Hi, I m using the Nonlinearfit command .the fit is very good and gives reasonable values for the parameters of he fitting but Maple says the Residual Mean Squre value is not available when I use the command
eq_fit:-Results(residualmeansquare)
please any one know the meaning?thanks
<p>If been able, in the other types of questions to use the commands;</p>
How do I add my own functions to the nonitalic list like sin, ln etc? I want eg. Col(A) and span{...} to not be in italic automatically.
I've seen in the typesetting rules, and tried adding them to dependency suppresion, but that doesn't accomplish anything :p
And #2: When I write {....}, I always get "Error, unable to match delimiters" on the last "}" -- how do I remove that message?
My function is: p(x) = 2*x^5-5*x^4+3*x^3-3*x^2+x+2. Question about this:
1. Find the 1st derivative of this function and plot it.
2. Find the 2nd derivative of this function and plot it.
3. Find the 3rd derivative of this function and plot it.
4. Find the 4th derivative of this function and plot it.
5. Plot p(x) and its derivative ont the same set of axes that clearly displays both graphs and all relative max and min. Use Paint menu to clearly label the functuon and it's derivative.
How do i go about identifying all horizontal and vertical asymptotes for a given problem?
Lets say (6x^2)/(x^3+2x^2-5x) for example, with multiple powers. How do I identify all of the asmpytotes?
And I was also curious, does every undefined value of f(x) lead to a vertical asymptote? Can the graph of of a function cross the graph of its horizontal or vertical asymptotes, and how many horizontal asymptotes can a graph have?
I need to answer a question, using maple, mathcad, or a similar algebra solver.
I have a little experience in Maple, and thought it would be easy, buts its not, here is the question.
The question is
Let P and Q be two points in the x-y plane with coordinates (1,2)  and (1,-1) respectively with respect to an origin O. Express OP, OQ and QP in the form Ai  + Bj   where A and B are scalars. Let R be a point on OP so that OR = 1/3OP . Find OR and QR in terms of i  and j .
I have no idea how to do this.
The question is
I wanted to make an animation of the 3-leaved rose, but the following codes only produce the separate figures.
r:=sin(3*t):
K:=30: for i from 1 to K do ti:=i*2*Pi/K:
curve[i]:=polarplot(r(t), t=0..ti) od:
C:=display(seq(curve[i],i=1..K), insequence=true):
display(C, scaling=constrained,tickmarks=[0,0], thickness=3);
 The following codes produces the animation I needed.
r:=sin(3*t):
display(C, C, scaling=constrained,tickmarks=[0,0], thickness=3);
The only difference is in the last line, where the “C” has been written twice instead of once. I don’t know why. Could anyone explain it to me? Thanks.
    It’s a pity that Maple does not offer easy ways to plot the region between two curves in the xy-plane. The option “filled=true” can only plot the region between the curve y=f(x) and the x-axis.
Maple 11:
I've made a list of all of the elements of the symmetric group s_6:
> S_6 := permgroup(6,{[[1,2]],[[1,2,3]],[[1,2,3,4]],[[1,2,3,4,5]],[[1,2,3,4,5,6]],[[1,2],[3,4]],[[1,2,3],[4,5]],[[1,2,3],[4,5,6]],[[1,2,3,4],[5,6]]});
> ident := permgroup (6, {[]} ):
> cosets(S_6, ident);
How do I extract certain types of cycle structures (e.g (**)(**)) from the list?
I typed in
series( 1/4*sqrt(2)*sqrt(Pi)*exp(-1/2)*(erf(1/2*sqrt(2)*x-1/2*I*sqrt(2))+erf(1/2*sqrt(2)*x+1/2*I*sqrt(2)))*exp(1/2*x^2),x);
I used  exp to avoid a pitfall.
Maple says
A link to a Maple10 worksheet is attached below.  The worksheet has the command lines but has not been executed so it size came under the limit for uploading.  The worksheet is an effort to animate the radius vector to a spacecurve complete with the tangent vector and associated normal and binormal vectors.  Early in the worksheet we suceed in animating the radius vector and the spacecurve.  This success was achieved with some pain.  For instance errors with the plot structures na ddisplay command would not work unless the whole sheet was executed - if, after this,
I have a system of 33 equations in 33 unknowns. I figured I could use Linear Algebra and Maple to solve this system. Now nearly 9 hours later Maple is still 'Evaluating'. It's been many years since I studied Mathematics and I am very rusty since I rarely use what I learned directly in my job.
Also this is my first attempt at using Maple so please be gentle if you see a ridiculously stupid mistake :-)
Hey,
I am trying to plot 3d graphs but I get the following error message written in blue:
Warning, unable to evaluate the function to numeric values in the region; see the plotting command's help page to ensure the calling sequence is correct.
The function im trying to plot is:
f(x,y)=[ xy (x²-y² ] / (x² + y²)=expr
This is what I write in Maple:
plot3d( expr,x=-1..1, y=-1..1)
In advance, thanks.
Emile
I have a number of expressions.  An example is:
-1/3*(xjm1^2-2*xj*xjm1+xj^2+3)/(xjm1-xj)
I would like to substitue the expression h=xj-xjm1, which in this case would result in
1/h+2*h/6.
Does anyone know how I can make this sort of substitution in Maple automatically?
First 2273 2274 2275 2276 2277 2278 2279 Last Page 2275 of 2434
