I am trying to solve 6 equations with 6 unknowns in maple. I tried to simplify them and they are shown below. Unfortunately, after using solve I get:
                            sol := ()
Can you help me with it, please? I tried to solve it with Matlab and got a warning that no explicit solution could be found and had no luck with mathematica either.  Thank you very much!!
omega_1 := 1;
beta_1 = 0.2;
omega_2 := 0.15;
beta_2 := 0.15;
mu := 0.4;
g := 9.81;
K := 5;
vb := 0.5;
tc := arccos(vb/(A*omega));
Ns := mu*(omega_2^2 - K)*B*(2*omega*tc - sin(2*omega*tc) - pi)/pi;
Nc := 4*mu*(omega_2^2 - K)*x2*sin(omega*tc)/pi + mu*(omega_2^2 - K)*C*(2*omega*tc + 2*sin(2*omega*tc) - pi)/pi;
a0 := -mu*(omega_2^2 - K)*x2*(1 - 2*omega*tc/pi) + 2*mu*(omega_2^2 - K)*C*sin(omega*tc)/pi;
eq1 := -A*omega^2 + A*omega_1^2 - B*K - Ns;
eq2 := 2*A*beta_1*omega*omega_1 - C*K - Nc;
eq3 := -2*C*beta_2*omega*omega_2 - B*omega^2 + B*omega_2^2 - A*K;
eq4 := 2*B*beta_2*omega*omega_2 - C*omega^2 + C*omega_2^2;
eq5 := omega_1^2*x1 - K*x2 - a0;
eq6 := omega_2^2*x2 - K*x1 - g;
sol := solve({eq1, eq2, eq3, eq4, eq5, eq6}, {A, B, C, omega, x1, x2});
I have a Maple program for plotting from z plane to w plane under transformation w=1/z
I have lines in the z plane and should have had nice circles in the w plane, but the circles are not so good. It is a hole around zero.I can do it manually, but I like to do it with the Maple program.
What must be done in the program to get nice circles???
Thanks for any answers!!
Kjell
eq32r:=diff(B(r),`$`(r,3))+diff(B(r),r);
diff(diff(diff(B(r), r), r), r)+diff(B(r), r)
with(PDEtools, casesplit, declare); with(DEtools, gensys):declare(b(r), prime = r);
[casesplit, declare]
b(r)*`will now be displayed as`*b
`derivatives with respect to`*r*`of functions of one variable will now be displayed with '`
eq32r;
latex(eq32r);
{\frac {{\rm d}^{3}}{{\rm d}{r}^{3}}}B \left( r \right) +{\frac
{\rm d}{{\rm d}r}}B \left( r \right)
#instead of {\frac {{\rm d}^{3}}{{\rm d}{r}^{3}}}B I want to have B''' in my latex file.
Download convert-latex.mw
Hi everybody
I have a differential equation where derivatives (for example d/dr) have been displayed by prime notation.
I want to convert this equation latex format by keeping the prime notation not d/dr.
I would appreciate it if anyone could help me.
I have attached a sample code.
Hadi
I'm having problems trying to plot a discrete plot for a Poisson Distribution CDF.  I followed a model found elsewhere that someone had used to do a discrete plot of a sum.  The OP, in that case, was looking to plot a partial sum of:
sum(1/(n^3*sin^2(n)),n=1..400);
The solution that was suggested to the OP was the following:
with(DynamicSystems):
f[N1_]=sum[1/(n^3*sin^2[n]), {n,1,N1}];
DiscretePlot[f[x], {x,0,400},PlotRange->All];
Using that solution as a guide, I tried this:
lambda := 15.4;
f[N1_] = sum[exp(-lambda)*lambda^n/n!, {0, N1, n}];
DiscretePlot[f[x], {0, 50, x}, PlotRange -> All];
In the attached image, you can see the output from my attempt.
I am completely flummoxed. Any suggestions would be greatly appreciated.
Dear Maple Expeets, In the attached Maple file, I have three procedures that are run smoothly. I am trying to compare outputs from each procedure to see which one if larger than the others. For changes on two parameters (alpha and delta), I used implicitplot and inequal commands to identify each region by a specific color. But the outcome is not reasonable. Would you please help with this? Thanks in advance!
