with(DynamicSystems)
T:= a vector
Iwant to make a single plot of:
DiscretePlot(T,x1,stile=stair); DisdretPlot(T,x2,stile=stair)
The usal way: DiscreePlot(T,[x1,x2]... ain't work
Thansk for helping
I am trying to solve a PDE which is converted to ODE when we assign one of the  variables some value. The boundary conditions given to the PDE are numerical values given for fixed numerical values to the two independent variables. I am trying to solve the PDE with the staandard syntax:
pds := pdsolve(pde,[ibc],numeric,time=z,range=0..beta);
The error message I get is:
Error, (in pdsolve/numeric/process_PDEs) PDEs can only contain dependent variables with direct dependence on the independent variables of the problem, got {theta(z, 0)}
The pde and boundary conditions are as follows:
PDE:   pde := diff(theta(z, 0), z, z)+theta(z, 0)
Where zero is the fixed value for an independent variable
Boundary Condition:  ibc:={theta(0,0)=beta,D[1](theta)(0,0)=0};
When I try to solve it as an ODE the error is:
Error, (in dsolve) not an ODE system, please try pdsolve
I would like to know : how I can get all the contents of the module GetMultibody of MapleSim?
Is there in classic maple a function enabling me to ask the content of a module ?
Thank a lot for your help.
i was stuck with some simple problem. I tried using if condition in program that involves a truth condition. If maple cannot determine the condition is true or false i want to assign o to a particular varable. I  show a similar program.
h[1] := -1;
for i from 1 by 1 while(i<150 and h[i]<0) do
p1[i] := .989347189582843*x^2-0.139423979061219e-1*x-1.82559474469870*10^8*x^15+1.30761381361453*10^8*x^16-6.88520063191821*10^7*x^17+2.51079317463498*10^7*x^18-5.66094206949155*10^6*x^19+5.94129446612678*10^5*x^20-6812.74182685426*x^5+59230.0931084044*x^6-3.83520584559500*10^5*x^7+1.90126822307036*10^6*x^8-7.34991883857609*10^6*x^9+2.24203561757434*10^7*x^10-5.43284775909785*10^7*x^11+1.04806113793011*10^8*x^12-1.60600324339222*10^8*x^13+1.94090536353833*10^8*x^14+559.557918804679*x^4-30.6576714427729*x^3-3.93727537464007*10^(-15)-i^2-i; fsolve(p1[i]-0.312e-1, x, -1 .. 1);
if fsolve(p1[i]-0.312e-1, x, -.2 .. 0) < 0 then h[i+1] := fsolve(p1[i]-0.312e-1, x, -.2 .. 0) elif FAIL then h[i+1] := 0 end if;
print(i, h[i])
i got an error message
Error, cannot determine if this expression is true or false: () < 0
how can i get a value of 0 for h[i] if the error comes.
Aditya
I would like to change the numbering of my equation.
For the moment, the numbering of my equations is : 4.2.4 for Section 4, Subsection 2 and 4th equations.
I would like to keep the number for the section but to remove the numbers for the subsections.
Consequently, I would like to have this kind of result only : 4.4 for Section 4, Equation 4.
Do you have some ideas to do this changement ?
Thanks a lot for your help.
i have to compute lie algebra condition by using maple 15, but currently i have code in maple 5.,
i already try to run in maple 15 but it say 'error,unable to match delimeters'
i try to find error, but i cant find it..
the coding are here...
check[lie]:=proc(A,n)
local  i,j,k,l,m;
for i from 1 by 1 to n do
for j from 1 by 1 to n do
for k  from 1 by 1 to n do
if A[i,i,k]<>0 then
RETURN ('Input is NOT a Lie algebra (',i,i,k,')=',A[i,i,k], 'is not zero');
elif A[i,j,k]+A[j,i,k]<>0 then
RETURN ('Input is NOT a Lie algebra,(',i,j,k,')+(',j,i,k,')=',A[i,j,k]+A[j,i,k],'is not zero');
for 1 from 1 by 1 to n do
if
simplify(sum(A[i,j,m]*A[m,l,k]+A[j,l,m]*A[m,i,k]+A[l,i,m]*A[m,j,k],   m=1..n))<>0
then
RETURN('Input is NOT a Lie algebra---the Jac(',i,j,l,') is not zero');
fi;
od;
fi;
od;
od;
od;
print('Yes,input IS a Lie algebra');
end:
can anyone help me here? Thank You..
Here, i attached the result in printscreen
I ues the optimization tool in Maple2015.
