I am trying to write a program for calculating the number of ways to place k non-attacking rooks on an m x n board with restricted positions defined in B.  If i remove "option remember" the program works but it doesn't work very efficiently, and my goal is to extend this into three dimensions, so it needs to work fairly quickly in 2 dimensions.  The problem comes when I put in "option remember&q
To whom it may concern:
It appears that 'GraphTheory[Trail]' is missing from the Maple help function. Am I overlooking something? I am running Maple 12.01.
Cheers
Roberto
      I really really need a command for getting the inflection point of a expression. Thank you very much!:)
Best regards.
I use solve() to sove a equation group. when I typed the command and press Enter. there is no response even a error or fail. what is the reason?
BTW: the equation is complex.
Best regards!
What's the standard (or a cool non-standard)  way to compute the expected value of a matrix, e.g., a covariance matrix? Using this code:
restart; with(LinearAlgebra): e1 := Statistics:-RandomVariable(Normal(0, sigma)); L := [seq(e1*cos(pi*t), t = 1 .. 3)]; convert(L, Matrix); Transpose(convert(L, Matrix)); M := Multiply(%, %%); S := map(Statistics:-Mean, M)
how do I simplify S to the matrix of +/- one's and factor out sigma^2 outside the matrix? Thanks.
When a user drags and drops a component from the pallette, a copy of the component is copied into the subsystem library located in the lower right of the screen.  This is handy if used again so that the user does not have to drill down into the pallettes repeatedly.  But, after a while the copies accumulate in the subsystems library, and it would be nice to selectively delete them if the user knows they will not be used again.  I have not found any way to delete the built in components copyied into the subsystem library.  I suppose it is childishly simple, but the operat
Given four points in 2D, P1=(0,7), P2=(1,-12), P3=(7,0), P4=(10,-9), solve the following problems:
(1) Determine if P1, P2, P3 form a triangle;
(2) If they form a triangle T, determine if T is isosceles (two sides equal) and plot T;
       I am a newer for Maple. When I want to type some command in maple, I find that the default font is not very good. I try to change it, but when I type next exe group, I find  that the default font is recovered~~ How to change it forever?
Best regards,
I am having trouble with the following sum not adding properly:
sum(sum(sum(1/k!/j!/m!,k=2-m-j..2-m-j),j=0..2-m),m=0..2);
By my hand calculations, this should be 4 (?), but maple says it is zero. If we remove a factorial (like below) we will get a non zero sum. What am I doing wrong,or is this a bug in maple?
sum(sum(sum(1/k!/j!,k=2-m-j..2-m-j),j=0..2-m),m=0..2);
thanks.
I'm having trouble figuring out how to find the 2-D scalar potential of a 3-D vector field projected onto a plane.  The vector field is computed on the plane, coordinates (X,Y), as a vector function with arguments (X,Y,u), with 'u' being a parameter.
After invoking the VectorCalculus package and specifying
    SetCoordinates(cartesian[X,Y]),
I use the solve command to solve a quadratic equation. I get two outputs and want to assign the second output to the variable x. How can I do this?
Quadratic equation is 3x^2 - 9x+11
Thanks in advance!!
I have calculated data in form of a matrix. The corresponding x- and y-values are given in two lists (see attached file).
Now I would like to export the data to a textfile to use it in another program. The problem is, that I need the following format (name_listA[i]_listB[j]= is a text string where the corresponding x- and y-values are integrated)(values[i,j] is the number out of the matrix):
name_listA[1]_listB[1]= values [1,1]
name_listA[1]_listB[2]= values [1,2]
etc....
hi guys, i have the following set of equations e1='a2+a3+a5+a6-1=0'; e2='2*a1+2*a4+4*a5-1.6-2*0.2=0'; e3='a2+2*a3+a4-0.77-0.2=0'; e4='(K1*((a1+a2+a3+a4+a5+a6)^2/4)*(a5*f))-(a1^3*a2)=0'; e5='K2*a2*a4-(a1*a3)=0'; e6='K3*a4*a6-(a1*a2)=0'; symbolic a1,a2,a3,a4,a5,a6 I can slove these set of equations for known values of K1,K2,K3 but i have a set of values for K1,k2,K3 (35 values) ie K1=[1 2 3 4.......35] K2=[1 2 3........35] K3=[1 2 3 .....35]
I have the next problem, i need to  use recursion to make the equation E(x+1)=E(x)+(E(x)*(P-E(x)))/P*10 with P 15000 and E(1)=1, i put for example E(20), but maple only use ram, but doesn't do anything.
I got a set of 8 variables and 8 equations, i need to solve them. I tried using "fsolve" but there are too many variables and too many equations. I thought I can try it using linearalgebra.
First 2156 2157 2158 2159 2160 2161 2162 Last Page 2158 of 2459