NULLNULL
with(plots)
c := 1; cr := 0.3e-1*c; u := 1; sExp := 0.6e-1*c; s := .65*c; v := 3*c
FirmModelPP := proc (alpha, delta) local p0, xi0, q0, Firmpf0, G0, Recpf0, Unsold0, Environ0, SoldPre0; option remember; xi0 := 1; p0 := min(s+sqrt((v-s)*(c-s)), delta*v+sExp); q0 := u*(v-p0)/(v-s); f(N) := 1/u; F(N) := N/u; G0 := int(F(N), N = 0 .. q0); Firmpf0 := (p0-c)*q0-(p0-s)*G0; Recpf0 := (sExp-cr)*xi0*q0; Environ0 := q0+G0; Unsold0 := G0; SoldPre0 := 0; return p0, q0, Firmpf0, Recpf0, Environ0, Unsold0, SoldPre0 end proc
FirmModelFC := proc (alpha, beta, delta) local p00, xi00, q00, Firmpf00, G00, Recpf00, Unsold00, Environ00, pr00, SoldPre00; option remember; xi00 := 1; p00 := s+sqrt((v-s)*(c-s)); if p00 < delta*v+sExp then q00 := u*(v-p00)/(v-s); f(N) := 1/u; F(N) := N/u; G00 := int(F(N), N = 0 .. q00); Firmpf00 := (p00-c)*q00-(p00-s)*G00; Recpf00 := `&xi;00*q00*`(sExp-cr); Unsold00 := G00; Environ00 := q00+Unsold00 else q00 := alpha*u*(v-p00)/(v-s); f(N) := 1/u; F(N) := N/u; G00 := int(F(N), N = 0 .. q00/alpha); pr00 := p00-delta*v; Firmpf00 := (p00-c)*q00-alpha*(p00-s)*G00; Recpf00 := (sExp-cr)*xi00*q00+(beta*xi00*q00-(1/2)*beta^2*xi00^2*q00^2/(u*(1-alpha)))*(pr00-sExp); Unsold00 := G00; Environ00 := q00+Unsold00; SoldPre00 := beta*xi00*q00-(1/2)*beta^2*xi00^2*q00^2/(u*(1-alpha)) end if; return p00, q00, Firmpf00, Recpf00, Environ00, Unsold00, SoldPre00 end proc
NULLNULL
FirmModelHmax := proc (alpha, beta, delta) local q, p, pr, FirmpfSiS, F1, G1, G2, G3, RecpfSiS, sol, UnsoldSiS, EnvironSiS, p0, OldSoldPrim, xi, h; option remember; xi := 1; if alpha <= 1/(1+beta*xi) then p := max(`assuming`([solve(u*(psol-c+(psol-delta*v-sExp)*beta*xi)/(beta^2*xi^2*(psol-delta*v-sExp)/(1-alpha)-(beta^2*xi^2/(1-alpha)-(1+beta*xi)^2)*(psol-s)) = alpha*u*(v-psol)/(v-s), psol, useassumptions)], [0 < psol])); q := alpha*u*(v-p)/(v-s); G2 := (1/2)*beta^2*xi^2*q^2/(u*(1-alpha)^2); G3 := (1/2)*q^2*(1+beta*xi)^2/u; h := (p-delta*v-sExp)/(p-delta*v); FirmpfSiS := (p-c)*q+(p-s)*((1-alpha)*G2-G3)+h*(p-delta*v)*(beta*xi*q-(1-alpha)*G2); RecpfSiS := ((1-h)*(p-delta*v)-sExp)*(beta*xi*q-G2)+sExp*xi*q-cr*xi*q; UnsoldSiS := G3-(1-alpha)*G2; EnvironSiS := q+UnsoldSiS; OldSoldPrim := beta*xi*q-(1-alpha)*G2 else p := max(`assuming`([solve(u*(psol-c+(psol-delta*v-sExp)*beta*xi)/((psol-s)/u+beta^2*xi^2*(psol-delta*v-sExp)/(1-alpha)) = alpha*u*(v-psol)/(v-s), psol, useassumptions)], [0 < psol])); q := alpha*u*(v-p)/(v-s); F1 := beta*xi*q/(u*(1-alpha)); G1 := (1/2)*q^2/(u*alpha^2); G2 := (1/2)*beta^2*xi^2*q^2/(u*(1-alpha)^2); G3 := (1/2)*q^2*(1+beta*xi)^2/u; h := (p-delta*v-sExp)/(p-delta*v); FirmpfSiS := (p-c)*q-alpha*(p-s)*G1+h*(p-delta*v)*(beta*xi*q-(1-alpha)*G2); RecpfSiS := ((1-h)*(p-delta*v)-sExp)*(beta*xi*q-G2)+sExp*xi*q-cr*xi*q; UnsoldSiS := alpha*G1; EnvironSiS := q+UnsoldSiS; OldSoldPrim := beta*xi*q-(1-alpha)*G2 end if; return p, q, FirmpfSiS, RecpfSiS, EnvironSiS, h, UnsoldSiS, OldSoldPrim, xi end proc
