Good day!
I have been wrestling with what appears to be a simple problem, but with no success and so, I thought I would reach out for support.
Consider a two-dimensional strip of any given width, x, and depth, y.
I wish to maximize the quantity of strips that can fit inside a larger two-dimensional surface of any given width, X, and depth, Y. Overhanging is not permitted and all smaller strips must lie within the interior of the larger surface.
I'm looking for a solution method that can calculate the best configuration necessary to fit the maximum number of smaller strips in the interior of the larger rectangle. Can someone suggest a way (if possible) to solve for this?
Thanks for reading.
diff(f(x), x) = a-a/((1+a*x)*(1/(1+a*x))^a)-a*f(x) where a is a constant and an initial condition f(0)= b is known Thank you.
How do I isolate the variable ng in the following expression:
rho := `ρg`*ng + `ρp`*np + `ρw`*nw;
B := np/Kp + nw/Kw + ng/Kg;
C := (B/rho)^(1/2);
As you can see, I am running the isolate command, but it is not including the variable C, or it returns the wrong result.
isolate(((np/Kp + nw/Kw + ng/Kg)/(`ρg`*ng + `ρp`*np + `ρw`*nw))^(1/2), ng);
                               ( Kp nw + Kw np) Kg
                   ng = -     -----------------
                                          Kw Kp
isolate(C=((np/Kp + nw/Kw + ng/Kg)/(`ρg`*ng + `ρp`*np + `ρw`*nw))^(1/2), ng);
                             0 = 0
I think some form of simplify() would do but I am not sure how.
See the following script for more details:
#Define the assumptions ex-ante (variances as real and positive, correlations in between -1 and +1 and so on...) - or Maple wouldn't know
assume(`#msub(mi("mu",fontstyle = "normal"),mi("1"))`::real, `#msub(mi("mu",fontstyle = "normal"),mi("2"))`::real, `#msub(mi("mu",fontstyle = "normal"),mi("3"))`::real, `#msub(mi("lambda",fontstyle = "normal"),mi("1"))`::real, `#msub(mi("lambda",fontstyle = "normal"),mi("2"))`::real, `#msub(mi("lambda",fontstyle = "normal"),mi("3"))`::real, `#msub(mi("sigma",fontstyle = "normal"),mi("epsilon1"))`::real, `#msub(mi("sigma",fontstyle = "normal"),mi("epsilon2"))`::real, (`#msub(mi("nu",fontstyle = "normal"),mi("0"))`[1])::real, (`#msub(mi("nu",fontstyle = "normal"),mi("0"))`[2])::real, (`#msub(mi("rho",fontstyle = "normal"),mi("u"))`[1, 2])::real, (`#msub(mi("rho",fontstyle = "normal"),mi("u"))`[1, 3])::real, (`#msub(mi("rho",fontstyle = "normal"),mi("u"))`[2, 3])::real, (`#msub(mi("rho",fontstyle = "normal"),mi("v"))`[1, 2])::real, (`#msub(mi("sigma",fontstyle = "normal"),mi("u"))`[1])::real, (`#msub(mi("sigma",fontstyle = "normal"),mi("u"))`[2])::real, (`#msub(mi("sigma",fontstyle = "normal"),mi("u"))`[3])::real, (`#msub(mi("sigma",fontstyle = "normal"),mi("v"))`[1])::real, (`#msub(mi("sigma",fontstyle = "normal"),mi("v"))`[2])::real)
assume(0 <= `#msub(mi("mu",fontstyle = "normal"),mi("1"))`, 0 <= `#msub(mi("mu",fontstyle = "normal"),mi("2"))`, 0 <= `#msub(mi("mu",fontstyle = "normal"),mi("3"))`, 0 <= `#msub(mi("lambda",fontstyle = "normal"),mi("1"))`, 0 <= `#msub(mi("lambda",fontstyle = "normal"),mi("2"))`, 0 <= `#msub(mi("lambda",fontstyle = "normal"),mi("3"))`, 0 <= `#msub(mi("sigma",fontstyle = "normal"),mi("epsilon1"))`, 0 <= `#msub(mi("sigma",fontstyle = "normal"),mi("epsilon2"))`, 0 <= `#msub(mi("nu",fontstyle = "normal"),mi("0"))`[1], 0 <= `#msub(mi("nu",fontstyle = "normal"),mi("0"))`[2], -1 <= `#msub(mi("rho",fontstyle = "normal"),mi("u"))`[1, 2] and `#msub(mi("rho",fontstyle = "normal"),mi("u"))`[1, 2] <= 1, -1 <= `#msub(mi("rho",fontstyle = "normal"),mi("u"))`[1, 3] and `#msub(mi("rho",fontstyle = "normal"),mi("u"))`[1, 3] <= 1, -1 <= `#msub(mi("rho",fontstyle = "normal"),mi("u"))`[2, 3] and `#msub(mi("rho",fontstyle = "normal"),mi("u"))`[2, 3] <= 1, -1 <= `#msub(mi("rho",fontstyle = "normal"),mi("v"))`[1, 2] and `#msub(mi("rho",fontstyle = "normal"),mi("v"))`[1, 2] <= 1, 0 <= `#msub(mi("sigma",fontstyle = "normal"),mi("u"))`[1], 0 <= `#msub(mi("sigma",fontstyle = "normal"),mi("u"))`[2], 0 <= `#msub(mi("sigma",fontstyle = "normal"),mi("u"))`[3], 0 <= `#msub(mi("sigma",fontstyle = "normal"),mi("v"))`[1], 0 <= `#msub(mi("sigma",fontstyle = "normal"),mi("v"))`[2])
