The text below was encrypted with a substitution cipher. Only the letters (both
upper-case and lower-case) were substituted, leaving punctuation and spaces alone.
Can any on help me to figure out what the original message was using maple procedures.
“wA’r aBeD WUeK AP XNaB NM U rALKNP USUeAJBMA NM zUM
nPrB ZNAW U JUM ZWP’r XBUeMNMO AP SXUD AWB aNPXNM.”
yWUA’r ZWUArWBAPXK AWB SPXNCB ZWBMrWBWUMKBK AWBJ
AWB BJSAD eBaPXaBe.
lNCWUeK heULANOUM, “yWB zCUeXUAAN yNXA”
I have no clue...
How do you calculate the final velocities and the angles when two objects collide into one another...any help/info would be highly appreciated.
When storing an inequality, Maple seems to always convert it to less than or less than or equal form.
x:=a>b  => x:= b<a;
Is it always true? Can someone explain a little bit how maple stores its data?
Peter
so far i plotted functions where z values were functions z=f(x,y) in cartesian coordinates. this was easily done with the plot3d command. now i have a function described in polar coordinates, z=f(r,phi). so far i haven't succeded in plotting it. as far as i see it cylindrical coordinates would be required here, but maple expects r=f(z,angle) and i need z=f(r,angle). maybe a changecoords operation would help, but I'm not sure how to perfrom that (I've just started using maple). would be thankful for pointers on how to tackle my problem.
i have an equation which is something like
F''(1)=a0+R*a1+R^2*a2+R^3*a3+...R^n*an
I need to write the coefficients an in a table against the power of R
so something like
n        an
0        ....
1       ....
2       ....
my table should go up to n=15
mj
Can it be done simpler/better/faster?
F3 := proc (n) options operator, arrow; ln(n)*mul(evalf(1-1/i), i = seq(ithprime(i), i = 1 .. n)) end proc; F3(100000); evalf(%);
F2 := proc (n) options operator, arrow; -ln(ln(n))+add(evalf(1/i), i = seq(ithprime(i), i = 1 .. n)) end proc; F2(100000); evalf(%);
F1 := proc (n) options operator, arrow; ln(n)-add(evalf(ln(i)/i), i = seq(ithprime(i), i = 1 .. n)) end proc; F1(5000); evalf(%);
how to write a procedure that counts ferquency of used letters in a string of a text for ex in this txt: fregs("I have the best dog.");
Hello all,
I'm fairly new to Maple and this problem has had me puzzled for hours now. I simply want to solve an algebraic equation, but I get 6 RootOf solutions. I need a numerical value. I've already tried a couple of things (and browsed these forums) but I haven't been able to achieve this...
I have included my worksheet so you know what I'm talking about.
The value I'm trying to find is tAC. I've tried allvalues(%) and convert(solAC[1],radical) but none of these would work. Do any of you have more useful ideas?
My Maple version is 11.02.
Please somebody can help : I have a matrix of 50x2 and I want to show her like another matrix of dimensions 17x6 Thanks for your help
How do I get Maple to display the result in lowest terms?  Maple is multiplying the numerator and denominator by 10000.  The answer is correct, but how do I prevent the numbers from being multiplied by 10000?  Do I have a setting or preference set incorrectly?
Hey guys, I am trying to plot a direction field using Maple 11.: //*** first I define the spline, this is the function that is giving me the error with(CurveFitting); BasinArea := H -> Spline([[-10, 36000000], [-8, 47000000], [-6, 57000000], [-4, 70000000], [-2, 81000000], [0, 89000000], [2, 95000000], [4, 100000000], [6, 105000000], [8, 111000000], [10, 125000000]], H, degree = 3) ; //*** then I define the two other functions that are used in the DE (error is not in these but I include them for //*** completeness)
I have created a user simplify procedure
`simplify\mysimplify` := proc(fun) ... etc ...
It works correctly, but not when i add it in a module.
ie a call as :
with(MyModule); simplify(x^2+x,mysimplify)
dont call mysimplify.
But it works if I call it directly
with(MyModule);
`simplify\mysimplify`(x^2+x);
I think I miss something but i can't point the error. What is the correct declaration ?
(the module is correct, others procedure works fine)
The attached worksheet shows you how to determine the arc length function and calculate the arc length of a function. The Arc Lengths Tutor will improve your understanding and help you with your homework ! You can also skip right away to an interactive video tutorial:
(Ctrl + Click)
Video Tutorial: Arc Lengths
Feel free to drop some comments !
Hi there ! The attached worksheet has a good review on the theory of determining volumes of solids through the method called "volume by cylindrical shells". You can also view an interactive video that shows you how to use Maple's powerful Volume by Revolution tutor that will help you with your homework.
(Ctrl + click on link)
<a href="http://www.maplesoft.com/demo/adoption/volume_by_cylindrical_shells.
Maybe this is a stupid question but if I have a function
how do I differentiate V with respect to t1 diff( V , t1) ?
First 2232 2233 2234 2235 2236 2237 2238 Last Page 2234 of 2468
