please help me solve equation ${\sqrt {x^2-10 x+1}=\sqrt {-8 x^2+9 x-1}}$
above equation, maple gives 2 solutions x=2, x=1/9
but in fact the equation has no solution
please help me.
solve(sqrt(x^2-10*x+1) = sqrt(-8*x^2+9*x-1))
1/9, 2
Download solve_eq_help.mw
Hello I cant sign in on my other MapleCloud account to view all my other Maple Documents.
It says "Oops an error stopped us, from verifying your account. Please sign in again or continue using public MapleCloud features maple" Any suggestions on how to fix it?
Maple 2020 beginner user - matrices shows 10 rows and columns on worksheet, by default. How to increase this value up to 16 and more? Of course, there is possibility (browse matrix) to see all values and export to Excel also, but better to see all 16 on worksheet.
For instance, I'd like to find the integer solutions of the following system (unknowns: k[1], k[2], k[3], k[4], k[5], and k[6]):
eqs:=eval~(k[1]*x^3+k[2]*x^2*y+k[5]*x^2*z+k[3]*x*y^2+k[6]*x*y*z+k[8]*x*z^2+k[4]*y^3+k[7]*y^2*z+k[9]*y*z^2+k[10]*z^3,{{x=1,y=1,z=1},{x=RootOf(_Z^3-4*_Z^2+_Z+1,index=1),y=RootOf(_Z^3-4*_Z^2+_Z+1,index=2),z=RootOf(_Z^3-4*_Z^2+_Z+1,index=3)},{x=RootOf(_Z^3-4*_Z^2+_Z+1,index=2),y=RootOf(_Z^3-4*_Z^2+_Z+1,index=3),z=RootOf(_Z^3-4*_Z^2+_Z+1,index=1)},{x=RootOf(_Z^3-4*_Z^2+_Z+1,index=3),y=RootOf(_Z^3-4*_Z^2+_Z+1,index=1),z=RootOf(_Z^3-4*_Z^2+_Z+1,index=2)}}):
{isolve}(eqs=~0);
It seems that the isolve command cannot solve such a system of linear equations, but its integer solutions do exist:
sol := [k[1] = _Z1, k[2] = _Z2, k[3] = _Z3, k[4] = _Z4, k[5] = _Z5, k[6] = _Z1 + 2*_Z3 + 2*_Z4 + _Z5 + 3*_Z6, k[7] = 2*_Z1 + _Z3 + 8*_Z4 - _Z6, k[8] = -21*_Z1 + 2*_Z2 - _Z4 - 4*_Z5 + _Z6, k[9] = 24*_Z1 - 4*_Z2 - 5*_Z3 - 12*_Z4 + 3*_Z5 - 4*_Z6, k[10] = -7*_Z1 + _Z2 + _Z3 + 2*_Z4 - _Z5 + _Z6]: (*results from Mathematica*)
evala(subs(sol, eqs));
                              {0}
Here _Z1, _Z2, _Z3, _Z4, _Z5, and _Z6 are integer parameters. However, how do I get this result in Maple?
I am trying to solve a nonlinear equation frequently and use the solution result to draw a plot. I was wondering when some solutions are complex numbers (I), how Maple treats them. Can we add a condition saying that if the solution is complex, it should be replaced by a real number (e.g., zero)
dear all:
    here I try to repeat the results as follows:
 (23) is my target
my 2 solving processes are included in the attachment.
using LinearSolve(A, b) and regular solve command can not generate results as (23)
Please take a look.
question_DHT.mw
thanks for your help.
best regards
I need help please. This is Maple 2019. I want to run through all possible bipartite tournaments with exactly 4 vertices in each partite set, and for each bipartite tournament compute the number of pair of vertices which has at least one common out-neighbor.
1) The following code stops after two lines of output. Please advise how the code can be fixed.
2) The printing of the adjaceny matrix using WeighMatrix(G) seems wrong too.
