2*epsilon*z*a[6]+2*epsilon*a[4]+w*a[5]+z*a[5]+a[5])*U[5]+(a[5]*epsilon+a[6]+epsilon^2*a[4]+w*a[6]/e^epsilon+z*a[6])*U[6]
Download Subs_not_giving_result.mwSubs_not_giving_result.mw
plot3d(x^2+y^2, x = -1 .. 1, y = -1 .. 1);
i searched this
http://www.maplesoft.com/support/helpJP/Maple/view.aspx?path=NAG/d06abc
DelaunayTriangulation(points) in help file
is there any example to show how to use these?
Hi all.
1. When plotting the function y=(x-1)/(x-2) on Maple 2016, the asymptote along with the actual curve is drawn as "solid lines/curves".  The asymptote should have been drawn as a dotted line to indicate that x=2 is an asymptote so as to distinguish itself from the actual curve.   This confuses my students.
2. The other question is if I modify the equation to y=1+ (x-1)/(x-2), the plot only shows the asymptote at x=2 (again, a solid line).  There should be another asymptote at y=1, which is not shown.
Can someone please advise if Maple would fix this in the next update?    If not, how should one "fix" this when graphing such functions?
Many thanks.
Hello, I have the system of equations in many vars as below, I want to make an implicit plot in Maple with the projection on 3 vars, for example, in this case (x,y,t1). The range is x[-10,10], y[-10,10], t1[-Pi,Pi] and the rest of the vars are [-Pi,Pi]. Does anyone know how to do it? We have also the inequalities in the system.
f1:= cos(t1)+1.35*cos(p1)-x;
f2:= sin(t1)+1.35*sin(p1)-y;
f3:= cos(t2)+1.35*cos(p2)-x +1.15;
f4:= sin(t2)+1.35*sin(p2)-y;
f5:= cos(t3)+1.35*cos(p3)-x+0.575;
f6:= sin(t3)+1.35*sin(p3)-y +0.995;
f7:= cos(t1)*cos(t2)*cos(t3)*sin(p1)*sin(p2)*sin(p3)-cos(t1)*cos(t2)*sin(t3)*sin(p1)*sin(p2)*cos(p3)-cos(t1)*sin(t2)*cos(t3)*sin(p1)*cos(p2)*sin(p3)+cos(t1)*sin(t2)*sin(t3)*sin(p1)*cos(p2)*cos(p3)-sin(t1)*cos(t2)*cos(t3)*cos(p1)*sin(p2)*sin(p3)+sin(t1)*cos(t2)*sin(t3)*cos(p1)*sin(p2)*cos(p3)+sin(t1)*sin(t2)*cos(t3)*cos(p1)*cos(p2)*sin(p3)-sin(t1)*sin(t2)*sin(t3)*cos(p1)*cos(p2)*cos(p3);
f8:= cos(t1)*sin(p1)-sin(t1)*cos(p1) >= 0;
f9:= cos(t2)*sin(p2)-sin(t2)*cos(p2) >= 0;
f10:= cos(t3)*sin(p3)-sin(t3)*cos(p3) >= 0;
Consider you have an expression like:
f := (125*x^3+525*x^2*y+735*x*y^2+343*y^3-36*z^2)/(-216*z^3+25*x^2+70*x*y+49*y^2)
By hand and spending much time maybe we can find out so far that:
f := ((5*x+7*y)^3-(6*z)^2)/((5*x+7*y)^2-(6*z)^3)
I thought that the code `combine(f)` would give us the second one, but it didn’t. Is there anything obvious I cannot see?
Thanks for the time.
I am fairly new to Maple and cannot figure this out.
I'm having some trouble in computing formally the derivatives of
some composite functions
h:= x -> f(g(x)),
imposing conditions on the unknown functions f and g.
For example, I cannot find a way to impose g'(0)=0,
such that the computation of
h'(0)
simply gives 0.
Thank you in advance!
