Does anyone know how to find the repeated part of a fraction. I know the command cfrac, but I have
heard there should be another command which give the repeated part of a fraction as a result.
Who can help me?
 3/11+3*sqrt(3) = [5, 2, 7, 1, 1, 6, 1, 627, 1, 6, 1, 1, 7, 2, 9, 1, 12, 16, 1, 10, 1, 4, 3, 1, 1, 2, 1, 14, 2, 3, 10, 9, 1, 1, 139, 5, 5, 3, 2, 3, 6, 1, 1, 1, 9, 1, 2, 1, 6, 1, 2, `...`]
Hi guys,
I can not convert a series with label.
If anyone can confirm this?
Maybe-Bug.mw
Another_way_to_calculate_the_definite_integral.mw
ptin the file I upload is a complicated expression containing θ and r. Will the accuracy of the result be affected if I use the second method in the file to calculate the definite integral?
Hi guys,
I can not execute any command in worksheet. I even can't set a variable to a number. When I write some lines and hit enter, it does not respond in anyway. Basicly I can't enter anything it doesn't do anything. How cold I solve this?
Dear Maple users
I know how to fit a function with some parameters to some data, but how can it be done if the data is 2-dimensional? I mean: I have some time array T, some X array and some Y array. How do I fit a function with certain parameters to the data: (x(t),y(t)) to fit (X(T), y(T)), ...
Erik
I've this equation ,what is displacement,
U := sum(C[i]*lambda[i]*h^2*M*(C[13]+C[55])*exp(Z*lambda[i]*M)*cos(M*x)/C[11], i = 1 .. 4);
 But when I used the data ,I do not get the right result
the datas are
h := .25;
M := Pi/L; L := 1;
E[3] := 1; E[1] := 40; E[2] := 1;
V[13] := .25; V[31] := .25; V[12] := .25; V[23] := .25; V[32] := .25; V[21] := .25;
G[44] := .2; G[55] := .2; G[66] := .2;
G[13] := .5;
C[55] := G[13];
Omega := -2*V[13]*V[21]*V[32]-V[12]*V[21]-V[13]*V[31]-V[23]*V[32]+1;
C[11] := (-V[23]*V[32]+1)*E[1]/Omega;
C[12] := (V[13]*V[32]+V[12])*E[2]/Omega;
C[33] := (1-V[12]*V[12])*E[3]/Omega;
C[1] := -.2596702449; C[2] := -2.411545729; C[3] := -0.6051254981e-1; C[4] := .4085627399;
lambda[1] := .6891428810; lambda[2] := -.6891428810; lambda[3] := 9.177422410; lambda[4] := -9.177422410;
could you help me plase
I'm trying to plot a piecewise function whose return value has units, but I get an error saying that it found a "name" (i.e., the unit symbol).
Example:
> f := t -> 2*t;
> fp := piecewise(f(tt) <= 4, 1*Unit(W), f(tt) > 4 and f(tt) <= 8, 2*Unit(W), f(tt) > 8, 3*Unit(W));
> plot(fp, tt = 0..10);
I've tried using the option useunits, but no success. Any help will be appreciated.
Limitation of Maple spreadsheet is only 100 x 52
I don't know why there's a limitation on the size but there's no way of increasing it either.  Is there?
Just to be sure that some outside operation wouldn't nudge the spreadsheet size I tried
with(Spread):
a:=CreateSpreadsheet():
b:=Matrix(100,100):
SetMatrix(a,b)
                           Error, (in Spread:-SetMatrix) spreadsheets cannot exceed 52 columns
So unfortunately until the feature gets built into Maple I don't believe there is a workaround.
Hello.
When I click to start simulation button maple start counting but after that don't open visualization. When I open visualization manually, there aren't results of simulation. Program don´t show any error. It does not work with my models and examples to. Thanks for your help.
I read research paper about elasticity, and I don't not how can get the results for displacment ant shaer stress,, could you help me please.
please help me
Kind Regards
I have a matrix A and a matrix B defined as B:=A. When an entry of B is changed in my Maple code, the matrix A is also changed.
A := Matrix([1, 1]):
B := A:
B[1, 1] := 2:
print(A):
The result is
[2,1] but as you see, I did not change the entries of A during the code.
This never happen for numbers.
Please help me.
confused in matrix substitution
http://tinypic.com/r/5a048l/9
I have a multivariate polynomial in x and y. How can I firstly collect the terms with respect to the powers of x and y and then simplifying their coefficients.
with(RealDomain):
A := Matrix(5, 5, {(1, 1) = 0, (1, 2) = 1, (1, 3) = 1, (1, 4) = 1, (1, 5) = 1, (2, 1) = 1, (2, 2) = 0, (2, 3) = c__1, (2, 4) = y, (2, 5) = c__2, (3, 1) = 1, (3, 2) = c__1, (3, 3) = 0, (3, 4) = c__3, (3, 5) = x, (4, 1) = 1, (4, 2) = y, (4, 3) = c__3, (4, 4) = 0, (4, 5) = c__4, (5, 1) = 1, (5, 2) = c__2, (5, 3) = x, (5, 4) = c__4, (5, 5) = 0})
Matrix(%id = 4510803138)
B := Determinant(A)
-2*c__1^2*c__4+2*c__1*c__2*c__3+2*c__1*c__2*c__4-2*c__1*c__2*x+2*c__1*c__3*c__4-2*c__1*c__3*y-2*c__1*c__4^2+2*c__1*c__4*x+2*c__1*c__4*y+2*c__1*x*y-2*c__2^2*c__3-2*c__2*c__3^2+2*c__2*c__3*c__4+2*c__2*c__3*x+2*c__2*c__3*y-2*c__2*c__4*y+2*c__2*x*y-2*c__3*c__4*x+2*c__3*x*y+2*c__4*x*y-2*x^2*y-2*x*y^2
Download A.mw
hi.i encounter error in pdsole equations with unknown parameter(N)??
please help me for solve it....thanks alotmaple_prime.mw
Dear friend! Hope every thing going fine with you. I need the solution of the following inqulity (for what values of a[1], a[2] and a[3] the equity hold) and it simplist form.
3*a[1]*a[2]*a[3]-2*a[1]*a[2]-2*a[1]*a[3]-2*a[2]*a[3]+2*a[1]+2*a[2]+2*a[3]-1 <= 3*a[2]*a[1]*a[3]-((a[1]*a[2]*a[3]+1)/(a[2]*a[3]-a[3]+1)-1)*((a[1]*a[2]*a[3]+1)/(a[1]*a[3]-a[1]+1)-1)-((a[1]*a[2]*a[3]+1)/(a[2]*a[3]-a[3]+1)-1)*((a[1]*a[2]*a[3]+1)/(a[1]*a[2]-a[2]+1)-1)-((a[1]*a[2]*a[3]+1)/(a[1]*a[3]-a[1]+1)-1)*((a[1]*a[2]*a[3]+1)/(a[1]*a[2]-a[2]+1)-1)
I am waiting your quick response
Mob #: 0086-13001903838
First 1192 1193 1194 1195 1196 1197 1198 Last Page 1194 of 2434