Thank you very much.😭😭
@nm I can see that working for a signal that has a starting point other than 0 and no other shifts involved, but I am wondering about signals built from shifted steps / ramps / etc.  If the forcing function is something like r(t) - u(t-1) - r(t-1) with u(t)=Heaviside(t) and r(t) = t Heaviside(t).  I won't have time to see if I can break Maple with that until this weekend, but I plan to try!
I would like to plot this function from x= 2pi to 4pi.  I entered this into the plotting command, and nothing happened.  How do I plot this from 2pi to 4pi?
plot_from_two_pi_to_4_pi.mw
Is it possible to have the results of a MapleFlow container wrap to the next line as opposed to just extending off the page?
kp := .3;
Pr := .3; N := .5; g := .5; A := 1; B := 0; M := .5; lambda := .5; Ec := .5;
rf := 997.1; kf := .613; cpf := 4179; `σf` := 0.5e-1;
p1 := 0.1e-1; sigma1 := 2380000; rs1 := 4250; ks1 := 8.9538; cps1 := 686.2;
p2 := 0.5e-1; sigma2 := 3500000; rs2 := 10500; ks2 := 429; cps2 := 235;
NULL;
a1 := (1-p1)^2.5*(1-p2)^2.5;
a2 := (1-p2)*(1-p1+p1*rs1/rf)+p2*rs2/rf;
a3 := 1+3*((p1*sigma1+p2*sigma2)/`σf`-p1-p2)/(2+(p1*sigma1+p2*sigma2)/((p1+p2)*`σf`)-((p1*sigma1+p2*sigma2)/`σf`-p1-p2));
a4 := (1-p2)*(1-p1+p1*rs1*cps1/(rf*cpf))+p2*rs2*cps2/(rf*cpf);
a5 := (ks1+2*kf-2*p1*(kf-ks1))*(ks2+2*kf*(ks1+2*kf-2*p1*(kf-ks1))/(ks1+2*kf+p1*(kf-ks1))-2*p2*(kf*(ks1+2*kf-2*p1*(kf-ks1))/(ks1+2*kf+p1*(kf-ks1))-ks2))/((ks1+2*kf+p1*(kf-ks1))*(ks2+2*kf*(ks1+2*kf-2*p1*(kf-ks1))/(ks1+2*kf+p1*(kf-ks1))+2*p2*(kf*(ks1+2*kf-2*p1*(kf-ks1))/(ks1+2*kf+p1*(kf-ks1))-ks2)));
OdeSys := (diff(U(Y), Y, Y))/(a1*a2)+Theta(Y)+N*(Theta(Y)*Theta(Y))-a3*(M*M)*U(Y)/a2-(kp*kp)*U(Y)/(a1*a2), a5*(diff(Theta(Y), Y, Y))/a4+Pr*Ec*((diff(U(Y), Y))^2+U(Y)^2*(kp*kp))/(a1*a2); Cond := U(0) = lambda*(D(U))(0), Theta(0) = A+g*(D(Theta))(0), U(1) = 0, Theta(1) = B; Ans := dsolve([OdeSys, Cond], numeric, output = listprocedure);
U := proc (Y) options operator, arrow, function_assign; (eval(U(Y), Ans))(0) end proc;
                 U := Y -> (eval(U(Y), Ans))(0)
Theta := proc (Y) options operator, arrow, function_assign; (eval(Theta(Y), Ans))(0) end proc;
             Theta := Y -> (eval(Theta(Y), Ans))(0)
Theta_b := (int(U(Y)*Theta(Y), Y = 0 .. 1))/(int(U(Y), Y = 0 .. 1));
Error, (in Theta) too many levels of recursion
Q := int(U(Y), Y = 0 .. 1, numeric);
NUMERIC := [(eval((diff(U(Y), Y))/a1, Ans))(0), (eval(-(diff(Theta(Y), Y))/(Theta_b*a5), Ans))(0)];
i need the solution  for Y=0 and Y=1
How to factor the following polynomial : n*xn - 2*n*x(n - 1) + xn
I can't find a command to write : xn-1*((n+1)*x-2n)
Thank you for your help.