with(StringTools):
FormatTime("%m-%d-%Y, %H:%M")
Pile spacing of each pile from a refrence pile:
S__p := Matrix(9, 9, {(1, 1) = 0., (1, 2) = 3.30, (1, 3) = 6.60, (1, 4) = 3.30, (1, 5) = 4.67, (1, 6) = 7.38, (1, 7) = 6.60, (1, 8) = 7.38, (1, 9) = 9.33, (2, 1) = 3.30, (2, 2) = 0., (2, 3) = 3.30, (2, 4) = 4.67, (2, 5) = 3.30, (2, 6) = 4.67, (2, 7) = 7.38, (2, 8) = 6.60, (2, 9) = 7.38, (3, 1) = 6.60, (3, 2) = 3.30, (3, 3) = 0., (3, 4) = 7.38, (3, 5) = 4.67, (3, 6) = 3.30, (3, 7) = 9.33, (3, 8) = 7.38, (3, 9) = 6.60, (4, 1) = 3.30, (4, 2) = 4.67, (4, 3) = 7.38, (4, 4) = 0., (4, 5) = 3.30, (4, 6) = 6.60, (4, 7) = 3.30, (4, 8) = 4.67, (4, 9) = 7.38, (5, 1) = 4.67, (5, 2) = 3.30, (5, 3) = 4.67, (5, 4) = 3.30, (5, 5) = 0., (5, 6) = 3.30, (5, 7) = 4.67, (5, 8) = 3.30, (5, 9) = 4.67, (6, 1) = 7.38, (6, 2) = 4.67, (6, 3) = 3.30, (6, 4) = 6.60, (6, 5) = 3.30, (6, 6) = 0., (6, 7) = 7.38, (6, 8) = 4.67, (6, 9) = 3.30, (7, 1) = 6.60, (7, 2) = 7.38, (7, 3) = 9.33, (7, 4) = 3.30, (7, 5) = 4.67, (7, 6) = 7.38, (7, 7) = 0., (7, 8) = 3.30, (7, 9) = 6.60, (8, 1) = 7.38, (8, 2) = 6.60, (8, 3) = 7.38, (8, 4) = 4.67, (8, 5) = 3.30, (8, 6) = 4.67, (8, 7) = 3.30, (8, 8) = 0., (8, 9) = 3.30, (9, 1) = 9.33, (9, 2) = 7.38, (9, 3) = 6.60, (9, 4) = 7.38, (9, 5) = 4.67, (9, 6) = 3.30, (9, 7) = 6.60, (9, 8) = 3.30, (9, 9) = 0.})
Angle of each pile from a reference pile in radian:
xi := Matrix(9, 9, {(1, 1) = 0., (1, 2) = 0., (1, 3) = 0., (1, 4) = 1.57, (1, 5) = .785, (1, 6) = .464, (1, 7) = 1.57, (1, 8) = 1.11, (1, 9) = .785, (2, 1) = 3.14, (2, 2) = 0., (2, 3) = 0., (2, 4) = 2.36, (2, 5) = 1.57, (2, 6) = .785, (2, 7) = 2.03, (2, 8) = 1.57, (2, 9) = 1.11, (3, 1) = 3.14, (3, 2) = 3.14, (3, 3) = 0., (3, 4) = 2.68, (3, 5) = 2.36, (3, 6) = 1.57, (3, 7) = 2.36, (3, 8) = 2.03, (3, 9) = 1.57, (4, 1) = 1.57, (4, 2) = .785, (4, 3) = .464, (4, 4) = 0., (4, 5) = 0., (4, 6) = 0., (4, 7) = 1.57, (4, 8) = .785, (4, 9) = .464, (5, 1) = 2.36, (5, 2) = 1.57, (5, 3) = .785, (5, 4) = 3.14, (5, 5) = 0., (5, 6) = 0., (5, 7) = 2.36, (5, 8) = 1.57, (5, 9) = .785, (6, 1) = 2.68, (6, 2) = 2.36, (6, 3) = 1.57, (6, 4) = 3.14, (6, 5) = 3.14, (6, 6) = 0., (6, 7) = 2.68, (6, 8) = 2.36, (6, 9) = 1.57, (7, 1) = 1.57, (7, 2) = 1.11, (7, 3) = .785, (7, 4) = 1.57, (7, 5) = .785, (7, 6) = .464, (7, 7) = 0., (7, 8) = 0., (7, 9) = 0., (8, 1) = 2.03, (8, 2) = 1.57, (8, 3) = 1.11, (8, 4) = 2.36, (8, 5) = 1.57, (8, 6) = .785, (8, 7) = 3.14, (8, 8) = 0., (8, 9) = 0., (9, 1) = 2.36, (9, 2) = 2.03, (9, 3) = 1.57, (9, 4) = 2.68, (9, 5) = 2.36, (9, 6) = 1.57, (9, 7) = 3.14, (9, 8) = 3.14, (9, 9) = 0.})
Angle of each pile from a reference pile in degrees:
theta := Matrix(9, 9, {(1, 1) = 0., (1, 2) = 0., (1, 3) = 0., (1, 4) = 90.0, (1, 5) = 44.8, (1, 6) = 26.6, (1, 7) = 90.0, (1, 8) = 63.6, (1, 9) = 44.8, (2, 1) = 180., (2, 2) = 0., (2, 3) = 0., (2, 4) = 135., (2, 5) = 90.0, (2, 6) = 44.8, (2, 7) = 116., (2, 8) = 90.0, (2, 9) = 63.6, (3, 1) = 180., (3, 2) = 180., (3, 3) = 0., (3, 4) = 153., (3, 5) = 135., (3, 6) = 90.0, (3, 7) = 135., (3, 8) = 116., (3, 9) = 90.0, (4, 1) = 90.0, (4, 2) = 44.8, (4, 3) = 26.6, (4, 4) = 0., (4, 5) = 0., (4, 6) = 0., (4, 7) = 90.0, (4, 8) = 44.8, (4, 9) = 26.6, (5, 1) = 135., (5, 2) = 90.0, (5, 3) = 44.8, (5, 4) = 180., (5, 5) = 0., (5, 6) = 0., (5, 7) = 135., (5, 8) = 90.0, (5, 9) = 44.8, (6, 1) = 153., (6, 2) = 135., (6, 3) = 90.0, (6, 4) = 180., (6, 5) = 180., (6, 6) = 0., (6, 7) = 153., (6, 8) = 135., (6, 9) = 90.0, (7, 1) = 90.0, (7, 2) = 63.6, (7, 3) = 44.8, (7, 4) = 90.0, (7, 5) = 44.8, (7, 6) = 26.6, (7, 7) = 0., (7, 8) = 0., (7, 9) = 0., (8, 1) = 116., (8, 2) = 90.0, (8, 3) = 63.6, (8, 4) = 135., (8, 5) = 90.0, (8, 6) = 44.8, (8, 7) = 180., (8, 8) = 0., (8, 9) = 0., (9, 1) = 135., (9, 2) = 116., (9, 3) = 90.0, (9, 4) = 153., (9, 5) = 135., (9, 6) = 90.0, (9, 7) = 180., (9, 8) = 180., (9, 9) = 0.})
The total number of piles in a pile group:
n__pile := 9
The length of each pile in the pile group in (meters):
L__p := 12.182
Diameter of pile (meter):
`φ__pile` := .457
The radius of each pile (meter):
r__0 := evalf((1/2)*`φ__pile`, 2)
`ρ__A` := 1.0
D__s := 0.5e-1
Omega := 46``
`ν__soil` := .5
E__p := 3.2*10^10``
G__s := 5.7*10^7``
V__s := 182.88
V__La := 395.845``
`&alpha;__&nu;` := proc (S__p, xi, n__pile) local `&alpha;__tmp`, flist, i, j, `&alpha;__1`, `&alpha;__2`, `&alpha;__3`; global D__s, V__La, V__s, Omega; description "Calculate the horizontal interaction factor from a refernce pile in a pile group"; flist := []; for i to `n__pile ` do for j to n__pile do `&alpha;__1`[i, j] := evalf[4](.5*(S__p[i, j]/`&phi;__pile`)^.5*exp(-D__s*Omega*S__p[i, j]/V__La)*exp(-I*Omega*S__p[i, j]/V__La)); `&alpha;__2`[i, j] := evalf[4]((3/4)*(S__p[i, j]/`&phi;__pile`)^.5*exp(-D__s*Omega*S__p[i, j]/V__s)*exp(-I*Omega*S__p[i, j]/V__s)/sqrt(2)); `&alpha;__3`[i, j] := evalf[4](`&alpha;__1`[i, j]*cos(xi[i, j])^2+`&alpha;__2`[i, j]*sin(xi[i, j])^2); if i = j then `&alpha;__tmp`[i, i] := 1.0 elif xi[i, j] = 0. then `&alpha;__tmp`[i, j] := `&alpha;__1`[i, j] elif xi[i, j] = 1.57 then `&alpha;__tmp`[i, j] := `&alpha;__2`[i, j] elif xi[i, j] <> 1.57 and xi[i, j] <> 0. then `&alpha;__tmp`[i, j] := `&alpha;__3`[i, j] end if; flist := [op(flist), `&alpha;__tmp`[i, j]] end do end do end proc:
NULLNULL
NULLNULLNULL
`&alpha;__v` := eval(Matrix(n__pile, n__pile, `&alpha;__&nu;`(S__p, xi, n__pile)))``
Download Test_pile.mw
Good Evening Maple Community,
Can anybody please help in the attached file. Highlighted in yellow are the three equations I'm trying to program in Maple procedure, but could not get any output due to an error message. Please Help.
Boyer
Is this what is supposed to happen when linking Maple to Matlab?  I was hoping it would open the actual Matlab program and write variables to the current worksheet.  I'm I missing something?
Nothing even pops up on the Matlab Command window. What good is this?
First 1179 1180 1181 1182 1183 1184 1185 Last Page 1181 of 2463