NULLNULL
FirmModelH := proc (alpha, beta, delta, h) local q, p, pr, FirmpfSiS, F1, G1, G2, G3, RecpfSiS, sol, UnsoldSiS, EnvironSiS, p0, OldSoldPrim, xi; option remember; xi := 1; if alpha <= 1/(1+beta*xi) then p := max(`assuming`([solve(u*(psol-c+h*(psol-delta*v)*beta*xi)/(beta^2*xi^2*h*(psol-delta*v)/(1-alpha)-(beta^2*xi^2/(1-alpha)-(1+beta*xi)^2)*(psol-s)) = alpha*u*(v-psol)/(v-s), psol, useassumptions)], [0 < psol])); q := alpha*u*(v-p)/(v-s); G2 := (1/2)*beta^2*xi^2*q^2/(u*(1-alpha)^2); G3 := (1/2)*q^2*(1+beta*xi)^2/u; FirmpfSiS := (p-c)*q+(p-s)*((1-alpha)*G2-G3)+h*(p-delta*v)*(beta*xi*q-(1-alpha)*G2); RecpfSiS := ((1-h)*(p-delta*v)-sExp)*(beta*xi*q-G2)+sExp*xi*q-cr*xi*q; UnsoldSiS := G3-(1-alpha)*G2; EnvironSiS := q+UnsoldSiS; OldSoldPrim := beta*xi*q-(1-alpha)*G2 else p := max(`assuming`([solve(u*(psol-c+h*(psol-delta*v)*beta*xi)/((psol-s)/u+beta^2*xi^2*h*(psol-delta*v)/(1-alpha)) = alpha*u*(v-psol)/(v-s), psol, useassumptions)], [0 < psol])); q := alpha*u*(v-p)/(v-s); F1 := beta*xi*q/(u*(1-alpha)); G1 := (1/2)*q^2/(u*alpha^2); G2 := (1/2)*beta^2*xi^2*q^2/(u*(1-alpha)^2); G3 := (1/2)*q^2*(1+beta*xi)^2/u; FirmpfSiS := (p-c)*q-alpha*(p-s)*G1+h*(p-delta*v)*(beta*xi*q-(1-alpha)*G2); RecpfSiS := ((1-h)*(p-delta*v)-sExp)*(beta*xi*q-G2)+sExp*xi*q-cr*xi*q; UnsoldSiS := alpha*G1; EnvironSiS := q+UnsoldSiS; OldSoldPrim := beta*xi*q-(1-alpha)*G2 end if; return p, q, FirmpfSiS, RecpfSiS, EnvironSiS, h, UnsoldSiS, OldSoldPrim, xi end proc
diffr1 := proc (alpha, delta) if not [alpha, delta]::(list(numeric)) then return ('procname')(args) end if; FirmModelPP(alpha, delta)[3]-FirmModelHmax(alpha, .2, delta)[3] end proc
diffr2 := proc (alpha, delta) if not [alpha, delta]::(list(numeric)) then return ('procname')(args) end if; FirmModelFC(alpha, delta)[3]-FirmModelHmax(alpha, .2, delta)[3] end proc
diffr3 := proc (alpha, delta) if not [alpha, delta]::(list(numeric)) then return ('procname')(args) end if; FirmModelFC(alpha, delta)[3]-FirmModelPP(alpha, delta)[3] end proc
P1 := implicitplot(diffr1, 0 .. 1, 0 .. 1, color = gray, thickness = 1)
P2 := implicitplot(diffr2, 0 .. 1, 0 .. 1, color = black, thickness = 1)
P3 := implicitplot(diffr3, 0 .. 1, 0 .. 1, color = pink, thickness = 1)
P7 := inequal({diffr1(alpha, delta) > 0, diffr2(alpha, delta) > 0, diffr3(alpha, delta) > 0}, alpha = 0 .. 1, delta = 0 .. 1, color = "LightBlue")
P8 := inequal({diffr1(alpha, delta) > 0, diffr2(alpha, delta) > 0, diffr3(alpha, delta) < 0}, alpha = 0 .. 1, delta = 0 .. 1, color = yellow)``