While I was elaborating on a math problem, I came across the following expression which actually should be equal to one. Maple unfortunately was unable to fully provide a simplified expression. Is there a way to do that?
Streamlines, isotherms and microrotations for Re = 1, Pr = 7.2, Gr = 105 and (a) Ha = 0 (b) Ha = 30 (c) Ha = 60 (d) Ha = 100.
Fig. 2
for Ra = 105Ha = 50, Pr = 0.025 and θ = 1 − Y
eqat := {M . (D(theta))(0)+2.*Pr . f(0) = 0, diff(phi(eta), eta, eta)+2.*Sc . f(eta) . (diff(phi(eta), eta))-(1/2)*S . Sc . eta . (diff(phi(eta), eta))+N[t]/N[b] . (diff(theta(eta), eta, eta)) = 0, diff(g(eta), eta, eta)-2.*(diff(f(eta), eta)) . g(eta)+2.*f(eta) . (diff(g(eta), eta))-S . (g(eta)+(1/2)*eta . (diff(g(eta), eta)))-1/(sigma . Re[r]) . ((1+d^%H . exp(-eta))/(1+d . exp(-eta))) . g(eta)-beta^%H . ((1+d^%H . exp(-eta))^2/sqrt(1+d . exp(-eta))) . g(eta) . sqrt((diff(f(eta), eta))^2+g(eta)^2) = 0, diff(theta(eta), eta, eta)+2.*Pr . f(eta) . (diff(theta(eta), eta))-(1/2)*S . Pr . eta . (diff(theta(eta), eta))+N[b] . Pr . ((diff(theta(eta), eta)) . (diff(phi(eta), eta)))+N[t] . Pr . ((diff(theta(eta), eta))^2)+4/3 . N . (diff((C[T]+theta(eta))^3 . (diff(theta(eta), eta)), eta)) = 0, diff(f(eta), eta, eta, eta)-(diff(f(eta), eta))^2+2.*f(eta) . (diff(f(eta), eta))+g(eta)^2-S . (diff(f(eta), eta)+(1/2)*eta . (diff(f(eta), eta, eta)))-1/(sigma . Re[r]) . ((1+d^%H . exp(-eta))/(1+d . exp(-eta))) . (diff(f(eta), eta))-beta^%H . ((1+d^%H . exp(-eta))^2/sqrt(1+d . exp(-eta))) . (diff(f(eta), eta)) . sqrt((diff(f(eta), eta))^2+g(eta)^2) = 0, g(0) = 1, g(6) = 0, phi(0) = 1, phi(6) = 0, theta(0) = 1, theta(6) = 0, (D(f))(0) = 1, (D(f))(6) = 0};
sys1 := eval(eqat, {M = 0, N = 2, Pr = .8, S = -2.5, Sc = .5, d = 2, sigma = .2, C[T] = .5, N[b] = .4, N[t] = .4, Re[r] = 1.1, beta^%H = .2, d^%H = 1.5});
sys2 := eval(eqat, {M = 0, N = 2, Pr = .8, S = -2.5, Sc = .5, d = 2, sigma = .2, C[T] = .5, N[b] = .4, N[t] = .4, Re[r] = 1.1, beta^%H = .4, d^%H = 1.5});
sys3 := eval(eqat, {M = 0, N = 2, Pr = .8, S = -2.5, Sc = .5, d = 2, sigma = .2, C[T] = .5, N[b] = .4, N[t] = .4, Re[r] = 1.1, beta^%H = .6, d^%H = 1.5});
sys4 := eval(eqat, {M = 0, N = 2, Pr = .8, S = -2.5, Sc = .5, d = 2, sigma = .2, C[T] = .5, N[b] = .4, N[t] = .4, Re[r] = 1.1, beta^%H = .8, d^%H = 1.5});
sys5 := eval(eqat, {M = .5, N = 2, Pr = .8, S = -2.5, Sc = .5, d = 2, sigma = .2, C[T] = .5, N[b] = .4, N[t] = .4, Re[r] = 1.1, beta^%H = .2, d^%H = 1.5});
