Can anyone tell me what this means? (workfile maple.file.mw)
I expected Maple Flow 2022 to return return 2 pi Radians as the answer to the below ... but instead it returned 360 arcdeg.
360 arcdeg * (pi rad/180 arcdeg) =
Question: Why don't the "arcdeg" units cancel out and Maple Flow 2022 return the answer 2 pi rad ?
I expected Maple Flow to handle the units by cancelling out the "arcdeg" units and return 2 pi rad as the answer.
(Note: in this post I placed a space between the numbers and the units for clarity ...
understanding that in Flow you actually enter the number, then press Ctl+Space+U then enter the unit.)
Thanks for any help.
maybe some of you can help me with this.
In the equations are variables F_[i][j] and GG_[i][j] (for i=1,2,3 and j=1,2,3). There are 5 Equations that equal 0 and 1 Equation that equals Q(given).
Is there a better way to try and solve this equations?
Hello everyone!
I've imported some values I gathered in a dat file, from Python, with the ImportMatrix, to Maple. This procedure gave me a 602x2 matrix, with the elements of the first column being the values of the horizontal plot and the ones of the second column, the values of the vertical plot.
The code that gave the dat file also works fine when I plot it in Python, the problem is that I need to do the same plot in Maple. I tried using differents commands of the plots package, but nothing seens to work
So my question is, anyone knows how can I counterplot the elements of a matrix or do a different approach for the plot of the dat file?
Any help with the problem will be appreciated and if any more information is necessary, please let me know. Thanks!
Hello Everyone;
I have 2D domain meshing defined. I need to plot it like figure given at end. I need to heighlights boundry and ineer points saperately and need to mention the points on it. Domain and mesh is given in Maple file attched. Kindly guide me.
Download Question2.mw
How do we make the maple to produce as general solutions as possible for ode/pde ??
For example, I have the following ODE with initial conditions (cons);
eq:=diff(x[0](tau), tau) + x[0](tau) - diff(y[0](tau), tau) - y[0](tau)=0;
cons:= x[0](0)=1 , y[0](0)=1;
The general solution for this ode is as
x[0](tau) = y[0](tau) = exp( - tau ),
but maple returns nothing.
when I use:
dsolve({cons, eq}, [v[0](tau), theta[0](tau)]);
Hi guys,
suppose we have metric in curve geometry such as ds2=A(r)*dt^2-B(r)*dr^2+r^2*dtheta^2+r^2*sin^2(theta)*dphi^2.
how we can calculate and find exact not symbolic different components of contravariant derivative of contravariant derivative of Weyl tensor and Riemann tensor.
with best regards,
Hello Everyone;
Hope you are fine. I am solving system of odes using rk-4 method. For this purpose I formulate the "residual" (on maple file) which is further function of "x" and "y". With the help of discritization point further I convert "residual" into system of ode's. Then i used "sys111 := solve(odes_Combine, `~`[diff](var, t))" to simplify the system. Finnally i applied RK-1. Code is pasted and attached. This all process is for "N=4". When i increase the value of "N", number of Odes increase accordingly. With increasing value of "N" the comand "sys111 := solve(odes_Combine, `~`[diff](var, t))" taking a lot of time due to heavy computation. Is that any way to proceed without this comand for rk-1?
