I am trying to solve 4 nonlinear equations for four variables using fsolve  and the output that i am getting is basically the same equations repeated after some time.  I even tried reducing one of the equations using assumptions from my side but it results in same behaviour..  Quite new to maple, would like some advice as to this behaviour. Thanks
 Here's the file
fsolve_1.mw
PS- using do loop is part of the solving so i cannot remove that
I am not seeing any reference in help to TRDPolynomial_ring in PolynomialRing function in RegularChains. Though if I debug it, I can get in it. Is it that it is part of kernel ?
Hi all
I need to convert int matrix into matrix over finite field.
E.g: Convert inform integer number
      A := <140, 155, 162, 64;
               218, 12, 245, 50;
                36, 251, 34, 253;
                171, 251, 184, 37>;
 into B = <x^7+x^3+x^2,x^7+x^4+x^3+x+1,x^7+x^5+x, x^6;
             x^7+x^6+x^4+x^3+x, x^3+x^2, x^7+x^6+x^5+x^4+x^2+1, x^5+x^4+x;
            x^5+x^2, x^7+x^6+x^5+x^4+x^3+x+1, x^5+x, x^7+x^6+x^5+x^4+x^3+x^2+1;
            x^7+x^5+x^3+x+1, x^7+x^6+x^5+x^4+x^3+x+1, x^7+x^5+x^4+x^3, x^5+x^2+1>;
(Matrix B over finite field GF(2^8)/f(x) =x^8 + x^6 +x^5 +x^3 +1)
Thanks alot.
I like to plot a function, let's say x^2 in a boxed axis mode; i.e.
plot(x^2,axis=boxed)
Howeve, I want the plot to have tickmarks on all four axises, and not only the normal x and y axis.
Can anyone help me with this please?
plotpoints.mw
I want to plot points when it =1,2,3,..,11,12 instead of a continous line displayed in the worksheet I uploaded. How to modify the function? Thank you for helping:)
How to  compute the recurrence relation and I find the problem when the summation of U because appear noise term self-canceling and I can not find the nth component of U?Mixed_volterra_-Fredholm_(278)_Ex(8.17).mw
"this program is solving Mixed Fredholmvolterra integral equation using modified decomposition method  page 278 Example(8.17) by    Creation date : (9\3\1437)   ------------------------------  u(x)=f(x,t)+(&int;)[0]^(t)(&int;)[0]^(1)F(x,t,r,s)*u(r,s) &DifferentialD;r ds.  -----------------------------"
f := proc (x, t) options operator, arrow; exp(-t)*(cos(x)+t*cos(x)+(1/2)*t*cos(x-1)*sin(1)) end proc:
U[0] := f1(x, t):
for i from 2 to 5 do U1[i-1] := subs({r = x, s = t}, U[i-1]); U[i] := simplify(-(int(int(F(x, t, r, s)*U1[i-1], r = 0 .. 1), s = 0 .. t))) end do:
Download Mixed_volterra_-Fredholm_(278)_Ex(8.17).mwMixed_volterra_-Fredholm_(278)_Ex(8.17).mw
thank you for helping:)
I have an non coupled non linear oscillator.
I notice that, if I try to plot for a time too big, my plot doesn't converge anymore and didn't keep an elliptic trajectory. In other words, the plot didn't stay in the limit cycle.
Do you know why, if tmax is too big, the solution is no longer stable ? Do you have ideas so that I can keep a stable limit cycle even if I increase tmax ?
My code is the following :
r:=sqrt((x(t)/a)^2+(z(t)/b)^2);
eqx:=diff(x(t),t)=alpha*(1-r^2)*x(t)+w*a/b*z(t);
eqz:=diff(z(t),t)=beta*(1-r^2)*z(t)-w*b/a*x(t);
EqSys:=[eqx,eqz];
params := alpha=1, beta=1, a=0.4, b=0.2, w=1;
EqSys := eval([eqx,eqz], [params]);
xmax := 0.8; zmax := 0.4;
tmax := 400;
ic:=[x(0)=0.4, z(0)=0];
DEplot(EqSys, [x(t),z(t)], t= 0..tmax, [ic],linecolor=black, thickness=1,x(t)=-xmax..xmax, z(t)=-zmax..zmax, scaling=constrained,arrows=none);
Thanks a lot for your help.
How to evaluate The Abel integral has the form I can not compute this
> restart;
> f := proc (x) options operator, arrow; (4/3)*x^(3/2) end proc; k := proc (x, t) options operator, arrow; 1/sqrt(x-t) end proc;
> int((4/3)*t^(3/2)/sqrt(x-t), t = 0 .. x);
Thank you :)
> restart;> f := proc (x) options operator, arrow; (4/3)*x^(3/2) end proc; k := proc (x, t) options operator, arrow; 1/sqrt(x-t) end proc;> int((4/3)*t^(3/2)/sqrt(x-t), t = 0 .. x);
I want to plot the curve of a pythagorean quadruple. Any suggestions? I think I have to use space curve. I never liked the options for color on those though. I'm guessing it's just a single curve based on what I know about these things. I have no idea what to expect but I'm sure it will please me no matter what.