t__1 := (`&sigma;__v`[2]^2*(`&rho;__v`[1, 2]^2-1)-`&sigma;__&epsilon;2`^2)*`&sigma;__v`[1]^2/((`&sigma;__v`[2]^2*(`&rho;__v`[1, 2]^2-1)-`&sigma;__&epsilon;2`^2)*`&sigma;__v`[1]^2-`&sigma;__&epsilon;1`^2*(`&sigma;__&epsilon;2`^2+`&sigma;__v`[2]^2))
t__2 := -`&sigma;__v`[1]*`&rho;__v`[1, 2]*`&sigma;__v`[2]*`&sigma;__&epsilon;1`^2/((`&sigma;__v`[2]^2*(`&rho;__v`[1, 2]^2-1)-`&sigma;__&epsilon;2`^2)*`&sigma;__v`[1]^2-`&sigma;__&epsilon;1`^2*(`&sigma;__&epsilon;2`^2+`&sigma;__v`[2]^2))
t__3 := (`&sigma;__v`[1]*`&rho;__v`[1, 2]*`&sigma;__v`[2]*`&sigma;__&epsilon;1`^2*`&nu;__0`[2]-`&nu;__0`[1]*`&sigma;__&epsilon;1`^2*(`&sigma;__&epsilon;2`^2+`&sigma;__v`[2]^2))/((`&sigma;__v`[2]^2*(`&rho;__v`[1, 2]^2-1)-`&sigma;__&epsilon;2`^2)*`&sigma;__v`[1]^2-`&sigma;__&epsilon;1`^2*(`&sigma;__&epsilon;2`^2+`&sigma;__v`[2]^2))
See for example that they share the same denominator...
# I want Maple to automatically/smartly choose the most compact way...e.g., (i) t2=t1+... or (ii) t2=t3*... (i) is equivalent to (ii) but I want Maple to pick (ii) if more compact than (i)
# I have 9 expressions like t1,t2,t3 and I want Maple to re-write them as function of each other smartly
Download rearrangingterms.mw
It must be something similar to this https://www.mapleprimes.com/maplesoftblog/201455-Rearranging-The-expression-Of-Equations, but my case is slighty different.
I was not able to apply ICs (initial conditions) using the advanced parameter settings of the flexible beam component in the attached file. My intention is to have a beam moving at t=0s (velocity of end frame <> 0). The computed initial values for the elastic coordinates (see output console for the disabled component below encircled in red) indicate that the flexible beam has no kinetic energy at t=0s.
A workaround is to attach a rigid body to the end frame and apply the ICs to the body. (Inertia and mass of the rigid body can be set to zero.)
How to apply initial conditions to the disabled component so that it moves as the workaround?
Imposing_IC_v.msim
In certain tasks, I need to find all accurate positive (not just nonnegative) roots that exist of some multivariate polynomials like:
nsd := 16*a*b*c*(9 + a^2 + b^2 + c^2)*(b*c + a*(b + c) + 3*(a + b + c)) - (3 + a + b + c)^2*(a*b + 3*c)*(3*b + a*c)*(3*a + b*c): # assume((a, b, c) >~ 0);
According to fsolve/details, for one general equation, the fsolve command only computes "a single real root", so it is inadequate to tackle this question. But if I use the solve command with floating-point values, the computation cannot finish in ten minutes instead! (Maybe a longer time will suffice, yet this is rather unacceptable.)
"Digits+=Digits:"
#assume((a, b, c) >~ 0);
nsd := 16*a*b*c*(a^2 + b^2 + c^2 + 9)*(a*(b + c) + 3*(a + b + c) + b*c) - (a + b + c + 3)^2*(a*b + 3*c)*(a*c + 3*b)*(b*c + 3*a):
fsolve({`~`[`>`](a, b, c, ` $`, 0), nsd = 0}, fulldigits)
Error, (in fsolve) expecting an equation or set or list of equations, but received inequalities {16*a*b*c*(a^2+b^2+c^2+9)*(a*(b+c)+3*a+3*b+3*c+b*c)-(a+b+c+3)^2*(a*b+3*c)*(a*c+3*b)*(b*c+3*a) = 0, 0 < a, 0 < b, 0 < c}
fsolve([`$`(nsd = 0, 3)], fulldigits, {`~`[`=`](a, b, c, ` $`, 0 .. infinity)}, avoid = {{a = 0}, {b = 0}, {c = 0}})eval(nsd, %)
{a = 3.0000000005817604971, b = 3.0000000004676996798, c = 3.0000000004610312655}
timelimit(0.6e3, RealDomain[solve]([`~`[`>`](a, b, c, ` $`, 0), nsd = 0.], allsolutions))
Error, (in gcd/gcdchrem1) time expired
timelimit(0.6e3, `assuming`([solve(nsd = 0., useassumptions, allsolutions)], [`~`[`>`](a, b, c, ` $`, 0)]))
Error, (in modp1/DistDeg) time expired
""(* However, there are (at least) five positive solutions to 'nsd = 0'. *)" map2(eval,nsd,[{a=1,b=1,c=1},{a=3,b=3,c=3},{a=3,b=3,c=9},{a=3,b=9,c=3},{a=9,b=3,c=3}])"
[0, 0, 0, 0, 0]
time()
11127.031
Download solve_numerically.mws
Is there any workaround to obtain those (finitely many) positive solutions completely?