Question1.mw
restart; with(PDEtools, Solve); with(LinearAlgebra); with(plots); DD := 30; Digits := DD; N := 4; nu := 1.0; t0, tf := 0, 1; Ntt := 10; h := evalf((tf-t0)/(Ntt-1)); xmin := 0; xmax := Pi; `Δxx` := 1.0*xmax/N; ymin := 0; ymax := xmax; `Δyy` := 1.0*ymax/N
0, 1
.111111111111111111111111111111
.785398163397448309615660845820
residual := 1.000000000*(diff(A[0, 0](t), t))-32.00000000*A[2, 0](t)-32.00000002*A[0, 2](t)+(diff(A[1, 1](t), t))*(4.000000001-8.000000003*y-8.000000003*x+16.00000000*x*y)+(diff(A[1, 0](t), t))*(-2.000000000+4.000000000*x)+(diff(A[0, 3](t), t))*(-4.000000000+40.00000000*y-95.99999994*y^2+64.00000001*y^3)+(diff(A[0, 2](t), t))*(3.000000000-16.00000001*y+16.00000001*y^2)+(diff(A[0, 1](t), t))*(-2.000000001+4.000000000*y)-A[3, 3](t)*(768.0000000-7680.000000*y+18432.00000*y^2-12288.00000*y^3-1536.000000*x+15360.00000*x*y-36863.99998*x*y^2+24576.00000*x*y^3)-A[3, 2](t)*(-576.0000002+3072.000000*y-3072.000000*y^2+1152.000000*x-6144.000000*x*y+6144.000000*x*y^2)-A[3, 1](t)*(384.0000000-768.0000000*y-768.0000006*x+1536.000000*x*y)-A[3, 0](t)*(-192.0000000+384.0000000*x)-A[2, 3](t)*(-128.0000000+1280.000000*y-3072.000000*y^2+2048.000000*y^3)-A[2, 2](t)*(96.00000000-512.0000002*y+512.0000002*y^2)-A[2, 1](t)*(-64.00000002+128.0000000*y)-A[3, 3](t)*(767.9999998-1536.000000*y-7679.999998*x+15360.00000*x*y+18432.00000*x^2-36864.00000*x^2*y-12288.00000*x^3+24576.00000*x^3*y)-A[2, 3](t)*(-575.9999998+1152.000000*y+3072.000000*x-6144.000000*x*y-3072.000000*x^2+6144.000000*x^2*y)-A[3, 2](t)*(-128.0000000+1280.000000*x-3072.000000*x^2+2048.000000*x^3)-A[1, 2](t)*(-64.00000002+128.0000000*x)-A[1, 3](t)*(384.0000000-768.0000000*y-767.9999998*x+1536.000000*x*y)-A[2, 2](t)*(96.00000004-512.0000002*x+512.0000002*x^2)+(diff(A[3, 3](t), t))*(16.00000000-160.0000000*y+383.9999999*y^2-256.0000000*y^3-160.0000000*x+1600.000000*x*y-3839.999999*x*y^2+2560.000000*x*y^3+384.0000000*x^2-3840.000000*x^2*y+9215.999998*x^2*y^2-6144.000001*x^2*y^3-256.0000000*x^3+2560.000000*x^3*y-6143.999998*x^3*y^2+4096.000000*x^3*y^3)+(diff(A[3, 2](t), t))*(-12.00000000+64.00000002*y-64.00000002*y^2+120.0000000*x-640.0000002*x*y+640.0000002*x*y^2-288.0000001*x^2+1536.000000*x^2*y-1536.000000*x^2*y^2+192.0000000*x^3-1024.000000*x^3*y+1024.000000*x^3*y^2)+(diff(A[3, 1](t), t))*(8.000000003-16.00000000*y-80.00000003*x+160.0000000*x*y+192.0000000*x^2-384.0000000*x^2*y-128.0000001*x^3+256.0000000*x^3*y)-A[0, 3](t)*(-191.9999999+384.0000000*y)+(diff(A[3, 0](t), t))*(-4.000000000+40.00000000*x-96.00000002*x^2+64.00000001*x^3)+(diff(A[2, 3](t), t))*(-12.00000000+120.0000000*y-287.9999999*y^2+192.0000000*y^3+64.00000000*x-640.0000000*x*y+1536.000000*x*y^2-1024.000000*x*y^3-64.00000000*x^2+640.0000000*x^2*y-1536.000000*x^2*y^2+1024.000000*x^2*y^3)+(diff(A[2, 2](t), t))*(8.999999999-48.00000002*y+48.00000002*y^2-48.00000000*x+256.0000001*x*y-256.0000001*x*y^2+48.00000000*x^2-256.0000001*x^2*y+256.0000001*x^2*y^2)+(diff(A[2, 1](t), t))*(-6.000000002+12.00000000*y+32.00000001*x-64.00000000*x*y-32.00000001*x^2+64.00000000*x^2*y)+(diff(A[2, 0](t), t))*(3.000000000-16.00000000*x+16.00000000*x^2)+(diff(A[1, 3](t), t))*(8.000000003-80.00000003*y+192.0000000*y^2-128.0000000*y^3-16.00000000*x+160.0000000*x*y-383.9999999*x*y^2+256.0000000*x*y^3)+(diff(A[1, 2](t), t))*(-6.000000000+32.00000001*y-32.00000001*y^2+12.00000000*x-64.00000002*x*y+64.00000002*x*y^2):