sys6 := eval(eqat, {M = .5, N = 2, Pr = .8, S = -2.5, Sc = .5, d = 2, sigma = .2, C[T] = .5, N[b] = .4, N[t] = .4, Re[r] = 1.1, beta^%H = .4, d^%H = 1.5});
sys7 := eval(eqat, {M = .5, N = 2, Pr = .8, S = -2.5, Sc = .5, d = 2, sigma = .2, C[T] = .5, N[b] = .4, N[t] = .4, Re[r] = 1.1, beta^%H = .6, d^%H = 1.5});
sys8 := eval(eqat, {M = .5, N = 2, Pr = .8, S = -2.5, Sc = .5, d = 2, sigma = .2, C[T] = .5, N[b] = .4, N[t] = .4, Re[r] = 1.1, beta^%H = .8, d^%H = 1.5});
sys9 := eval(eqat, {M = 1, N = 2, Pr = .8, S = -2.5, Sc = .5, d = 2, sigma = .2, C[T] = .5, N[b] = .4, N[t] = .4, Re[r] = 1.1, beta^%H = .2, d^%H = 1.5});
sys10 := eval(eqat, {M = 1, N = 2, Pr = .8, S = -2.5, Sc = .5, d = 2, sigma = .2, C[T] = .5, N[b] = .4, N[t] = .4, Re[r] = 1.1, beta^%H = .4, d^%H = 1.5});
sys11 := eval(eqat, {M = 1, N = 2, Pr = .8, S = -2.5, Sc = .5, d = 2, sigma = .2, C[T] = .5, N[b] = .4, N[t] = .4, Re[r] = 1.1, beta^%H = .6, d^%H = 1.5});
sys12 := eval(eqat, {M = 1, N = 2, Pr = .8, S = -2.5, Sc = .5, d = 2, sigma = .2, C[T] = .5, N[b] = .4, N[t] = .4, Re[r] = 1.1, beta^%H = .8, d^%H = 1.5});
sys13 := eval(eqat, {M = 1.5, N = 2, Pr = .8, S = -2.5, Sc = .5, d = 2, sigma = .2, C[T] = .5, N[b] = .4, N[t] = .4, Re[r] = 1.1, beta^%H = .2, d^%H = 1.5});
sys14 := eval(eqat, {M = 1.5, N = 2, Pr = .8, S = -2.5, Sc = .5, d = 2, sigma = .2, C[T] = .5, N[b] = .4, N[t] = .4, Re[r] = 1.1, beta^%H = .4, d^%H = 1.5});
sys15 := eval(eqat, {M = 1.5, N = 2, Pr = .8, S = -2.5, Sc = .5, d = 2, sigma = .2, C[T] = .5, N[b] = .4, N[t] = .4, Re[r] = 1.1, beta^%H = .6, d^%H = 1.5});
sys16 := eval(eqat, {M = 1.5, N = 2, Pr = .8, S = -2.5, Sc = .5, d = 2, sigma = .2, C[T] = .5, N[b] = .4, N[t] = .4, Re[r] = 1.1, beta^%H = .8, d^%H = 1.5});
I ploted the step response of a MIMO system in Maple using DynamicSystems object.
The plot is incorrect.
What am I doing wrong?
Thanks for your help
I have a system described by
I want to plot Y(s)/Z(s) = ((C . (1/((s . I) - A))) . B) + D with stepped inputs on both inputs
The system above evaluates to
My commands are
ss_a := A__m;
ss_b := B__m;
ss_c := C__m;
ss_d := D__m;
sys4 := StateSpace(ss_a, ss_b, ss_c, ss_d);
plots:-display([ResponsePlot(sys4, [Step(), Step()], 'duration' = 5, color = red)]);
Maple is returning the incorrect plot
The correct plot is
SYSTEM
Correct plot
First 225 226 227 228 229 230 231 Last Page 227 of 2424