Dear all:
    I am using maple2022 to learn Fourier Series package - Maple Application Center (maplesoft.com) . the author provide the package here:
cgi.math.muni.cz/kriz/xsrot/fourierseries/  I use the lastest version: Package FourierTrigSeries version 0.41
there is no .mla so I do not know how to use this package.(the package is a little old).
please enlight me if you know how to install this old package.
but the author provide the code inside fourierseries-structs.mws
here is what I do:
1. first delete some lines which is not useful(which I shared in the attachment as FourierTrigSeries.mw)
and remain everything inside module and save as .mw (maybe the orginal .mws is a old version of maple files)
2. export as .FourierTrigSeries.mpl (also attached)
3. use the examples.mws (the code also from author)
I got error as:
the package can be recognized, but the first line wil give some error which is out of my knowledge field.
everything mentioned above is here, including the original author's files.
fouriertrigseries_0_41en_mapleprime.zip
Could you please have a look. your idea is valuable to me.
PS: this package is not available The Fourier Series package for Maple - Maple Application Center (maplesoft.com) whenI try to learn  Teaching Fourier Series with Maple II
if anyone keep it before, please share it.
thanks for your help.
rockyicer
with(geometry):
_EnvHorizontalName = 'x':  _EnvVerticalName = 'y':
point(A, -1, 9):
point(B, -5, 0):
point(C, 6, 0):
triangle(ABC,[A,B,C]):
midpoint(M1,A,C): midpoint(M2,B,C):midpoint(M3,A,B):
rotation(J, C, Pi/2, 'counterclockwise', M1):triangle(AJC,[A,J,C]):
rotation(Ii, C, Pi/2, 'counterclockwise', M2):triangle(BIC,[B,Ii,C]):
rotation(K, A, Pi/2, 'counterclockwise', M3):triangle(AKB,[A,K,B]):
midpoint(O1,K,J): coordinates(O1):
midpoint(O2,A,Ii): coordinates(O2):
poly:=[coordinates(A),coordinates(J),coordinates(Ii),coordinates(K)]:
display(draw([A(color = black, symbol = solidcircle, symbolsize = 12),
B(color = black, symbol = solidcircle, symbolsize = 12),
C(color = black, symbol = solidcircle, symbolsize = 12),
J(color = black, symbol = solidcircle, symbolsize = 12),
polygonplot(poly,color = "DarkGreen", transparency = 0.5),
ABC(color = red ),
BIC(color = green),
AKB(color = grey),
AJC(color =blue)]),
textplot([[coordinates(A)[], "A"],[coordinates(J)[], "J"],[coordinates(Ii)[], "I"],
[coordinates(B)[], "B"], [coordinates(K)[], "K"],
[coordinates(C)[], "C"]],
align = [above, right]),  axes = none);
Error, (in geometry:-draw) the option must be of type equation or name. I don't see how to correct this error/
Hi, I have the equation below and I'm trying to use "collect " to get the coefficient of dudy^2 and dvdx^2. I tried
aa1 := subs({gamma[1] = alpha[3]-alpha[2], gamma[2] = alpha[6]-alpha[5]}, collect(aa, {dudy^2, dvdx^2}))
But is not collecting the coefficient of dvdx^2. Please can someone help?