P9 := inequal({diffr1(alpha, delta) > 0, diffr3(alpha, delta) > 0, diffr2(alpha, delta) < 0}, alpha = 0 .. 1, delta = 0 .. 1, color = cyan)
P10 := inequal({diffr1(alpha, delta) > 0, diffr2(alpha, delta) < 0, diffr3(alpha, delta) < 0}, alpha = 0 .. 1, delta = 0 .. 1, color = grey)
P11 := inequal({diffr2(alpha, delta) > 0, diffr3(alpha, delta) > 0, diffr1(alpha, delta) < 0}, alpha = 0 .. 1, delta = 0 .. 1, color = green)
P12 := inequal({diffr2(alpha, delta) > 0, diffr1(alpha, delta) < 0, diffr3(alpha, delta) < 0}, alpha = 0 .. 1, delta = 0 .. 1, color = red)
P13 := inequal({diffr3(alpha, delta) > 0, diffr1(alpha, delta) < 0, diffr2(alpha, delta) < 0}, alpha = 0 .. 1, delta = 0 .. 1, color = pink)
P14 := inequal({diffr1(alpha, delta) < 0, diffr2(alpha, delta) < 0, diffr3(alpha, delta) < 0}, alpha = 0 .. 1, delta = 0 .. 1, color = coral)
display(P7, P8, P9, P10, P11, P12, P13, P14, textplot([.2, .9, "some text"]), scaling = constrained, view = [0 .. 1, 0 .. 1], labels = [alpha, delta])
Download Compare_three_regions.mw
the final plot does not look reasonable. Would you please guide me?
This worksheet contains an unnamed theorem on page 202 of David Wells's book The Penguin Dictionary of Curious and Interesting Geometry.
Somehow I have uploaded both its contents and (a) link(s) to it.
What Maple code can animate and display, in turn, each of the portrayed pursuit paths?
Pursuit_problem.mw
Consider a target point T which moves at constant speed along a straight line, and a moving point P which at all times moves directly towards T. If P starts anywhere on the outermost ellipse, and T starts from a focus of the outer ellipse, then P always captures T at the same point, the centre of the ellipse.
The concentric ellipses, whose shape depends on the relative velocities of T and P, are isochrones, and the curves of pursuit are their isoclinal trajectories
Download Pursuit_problem
Please how can I export a matrix from maple to matlab
A := Matrix(5, 5, {(1, 1) = -.841752461600000, (1, 2) = -71.7787800100000, (1, 3) = 0.701877157500000e-2, (1, 4) = 0.672783592200000e-2, (1, 5) = 0.646005759700000e-2, (2, 1) = -.877557898000000, (2, 2) = -100., (2, 3) = 0.701617590500000e-2, (2, 4) = 0.672545092900000e-2, (2, 5) = 0.645785863600000e-2, (3, 1) = -1.00426692300000, (3, 2) = -.677765381900000, (3, 3) = 0.700840041000000e-2, (3, 4) = 0.671830608400000e-2, (3, 5) = 0.645127072200000e-2, (4, 1) = -1.31039754100000, (4, 2) = -.820833777300000, (4, 3) = 0.699547946600000e-2, (4, 4) = 0.670643167900000e-2, (4, 5) = 0.644032067900000e-2, (5, 1) = -2.17574621300000, (5, 2) = -1.15959068100000, (5, 3) = 0.697746998200000e-2, (5, 4) = 0.668987785500000e-2, (5, 5) = 0.642505292600000e-2})
I tried
ExportMatrix(matlabData, A, target=MATLAB,format=rectangular,mode=ascii);
 but didn't work.
