I have two big equations in terms of 'a & w'.
While solving two equations, it shows "The solution may be lost".
!!!!!!!!!!!!!!!!!! (This is my problem file)
Kiran_Mukund_(solve).mw
Please suggest me a solution.
Thanking You
KIRAN MUKUND
I have three separate matrices with 3 function values, and i want to plot them all together. I tried using listplot3d, but it seems to be impossible. How do i do it?
I'm new to Maple, and I come from using Matlab.  Apparently my Matlab way of thinking isn't working on Maple.  I'm trying  to ride a bit of code that simulates flipping a coin 1000 times.  The code counts one partiuclar result (1=heads) at the end prints that result.
Here's the code:
dice:=proc()
count:=0:
for i from 1 to 10000 do
roll := rand(1..2):
roll:=()
if (roll=1) then count:=count+1 end if
end do
print(count)
 I get errors saying I didn't terminate my loops correctly.  Help, please.
Hi everyone. This problem is driving me nuts. I'm pretty sure it's a glitch but I'm not sure how to solve it. I'm trying to do some data analysis with Maple:
(as a side note, even if I remove the for loop but don't execute the restart command the error remains, however if I get rid of the for loop and execute the restart command it is fine.)
Any help would be greatly appreciated. As it stands this is really driving me insane.
How can I quickly  convert a maple file ful of equations into MathML in Word, nt losing the upper and lower index structure - basically to be able to count each letter in MS Word 2013?
When I tried via Latex or MathML, I have lost the letter structure and got the conversion as an image.
Euler := proc (f::procedure, a, b, alpha, n::integer)
local w, h, i, xN, yN;
w := array(1 .. 2, 1 .. n+1);
h := (b-a)/n;
i := 1;
xN := a;
yN := alpha;
while i <= n+1 do
w[1, i] = xN;
w[2, i] = yN;
print*w[1, i]
yN = yN+h*f(yN, xN);
xN = xN+h;
i = i+1
print*w
end proc
Hello.
I want to to evalute a picewice variable for a vector of values (like t=<0,0.1,0.2,0.3,...,10>) through a button action's code, but i do not know how can i do that. I have attached a picture of my problem. Could you please help me to solve it?
I am new to Maple. I am working on PDE and I wanted to try an easy example to know how to work with Maple. So, I startted with the example from the HELP, but still get error as shown below. Can someone guides me.
How can I make tick marks on the 2-D plot more visible. Attached is a figure created using my maple 2015 student edition
Eight matrices inside the list J:
J := [Matrix([[1, 0], [0, 1]]), Matrix([[0, -I], [-I, 0]]), Matrix([[0, -1], [1, 0]]), Matrix([[-I, 0], [0, I]]), Matrix([[-1, 0], [0, -1]]), Matrix([[0, I], [I, 0]]), Matrix([[0, 1], [-1, 0]]), Matrix([[I, 0], [0, -I]])];
Function member identifies J[2] as a member of J and returns its position in j:
member(J[2], J, 'j'); j;
Matrix multiplication inside a loop does not have a matrix type:
for i to 1 do for j to 2 do a := J[i].J[j]; member(a, J, 'k'); print(i, j, k, a, whattype(a)) end do end do;
Has anyone any ideia of what is going on?
Hi every one, I'm trying to plot the function f which is functions in terms of Bessel functions:Here is the code plz any advise i'll be grateful.
assume(d,real):assume(t,real):omega:=10^6:Digits:=15:assume(n,real):Delta:=0:
N:=1:N1:=1+2*N;M:=sqrt(N*(N+1));alpha:=M/(2*omega):z(0):=-1:
(1/2)
I1:=simplify(Sum(BesselJ(n,-I*alpha)*(1/(N1+I*2*omega*n))*(exp((N1+I*2*omega*n)*t)-1),n=-10..10)):
sz:=z(0)*exp(-N1*t)*exp(-alpha*sin(2*omega*t))-exp(-N1*t)*exp(-alpha*sin(2*omega*t))*I1:
I3:=Sum((BesselJ(n,-2*alpha)*(-1)^n+BesselJ(n,-2*I*alpha))*exp(-(N1-I*Delta+2*n*omega)*t),n=-infinity..infinity):
w:=laplace(I3,t,s): w1:=subs(s=I*d,w):
w2:=limit(sz,t=infinity):
Need to plot f
f:=w1*w2:
with(plots):plot(Re(f),d=0..5,tickmarks=[2, 2],thickness=2,linestyle=1,color=black,axes=boxed,titlefont=[SYMBOL,14],font=[1,1,18],tickmarks=[2,3],thickness=2);
So I'm trying to generate a .dat file that has x in the first column, then the output for y1 in the next and y2 in the following, where y1 and y2 are functions of x so the data file would look something like this from x=-5..5 in equal steps of 0.01.
-5          12           8
-4.99     7             5
etc
I'm struggling to get my head around how to do this, i understand i should use the seq function in maple and save it in array of sorts and then use writedata, but im not sure how to piece it together for having 3 columns
thanks in advance for any help!
Executing HelpTools:-Database:-ConvertAll(): produced file DirectSearch.help apparently without content. How can all content within DirectSearch.hdb be converted to a .help file accessible through help in Maple 2016?
Hi, may I know how I should write the commands after I convert my 'Hello' to 34 and 27 by using the commands below..
Hope someone can help me, thanks a lot..=]] Have a nice day~
message:=’Hello’;
>Hello
plaintext:=convert(message,bytes);
>[72, 101, 108, 108, 111]
P:=numtheory[cfrac](plaintext);
>9418838187/130799212
M1:=numer(P);
>9418838187
M2:=denom(P);
>130799212
with(Bits):
bitM1:=Split(M1);
>[1, 1, 0, 1, 0, 1, 0, 1, 0, 0, 0, 0, 1, 0, 0, 0, 0, 0, 0, 1, 0, 1, 1, 0, 1, 0, 0, 0, 1, 1, 0, 0, 0, 1]
bitM2:=Split(M2);
>[0, 0, 1, 1, 0, 1, 1, 0, 0, 1, 1, 0, 1, 0, 1, 1, 1, 1, 0, 1, 0, 0, 1, 1, 1, 1, 1]
with(Statistics):
Count(bitM1);
>34
Count(bitM2);
>27
First 1186 1187 1188 1189 1190 1191 1192 Last Page 1188 of 2463