for i2 from 0 while i2 <= N-1 do odes11[0, i2] := simplify(eval(residual, [x = 0, y = i2*ymax/(N-1)])) = 0; odes11[N-1, i2] := simplify(eval(residual, [x = xmax, y = i2*ymax/(N-1)])) = 0 end do:
8
odes_Combine := {seq(seq(odes11[i, j], i = 0 .. N-1), j = 0 .. N-1)}:
sys111 := solve(odes_Combine, `~`[diff](var, t)):
ICS1 := {A[0, 0](0) = .444104979341173495851499233536, A[0, 1](0) = .198590961107083475045046921568, A[0, 2](0) = -0.167999146492673347540059075790e-1, A[0, 3](0) = -0.869171705198864625153083083786e-3, A[1, 0](0) = .198590961107083475045046921567, A[1, 1](0) = 0.888041604305848495880917177172e-1, A[1, 2](0) = -0.751243816645416714455046298805e-2, A[1, 3](0) = -0.388668563362181391196975707953e-3, A[2, 0](0) = -0.167999146492673347540059075793e-1, A[2, 1](0) = -0.751243816645416714455046298835e-2, A[2, 2](0) = 0.635518954643030408055028178047e-3, A[2, 3](0) = 0.328796368925226898150257328603e-4, A[3, 0](0) = -0.869171705198864625153083083734e-3, A[3, 1](0) = -0.388668563362181391196975707910e-3, A[3, 2](0) = 0.328796368925226898150257328592e-4, A[3, 3](0) = 0.170108305076655667148638268230e-5}:
f, diffs := eval(GenerateMatrix(`~`[`-`](`~`[rhs](sys222), `~`[lhs](sys222)), var1))
f, diffs := Matrix(16, 16, {(1, 1) = 0, (1, 2) = 0, (1, 3) = 32., (1, 4) = 0.494812294492356575865153049102e-27, (1, 5) = 0, (1, 6) = 0, (1, 7) = 0.120000000000000000001649374315e-7, (1, 8) = -0.107999999927999999998854228220e-6, (1, 9) = 32.0000000200000000000000000000, (1, 10) = -0.199999999999999999998350625685e-7, (1, 11) = 0.249999999859375000081951230025e-7, (1, 12) = -0.700000000203125000132933066388e-7, (1, 13) = 0.196000000000000000000494812294e-6, (1, 14) = 0.292000000072000000001204420404e-6, (1, 15) = -0.458000000726562499721923065316e-6, (1, 16) = 0.682900000453875000014432471170e-5, (2, 1) = 0, (2, 2) = 0, (2, 3) = 0, (2, 4) = -0.377561971763063776372092766396e-27, (2, 5) = 0, (2, 6) = 0, (2, 7) = 32.0000000000000000000000000000, (2, 8) = 0.719999999999999999998878327317e-7, (2, 9) = 0, (2, 10) = -0.125853990587687925457364255465e-27, (2, 11) = 0.906355783222184042180194163758e-27, (2, 12) = 0.135077431625990682476379737660e-25, (2, 13) = 96.0000000000000000000000000001, (2, 14) = 0.719999999999999999989394464730e-7, (2, 15) = -0.549999999914062500010607576813e-6, (2, 16) = 0.202000000048749999997617654955e-5, (3, 1) = 0, (3, 2) = 0, (3, 3) = 0, (3, 4) = 0.855583965847405137008732798371e-28, (3, 5) = 0, (3, 6) = 0, (3, 7) = -0.257808598553160159742093659020e-28, (3, 8) = -0.377264825438544618607975742790e-27, (3, 9) = 0, (3, 