I've got a set of Mathematica notebooks written by my co-author which I was thinking about translating into Maple worksheets (we also have a Matlab version of the same simulations so I thought it would be fitting to have a set of Maple equivalents too)... until I realized it may not be all that simple. Does anyone have prior experience using the MmaTranslator?
Good Morning,
How do I do a linear interpolation in Maple if I have the following list below
v := 1.7 is the value in R
R := [1.0, 1.5, 2.0, 3.0, 5.0,10]
X := [1.87, 2.11, 2.31,2.63, 3.04, 3.53]
c1 :=BSpline(R, X, v) (Is this correct) because I did not get the expecting X value
Please Help.
I have been working on a problem related to and using the famous Hadamard-Weierstrass Factorization Theorem (HWFT) for representing an entire function, E(z), with pre-defined zeroes, a(n), which go off to infinity. From HWFT one can represent any meromorphic function with pre-defined poles and zeroes as the ratio of two entire functions.
I am not interested in creating an entire function, but a function F(z) analytic on a disk centered at a pre-defined point such that the analytic continuation, A(z), of F(z) equals pre-defined values
I have a loop that generates a vector:
for i to 5 do
eqn[i] := i;
I then want to print the vector so it looks like this:   eqn = [1, 2, 3, 4, 5]
eqn;    just prints the word eqn
Hello I am hoping someone can help me find a solution to this equation with MAPLE. The solution (sol) comes out as a rootof structure with constants numbered C1 to C8 (see input below,try yourself and see format of sol). I don't know how to simplify this rootof structure and find the values for the constants that i want. I know that C2=C3=C5=C7=0 but I need to find C1, C4, C6 and C8. Can anyone help me find the values for these constants when the boundary conditions are such that f1(0)=f2(0)=f3(0)=0 and f4(0)=(r1+r2+r3+r4)/r4 . Thank you very much. > restart; Digits := 10;
Hi, I am a Maple newbie. My problem is I have implicit function in two dimensions and want to calculate the surface area of it. It is not possible to calculate the explicit representation of that function. Does anyone has a suggestion?? Thank you, Flo
hi all my 1th post i am rookie , and finishing of the subject is hard for me ! i hope a gentleman show me how can i draw a Huffman tree in maple ! it is a great template for me ! this is a good reference that contains some code too ! http://www.cs.tut.fi/~albert/Dev/pucrunch/packing.html sincerely Fereydoon Shekofte many appreciate and regards :-)
LF1 and LF2 return quite different numbers, and only that of LF2 agrees with theoretical results and computations done with other packages. What do I do wrong, or how do I optimise correctly, only knowing that p in (0,1) and lambda >0? Is there anything more appropriate than NLPSolve?
Hi there,
I want to use Maple with the non-graphical interface on a standard konsole (not xmaple, just maple).
This works fine, except: how do I store the current file? (there are no menues...)
How do I open one?
Good Morning,
Would anybody be kind to help me with the attached Maple worksheet. My goal is to use Maple procedure to generate all the equations and then solve the equations for all the variables. Also, I have attached the PDF file on the paper I'm trying to develope, the equations are on page 8. Please Help.
Moses
dears
            i am try to solve lagrange dynamics in maple , i have problem with the solution , the maple make the solution but it get stuck after some time and maple is closed.. wheh i am  using inertia withoutout transformation matix , maple solve the equation but when i transform the inertia matrix  using transformatin matix, i am getting this problme, can any brother help in this regard, the file is attached..
For solving a 2nd order hyperbolic PDE numerically (pdsolve/numeric), is it possible to choose more restricted and different time/space ranges, rather than what is defined in initial/boundary conditions? (assuming the fact that one defined Cauchy initial conditions for time variable at t[0], and Dirichlet boundary condition for space variable) thanks
I was wondering if anyone could tell me whether (and if so, how) it's possible to get Maple code to run an external program mid-process?  The program in question is qHull, which I downloaded from www.qhull.org.  Some searching has informed me it's possible to run C and JAVA bits in Maple, but with no programming experience I'm not sure whether that extends in any way to this, or if so, how.
How do I get Maple to factor some of the terms in the expression and ignore the irrelavent ones?
eg
factor(x^2+2x+1)   gives  (x+1)^2
but   factor(x^2+2x+1+y)   just returns  x^2+2x+1+y
So  factor((x^2+2x+1+y)/(x+1)^2)  will not automatically simplify to   1 + y/(x+1)^2
I'm looking to simplify a very long an expression such as this one:
I have used Maple to do a lot of plottings. But the image quality is not always satisfactory.
So I wonder if Maple can produce high quality images (surfaces), like those displayed here:
http://xahlee.org/surface/gallery.html
Thanks for your suggestions.
First 2104 2105 2106 2107 2108 2109 2110 Last Page 2106 of 2434