X=2*m*p/(m^2+n^2+p^2)
y=2*n*p/(m^2+n^2+p^2)
z=(p^2-(m^2+n^2))/(m^2+n^2+p^2)
using FDM or FEM rather than dsolve?
ode.docxode.docx
Hello everyone! I'm currently trying to plot the effective potential for Sun-Jupiter system, to show the lagrangian points in this system. I've converted to a system of units where G=1, m_sun+m_jupiter=1 and R=1, whereby I get the following equation describing the effective potential of a third mass m in the system:
U(x,y)=-1 * 0.999047/abs(sqrt((x-(-0.000953))^2 +y^2 ))-1 * 0.000953/abs(sqrt((x-0.999047)^2 +y^2 ))
However, when I plot this in Maple, I don't get a contour plot that matches up with what I would [expect](https://upload.wikimedia.org/wikipedia/commons/thumb/e/ee/Lagrange_points2.svg/2000px-Lagrange_points2.svg.png), but [this](http://imgur.com/oZLE3gV). Is there possibly anyone here who could point out a mistake I've done, or give me some advice? Thanks in advance!
Occasionally I have need to import 1D Maple expressions into Mathematica, because I believe mma has superior simplify functionality (sorry Maple). Mathematica has its own syntax which (of course) differs to maple.  eg sin(x) in maple is Sin[x] in mma ; ln(x)=Log[x] ;....... I'm aware of the package MmaTranslator, but I think it only converts mma to maple.
so i need some code pls.
(i have bolded the functions which need to be converted)
eg: i/p:
(1/365)*(365*B21*EP*ln(1+i)*(1+i)^B21*hr*kw*p-365*EP*hr*kw*p*(1+i)^(-1+B21)*i-365*EP*hr*kw*p*(1+i)^(-1+B21)+365*EP*hr*kw*p+SC*i)/(hr*kw*(EP*ln(1+i)*(1+i)^B21*p-FIT*i*p+cos(omega)))
o/p:
(1/365)*(365*B21*EP*Log[1+i]*(1+i)^B21*hr*kw*p-365*EP*hr*kw*p*(1+i)^(-1+B21)*i-365*EP*hr*kw*p*(1+i)^(-1+B21)+365*EP*hr*kw*p+SC*i)/(hr*kw*(EP*Log[1+i]*(1+i)^B21*p-FIT*i*p+Cos[omega]))
I ran into a problem with define that I traced to the 'linear' option in the define statement, and I would like to know whether this is my lack of understanding define, or a bug.
I want to define a function called avg(parm) (which I never will need to use explicitly but  I need to be able to manipulate). This function has the property of being linear, and terms not depending on x can be pulled out. Also, avg(parm)=parm unless parm depends on x. (Yes, it stands for a kind of averaging, but that is not relevant here).
So I programmed it in this way:
define(avg,'linear','conditional'(avg(a::algebraic) = a, _type(a, freeof(x))),\
'conditional'(avg(a::(nonunit(algebraic))*b::(nonunit(algebraic))) = a*avg(b), _type(a, freeof(x))));
For the heck of it I could not get it to work. Basically, none of the equations in the definition were ever used, except that constant numeric factors were pulled out, as they should.
Eventually I found that the 'linear' option was the culprit. Once I got rid of that, the definition of avg did what I wanted it to do (like avg(a*x) => a*avg(x); avg(a) => a). The reason a constant numeric factor was pulled out before is because the 'linear' option does that; it never gets to my definitions (one can see that when printing avg).
Am I missing something fundamental here, or is define not working right?
For the record, I did this in Maple 15 on a PPC Mac. I don't have my Maple 2015 handy to test on that version.
Any insights?
Mac Dude
I'm null in statistic. I'm doing a calculation to calculate a set of parameter. By example:
I have to calculate 5 parameters x1,x2,x3,x4,x5 from 7 equations f1,f2,f3,f4,f5,f6,f7. Because it is difficult to calculate directly 5 parameters, I used chisquare to minimize the difference between experimental and theorical data. Then, I can get the results. After that, I used these 5 parameters to back-calculate the data using 7 equations above. My question is about how to calculate the error bar (or standard error) of the back-calculate datato add to the plot.
Thank you  for helping me,
Best regards.
a := Matrix(2, 2, {(1, 1) = 1, (1, 2) = 2, (2, 1) = 3, (2, 2) = 4})with(LinearAlgebra)
a.a^T = (Matrix(2, 2, {(1, 1) = 1, (1, 2) = 2, (2, 1) = 3, (2, 2) = 4})).(Matrix(2, 2, {(1, 1) = 1, (1, 2) = 2, (2, 1) = 3, (2, 2) = 4}))^TNULL
I am not getting the answer.
I want to get the answer for this product of matrix and its tranport.
I do not want to create transport matrix again for this calculation.
The transporse matrix b is
b := Matrix(2, 2, {(1, 1) = 1, (1, 2) = 3, (2, 1) = 2, (2, 2) = 4}) = Matrix([[1, 3], [2, 4]])
a.a^T is equal to a.b = Matrix([[5, 11], [11, 25]])NULL
For large matrices i cannot do this. Hence this request.Any one please send the code. Thanks.
Download transpose_doubt_1.mwtranspose_doubt_1.mw
Ramakrishnan V
rukmini_ramki@hotmail.com
First 1188 1189 1190 1191 1192 1193 1194 Last Page 1190 of 2434
