DO not know if this is new in Maple 2025.2 or not as I have not looked yet if it is possible to install Maple 2025.1 on my new PC given Maple 2025.2 is already installed.
Found That Maple 2025.2 gives "Error, (in dsolve) numeric exception: division by zero" when asked to solve this ode using Lie symmetry.  The error comes when it tried to
                        Computing canonical coordinates for the symmetry
Even if this problem was in earlier Maple versions, this ofcourse should not happen.
`The "Physics Updates" version in the MapleCloud is 1882 and is the same as the version installed in this computer, created 2025, December 1, 6:58 hours Pacific Time.`
SupportTools:-Version();
libname;
"C:\Users\me\maple\toolbox\2025\Physics Updates\lib", "C:\Users\me\maple\toolbox\2025\Maple Customer Support Updates\lib", "C:\Program Files\Maple 2025\lib"
ode:=sin(x)*diff(y(x), x, x) + (2*sin(x) - cos(x))*diff(y(x), x) + (sin(x) - cos(x))*y(x) = exp(-x);
sin(x)*(diff(diff(y(x), x), x))+(2*sin(x)-cos(x))*(diff(y(x), x))+(sin(x)-cos(x))*y(x) = exp(-x)
dsolve(ode)
y(x) = exp(arcsin(cos(x)))*c__2+exp(arcsin(cos(x)))*cos(x)*c__1+exp(arcsin(cos(x)))*(-(Int(csc(x)^2*exp(-arcsin(cos(x))-x), x))*cos(x)+Int(cot(x)*csc(x)*exp(-arcsin(cos(x))-x), x))
dsolve(ode,Lie)
Download division_by_zero_dsolve_maple_2025_2_on_dec_2_2025.mw
I would like to change the document and worksheet colour in Maple 2025. I would like to darken or change the color of the icons and text in the tool bar. I have searched everywhere and can't seem to locate it. As currently configured, it is hard on the eyes; my eyesight is not the best. I beleive there is a softer yellow colour that can be picked, which I believe is called classic. Thank you
I am using Maple 2025.  I have the following in my ini file:
    with(VectorCalculus):
    with(plottools):
    with(DocumentTools):
    with(Units[Simple]):
    with(StringTools):
    stoperror(all):
   interface(displayprecision = 4):
    _EnvUseHeavisideAsUnitStep := true:
    Digits := 10:
I want to set my default number formatting to "Engineering."  I cannot find where or how to do this, either in the menues or the an ini file command.  I can do it in the context panel line by line, but want it to be global and automatic.
Thanks in advance for your assistance.
I have an expression with y,y',y''. I found that I had to use collect first to make Maple simplifies it more.
Why is that? Is this expected?
B:=-(-t^2+1)*(-diff(y(t),t$2)*(-t^2+1)^(1/2)+diff(y(t),t)/(-t^2+1)^(1/2)*t)-(2*(-t^2+1)^(1/2)-t)*diff(y(t),t)*(-t^2+1)^(1/2)+((-t^2+1)^(1/2)-t)*y(t);
-(-t^2+1)*(-(diff(diff(y(t), t), t))*(-t^2+1)^(1/2)+(diff(y(t), t))*t/(-t^2+1)^(1/2))-(2*(-t^2+1)^(1/2)-t)*(diff(y(t), t))*(-t^2+1)^(1/2)+((-t^2+1)^(1/2)-t)*y(t)
simplify(B);
((diff(diff(y(t), t), t))*t^4+2*(diff(y(t), t))*t^2*(-t^2+1)^(1/2)-2*(diff(diff(y(t), t), t))*t^2-y(t)*t^2-y(t)*(-t^2+1)^(1/2)*t-2*(diff(y(t), t))*(-t^2+1)^(1/2)+diff(diff(y(t), t), t)+y(t))/(-t^2+1)^(1/2)
B:=collect(B,{diff(y(t),t$2),diff(y(t),t),y(t)},'distributed'):
simplify(B);
2*(t^2-1)*(diff(y(t), t))+((-t^2+1)^(1/2)-t)*y(t)+(-t^2+1)^(3/2)*(diff(diff(y(t), t), t))
Download why_collect_is_needed_to_simplify_more_maple_2025_2_nov_30_2025.mw
Notice how much simpler the result when doing collect first.
I've seen many here recommend using the screen reader for Maple 2025. So this is first time I tried it.
