This is really weird.
eq:=phi(f(x,y(x),diff(y(x),x)),g(x,y(x),diff(y(x),x)));
Does any one see a "||" in the above? I do not. Then why Maple shows this:
r := cat("dsolve(",eq,",y(x))");
       r:="dsolve("||phi(f(x,y(x),y'(x)),g(x,y(x),y'(x)))||",y(x))"
This is Maple 2015 on windows. Running in worksheet mode
Here is screen shot
This problem does not show up all the time. For example, this works ok:
No "||" added. The problem with all the above, is that I can't make it all as a string in the first example above. I am trying to make a string of   "dsolve(" + ode + "),y(x)"
Here is the display options
thank you
Can somebody help me to find the solution?
I think there is something wrong with the definition of bvw1. If I use dsolve (in soln) with only bvw as Initial Condition,
I get a solution but if I also insert bvw1 as an Initial condition soln won't appear.
Here's what's written in the image:
'Imagine the course of a planet around a star with L=0.5 and e=0.7'
Solve Keppler's differential equation with Initial Conditions:'
pendulums
Of course, in Maple. Source http://www.mmf.lnu.edu.ua/
I am making a mpl file which looks like below:
font_size := thickness = 4, font = [bold, "TimesNewRoman", 30], labelfont = [bold, "TimesNewRoman", 30], axis[1] = [thickness = 3], axis[2] = [thickness = 3], captionfont = [bold, "TimesNewRoman", 30], legendstyle = [font = [bold, "TimesNewRoman", 30]];
I  export it as mpl, but when I want to read it in a worksheet, I get the error below:
Error, on line 1, syntax error, character `?` unexpected:
<?xml version="1.0" encoding="UTF-8"?>
Error, while reading ``/Users/..../font_size.mpl``
This is just a simple mpl, I get this error for all mpl s that I want to read!
Can somebody help me with this please? It is really annoying :(
Remark from Markiyan Hirnyk.
The body of this question disappeared when I was editing its title only.
abc
bca
if starting position is at first position,
i have to write a very long substitution, and need a temporary variable t and t2
subs(t2=c,subs(t=a,subs(a=b,subs(b=t2,subs(c=t,a*b*c+a*b)))));
if starting position is at second position, it will be
abc
acb
is there any simple method to do this circular shift of variables for a polynomial
I am able to get unlimeted numbers of equations describing my system. These equations are generally relate quotients of multivariate polynomials. Each additional equation I get is generally less than twice the length of the last, and it is not always the case that an equation is independant of the previous equations. Although I can get unlimited numbers of equations describing the system, it is not overdetermined.
I am interested in solving these equations for their variables. There are about 30 cases I am working on, the smallest number of evariables is six, the largest would be twenty.
I want to be able to solve these equations in the minimal time possible. But I don't understand the function solve well enough to do so.
How do I choose the equations to minimise the time taken for the command solve to proccess them?
How does the command solve work?
particularly:
  1. if I process the command solve([Eq1,Eq2,Eq3...Eqn],variables) would the command solve([Eq[1],Eq[2],Eq[3]...Eq[n],Eq[n+1]],variables) take longer if Eq[n+1] is not indipendant of the previous equations?
  2. Is there a way of checking whether Eq[n+1] is independant of the previous vequations, fast enough for it to be useful to check the equations before they are processed?
  3. Does the ordering of the equations affect the speed of solve?
  4. Is there a way of pre processing the equations before they are put into solve that will save it time? (for example factorising them, simplifying them etc...)
I'm trying to solve the integral u/(1-u) with Maple and noticed that it returned a result that doesn't accord to the solution I found by hand or the solution from WolframAlpha. This is a screenshot of the weird behaviour:
Does Maple do any weird conversions? Or did I do something wrong or is Maple wrong?
Thanks in advance,
Hello everyone!
Suppose, we have a differential polynomial
P := u(x) + (D@@2)(u)(x)
Given this, I am looking for a procedure which gives coefficients depending on the order given as input, for example, lets say, procedure name is fun_coeff which depends on two parameters, original polynomial P and the order n, then
fun_coeff(P, 3) should give [1, 0, 1, 0]
where each entry corresponds to the coeff of
 [u(x), (D@@1)(u)(x), (D@@2)(u)(x), (D@@3)(u)(x)]
in the polynomial, similarly
fun_coeff(P,4) should give [1, 0, 1, 0, 0]
corresponding to
 [u(x), (D@@1)(u)(x), (D@@2)(u)(x), (D@@3)(u)(x), (D@@4)(u)(x) ]
Thank you all for your time :)
I have downloaded a third party Maple package from following link:
http://cpc.cs.qub.ac.uk/summaries/AEQP_v1_0.html
The distribution format is  "tar.gz", but I don't know what to with this format, that how should I load this package into Maple library. I have window 8.1.