aa := alpha[1]*(cos(theta(x, y, t))^4*dudx^2+2*cos(theta(x, y, t))^3*dudx*sin(theta(x, y, t))*dvdx+2*cos(theta(x, y, t))^3*dudx*sin(theta(x, y, t))*dudy+2*cos(theta(x, y, t))^2*dudx*sin(theta(x, y, t))^2*dvdy+cos(theta(x, y, t))^2*sin(theta(x, y, t))^2*dvdx^2+2*cos(theta(x, y, t))^2*sin(theta(x, y, t))^2*dvdx*dudy+2*cos(theta(x, y, t))*sin(theta(x, y, t))^3*dvdx*dvdy+cos(theta(x, y, t))^2*sin(theta(x, y, t))^2*dudy^2+2*cos(theta(x, y, t))*sin(theta(x, y, t))^3*dudy*dvdy+sin(theta(x, y, t))^4*dvdy^2)+(alpha[2]+alpha[3]+gamma[2])*(-dudx*cos(theta(x, y, t))*sin(theta(x, y, t))*thetadot-(1/2)*dudx*cos(theta(x, y, t))*sin(theta(x, y, t))*dudy+(1/2)*dudx*cos(theta(x, y, t))*sin(theta(x, y, t))*dvdx+(1/2)*cos(theta(x, y, t))^2*dvdx*thetadot-(1/4)*cos(theta(x, y, t))^2*dvdx^2+(1/2)*cos(theta(x, y, t))^2*dudy*thetadot+(1/4)*cos(theta(x, y, t))^2*dudy^2-(1/2)*sin(theta(x, y, t))^2*dvdx*thetadot+(1/4)*sin(theta(x, y, t))^2*dvdx^2-(1/2)*sin(theta(x, y, t))^2*dudy*thetadot-(1/4)*sin(theta(x, y, t))^2*dudy^2+dvdy*sin(theta(x, y, t))*cos(theta(x, y, t))*thetadot-(1/2)*dvdy*sin(theta(x, y, t))*cos(theta(x, y, t))*dvdx+(1/2)*dvdy*sin(theta(x, y, t))*cos(theta(x, y, t))*dudy)+alpha[4]*(dudx^2+(1/2)*dvdx^2+dvdx*dudy+(1/2)*dudy^2+dvdy^2)+(alpha[5]+alpha[6])*(cos(theta(x, y, t))^2*dudx^2+2*cos(theta(x, y, t))*dudx*((1/2)*dvdx+(1/2)*dudy)*sin(theta(x, y, t))+cos(theta(x, y, t))^2*((1/2)*dvdx+(1/2)*dudy)^2+2*cos(theta(x, y, t))*((1/2)*dvdx+(1/2)*dudy)*dvdy*sin(theta(x, y, t))+sin(theta(x, y, t))^2*((1/2)*dvdx+(1/2)*dudy)^2+sin(theta(x, y, t))^2*dvdy^2)+gamma[1]*(sin(theta(x, y, t))^2*thetadot^2+sin(theta(x, y, t))^2*dudy*thetadot-sin(theta(x, y, t))^2*dvdx*thetadot+(1/4)*sin(theta(x, y, t))^2*dudy^2-(1/2)*sin(theta(x, y, t))^2*dudy*dvdx+(1/4)*sin(theta(x, y, t))^2*dvdx^2+cos(theta(x, y, t))^2*thetadot^2-cos(theta(x, y, t))^2*dvdx*thetadot+cos(theta(x, y, t))^2*dudy*thetadot+(1/4)*cos(theta(x, y, t))^2*dvdx^2-(1/2)*cos(theta(x, y, t))^2*dudy*dvdx+(1/4)*cos(theta(x, y, t))^2*dudy^2)+xi*(cos(theta(x, y, t))^2*dudx+2*cos(theta(x, y, t))*sin(theta(x, y, t))*((1/2)*dvdx+(1/2)*dudy)+sin(theta(x, y, t))^2*dvdy);
hi every body
please How to write these solutions in fraction form
sol := {S[0] = 0., U[0] = 0., V[0] = 0., W[0] = 0., Z[0] = 0., r[0] = 84.85281372}, {S[0] = 13.43136878, U[0] = -1.505103614, V[0] = 3.811200525, W[0] = 25.03669048, Z[0] = -66.61776811, r[0] = 45.45242389}, {S[0] = 19.84202712, U[0] = -182.3505467, V[0] = 0., W[0] = 19.66995891, Z[0] = 0., r[0] = 40.87682398}, {S[0] = -19.84202712, U[0] = 0., V[0] = 19.66995891, W[0] = 0., Z[0] = 182.3505467, r[0] = 40.87682398}, {S[0] = 0., U[0] = 7.778720282, V[0] = 22.80551297, W[0] = 22.80551297, Z[0] = -7.778720282, r[0] = 26.37225141}, {S[0] = 0., U[0] = -7.778720282, V[0] = 22.80551297, W[0] = -22.80551297, Z[0] = -7.778720282, r[0] = 26.37225141}
Download problem1.mw
How to get the series and plot.I got this error.
TL.mw
At the end of 2021, Mathematica added capability for integration:
https://blog.wolfram.com/2021/12/13/new-in-13-symbolic-numeric-computation/
Trying this in Maple, it does not look like it can solve it:
My questions are then, is there a way to get Maple to solve this? Does Maplesoft actively work on solving more integral types and is it likely support for this integral will be added at some point?
In Hansen's book "A table of Series and Products" there is an unsourced listed identity 43.6.1:
S1 := Sum(2^k*tanh(2^k*x), k = 0 .. n - 1) = 2^n*coth(2^n*x) -   coth(x)
It appears to be to be numerically correct, and can be obtained from a second identity
S6:=Sum(2^(-k)*tanh(2^(-k)*x), k = 1 .. n) =- 2^(-n)*coth(2^(-n)*x) + coth(x)
by "summing in reverse order". S6 is also numerically correct.
Starting from S1 and reversing the order, gives
S2 := Sum(2^(n - k - 1)*tanh(2^(n - k - 1)*x), k = 0 .. n - 1) = 2^n*coth(2^n*x) - coth(x)
Then shifting the index gives
 S3 := Sum(2^(-k)*tanh(2^(-k)*x), k = -n + 1 .. 0) =  2^n*coth(2^n*x) - coth(x)
both of which test OK numerically since n>0. Now it begins to get strange.
In S3, let n->-n (highly illegal) to obtain
S4 := Sum(2^(-k)*tanh(2^(-k)*x), k = n + 1 .. 0) = 2^(-n)*coth(2^(-n)*x) - coth(x)
and, surprisingly Maple tests S4 to be correct numerically.