Clicked on this second icon in my windows 10 start menu
Maple came up using the old UI, which is good:
But here comes the big problem. The file->Open menu does not work. It automatically opened in location which is not what I want. I wanted to navigate to different place on my PC. But anything I click on just generates loud beep and does nothing. Can't type anything to change location either.
So can't open any file. Not only that, It is stuck and can't even close the windows. Can't get out. Everything is stuck.
It could be because I have 2 monitors. I had this open on the second monitor on the right. Everything on the second monitor now do not respond like Maple. Luckily, on the left monitor I was able to start task manager and kill Maple in order to get out of this hang.
Basically screen reader does not work at all for me. If I can't open a file.
It could be due to using 2 monitors. I do not know.
Does file open work for others?
Here is small movie.
I could not get the max() function to work with units.  I had to strip out the units, do the max() and then add them back in.  It seems overly complicated and wrong.  I am sure there is a better way.
Could someone please check if Maple 2025.1 gives this error?  I only have Maple 2025.2 (is there a way to install Maple 2025.1 on same PC, after installing Maple 2025.2? Will Maple complain or remove Maple 2025.2 if I do this? Can I use same activation key to do this? I only have one.
Will call support and ask them on monday. This way I can check myself from now on.
Calling dsolve on an ode gives Error, (in dsolve) improper op or subscript selector which comes from
             Computing canonical coordinates for the symmetry [x*(x^2+y^2+a), -y*(-x^2-y^2+a)]
Worksheet below.
`The "Physics Updates" version in the MapleCloud is 1881 and is the same as the version installed in this computer, created 2025, October 7, 16:4 hours Pacific Time.`
libname;
ode:=x*y(x)*diff(y(x),x)^2+(a+x^2-y(x)^2)*diff(y(x),x)-y(x)*x = 0;
x*y(x)*(diff(y(x), x))^2+(a+x^2-y(x)^2)*(diff(y(x), x))-y(x)*x = 0
dsolve(ode);
infolevel[dsolve]:=5;
5
dsolve(ode);
Methods for first order ODEs:
   *** Sublevel 2 ***
   -> Solving 1st order ODE of high degree, 1st attempt
   trying 1st order WeierstrassP solution for high degree ODE
   trying 1st order WeierstrassPPrime solution for high degree ODE
   trying 1st order JacobiSN solution for high degree ODE
   trying 1st order ODE linearizable_by_differentiation
   trying differential order: 1; missing variables
   trying simple symmetries for implicit equations
   Successful isolation of dy/dx: 2 solutions were found. Trying to solve each resulting ODE.
      *** Sublevel 3 ***
      trying homogeneous types:
      trying exact
      Looking for potential symmetries
      trying an equivalence to an Abel ODE
   -> Solving 1st order ODE of high degree, Lie methods, 1st trial
    -> Computing symmetries using: way = 3
[x^3+x*y^2+a*x, x^2*y+y^3-a*y]
    <- successful computation of symmetries.
 1st order, trying reduction of order with given symmetries:
   1st order, trying the canonical coordinates of the invariance group
   -> Computing canonical coordinates for the symmetry [x*(x^2+y^2+a), -y*(-x^2-y^2+a)]
Download dsolve_gives_parsing_error_maple_2025_2_nov_20_2025.mw
This internal error happens even if Physics or Support tools are not in libname.
On Windows 11.
When I insert a link to a worksheet Maple 2025 crashes (also with the Screen Reader version).
When I click on a hyperlink to a workbook in a document created with Maple 2024, Maple 2025 crashes.
Is this reproducible?
Edit:
Also opening a workbook crashes Maple 2025 (i.e. no hyperlinks involved)
i did simplify and each time work but this time is give me another thing can anyone find what is problem?
pdetest2.mw
Do not know if this is new or not.
I have found about 12 Maple crashes so far in just 2 days running a test in Maple 2025.2
But this one I am not sure if it is new or not as never seen it before.
Could someone please just run this in Maple 2025.1 and see if you get same crash? So I know if it is new or not. Only have Maple 2025.2 on this new PC.