Digits:=15;
15
A:=Matrix(4,4,[[-1,2,0,0],[2,-1,2,0],[0,2,-1,2],[0,0,1,-1]],datatype=float[8],storage=sparse);
Matrix(4, 4, {(1, 1) = -1.0000000000000000, (1, 2) = 2.0000000000000000, (1, 3) = 0., (1, 4) = 0., (2, 1) = 2.0000000000000000, (2, 2) = -1.0000000000000000, (2, 3) = 2.0000000000000000, (2, 4) = 0., (3, 1) = 0., (3, 2) = 2.0000000000000000, (3, 3) = -1.0000000000000000, (3, 4) = 2.0000000000000000, (4, 1) = 0., (4, 2) = 0., (4, 3) = 1.0000000000000000, (4, 4) = -1.0000000000000000})
b:=Vector(4,[1,0.,0,0],datatype=float[8]):
sol:=LinearAlgebra:-LinearSolve(A,b,method=SparseDirectMKL);
Error, invalid input: LinearAlgebra:-LinearSolve expects value for keyword parameter method to be of type identical(none,SparseLU,SparseDirect,SparseDirectMKL,SparseIterative,LU,QR,solve,hybrid,Cholesky,subs,modular), but received SparseDirectMKL
Download buglinearsolve.mw
I was pleased to see the description of SparseDirectMKL, but it is not implemented properly yet. It is a step in the right direction, so please make this available in the near future
Hello everyone. after runnig this maple code i get the error :" Error, (in Optimization:-NLPSolve) non-numeric result encountered" . How can fix it?
Digits := 20;
with(LinearAlgebra);
with(linalg);
with(Optimization);
with(Student[Calculus1]);
NULL;
n := 2;
z := 1;
a := 0;
b := 1;
m := 2;
NULL;
PS1 := (j, t) -> piecewise(j = 0, 1, t^(j + s[j]));
PI1 := (j, t) -> piecewise(j = 0, 1, t^(j + q[j]));
PH1 := (j, t) -> piecewise(j = 0, 1, t^(j + h[j]));
PL1 := (j, t) -> piecewise(j = 0, 1, t^(j + l[j]));
NULL;
PS := t -> local j; Transpose(convert([seq(PS1(j, t), j = 0 .. n - 1)], Matrix));
P_I := t -> local j; Transpose(convert([seq(PI1(j, t), j = 0 .. n - 1)], Matrix));
PH := t -> local j; Transpose(convert([seq(PH1(j, t), j = 0 .. n - 1)], Matrix));
PL := t -> local j; Transpose(convert([seq(PL1(j, t), j = 0 .. n - 1)], Matrix));
Warning, (in PS) `j` is implicitly declared local
Warning, (in P_I) `j` is implicitly declared local
Warning, (in PH) `j` is implicitly declared local
Warning, (in PL) `j` is implicitly declared local
NULL;
NULL;
B1 := (i, j) -> piecewise(i = j and j = 1, 1, i = 1 and 1 < j, 0, i = j and j = 2, 1, i = 2 and 2 < j, 0, j <= i, (i + j - 2)!/(2^(j - 1)*(j - 1)!*(i - j)!));
NULL;
B := t -> Matrix(n, B1);
DS1 := (m, k) -> piecewise(m <= 1, 0, m = k, GAMMA(k + s[k - 1])/GAMMA(k + s[k - 1] - z));
DI1 := (m, k) -> piecewise(m <= 1, 0, m = k, GAMMA(k + i[k - 1])/GAMMA(k + i[k - 1] - z));
DH1 := (m, k) -> piecewise(m <= 1, 0, m = k, GAMMA(k + h[k - 1])/GAMMA(k + h[k - 1] - z));
DL1 := (m, k) -> piecewise(m <= 1, 0, m = k, GAMMA(k + l[k - 1])/GAMMA(k + l[k - 1] - z));
DS := t -> t^(-z)*Matrix(n, DS1);
DI := t -> t^(-z)*Matrix(n, DI1);
DH := t -> t^(-z)*Matrix(n, DH1);
DL := t -> t^(-z)*Matrix(n, DL1);
NULL;
NULL;
cs := i -> ps[i];
ci := j -> p[j];
ch := j -> ph[j];
cl := i -> pl[i];
CS := convert([seq(cs(i), i = 1 .. n)], Matrix);
CI := convert([seq(ci(i), i = 1 .. n)], Matrix);
CH := convert([seq(ch(i), i = 1 .. n)], Matrix);
CL := convert([seq(cl(i), i = 1 .. n)], Matrix);
NULL;
NULL;
NULL;