Here's how that happened. The lower limit of the S4 sum exceeds the upper limit, so there are three possible ways to interpret this:
1. In standard mathematical usage, this is usually set to zero by caveat;
2. In a practical sense, one might expect the order of summation to be irrelevant so S4 is the same as
S5:= Sum(2^(-k)*tanh(2^(-k)*x), k = 0 .. n + 1) = 2^(-n)*coth(2^(-n)*x) - coth(x)
but that fails numerically.
3. Maple has a built-in algorithm (see the help page on "Sum") that interprets
Sum(f(k), k = m .. n) = -Sum(f(k), k = n + 1 .. m - 1)
when m exceeds n and that is why S4 works numerically and, when applied to S4 gives the result S6.
So where did Maple's prescription come from, and what is it's justification?
This is from a graph G with vertex set {0,1,2,3,4,5,6,7,8,9} always labelled from {0,1,2,3,...,n-1}
L:=[{{0, 1}, {0, 3}, {0, 5}, {0, 7}, {2, 9}}, {{0, 1}, {0, 3}, {0, 5}, {0, 7}, {4, 9}}, {{0, 1}, {0, 3}, {0, 5}, {0, 7}, {6, 9}}, {{0, 1}, {0, 3}, {0, 5}, {0, 7}, {8, 9}}, {{0, 1}, {0, 3}, {0, 5}, {0, 9}, {2, 7}}, {{0, 1}, {0, 3}, {0, 5}, {0, 9}, {4, 7}}, {{0, 1}, {0, 3}, {0, 5}, {0, 9}, {6, 7}}, {{0, 1}, {0, 3}, {0, 5}, {0, 9}, {7, 8}}, {{0, 1}, {0, 3}, {0, 7}, {0, 9}, {2, 5}}, {{0, 1}, {0, 3}, {0, 7}, {0, 9}, {4, 5}}, {{0, 1}, {0, 3}, {0, 7}, {0, 9}, {5, 6}}, {{0, 1}, {0, 3}, {0, 7}, {0, 9}, {5, 8}}, {{0, 1}, {0, 5}, {0, 7}, {0, 9}, {2, 3}}, {{0, 1}, {0, 5}, {0, 7}, {0, 9}, {3, 4}}, {{0, 1}, {0, 5}, {0, 7}, {0, 9}, {3, 6}}, {{0, 1}, {0, 5}, {0, 7}, {0, 9}, {3, 8}}, {{0, 1}, {1, 2}, {1, 4}, {1, 6}, {3, 8}}, {{0, 1}, {1, 2}, {1, 4}, {1, 6}, {5, 8}}, {{0, 1}, {1, 2}, {1, 4}, {1, 6}, {7, 8}}, {{0, 1}, {1, 2}, {1, 4}, {1, 6}, {8, 9}}, {{0, 1}, {1, 2}, {1, 4}, {1, 8}, {3, 6}}, {{0, 1}, {1, 2}, {1, 4}, {1, 8}, {5, 6}}, {{0, 1}, {1, 2}, {1, 4}, {1, 8}, {6, 7}}, {{0, 1}, {1, 2}, {1, 4}, {1, 8}, {6, 9}}, {{0, 1}, {1, 2}, {1, 6}, {1, 8}, {3, 4}}, {{0, 1}, {1, 2}, {1, 6}, {1, 8}, {4, 5}}, {{0, 1}, {1, 2}, {1, 6}, {1, 8}, {4, 7}}, {{0, 1}, {1, 2}, {1, 6}, {1, 8}, {4, 9}}, {{0, 1}, {1, 4}, {1, 6}, {1, 8}, {2, 3}}, {{0, 1}, {1, 4}, {1, 6}, {1, 8}, {2, 5}}, {{0, 1}, {1, 4}, {1, 6}, {1, 8}, {2, 7}}, {{0, 1}, {1, 4}, {1, 6}, {1, 8}, {2, 9}}, {{0, 1}, {2, 3}, {2, 5}, {2, 7}, {2, 9}}, {{0, 1}, {2, 3}, {3, 4}, {3, 6}, {3, 8}}, {{0, 1}, {2, 5}, {4, 5}, {5, 6}, {5, 8}}, {{0, 1}, {2, 7}, {4, 7}, {6, 7}, {7, 8}}, {{0, 1}, {2, 9}, {4, 9}, {6, 9}, {8, 9}}, {{0, 1}, {3, 4}, {4, 5}, {4, 7}, {4, 9}}, {{0, 1}, {3, 6}, {5, 6}, {6, 7}, {6, 9}}, {{0, 1}, {3, 8}, {5, 8}, {7, 8}, {8, 9}}, {{0, 3}, {0, 5}, {0, 7}, {0, 9}, {1, 2}}, {{0, 3}, {0, 5}, {0, 7}, {0, 9}, {1, 4}}, {{0, 3}, {0, 5}, {0, 7}, {0, 9}, {1, 6}}, {{0, 3}, {0, 5}, {0, 7}, {0, 9}, {1, 8}}, {{0, 3}, {1, 2}, {1, 4}, {1, 6}, {1, 8}}, {{0, 3}, {1, 