Calling solve causes Maple server to crash. Save your work before just in case.
sol:=ln( (y-1)^(1/3)* (y^2+y+1)^(1/3) ) - ln(y) = 2/5* ln(t^2+1)+_C1;
ln((y-1)^(1/3)*(y^2+y+1)^(1/3))-ln(y) = (2/5)*ln(t^2+1)+_C1
infolevel[solve]:=5;
5
solve( sol,y);
Main: Entering solver with 1 equation in 1 variable
Dispatch: dispatching to Radicals handler
Transformer:   solving for linear equation in y
Recurse: recursively solving 1 equations and 4 inequations in 1 variables
Dispatch: dispatching to ln handler (extension)
Dispatch: logarithm substitution _S000002 = ln(_S000001)
Dispatch: logarithm substitution _S000003 = ln(t^2+1)
Transformer:   solving for linear equation in _S000003
Recurse: recursively solving 1 equations and 3 inequations in 1 variables
Dispatch: logarithm substitution _S000004 = ln(exp(_S000002)^3+1)
Recurse: recursively solving 2 equations and 3 inequations in 2 variables
Dispatch: logarithm substitution _S000005 = ln(exp(_S000002)^6+3*exp(_S000002)^3+3)
Recurse: recursively solving 3 equations and 3 inequations in 3 variables
Dispatch: dispatching to Exponentials handler
Transformer:   solving for linear equation in _S000005
Recurse: recursively solving 3 equations and 4 inequations in 4 variables
Transformer:   solving for linear equation in _S000004
Recurse: recursively solving 3 equations and 5 inequations in 5 variables
Transformer:   solving for linear equation in _S000002
Recurse: recursively solving 3 equations and 6 inequations in 6 variables
Dispatch: dispatching to Rename handler
Dispatch: renaming exp(5/2*_C1) = _S000012, exp(-5/2*_C1) = 1/_S000012
Dispatch: handling polynomials of the form a*x^n-b
Dispatch: dispatching to PolynomialSystem handler
Main: polynomial system split into 1 parts under preprocessing
Main: using RegularChains based methods
SolverVariableOrder: using the variable order  _S000008 > _S000006 > _S000010
TriangularDecomposition: using deterministic algorithm for decomposition
Download calling_solve_crashes_maple_2025_2_nov_28_2025.mw
Note that this crash happens even when removing Physics update and SupportTools from libname.
in here i did exactly the same but i am not sure the author did something mistake or i did becuase one term in the pde is change and how exactly do that replacement in eq62?
S.mw
I only have Maple 2025.2 on this new PC. Could someone just run this code on earlier Maple version and see if they get same crash?
I am finding many crashes in Maple 2025.2 (3 so far) and I am only 25% in my test.  But not sure if this is new or was there in Maple 2025.1 or earlier.
I am trying to document all the new problems in Maple 2025.2.
Here is the worksheet (save all your work just in case).
ode:=(4+2*x-y(x))*diff(y(x),x)+5+x-2*y(x) = 0;
(4+2*x-y(x))*(diff(y(x), x))+5+x-2*y(x) = 0
sol:=y(x) = ((2*(x+11)*(x+1)^4*exp(12*_C1)-29*(x+103/29)*(x+1)^2*exp(6*_C1)+27*x+81)
*RootOf(2+(exp(6*_C1)*x^2+2*exp(6*_C1)*x+exp(6*_C1)-1)*_Z^6+3*_Z^2)^4+(-2*(x-4)
*(x+1)^4*exp(12*_C1)-34*(x+1)^2*(x+67/17)*exp(6*_C1)+54*x+162)*RootOf(2+(exp(6*
_C1)*x^2+2*exp(6*_C1)*x+exp(6*_C1)-1)*_Z^6+3*_Z^2)^2-(x-1)*(x+1)^4*exp(12*_C1)-\
14*(x+1)^2*(x+29/7)*exp(6*_C1)+27*x+81)/((10*(x+1)^4*exp(12*_C1)+27-37*(x+1)^2*
exp(6*_C1))*RootOf(2+(exp(6*_C1)*x^2+2*exp(6*_C1)*x+exp(6*_C1)-1)*_Z^6+3*_Z^2)^
4+(5*(x+1)^4*exp(12*_C1)+54-50*(x+1)^2*exp(6*_C1))*RootOf(2+(exp(6*_C1)*x^2+2*
exp(6*_C1)*x+exp(6*_C1)-1)*_Z^6+3*_Z^2)^2+(x+1)^4*exp(12*_C1)+27-22*(x+1)^2*exp
(6*_C1));