S := unapply(simplify(Multiply(Multiply(CS, B(t)), PS(t))[1, 1]), [t]);
I1 := unapply(simplify(Multiply(Multiply(CI, B(t)), P_I(t))[1, 1]), [t]);
H := unapply(simplify(Multiply(Multiply(CH, B(t)), PH(t))[1, 1]), [t]);
L := unapply(simplify(Multiply(Multiply(CL, B(t)), PL(t))[1, 1]), [t]);
DSS := unapply(simplify(Multiply(Multiply(Multiply(CS, B(t)), DS(t)), PS(t))[1, 1]), [t]);
DII := unapply(simplify(Multiply(Multiply(Multiply(CI, B(t)), DI(t)), P_I(t))[1, 1]), [t]);
DHH := unapply(simplify(Multiply(Multiply(Multiply(CH, B(t)), DH(t)), PH(t))[1, 1]), [t]);
DLL := unapply(simplify(Multiply(Multiply(Multiply(CL, B(t)), DL(t)), PL(t))[1, 1]), [t]);
NULL;
NULL;
RS := unapply(evalf(DSS(t) + (-0.0043217^z + 0.5944^z*Multiply(S(t), I1(t)) + (0.025^z + 0.0008^z)*S(t))), [t]);
RI := unapply(evalf(DII(t) + (-0.5944^z*Multiply(S(t), I1(t)) - 0.0056^z*Multiply(H(t), I1(t)) - 0.027^z*L(t) + (((0.025^z + 0.0008^z) + 0.025^z) + 0.5^z)*I1(t))), [t]);
RH := unapply(evalf(DHH(t) + (-0.535^z + 0.0056^z*Multiply(H(t), I1(t)) - 0.5^z*I1(t) + (0.025^z + 0.0008^z)*H(t))), [t]);
RL := unapply(evalf(DLL(t) + (-0.025^z*I1(t) + (0.025^z + 0.0008^z + 0.027^z)*L(t))), [t]);
R := unapply(evalf(RS(t)^2 + RI(t)^2 + RH(t)^2 + RL(t)^2), [t]);
NULL;
p1 := x -> (x^2 - 1)^m;
dmp1 := x -> diff(p1(x), x $ m);
NULL;
p := x -> dmp1(x)/(2^m*m!);
eq := p(x) = 0;
r := solve(eq, x);
NULL;
ss := Vector[row](m);
w := Vector[row](m);
for i to m do
    w[i] := 2/((-r[i]^2 + 1)*D(p)(r[i])^2);
    ss[i] := w[i]*evalf(R((b - a)/2*r[i] + (b + a)/2));
SS := add(ss);
Lambda := evalf((b - a)/2*SS);
C1 := S(0) - 43994 = 0;
C2 := I1(0) - 0.1 = 0;
C3 := H(0) = 0;
C4 := L(0) - 1 = 0;
NULL;
NLP := NLPSolve(Lambda, {C1, C2, C3, C4});
It might be really trivial, but I am struggling in the algebraic manipulation of the argument of the exponential function. As an example, I want to substitute
I*T[0]*(omega1-2*omega2) = I*omega2*T[0]-I*si*T[2]
in the expression of
exp(-I*T[0]*(omega1-2*omega2)).
However, I am only able to do so by subs command and also by exactly copying the argument in the following manner.
subs(-I*T[0]*(omega1-2*omega2) = I*omega2*T[0]-I*si*T[2], exp(-I*T[0]*(omega1-2*omega2)))
The issue is I have expressions like this all over in the main problem, and I have to copy-paste such expressions for the substitution. So I am wondering if there is a more efficient way to tackle this problem.
Thanks in Advance,
I am trying to determine constraints for a,b,c that are real, such that the eigenvalues of my system matrix have all negative real part.
assume(a,'real');
assume(b,'real');
assume(c,'real');
A:=<c,0,0;0,-1,a;0,b,-1>
elist:=Eigenvalues(A):
map(lprint,elist):
c
-1+(b*a)^(1/2)
-1-(b*a)^(1/2)
If all eigenvalues real part must be less than 0, then clearly:
c < 0
ab < 1
However, when trying to verify these results with "is" and "coulditbe" Maple gives me blatantly false results:
additionally(c<0)
additionally(a*b<1)
is(Re(-1+sqrt(a*b))<0)
coulditbe(Re(-1+sqrt(a*b))>0)
The real part of -1+sqrt(a*b) can never be greater than 0 under the assumption that ab<1. So why is Maple giving me nonsense? Am I using the commands incorrectly?