If anybody have an idea about this format "tar.gz" please help me out.
i am working on a simple control project.i should make a transfer function from the below equation (as an example):
 (s^2*m1+I1*(s^2)*(1/r^2))*x(s)+(-(1/2)*s^2*b*m1-s^2*m1*r-I1*(s^2)*(1/r)+m1*g)*theta(s)+(1/2)*theta(0)*s*b*m1+theta(0)*s*m1*r-x(0)*s*m1+(1/2)*(D(theta))(0)*b*m1+(D(theta))(0)*m1*r-(D(x))(0)*m1+I1*s*theta(0)*(1/r)+I1*(D(theta))(0)*(1/r)-I1*s*x(0)*(1/r^2)-I1*(D(x))(0)*(1/r^2) = 0
in order to make the T.F i have to make " x(s)/theta(s) " on the lhs and put the rest on the rhs. i have no idea how to do so.(the underlined part involves no x(s) and theta(s). obviously a theta(s) will appear on the rhs in the one of the denominators which doesn't matter.)
please help me with this problem.since i don't know what the commands are called in english, i failed in searching for it.
thanks.
hi.please remove error in attached file
thanks...gfhf.mw
 a new function from an existing function and how?
I try to assign a value "y" function "g" but not working. Should be g(0.5,y)=800, but it is not appear in screen. Regards.
value_function.mw
g(.5, y) := 200*y;
200*y
y := 4;
4
g(.5, y)
g(.5, 4)
Download value_function.mw
Please guide me how to convert system of expressions into system of equations, so as solve them using "solve command".
The following expressions are just coefficients extracted from certain equation.
16*a[2]^4*delta[1]^2-48*a[2]^3*a[3]*delta[1]*delta[2]-2*a[2]*b[2]*delta[1]^2, 48*a[2]^2*a[3]^2*delta[1]*delta[2]-80*a[3]^4*delta[1]*delta[2]-4*a[3]*b[3]*delta[1]*delta[2], 64*a[2]^3*a[3]*delta[1]*delta[2]-64*a[2]*a[3]^3*delta[1]*delta[2]-2*a[2]*b[3]*delta[1]*delta[2]-2*a[3]*b[2]*delta[1]*delta[2]
It possible for me to write (1) in the following form
for EQ in 16*a[2]^4*delta[1]^2-48*a[2]^3*a[3]*delta[1]*delta[2]-2*a[2]*b[2]*delta[1]^2, 48*a[2]^2*a[3]^2*delta[1]*delta[2]-80*a[3]^4*delta[1]*delta[2]-4*a[3]*b[3]*delta[1]*delta[2], 64*a[2]^3*a[3]*delta[1]*delta[2]-64*a[2]*a[3]^3*delta[1]*delta[2]-2*a[2]*b[3]*delta[1]*delta[2]-2*a[3]*b[2]*delta[1]*delta[2] do EQ = 0 end do
16*a[2]^4*delta[1]^2-48*a[2]^3*a[3]*delta[1]*delta[2]-2*a[2]*b[2]*delta[1]^2 = 0
48*a[2]^2*a[3]^2*delta[1]*delta[2]-80*a[3]^4*delta[1]*delta[2]-4*a[3]*b[3]*delta[1]*delta[2] = 0
64*a[2]^3*a[3]*delta[1]*delta[2]-64*a[2]*a[3]^3*delta[1]*delta[2]-2*a[2]*b[3]*delta[1]*delta[2]-2*a[3]*b[2]*delta[1]*delta[2] = 0
But I want to write (1) in the following form
16*a[2]^4*delta[1]^2-48*a[2]^3*a[3]*delta[1]*delta[2]-2*a[2]*b[2]*delta[1]^2 = 0, 48*a[2]^2*a[3]^2*delta[1]*delta[2]-80*a[3]^4*delta[1]*delta[2]-4*a[3]*b[3]*delta[1]*delta[2] = 0, 64*a[2]^3*a[3]*delta[1]*delta[2]-64*a[2]*a[3]^3*delta[1]*delta[2]-2*a[2]*b[3]*delta[1]*delta[2]-2*a[3]*b[2]*delta[1]*delta[2] = 0
Download Maple_Query.mw
First 1212 1213 1214 1215 1216 1217 1218 Last Page 1214 of 2463
