Hello I have a table of x values and y values and after plotting them I found a trend line by least square. But at the moment of plotting the values and the trend line, this last one doesn't reach all the plot width. How can I enlarge its reaching? Thank you,
hello, first post here.
i'm attempting to solve the 1 d heat equation using a finite difference scheme, with continous boundaries eg.
Where I can get right and complete instructions for read .txt files from Maple 7 ?
I follow the instructions like:
L := ImportMatrix( "data.txt", delimiter=" " );
for read a deta.txt file, or others like fopen, etc, and do not get the data.
How do I plot in the simplex with Maple [11]?
I am working with variables x1,x2,x3, each non-negative, and summing to one.  Thus, the triangular 2-simplex is an easier environment to work in.
Thank you in advance,
Colin Rowat, Department of Economics, University of Birmingham
Can I get maple to give me a hint as to what test for convergence to use with infinite series?
HI to all!
I've a math question about the Hessian Matrix. I know that it's used for clasify critical points of a 3-D function, but what happens if the Hessian is undefined (Hessian = 0) in a point?... How i can analyze the critical point?...
A particular sample is:  f(x,y) = (y-x)^2*(y+x).
The gradient vector of this function is: grad(f)= [ 3x^2 - 2xy - y^2 , -x^2 - 2xy + 3y^2 ]. To find critical points we have to do grad(f)=0 (vector). And in this case it's easy to verify that the critical points lie in the Y=X line.
hi
i have to calculate a extreme value for a box that is open on one side that should have a volume of 32.
V = x * y*z
For the surface ob the box-sides i used this function:
O = 2xz + xy + 2yz
my idea was to solve this in maple using lagrange because i ve a side condition
with(RealDomain):
L:=(x,y,lambda)->x*y + 2*x*z * 2*y*z +lambda*(x*y*z-32);
solve({diff(L(x,y,lambda),x)=0, diff(L(x,y,lambda),y)=0, diff(L(x,y,lambda),lambda)=0});
evalf(%);
it gives me for my values x = 32/x*y; y = y; z =z
Hello! I would like to know if there is a way that Maple finds the equation on its own. I have a table of x values and y values and after plotting them I would like to find a trend line by least square.
I would use the chain rule twice:
f(s,t) = e^u
u = sin(s*t);
u = sin(v);
v = s*t
v' = s;
u' = cos(s*t*)*s
f' = e^cos(s*t)*s
Maple adds *ln(exp), what's wrong with my way?
complete maple output: exp^sin(s*t)*cos(s*t)*t*ln(exp)
I want to create a list of the first 100 prime numbers.  I remember vaguely the use of seq and type but I can find it in the differents forums.  Could someone state it again for me.  thanks!
I have a matrix
A:=<<1,-3,2>|<-2,6,-4>|<2,-1,5>|<3,1,8>|<-1,-7,-4>>;
how do I find a basis of im(A)?
Chen
Hello everybody,
I am using the GF package from Maple to solve an equation with elements of a given galois field. It looks like that:
field := GF(7, 1):
eq1 := x = y^2:
eq2 := x^2 = y^4:
equationToUse := eq1:
isSolving := false:
use field in
    isSolving := is(eval(equationToUse, [x=field:-random(), y=field:-random()]));
end use:
if isSolving then
    print(`Equation solved`);
end if:
The Maple Manual says to use a parametric plot to graph a circle.  I've been fiddling with the syntax  but can't seem to get it right.  I want to plot
x^2 - 2x + y^2 = 0,           which can be written as
(x-1)^2 + y^2 = 1
Can someone please give me the PLOT command to plot this circle?
Allan
I wrote a procedure shrinkTime:=proc(n::posint); The procedure only works with a positive integers and I need to plot this function. However, whenever I goto plot it; plot(shrinkTime(n)); I get this error: " Error, invalid input: shrinkTime expects its 1st argument, n, to be of type posint, but received posint" How can I specifically instruct maple to only plot at points where x is a positive integer?
First 2270 2271 2272 2273 2274 2275 2276 Last Page 2272 of 2459
