I want to define a proc in Maple which gets an integer n and gives a set of arrays like {1,2,3}^n, meaning {[a[1],...,a[n]]|for all 1<=i<=n a[i] in {1,2,3}}. For a fix n, obviously one can use n-for, for example when n is 2
A:=Array(1..3,1..3):
for a[1] from 1 by 1 to 3 do
 for a[2] from 1 by 1 to 3 do
  A(a[1],a[2]):=[a[1],a[2]];
 end for:
end for:
But when n is not fixed, how can I tell Maple to consider n for?! Also how can ask him to make a n-dimensional array?
I have 3 equations
eq1 := vs = (Rs+Z)*i1+Z*i3
eq2 := A*vi = Z*i1+(Z+Rf+ro)*i3
eq3:= vo = (Rf+Z)*i3+Z*i1
and I want to solve for vo/vs . How to do that ?
the expected solution is
Hi;
Could anyone help me to compute the lie derivative of the function h:R^3-->R with respect to the vector-valued function f:R^5-->R^3 below?
f(x,y,L,u,v) = [x + u;
y + v;
L]
h(x,y,L) = sqrt((y-x)^2 + (L)^2)
Thank you in advance.
I have have s simple graph, see figure below. I want to export it to e.g. PDF-format.
But I want landscape, not portrait. How can I export PDF to landscape?
I tried a workaround: Export it as to JPG gives very bad quality.
I simply want to export my figures to landscape with good quality.
How can I solve this?
Here is my command
> teksbiasa:=`Kriptografi`;
teksbiasa:=Kriptografi
>len:=length(teksbiasa);
len:=11
>nilaiASCII:=convert(teksbiasa, bytes);
nilaiASCII:=[75,114,105,112,116,111,103,114,97,102,105]
>L:=[seq(i,i=nilaiASCII)]
L:=[75,114,105,112,116,111,103,114,97,102,105]
Anyone know how i need to write the command to add the lenght of the text (len) into each of the number in nilaiASCII?
What is want to get is:
[86,125,116,123,127,122,114,125,108,113,116]
Thank you~=]]
For bonus in my one class, we are required to change the code in a program to have it produce another row when running Neville's Method. We need to, after it runs initially, have it ask "Run another time? Y/N" and type 'Y' or 'N' for Yes or No. If No, it ends the program. If yes, we need to have it input another x(i) and f(x(i)) without having to input all the other data points again. Here is what I have so far (this is just the additional part we have to add, not the whole code):
 print(`Do you want another point? Type Y or N.`):
  J := scanf(` %c`)[1]:print(`Entry = `):print(J):
  if J = "Y" or J="y" then
  AGAIN := "Y":
  AGAIN = "Y" or AGAIN = "y":
        OUP := default:
      fprintf(OUP, `NEVILLE'S METHOD\n `):
       fprintf(OUP, `Table for P evaluated at X = %12.8f , follows: \n`, X):
       fprintf(OUP, `Entries are XX(I), Q(I,0), ..., Q(I,I) `):
       fprintf(OUP, `for each I = 0, ..., N where N = %3d\n\n`, N):
       for I1 from 0 to N+1 do
         fprintf(OUP, `%11.8f `, XX[I1]):
         for J from 0 to I1 do
           fprintf(OUP, `%11.8f `, Q[I1,J]):
         fprintf(OUP, `\n`):
    if J="Y" or J="y" then
         AGAIN := Y:
             if AGAIN = Y or AGAIN = y then
                 #N=N+1:
                  if N > 0 then
                  OK := TRUE:
                 for I1 from N to N+1 do
                        print(`Input X(i) and F(X(i)) for i = `):print(I1):
                        print(`separated by a space `):
                       XX[I1] := scanf(`%f`)[1]:
                       Q[I1,0] := scanf(`%f`)[1]:print(`Entries are`):print(XX[I1],Q[I1,0]):
                  print(`Number must be a positive integer `):
               fi:
                AGAIN := No:
         fi:
         fi:
        print(`Ok thanks`):
 fi:
Not sure what I am doing wrong and any help is appreciated. Thanks.