Hi, I am completely new to Maple and I keep getting this message:
Error, invalid input: rhs received 19715.18184, which is not valid for its 1st argument, expr
my code is:
sqq:=Vector(n):
for i from 1 by 1 to n do
pom:=eval(sigma[qq],[K=0.5,Fred=0,Phi[a]=0.8,Phi[p]=0.2,camax=300000,Kmin=0.5,co=11230,c11=6120,c12=12710,c21=14.17,c22=6.61,c13=9270,c23=16.16,c14=9270,c24=16.16,g=0.745430443,R=0.00652,H=0.00081,l=2,P=Pload[i],lambda[Q]=lQres1[i], lambda[Z]=lZres1[i]]):
sqq[i]:=rhs(pom):
I am trying to get a vector sqq solving the equation sigma[qq] using the constants and vectors written there. Can anybody help me please?
While Maple itself is a pleasure to work with, the multitude and persistance of bugs in the Units package doesn't stop to surprise.
Especially as the same bugs come up again and again, after having been fixed i older versions.
In general, working with units and 0 is a pain in the ass. And this one doesn't even need a unit to compare with.
This one works in Maple 2022 - does not work in Maple 2023.
with(Units[Simple]);
min(0, 0);
Im trying to solve a system of 4 non-linear equations using the fsolve function. When i compute the command i seemingly dont get an answer to the system. Maple only prompts the command itself, can any of you locate my mistake or give any input on how to solve the issue.
My code is as follows:
r__C := 400;
r__D := 600;
r__E := 800;
a := 100;
p := 0.7;
q := Pi*a^2*p;
h__eq := 0.9*h__1*(E__1/E__2)^(1/3);
R__Ceq := sqrt(h__eq^2 + r__C^2);
R__C := sqrt(r__C^2 + h__1);
R__Deq := sqrt(h__eq^2 + r__D^2);
R__D := sqrt(r__D^2 + h__1);
R__Eeq := sqrt(h__eq^2 + r__E^2);
R__E := sqrt(r__C^2 + h__1);
eqC := 174.5*10^(-3) = q*(1 + nu)/(2*Pi*E__2*R__Ceq)*(2*(1 - nu) + h__eq^2/R__Ceq^2) + q*(1 + nu)/(2*Pi*E__1*r__C)*(2*(1 - nu) + 0) - q*(1 + nu)/(2*Pi*E__1*R__C)*(2*(1 - nu) + h__1^2/R__C^2);
eqD := 151.7*10^(-3) = q*(1 + nu)/(2*Pi*E__2*R__Deq)*(2*(1 - nu) + h__eq^2/R__Deq^2) + q*(1 + nu)/(2*Pi*E__1*r__D)*(2*(1 - nu) + 0) - q*(1 + nu)/(2*Pi*E__1*R__D)*(2*(1 - nu) + h__1^2/R__D^2);
eqE := 133.2*10^(-3) = q*(1 + nu)/(2*Pi*E__2*R__Eeq)*(2*(1 - nu) + h__eq^2/R__Eeq^2) + q*(1 + nu)/(2*Pi*E__1*r__E)*(2*(1 - nu) + 0) - q*(1 + nu)/(2*Pi*E__1*R__E)*(2*(1 - nu) + h__1^2/R__E^2);
eqA := 401.7*10^(-3) = 2*q*a*(-nu^2 + 1)*(sqrt(1 + (h__eq/a)^2) - h__eq/a)/E__2 + 2*(-nu^2 + 1)*q*a/E__1 - 2*q*a*(-nu^2 + 1)*(sqrt(1 + (h__1/a)^2) - h__1/a)/E__1;
fsolve({eqA, eqC, eqD, eqE}, {E__1, E__2, h__1, nu}, {E__1 = 0 .. 5000, E__2 = 0 .. 5000, h__1 = 0 .. 1000, nu = 0 .. 0.5});
Picture for refference:
I am using A:=LinearAlgebra:-RandomMatrix(10,10,generator=-10..10) to generate a random matrix. How may I specify that every row of A has at least three non-zero entries?
First 207 208 209 210 211 212 213 Last Page 209 of 2458
