how do i count the numbers of elements inside of a list like [[x,y,z]]? ie. [[3,2,5],[2,34,6]]. i would want it to return 2.
Why do I get the same output with the two following statements plot3d(0, 0..20, 0..70, color=proc(x,y) 200000*x end proc); plot3d(0, 0..20, 0..70, color=proc(x,y) x end proc); How does the option "color=proc() ..end;" works? How can I choose the colors? (The reason behind my question is that I am trying understand how to plot the Mandelbrot set)
i have a list in the form of [[x,y,z]] where x,y,z are integers, i want to find all the elements of the form [0,y,z]. how do i do that?
This is a screenshot of what I get when I open Maple 10 http://img226.imageshack.us/img226/5010/maple100fe.jpg (copy and paste url) The Maple Calculator also results in the same problem What Java programs are required for Maple 10? I have the Microsoft Virtual Machine installed as well as Microsoft SDK 4.0. I am running XP with SP2. Any help is greatly appreciated.
Why am I getting a false statement as output for this input ? > >
hi i am mechanical eng. student. i am new user of maple and i am useing maple 8. i need to do symbolic diff, diff of theta is theta dot. theta is function of t but i don't know it. i am building a def. eqn. with Lagrange equations. how i do it with maple?
I have a module with an exported procedure defined by define_external, like this:
loadtest := module()
export hb;
option package;
hb:=define_external(
`hb`,
`MAPLE`,
`LIB`="/home/hans/system/maple/libhb.so");
end module:
This works if I put the code above into a .mpl file, and use read to load it. The problem is that I would like to save this module to a maple library:
> libname;
"/home/hans/system/maple", "/usr/local/maple8/lib"
> savelibname:="/home/hans/system/maple/loadtest.lib":
> march('create',savelibname,100);
> savelib('loadtest');
> map( march, [ 'gc', 'reindex', 'pack' ], savelibname ):
When I try to use this newly created library after restarting maple the following happens:
> A:=Matrix([[3,2,1,-2,-1,-4],[1,0,1,0,-1,0]]):
> with(loadtest);
[hb]
> hb(A);
[3 2 1 -2 -1 -4]
CALL_EXTERNAL([ ])
[1 0 1 0 -1 0]
Hi everybody, in Maple 9.5 I need to generate two Vectors of random generated numbers from a normal distribution with a certain correlation. The correlation should be an input factor. Does anyone know how to do that?
Hello everyone, my first post here. I'm studying mechatronic engineering at university so Maple is somewhat of a godsend. I got Maple 9.5 some years ago and it worked perfectly. But sometime last year it started going wrong. Whenever I tried to start standard maple it would give me some cryptic errors and refused to start. I had to resort to using Maple classic worksheet and it works just fine. Try as I might I could not discern the cause of my problems. I tried disabling my firewall and a number of other suggested fixes, none of which helped. Recently I was given Maple 10.0 and I thought installing it might fix my problems. I wasn't so lucky. I get essentially the exact same error when attempting to start Maple 10.0:
I had a few students drop after the first few days of class, and I've deleted their records from the "administration" part of the gradebook in Maple T.A., but their names continue to appear when I generate student statistics reports. Is there a way to prevent their names from appearing the in report? Thanks, Marc
I have a student who missed a Maple T.A. assignment, but he made the work up for me later by turning in a hard copy. Now I'd like to enter his grade and let Maple T.A. continue to keep accurate track of his record, but I can't make this assignment appear on the student's record. Any suggestions? Thanks, Marc
Hello all, I'm trying to use Maple 9.5 to interpolate the data from the points in the worksheet below. I would have attached the 3K file but the web page says the file size is too big. The spline function gives me what appears to be a valid (if big and complicated) piecewise function, but I get an error when I try to plot it. I'm a little confused since I followed the help file for the spline function closely. Any ideas on how to troubleshoot this error? I get "Warning, unable to evaluate the function to numeric values in the region; see the plotting command's help page to ensure the calling sequence is correct"
Of course, there are big differences in dsolve and dsolve numeric. But also there is a difference that is subtle. It would be nice if this subtle one were not there. It may be that there is an easy work-around. Of course, the complication that is at the root of the problem may not be subtle at all. Look at the results of these two situations. First situation. > restart; > h[0]:=t->(1+t)*t^2*cos(t): > sol1:=dsolve({diff(y(t),t)=-h[0](t-1),y(0)=h[0](0)},y(t)): > h[1]:=unapply(rhs(sol1),t): > sol2:=dsolve({diff(y(t),t)=-h[1](t-1),y(1)=h[1](1)},y(t)): > h[2]:=unapply(rhs(sol2),t): > plot([[t,h[0](t),t=-1..0],[t,h[1](t),t=0..1], [t,h[2](t),t=1..2]],color=blue); Second situation
Hi How do i solve a 3. order ODE to a 2. order. I am using maple 10. It seems to me that i am only able to solve to 1. order via the context menu or via the dsolve command. I am a engineer student, and we often need to dsolve from 3. or 4. order down to 1. order including the ones inbetween. I hope you will be able to help me out. TIA Otto
Entering
Tst0:= 0.5, 27.1, 0.1, 0.2, 24.0;
tst0:= beta=Tst0[1], lambda=Tst0[2], sigma=Tst0[3], P=Tst0[4], M=Tst0[5];
someFct([1/2*P, 1/lambda*beta],[(lambda+beta)/lambda],-sigma*(1+z)^lambda);
eval(%,evalf([tst0])); subs(z=0.1, %);
myTerm:=subs(someFct=hypergeom,%);
and using evalf(myTerm) I get .9981665521 while evalhf(myTerm) gives me
Error, remember tables are not supported in evalhf
What happens here?
First 2418 2419 2420 2421 2422 2423 2424 Page 2420 of 2424
