For the comand:
plot({[2-3*sin(t), t, t = 0 .. 2*Pi], [2-3*cos(t), t, t = 0 .. 2*Pi]}, scaling = constrained, coords = polar)
Alright people im really stuck on this maple question and i was wondering if any of you lot could help me out :)
Im really new to maple and ive been attempting this question for ages with various google searches etc..
Help will be appricated greatly
David.
I must work with the textual version of Maple, via ssh. My program asks for a lot of time (10^5 seconds) , so that  I usally let it to run all the night. What happens is that when the calculation is done, the ssh server close the connection due to time inactivity, and I can't either use the results or continue my work there.
My questions are then:
1) Can I set Maple to keep the connection alive?
for wha m the following inequality holds
(1+x)^(m+1) > 2^m*(x^m+x)
1<=x<=2
I'm new with maple.
I'm trying to solve a nonlinear system of equations (4x4). I tried fsolve and solve but neither work :'(
Could someone give me a hand?
Thanks!!!
Ignacio
PS: Here is the system:
View 12104_system.mw on MapleNet or Download 12104_system.mw
View file details
Hi, I have a system of four first order, nonlinear, differential equations with four dependent variables.  The variable F(t) can be set equal to zero or to some known function.
A*(diff(xx(t), t)) + epsilon*xx(t) + B*(diff(phi(t), t))*cos(theta(t)) + C*phi(t)^2*sin(theta(t)) = F(t),
D*(diff(xx(t), t))*cos(theta(t)) + E*diff(phi(t), t)) + F*sin(theta(t)) = 0,
xx(t) = diff(x(t), t),
phi(t) = diff(theta(t), t)
Can anyone tell me if
plot((4*x+4)*(u(x+2)-u(x))+4*(u(x)-u(x -2)),x=-5..5);
is the correct syntax to plot question a) shown in
Any help is appreciated
 NEWTON_RAPH:= proc(f,z,M)
   local x,A:
    x := z:
    for A to M do:
      x :=  ( x - ( f ( x ) / D ( f ) ( x ) )  - ( ( ( ( D@@2 ) ( f ) ) * ( ( f( x ) ) ^ 2 ) n ) / ( 2 * ( D ( f ) ( x) ) ^3 ) ) )
    evalf(x):
 f:= x-> x ^ 2 - 5:
 NEWTON_RAPH(f,1,10);
I have this function: f(x):=x*sin(x^(2))+1 The function is defined in the interval [-1;3] and the diff: df := sin(x^2)+2*x^2*cos(x^2) But when I try to find out where the diff function equals 0: solve(df = 0, x)*assume-1
I trying to solve the following matrix
A:=Matrix([[alpha_O-E, beta_CO, 0, 0],[beta_CO, alpha_C-E, beta_CC, 0],[0, beta_CC, alpha_C-E, beta_CC],[0, 0, beta_CC, alpha_C-E]]);
by setting the determinant to zero and finding the roots in terms of parameters alpha_O, beta_CO, alpha_C, and beta_CC.  I have tried to use solve which returns
Look at the link below, for image! http://img109.imageshack.us/img109/3676/problem.png Thanks, Jonas
View 12077_PR2COPY.mw on MapleNet or Download 12077_PR2COPY.mw
View file details
I have uplaoded my maple worksheet.The problem is that I need to modify my differential equation according to  value of a given variable.I donot know how to do that.
I was checking out a problem that graphically solved e (2.71828....) etc..
A procedure was created to find the slopes of incremental numbers between 2 selections.  The procedure was in it's simplest form like this
E := proc(c,d)
plot({(c+(d-c)*j/10^x-x-1 $ j=0..10}, x=0..(d-c)/1000,xtickmarks=0);
end;
Now so I start the process
E(2,3);
The slope closest to 0 and just under will determine my next decimal point.  So I find the next number as 7.  I continue finding more decimal points graphically using the procedure.
I am new to Maple 13, I have a data set that I can fit a b-spline curve to and out put the polynomials. I plot the the curve but I want the predicted values of the curve so I can compare them to other predicted values from other programs (eg SAS). I want to plot all the curves from each program in Excel against to actual values. Here is my worksheet for reference: Loading CurveFitting Loading plots Loading plottools
First 2106 2107 2108 2109 2110 2111 2112 Last Page 2108 of 2459