One new feature of Maple 2016 is claimed to be
          FunctionAdvisor(plot, .......)
but when I try HeunD or HeunG there is no output -- no error message, nothing.  Is this behaviour what a user should expect of this command?
I would like to scale the last KernelDensityPlot in the attached worksheet to overlay with the Histogram above it.  The result would look like the 3rd plot in the worksheet, except the y-axis ranges would match.
MonteCarloHistogram.mw
montecarloHistogramExample.txt
Georgios
I'm trying to solve a recurrence relation by generating terms and looking for a pattern.  I've learned that i can't stop
Maple's autosimplification process and the best I can do is use Parse from the InertForm package.  The hand drawn picture below is what I'm trying to replicate.  I know I can use rsolve but I'm trying to do the steps I would with pencil and paper.
I want to set the determinant of the coefficient matrix equal to zero and then solving for the roots. But I could not achieve it via Maple. Can you help me please?
You can reach two examples in the following file.  Yeni_Microsoft_Word_Belgesi_(2).docx
Besides. how can i compute the following transcental equations via maple
sinh(beta*L)*sin(beta*L)=0
cosh(beta*L)*cos(beta*L)-1=0
cosh(beta*L)*cos(beta*L)+1=0
regards
mehmet
Here is my command..
> mylist:=[4,6,2]: for x from 1 to nops (mylist) do convert (mylist[x], binary) end do;
> z:=map(convert, mylist, binary);
[100, 110, 10]
> map2(nprintf,"%08d",z);
[00000100, 00000110, 00000010]
how I need to continue the command to get the number of 1s in each of the binary number?
Thank you~=]]
`00000100`, `00000110`, `00000010`
Sorry for disturbing you again. I am haunted by a problem about Taylor expansion in Maple.
For example, when the angle alpha is small, thus we could use taylor(sin(x),x=0,1) to get a approximated function of sin(x) with different order of precision.
But, if the sin(x) meets diff(x(t),t), (x is a time-dependant variable), could we also apply the Tayolr expansion in Maple to obtain a approximation?
For example, the function: sin(x(t))*diff(x(t),t), x(t) is given with a small value, but diff(x(t),t) could not be neglected, because even x(t) is with a small value , diff(x(t),t) could be great. We could conduct the Talyor expansion with hands, and sin(x(t))*diff(x(t),t) becomes x(t)*diff(x(t),t). But I wonder if we could use Maple to realize this procedure. And if the Maple could make it, I would like to know if the Maple could handle the multi-variable Taylor expansion accompanied with the time derivative. For example, the x(t) and y(t) are considered as small value variables, could we simplified the following function sin(x(t))*cos(y(t))*diff(x(t),t)*diff(y(t),t).
Thank you very much in advance for taking a look.
Hi. Is there a maple function which can interpolate values from a simple table:
given (x,y) compute z value
eg z(0.5,0.5)=1.5
x:=[0,1,2];y:=[0,1,2]
array:=[0,2,4;1,3,5;2,4,6] #probably the wrong input, but you get the idea
ArrayInterpolation?
there is a method in vba:
http://www.tushar-mehta.com/excel/newsgroups/interpolation/#Two_dimensional_interpolation_
I noticed exactly the same expression in Help file of Maple2015.2 and Online Help (http://www.maplesoft.com/support/help/Maple/view.aspx?path=DifferentialGeometry/DGsetup).
Currently Online Help of DGsetup has been reverted to 'normal expression' and we cannot see the expression anymore by Online Help.  Help of Maple2015.2 is still kept unchanged or possibly awaiting update, though such expression has never appeared with Maple2015.2 runs.
Maple18 had a minor update of 18.02. Maple18.02 in hand does not produce such expression. Had you tried it by Maple18?    I am rather interested in the intension of developer to modify the original familiar expression.
Best regards, Stev Eland
Is there a way to apply op to an expression and get back every possible operand and the corresponding list value?  I sometimes don't know how far to go with a list of inputs to get what I want.
First 1180 1181 1182 1183 1184 1185 1186 Last Page 1182 of 2463