2}, {2, 5}, {2, 7}, {2, 9}}, {{0, 3}, {1, 2}, {3, 4}, {3, 6}, {3, 8}}, {{0, 3}, {1, 4}, {2, 3}, {3, 6}, {3, 8}}, {{0, 3}, {1, 4}, {4, 5}, {4, 7}, {4, 9}}, {{0, 3}, {1, 6}, {2, 3}, {3, 4}, {3, 8}}, {{0, 3}, {1, 6}, {5, 6}, {6, 7}, {6, 9}}, {{0, 3}, {1, 8}, {2, 3}, {3, 4}, {3, 6}}, {{0, 3}, {1, 8}, {5, 8}, {7, 8}, {8, 9}}, {{0, 3}, {2, 3}, {3, 4}, {3, 6}, {5, 8}}, {{0, 3}, {2, 3}, {3, 4}, {3, 6}, {7, 8}}, {{0, 3}, {2, 3}, {3, 4}, {3, 6}, {8, 9}}, {{0, 3}, {2, 3}, {3, 4}, {3, 8}, {5, 6}}, {{0, 3}, {2, 3}, {3, 4}, {3, 8}, {6, 7}}, {{0, 3}, {2, 3}, {3, 4}, {3, 8}, {6, 9}}, {{0, 3}, {2, 3}, {3, 6}, {3, 8}, {4, 5}}, {{0, 3}, {2, 3}, {3, 6}, {3, 8}, {4, 7}}, {{0, 3}, {2, 3}, {3, 6}, {3, 8}, {4, 9}}, {{0, 3}, {2, 5}, {3, 4}, {3, 6}, {3, 8}}, {{0, 3}, {2, 5}, {4, 5}, {5, 6}, {5, 8}}, {{0, 3}, {2, 7}, {3, 4}, {3, 6}, {3, 8}}, {{0, 3}, {2, 7}, {4, 7}, {6, 7}, {7, 8}}, {{0, 3}, {2, 9}, {3, 4}, {3, 6}, {3, 8}}, {{0, 3}, {2, 9}, {4, 9}, {6, 9}, {8, 9}}, {{0, 5}, {1, 2}, {1, 4}, {1, 6}, {1, 8}}, {{0, 5}, {1, 2}, {2, 3}, {2, 7}, {2, 9}}, {{0, 5}, {1, 2}, {4, 5}, {5, 6}, {5, 8}}, {{0, 5}, {1, 4}, {2, 5}, {5, 6}, {5, 8}}, {{0, 5}, {1, 4}, {3, 4}, {4, 7}, {4, 9}}, {{0, 5}, {1, 6}, {2, 5}, {4, 5}, {5, 8}}, {{0, 5}, {1, 6}, {3, 6}, {6, 7}, {6, 9}}, {{0, 5}, {1, 8}, {2, 5}, {4, 5}, {5, 6}}, {{0, 5}, {1, 8}, {3, 8}, {7, 8}, {8, 9}}, {{0, 5}, {2, 3}, {3, 4}, {3, 6}, {3, 8}}, {{0, 5}, {2, 3}, {4, 5}, {5, 6}, {5, 8}}, {{0, 5}, {2, 5}, {3, 4}, {5, 6}, {5, 8}}, {{0, 5}, {2, 5}, {3, 6}, {4, 5}, {5, 8}}, {{0, 5}, {2, 5}, {3, 8}, {4, 5}, {5, 6}}, {{0, 5}, {2, 5}, {4, 5}, {5, 6}, {7, 8}}, {{0, 5}, {2, 5}, {4, 5}, {5, 6}, {8, 9}}, {{0, 5}, {2, 5}, {4, 5}, {5, 8}, {6, 7}}, {{0, 5}, {2, 5}, {4, 5}, {5, 8}, {6, 9}}, {{0, 5}, {2, 5}, {4, 7}, {5, 6}, {5, 8}}, {{0, 5}, {2, 5}, {4, 9}, {5, 6}, {5, 8}}, {{0, 5}, {2, 7}, {4, 5}, {5, 6}, {5, 8}}, {{0, 5}, {2, 7}, {4, 7}, {6, 7}, {7, 8}}, {{0, 5}, {2, 9}, {4, 5}, {5, 6}, {5, 8}}, {{0, 5}, {2, 9}, {4, 9}, {6, 9}, {8, 9}}, {{0, 7}, {1, 2}, {1, 4}, {1, 6}, {1, 8}}, {{0, 7}, {1, 2}, {2, 3}, {2, 5}, {2, 9}}, {{0, 7}, {1, 2}, {4, 7}, {6, 7}, {7, 8}}, {{0, 7}, {1, 4}, {2, 7}, {6, 7}, {7, 8}}, {{0, 7}, {1, 4}, {3, 4}, {4, 5}, {4, 9}}, {{0, 7}, {1, 6}, {2, 7}, {4, 7}, {7, 8}}, {{0, 7}, {1, 6}, {3, 6}, {5, 6}, {6, 9}}, {{0, 7}, {1, 8}, {2, 7}, {4, 7}, {6, 7}}, {{0, 7}, {1, 8}, {3, 8}, {5, 8}, {8, 9}}, {{0, 7}, {2, 3}, {3, 4}, {3, 6}, {3, 8}}, {{0, 7}, {2, 3}, {4, 7}, {6, 7}, {7, 8}}, {{0, 7}, {2, 5}, {4, 5}, {5, 6}, {5, 8}}, {{0, 7}, {2, 5}, {4, 7}, {6, 7}, {7, 8}}, {{0, 7}, {2, 7}, {3, 4}, {6, 7}, {7, 8}}, {{0, 7}, {2, 7}, {3, 6}, {4, 7}, {7, 8}}, {{0, 7}, {2, 7}, {3, 8}, {4, 7}, {6, 7}}, {{0, 7}, {2, 7}, {4, 5}, {6, 7}, {7, 8}}, {{0, 7}, {2, 7}, {4, 7}, {5, 6}, {7, 8}}, {{0, 7}, {2, 7}, {4, 