y(x) = ((2*(x+11)*(x+1)^4*exp(12*_C1)-29*(x+103/29)*(x+1)^2*exp(6*_C1)+27*x+81)*RootOf(2+(exp(6*_C1)*x^2+2*exp(6*_C1)*x+exp(6*_C1)-1)*_Z^6+3*_Z^2)^4+(-2*(x-4)*(x+1)^4*exp(12*_C1)-34*(x+1)^2*(x+67/17)*exp(6*_C1)+54*x+162)*RootOf(2+(exp(6*_C1)*x^2+2*exp(6*_C1)*x+exp(6*_C1)-1)*_Z^6+3*_Z^2)^2-(x-1)*(x+1)^4*exp(12*_C1)-14*(x+1)^2*(x+29/7)*exp(6*_C1)+27*x+81)/((10*(x+1)^4*exp(12*_C1)+27-37*(x+1)^2*exp(6*_C1))*RootOf(2+(exp(6*_C1)*x^2+2*exp(6*_C1)*x+exp(6*_C1)-1)*_Z^6+3*_Z^2)^4+(5*(x+1)^4*exp(12*_C1)+54-50*(x+1)^2*exp(6*_C1))*RootOf(2+(exp(6*_C1)*x^2+2*exp(6*_C1)*x+exp(6*_C1)-1)*_Z^6+3*_Z^2)^2+(x+1)^4*exp(12*_C1)+27-22*(x+1)^2*exp(6*_C1))
infolevel[odetest]:=5;
5
odetest(sol,ode);
odetest: Performing an implicit solution test
odetest: Trying to eliminate constants using the order: [_C1]
odetest: Trying to eliminate _C1
Download maple_crash_odetest_2025_2_nov_26_2025.mw
Update
Based on comment below, I just checked. If I remove "C:Usersmemaple\toolbox2025Maple Customer Support Updateslib" and "C:Usersmemaple\toolbox2025Physics Updateslib"  from libname, then the crash goes away !
libname
libname:=libname[3];
(6*_C1));
5
odetest(sol,ode);
odetest: Successful elimination of c__1
odetest: length of implicit solutions after isolating _Cn constants: 164
odetest: length after collecting objects and simplifying coefficients: 126
odetest: length after Solve w.r.t yn: 66
odetest: length after collect @ normal @ eval the ODE at the implicit solution: 0
Successful implicit test
Download maple_crash_odetest_2025_2_nov_26_2025_V2.mw
I also checked if libname had PHYSICS on it but no SUPPORT tools, and the crash also goes away. So the bug seems to be when adding SUPPORT tools.
libname
libname:=libname[1],libname[3]
"C:\Users\me\maple\toolbox\2025\Physics Updates\lib", "C:\Program Files\Maple 2025\lib"
libname
(6*_C1));
5
odetest(sol,ode);
Download maple_crash_odetest_2025_2_nov_26_2025_V3.mw
The crash only happens when SUPPORT tools is added:
Update DEC 6, 2025
I found something new about this crash. May be this gives someone at Maplesoft a clue why it happens.
Removing both Physics and SupportTools from libname, I can make it crash simply by adding this line before calling odetest
dsolve(diff(y(x),x$2)=0,arbitraryconstants=traditional):
If the above line is not there, there is no crash.
How could adding the above line cause the math engine to crash when calling odetest??
This worksheet shows this
Worksheet of the above
libname;
sol:=y(x) = ((2*(x+11)*(1+x)^4*exp(12*_C1)-29*(1+x)^2*(x+103/29)*exp(6*_C1)+27*x+81)
*(1+x)^4*exp(12*_C1)-34*(1+x)^2*(x+67/17)*exp(6*_C1)+54*x+162)*RootOf(2+(exp(6*
_C1)*x^2+2*exp(6*_C1)*x+exp(6*_C1)-1)*_Z^6+3*_Z^2)^2-(x-1)*(1+x)^4*exp(12*_C1)-\
14*(x+29/7)*(1+x)^2*exp(6*_C1)+27*x+81)/((10*(1+x)^4*exp(12*_C1)+27-37*(1+x)^2*
4+(5*(1+x)^4*exp(12*_C1)+54-50*(1+x)^2*exp(6*_C1))*RootOf(2+(exp(6*_C1)*x^2+2*
exp(6*_C1)*x+exp(6*_C1)-1)*_Z^6+3*_Z^2)^2+(1+x)^4*exp(12*_C1)+27-22*(1+x)^2*exp
(6*_C1)):
#keep on Maple lib and remove everything else
libname:=libname[3]
#this will crash
odetest(sol,ode)
Download odetest_crash_maple_2025_2_at_dec_6_2025.mw
Now will repeat the above, but comment the line dsolve(diff(y(x),x$2)=0,arbitraryconstants=traditional): and now the crash goes away
libname;
#comment out
#dsolve(diff(y(x),x$2)=0,arbitraryconstants=traditional):
(6*_C1)):
libname:=libname[3]
#this will not crash now
odetest(sol,ode)
Download odetest_crash_maple_2025_2_at_dec_6_2025_V2.mw
Why is adding the line dsolve(diff(y(x),x$2)=0,arbitraryconstants=traditional): cause odetest to crash?