In my experience, Maple optimizatiom tool just shows the optimum values, not a history of the optimizatiom process.
I want to know how I can obtain the history of the optimization process, such as values of the objective, constraints, and tolerance at every iteration.
Is there anyone who knows how to obtain the history data of the optimization process?
Do you have physical components like MOSFETs and IGBTs in your library? How can I have a look at the tool and library block sets?
Hi everyone,
I am trying to solve the equation of heat tranfer, time dependent, with particular Initial and boundary conditions but I am stuck by technical problems both in getting an analytical solution and a numerical one.
The equation
the equation.
I defined a and b numerically. domain is : and I defined surf_power numerically.
The initial condition is : , T0 defined numerically
The boundary condition is : , because it has a shperical symetry.
To me, it looks like a well posed problem. Does it look fine ?
Problem in analytical solution :
It doesn't accept the boundary condition so I only input the initial condition and it actually gives me back an expression that can be evaluated but it never does : I can't reduce it more than an expression of fourier which I can't eval. The solution :
The solution calculated in (0,0). I was hoping T0...
Are you familiar with these problems ? What would be the perfect syntax you would use to solve this ?
The numerical solution problems :
Sometimes it tells me that my boundary condition is equivalent  to 0 = 0, and I don't see why. Some other times it tells me I only gave 1 boundary/initial condition even if I wrote both. Here is what I wrote for example :
(because it kept asking me to add these two options : 'time' and 'range')
Are you familiar with these problems ? What would be the perfect syntax you would use to solve this ? I must at least have syntax problems because even if I keep reading the Help, it's been a long time since I used Maple.
Thank very much for any indication you could give me !
Simon
I want to refer to the first element in a list such as x:=[1,2,3] as x[0] not x[1].
How to do it?
Hello Mapleprime members
I am having an issue with a Maple script I have written that reads in a separate Maple script at the start of the code which deals with regular Jacobian transformations I apply to the problem and got tired writing it each time so externalised it and read it in each time.
On Maple 2015 on my Mac there is nothing wrong with the script and it runs without issue.
When I run it on Maple 17 on my linux machine It says the read in file does not exist and the only difference between both machines is the home directory path. (or perhaps version of Maple, but I have used thew following commands in older Maple versions)
The Maple script has this at the top:
cwd:=currentdir():
home:=getenv("HOME");
Expspath:=cat(home,"Pathway to the file to be read in");
currentdir(Expspath);
I am simply getting Maple to find the home directory and apply it to the start of the file path which i thought would universally work between machines, and allow the running of Maple scripts between operating systems.
When I run the program on the linux Maple 17, printing Expspath from above gives  exactly where the file is located as it finds the home directory correctly and uses the correct filepath, it just says it does not exist. is there something obvious I am missing?
The Maple file to be read in is on Dropbox so just after the home directory is /Dropbox. If that makes any difference. In both instances the file path is where the file is located (exact match) but the mac will read in the file and linux says it does not exist even though it is the correct filepath.
Any help would be appreciated
- Yeti
Consider the following function.
f (x) = ( x3 − 442x2 + 65107x − 3196058) e1/x
f:=x->(x^3-442*x^2+65107*x-3196058)*exp(1/x);
Use Newton's method to find all 3 roots (correct to at least 6 decimal places) of f (x). (Note that you might have to increase the 'Digits' variable to 15, i.e., Digits:=15, in order to get the required accuracy.)
 my answer are 143.2030067,143.2030339,143.2030610
but, it is wrong. can anyone tell me where is the wrong part?
please!!
I am attempting to solve a system of second order ODEs. I place conditions on the solutions and use the solve command to figure the correct constants for the general solutions of the ODEs; however, the conditions do not appear to hold after I substitute the constants back into the general solutions. Any help would be greatly appreciated. Here's the code and an explanation:
First some constants
> A := 1; B := 9/10;
> j := 1-1/B;
 This is our homogeneous odes. I will give the general solutions of the inhomogeneous system momentarily
> eqnv1 := diff(v1(x), `$`(x, 2)) = (1-1/(j+1))*v1(x)+v2(x)/(j+1);
> eqnv2 := diff(v2(x), `$`(x, 2)) = -v1(x)/(A*(j+1))+(B/A+1/(A*(j+1)))*v2(x);
Next we get the general solution of this sytem of odes.
> soln := dsolve([eqnv1, eqnv2])
Next we have our solutions of the inhomogeneous problem1. Basically solution v1neg, v2neg on [0,xi] and v1pos, v2pos on [xi,1]. We will assume v1,v2 are C^1 across xi; however, the location of xi is not known at this time so they must remain split.