7}, {5, 8}, {6, 7}}, {{0, 7}, {2, 7}, {4, 7}, {6, 7}, {8, 9}}, {{0, 7}, {2, 7}, {4, 7}, {6, 9}, {7, 8}}, {{0, 7}, {2, 7}, {4, 9}, {6, 7}, {7, 8}}, {{0, 7}, {2, 9}, {4, 7}, {6, 7}, {7, 8}}, {{0, 7}, {2, 9}, {4, 9}, {6, 9}, {8, 9}}, {{0, 9}, {1, 2}, {1, 4}, {1, 6}, {1, 8}}, {{0, 9}, {1, 2}, {2, 3}, {2, 5}, {2, 7}}, {{0, 9}, {1, 2}, {4, 9}, {6, 9}, {8, 9}}, {{0, 9}, {1, 4}, {2, 9}, {6, 9}, {8, 9}}, {{0, 9}, {1, 4}, {3, 4}, {4, 5}, {4, 7}}, {{0, 9}, {1, 6}, {2, 9}, {4, 9}, {8, 9}}, {{0, 9}, {1, 6}, {3, 6}, {5, 6}, {6, 7}}, {{0, 9}, {1, 8}, {2, 9}, {4, 9}, {6, 9}}, {{0, 9}, {1, 8}, {3, 8}, {5, 8}, {7, 8}}, {{0, 9}, {2, 3}, {3, 4}, {3, 6}, {3, 8}}, {{0, 9}, {2, 3}, {4, 9}, {6, 9}, {8, 9}}, {{0, 9}, {2, 5}, {4, 5}, {5, 6}, {5, 8}}, {{0, 9}, {2, 5}, {4, 9}, {6, 9}, {8, 9}}, {{0, 9}, {2, 7}, {4, 7}, {6, 7}, {7, 8}}, {{0, 9}, {2, 7}, {4, 9}, {6, 9}, {8, 9}}, {{0, 9}, {2, 9}, {3, 4}, {6, 9}, {8, 9}}, {{0, 9}, {2, 9}, {3, 6}, {4, 9}, {8, 9}}, {{0, 9}, {2, 9}, {3, 8}, {4, 9}, {6, 9}}, {{0, 9}, {2, 9}, {4, 5}, {6, 9}, {8, 9}}, {{0, 9}, {2, 9}, {4, 7}, {6, 9}, {8, 9}}, {{0, 9}, {2, 9}, {4, 9}, {5, 6}, {8, 9}}, {{0, 9}, {2, 9}, {4, 9}, {5, 8}, {6, 9}}, {{0, 9}, {2, 9}, {4, 9}, {6, 7}, {8, 9}}, {{0, 9}, {2, 9}, {4, 9}, {6, 9}, {7, 8}}, {{1, 2}, {2, 3}, {2, 5}, {2, 7}, {4, 9}}, {{1, 2}, {2, 3}, {2, 5}, {2, 7}, {6, 9}}, {{1, 2}, {2, 3}, {2, 5}, {2, 7}, {8, 9}}, {{1, 2}, {2, 3}, {2, 5}, {2, 9}, {4, 7}}, {{1, 2}, {2, 3}, {2, 5}, {2, 9}, {6, 7}}, {{1, 2}, {2, 3}, {2, 5}, {2, 9}, {7, 8}}, {{1, 2}, {2, 3}, {2, 7}, {2, 9}, {4, 5}}, {{1, 2}, {2, 3}, {2, 7}, {2, 9}, {5, 6}}, {{1, 2}, {2, 3}, {2, 7}, {2, 9}, {5, 8}}, {{1, 2}, {2, 5}, {2, 7}, {2, 9}, {3, 4}}, {{1, 2}, {2, 5}, {2, 7}, {2, 9}, {3, 6}}, {{1, 2}, {2, 5}, {2, 7}, {2, 9}, {3, 8}}, {{1, 2}, {3, 4}, {4, 5}, {4, 7}, {4, 9}}, {{1, 2}, {3, 6}, {5, 6}, {6, 7}, {6, 9}}, {{1, 2}, {3, 8}, {5, 8}, {7, 8}, {8, 9}}, {{1, 4}, {2, 3}, {2, 5}, {2, 7}, {2, 9}}, {{1, 4}, {2, 3}, {4, 5}, {4, 7}, {4, 9}}, {{1, 4}, {2, 5}, {3, 4}, {4, 7}, {4, 9}}, {{1, 4}, {2, 7}, {3, 4}, {4, 5}, {4, 9}}, {{1, 4}, {2, 9}, {3, 4}, {4, 5}, {4, 7}}, {{1, 4}, {3, 4}, {4, 5}, {4, 7}, {6, 9}}, {{1, 4}, {3, 4}, {4, 5}, {4, 7}, {8, 9}}, {{1, 4}, {3, 4}, {4, 5}, {4, 9}, {6, 7}}, {{1, 4}, {3, 4}, {4, 5}, {4, 9}, {7, 8}}, {{1, 4}, {3, 4}, {4, 7}, {4, 9}, {5, 6}}, {{1, 4}, {3, 4}, {4, 7}, {4, 9}, {5, 8}}, {{1, 4}, {3, 6}, {4, 5}, {4, 7}, {4, 9}}, {{1, 4}, {3, 6}, {5, 6}, {6, 7}, {6, 9}}, {{1, 4}, {3, 8}, {4, 5}, {4, 7}, {4, 9}}, {{1, 4}, {3, 8}, {5, 8}, {7, 8}, {8, 9}}, {{1, 6}, {2, 3}, {2, 5}, {2, 7}, {2, 9}}, {{1, 6}, {2, 3}, {5, 6}, {6, 7}, {6, 9}}, {{1, 6}, {2, 5}, {3, 6}, {6, 7}, {6, 9}}, {{1, 6}, {2, 7}, {3, 6}, {5, 6}, {6, 9}}, {{1, 6}, {2, 9}, {3, 6}, {5, 6}, {6, 7}}, {{1, 6}, {3, 4}, {4, 5}, {4, 