Using Maple 2025.2, I need to run my test in command line (for other reasons).
Only problem is that plottools:-exportplot does not work as well as in the GUI.  The gridlines do not show.
I reported this to Maplesoft years ago. Was hoping may be it is fixed in Maple 2025.2 but it does not seem to be.
Anyone knows of a trick to show gridlines in plot (2D) when using cmaple.exe?
Here is example. Started cmaple.exe from command line (which on windows is
c:/Program Files/Maple 2025/bin.X86_64_WINDOWS/cmaple.exe
> p:=plot(x^3, x = -8 .. 8, color = "blue",axis=[gridlines=[10,color="red"]]):
> plottools:-exportplot("filename2.png",p);
You might want to use setdirectory() to some folder such as c:\tmp to save the plot to.
But the plot is missing the gridlines
In the UI it looks like this
This is really a big problem for me. I have to run the program in command line, but the plots geneated from command line do not look as good as when running the same program in maplew.exe vs. cmaple.exe.
This is a problem in Maple for years and years and no one in Maplesoft seems to care to fix it.
So I am asking hoping someone will have a trick to make gridline show using cmaple.exe.
Updated
I just found the case number. Actually I only reported this to Maplesoft 6 months ago. I thought it was longer than this.
Maybe they will fix it in Maple 2026?
I know Maplesoft is very busy with A.I. stuff these days, but hopefully someone will be able to have 1-2 hrs spare time from AI work and look at this and fix it.
It should not be hard to fix I would imagine, since code works in worksheet so someone just needs to use /copy same code that works in worksheet and make sure it works in cmaple.exe
Case - 00177734 | exporting plot using command line maple 2025 losses gridlines.
Thank you for contacting Maplesoft.
I have forwarded this inquiry to our Math Team / R&D Team. Once they review the situation and provide any further updates and/or insights, we will contact you. Thank you for your patience.
Best Regards,
Harish
Technical Support Analyst
Maplesoft
https://www.maplesoft.com
--------------- Original Message ---------------
Sent: 2025-04-01, 3:34 a.m.
To: support@maplesoft.com
Subject: exporting plot using command line maple 2025 losses gridlines.
When I export a plot to postscript using command line Maple 2025,
the generated plot is missing gridlines.
Same exact code executed inside GUI Maple 2025 shows the grid lines
as expected.
What to do to obtain same plot from command line Maple as from
the GUI?
I am using Linux Arch based distribution with Maple 2025 linux.
Here is the command I used
/home/me/maple2025/bin/maple A.mpl
Here is A.mpl
p:=plot(25*t^2+10*t+20,
axes=boxed,
labels=[t,x(t)],
axis=[gridlines=[color=lightblue]],
'color' = 'red'):
plotsetup(ps, plotoutput="p.ps",plotoptions=`color,noborder`);
print(p);
If you run the above, you will see p.ps file generated.
But looking at the plot inside it, shows no gridlines.
Could this be fixed or do I need different options to
make gridlines show running command line Maple?
I am trying to see if installing Physics update package will fix a problem I am having as described here by having a fix that maybe not included in Maple 2025.2
But I do not know how to do that. When doing Physics:-Version(); or Physics:-Version(latest); Maple says
             `The "Physics Updates" package is not available for the version of Maple under development`
Does this mean Physics update package is not needed in Maple 2025.2?  Otherwise, what are the instructions to install Physics package now?
May be someone could clarify the status of Physics package and if it is something that one should still install along with SupportTools which in Maple 2025.2 was there automatically and did not need to install it.
Update
JUst verified that Physics update package V 1881 is still needed in Maple 2025.2 as it has important fixes not merged in Maple 2025.2.