> v1neg := op([1, 2], soln)-1;
> v2neg := op([2, 2], soln)-1/B;
> v1pos := op([1, 2], soln)+1;
> v2pos := op([2, 2], soln)+1/B;
There's probably a better way to do this, but I relabeled the constants:
> v1negc := subs([_C1 = a[1], _C2 = a[2], _C3 = a[3], _C4 = a[4]], v1neg);
> v2negc := subs([_C1 = a[1], _C2 = a[2], _C3 = a[3], _C4 = a[4]], v2neg);
> v1posc := subs([_C1 = a[5], _C2 = a[6], _C3 = a[7], _C4 = a[8]], v1pos);
> v2posc := subs([_C1 = a[5], _C2 = a[6], _C3 = a[7], _C4 = a[8]], v2pos);
Next we have eight conditions the solutions must satisfy. Namely v1, v2 are C^1 across xi and v1',v2' are 0 at {0,1}.
> syscon1 := subs(x = xi, v1negc) = subs(x = xi, v1posc);
> syscon2 := subs(x = xi, v2negc) = subs(x = xi, v2posc);
> syscon3 := subs(x = xi, diff(v1negc, x)) = subs(x = xi, diff(v1posc, x));
> syscon4 := subs(x = xi, diff(v2negc, x)) = subs(x = xi, diff(v2posc, x));
> syscon5 := subs(x = 0, diff(v1negc, x)) = 0;
> syscon6 := subs(x = 0, diff(v2negc, x)) = 0;
> syscon7 := subs(x = 1, diff(v1posc, x)) = 0;
> syscon8 := subs(x = 1, diff(v2posc, x)) = 0;
We solve to get the constants for the solutions.
> constants := simplify(evalf(solve({syscon1, syscon2, syscon3, syscon4, syscon5, syscon6, syscon7, syscon8}, {a[1], a[2], a[3], a[4], a[5], a[6], a[7], a[8]})));
We substitute the values for the constants.
> a[1] := op([1, 2], constants); a[2] := op([2, 2], constants); a[3] := op([3, 2], constants); a[4] := op([4, 2], constants); a[5] := op([5, 2], constants); a[6] := op([6, 2], constants); a[7] := op([7, 2], constants); a[8] := op([8, 2], constants);
Lastly we try to verify that the conditions from earlier hold:
> evalf(subs(xi = .2, subs(x = xi, v1negc-v1posc)));
-1.7597825261536669519
> evalf(subs(xi = .2, subs(x = xi, v2negc-v2posc)));
-1.8936659961101033997
> evalf(subs([x = 0, xi = .2], diff(v1negc, x)));
-0.38633519704430619686
They should hold for any xi, but they don't appear to. All of these should be 0. For a large xi, the numbers get very large so I was thinking perhaps roundoff error, but even when I do an exact solution and then evalf just at the end, I still have large error so I'm not sure what the problem is. Sorry for the long question. Thanks so much for the help.
Hi!! i am working on assignment.
h:= x-> (x^17-x*sin(x^16))/x^49+exp(sqrt(x+8))*ln(abs((cos^4*(x)-5)));
i want to find the value of the h(10)
i use eval , but it comes out a function, not a solution.
please.help!!
I'm trying to solve a fourth order ODE but for some reason I only end up with three constants at the end. I'm using Maple 16. Here's the code I have been using:
dsolve(diff(x(t), t$4)+4*diff(x(t), t$2)-4*x(t)+1);
The output is
x(t) = 1/4+_C1*exp(sqrt(-2+2*sqrt(2))*t)+_C2*exp(-sqrt(-2+2*sqrt(2))*t)+_C3*exp(-I*sqrt(2+2*sqrt(2))*t)
When I try to solve the homogeneous equation I get the expected four linearly indep solutions:
x(t) = _C1*exp(-sqrt(-2+2*sqrt(2))*t)+_C2*exp(sqrt(-2+2*sqrt(2))*t)+_C3*exp(-I*sqrt(2+2*sqrt(2))*t)+_C4*exp(sqrt(-2+2*sqrt(2))*t)
Adding 1/4 to this gives me the general solution I would expect, but I don't see why I should need to do this step. I'm at a loss for what I am doing wrong so any help would be greatly appreciated. Thanks in advance.
First 1256 1257 1258 1259 1260 1261 1262 Last Page 1258 of 2463