7}, {4, 9}}, {{1, 6}, {3, 4}, {5, 6}, {6, 7}, {6, 9}}, {{1, 6}, {3, 6}, {4, 5}, {6, 7}, {6, 9}}, {{1, 6}, {3, 6}, {4, 7}, {5, 6}, {6, 9}}, {{1, 6}, {3, 6}, {4, 9}, {5, 6}, {6, 7}}, {{1, 6}, {3, 6}, {5, 6}, {6, 7}, {8, 9}}, {{1, 6}, {3, 6}, {5, 6}, {6, 9}, {7, 8}}, {{1, 6}, {3, 6}, {5, 8}, {6, 7}, {6, 9}}, {{1, 6}, {3, 8}, {5, 6}, {6, 7}, {6, 9}}, {{1, 6}, {3, 8}, {5, 8}, {7, 8}, {8, 9}}, {{1, 8}, {2, 3}, {2, 5}, {2, 7}, {2, 9}}, {{1, 8}, {2, 3}, {5, 8}, {7, 8}, {8, 9}}, {{1, 8}, {2, 5}, {3, 8}, {7, 8}, {8, 9}}, {{1, 8}, {2, 7}, {3, 8}, {5, 8}, {8, 9}}, {{1, 8}, {2, 9}, {3, 8}, {5, 8}, {7, 8}}, {{1, 8}, {3, 4}, {4, 5}, {4, 7}, {4, 9}}, {{1, 8}, {3, 4}, {5, 8}, {7, 8}, {8, 9}}, {{1, 8}, {3, 6}, {5, 6}, {6, 7}, {6, 9}}, {{1, 8}, {3, 6}, {5, 8}, {7, 8}, {8, 9}}, {{1, 8}, {3, 8}, {4, 5}, {7, 8}, {8, 9}}, {{1, 8}, {3, 8}, {4, 7}, {5, 8}, {8, 9}}, {{1, 8}, {3, 8}, {4, 9}, {5, 8}, {7, 8}}, {{1, 8}, {3, 8}, {5, 6}, {7, 8}, {8, 9}}, {{1, 8}, {3, 8}, {5, 8}, {6, 7}, {8, 9}}, {{1, 8}, {3, 8}, {5, 8}, {6, 9}, {7, 8}}]
Now to Split the List L to sublists like this
Now going through L list in details (All my lists will be like this only}
Sublist L1 will have all those from first in this firstly we see  edge {0,1} we take all those which take {0,1} in sequencial manner and put in sublist L1
Now as we proceed we see the next starting edge is {0,3} so their is none with {0,2} so we pick all those with {0,3} in the first sequencial manner and put in sublist L2
Similiar we pick all sublist from this with first element unique in the sequential manner and make a list of lists
Lk:=[L1,L2,L3,L4,....]
Code until L
which was done
Toy_code_(1).mw
Now again proceed we can observe we can see their none with {0,4} next is only with {0,5}
Then i need write a function F which takes a List say L1 returns
all possible 2 element permutions from L1 list say [S1,S2] and [S2,S1] like that all possible as order also matter where that set is positioned
Given Graph G and Graph H how to store the list of all the various Subgraphs of Shape H in G with their vertex labels.
I have write a code but it may not be the optimal way to do it and it may be time consuming for even medium graphs too
Any way to optimize
Let From this list of subgraphs H of say [G0,G1,G2,.....] we pick NumberOfVertices(G) Graphs
say H= [H0,H1,H2,H3,....,Hn]
i) Now any two graph Hi,Hj have excatly one edge interection if (i,j) is an edge in G
 ii) An edge in  the list H will occur exactly twice only in the entire list of graphs
If these two conditions satifies all such H I need to save
Toycode until picking graphs
From that how to pick lists which satify conditions i) and ii) is another need help
Toy_code.mw
First 208 209 210 211 212 213 214 Last Page 210 of 2434