To install Physics package in Maple 2025.2 had to click on the top right corner of the worksheet (the down arrow) near the "sign in".
Then go down to "packages" and select and click on the install button next to Physics package.  (first in list).
This will download and install it.
Now closed all of Maple and restarted it.
Now Physics package V 1881 is installed and have fixes in it that are missing from Maple 2025.2.  This is why my test was failing. Now the test do not fail.
So first time, the command Physics:-Version(latest) does not work. But from now on it should work.
I would have expected all fixes made in Physics update to have been merged into the new Maple release.
In 2025.2, I found that calling Physics:-Setup causes code of `convert/diff` to change (on the fly) causing error.
I removed from my code the places I was calling Physics:-Setup explicitly, but the error still shows up. Which means there is still places in the code to cause Physics to come into play.
I just installed 2025.2 and have not done anything yet. Just running a test.
Does one need to install Physics package?
First, let me give an example showing that calling Physics:-Setup changes `convert/diff` which ends up causing an internal Maple error
Original result. No problem
print(`convert/diff`);
proc (a, { useeval::truefalse := false }) local ee, zD; ee := `PDEtools/usediff`(a); zD := indets(ee, 'And(function, satisfies(proc (f) options operator, arrow; (op(0, f))::`PDEtools/D/structure` end proc))'); if zD = {} then ee else _Env_t_in_use := `tools/get_symbols`(a); if useeval then zD := map(`convert/diff/D_to_eval@diff`, zD, ':-useEval'); zD := map(proc (u) options operator, arrow; lhs(u) = subsop(0 = eval, rhs(u)) end proc, zD); subs(zD, ee) else subs(map(`convert/diff/D_to_eval@diff`, zD), a) end if end if end proc
T:=D(x)(infinity):
PDEtools:-difforder(convert(T,diff))
After call Physics:-Setup
Physics:-Setup('assumingusesAssume' = false):
proc () local ans; ans := usepdiff(args); if has([ans], 'D') then ans := Physics:-OriginalValue["convert/diff"](ans, args[2 .. -1]) end if; ans end proc
T:=D(x)(infinity):
Error, (in unknown) invalid input: diff received infinity, which is not valid for its 2nd argument
Download why_code_changes_calling_Physics_maple_2025_2_nov_24_2025.mw
Notice that now calling PDEtools:-difforder(convert(T,diff))  fail because Physics:- was called.
But my code now has no calls to Physics:-, I made sure to comment all those out.
But I still get same error when I run my test program. Not able to find where Physics is "activated" again to cause the code change in `convert/diff` that happens dynamically when Physics is loaded.
It must be happining on different call internally. But have no idea why and where.
This is all on new PC. I have no Maple ini files or anything like this that can cause this.
Will installing Physics package explicity fixes this?
Update
I think I know why this happens. Not all fixes made by Edgardo S. Cheb-Terrab in last Physics update are included in Maple 2025.2 !
See https://mapleprimes.com/questions/240843-Why-PDEtoolsSolve-Fail-On-This-Equation  where fix is made in Physics  v.1880 which I confirmed in Maple 2025.1.
But now I checked and this problem is back in Maple 2025.2. which means that fix was not merged into Maple 2025.2. How could this happen?
eq:=D(y)(0)+1 = 0;
solve(eq,D(y)(0));
(D(y))(0)+1 = 0
-1
PDEtools:-Solve(eq,D(y)(0));
Error, (in PDEtools:-Solve) required an indication of the solving variables for the given system
Download fixed_in_2025_1_but_missing_in_2025_2.mw
So I am hoping that figuring how to install Physics update in Maple 2025.2 will fix the current problem with convert and also bring that old fix for PDEtools:-Solve back into Maple 2025.2.
This is something that Maplesoft should have taken care of.
Update
Figured how install Physics update package V 1881 and doing so fixed this problem in Maple 2025.2 !
This tells me that all fixes that were in Physics update package were not merged into Maple 2025.2
This worksheet shows that now code works OK, but need to make sure to install Physics update package in Maple 2025.2
T:=D(x)(infinity):
After call Physics:-Setup. now works OK since Physics update is installed
T:=D(x)(infinity):
Download why_code_changes_calling_Physics_maple_2025_2_nov_24_2025_V2.mw
First 14 15 16 17 18 19 20 Last Page 16 of 2457