10) = 0.285194655282468379002910932790e-28, (3, 11) = 31.9999999925000000046874999970, (3, 12) = 0.326865301360930805043812804544e-26, (3, 13) = -0.773425795659480479226280977060e-28, (3, 14) = -0.313579545661510489918366218529e-27, (3, 15) = -0.149999999882812500075601322065e-6, (3, 16) = 0.324999999796875000093151106353e-6, (4, 1) = 0, (4, 2) = 0, (4, 3) = 0, (4, 4) = -0.384112032581666751703476763000e-29, (4, 5) = 0, (4, 6) = 0, (4, 7) = 0.265935771387910529598689301718e-29, (4, 8) = 0.399754551928273029196600976861e-28, (4, 9) = 0, (4, 10) = -0.128037344193888917234492254333e-29, (4, 11) = 0.173718566046259004921454811253e-28, (4, 12) = -0.553232882345597286403223410199e-27, (4, 13) = 0.797807314163731588796067905154e-29, (4, 14) = 0.427742792008362106477653509643e-28, (4, 15) = 31.9999999950000000007812499996, (4, 16) = 0.583137134641934297089284679036e-26, (5, 1) = 0, (5, 2) = 0, (5, 3) = 0, (5, 4) = 96.0000000000000000000000000001, (5, 5) = 0, (5, 6) = 0, (5, 7) = -0.125853990576278889372664086359e-27, (5, 8) = -0.780000000000000000003341913398e-7, (5, 9) = 0, (5, 10) = 32.0000000000000000000000000000, (5, 11) = 0.155215894719877680168982772333e-28, (5, 12) = 0.179999999957812500011610427218e-6, (5, 13) = -0.377561971728836668117992259076e-27, (5, 14) = 0.121999999999999999999928850210e-6, (5, 15) = 0.957742348838601502120463181878e-26, (5, 16) = 0.413250000106171874986265224797e-5, (6, 1) = 0, (6, 2) = 0, (6, 3) = 0, (6, 4) = -0.821348457439978150891092618719e-28, (6, 5) = 0, (6, 6) = 0, (6, 7) = -0.273782819058452669879599110853e-28, (6, 8) = 95.9999999999999999999999999997, (6, 9) = 0, (6, 10) = -0.273782819146659383630364206240e-28, (6, 11) = 0.294057068291966163490658104104e-27, (6, 12) = -0.253498333196688505804635565222e-27, (6, 13) = -0.821348457175358009638797332558e-28, (6, 14) = 95.9999999999999999999999999997, (6, 15) = 0.212121033252676198558579131631e-28, (6, 16) = 0.649999999999999999980740836208e-6, (7, 1) = 0, (7, 2) = 0, (7, 3) = 0, (7, 4) = 0.186123768597305842557431955743e-28, (7, 5) = 0, (7, 6) = 0, (7, 7) = 0.214460223691860703703477959545e-28, (7, 8) = 0.317673924810187018756335641686e-28, (7, 9) = 0, (7, 10) = 0.620412561991019475191439852476e-29, (7, 11) = 0.753895620987131323747484439705e-28, (7, 12) = 95.9999999700000000093749999970, (7, 13) = 0.643380671075582111110433878635e-28, (7, 14) = 0.348244413167432788858088750543e-30, (7, 15) = -0.195081345734130085456007896310e-26, (7, 16) = 0.162499999949218750020914346448e-6, (8, 1) = 0, (8, 2) = 0, (8, 3) = 0, (8, 4) = -0.835597462589282450911924283887e-30, (8, 5) = 0, (8, 6) = 0, (8, 7) = -0.168983990754200234313642237958e-29, (8, 8) = 0.255518912827614707211229660888e-30, (8, 9) = 0, (8, 10) = -0.278532487529760816970641427962e-30, (8, 11) = -0.912041057783558505972445866734e-29, (8, 12) = 0.152862192823148604497047654434e-28, (8, 13) = -0.506951972262600702940926713875e-29, (8, 14) = 0.212025424265299406832408057357e-29, (8, 15) = 0.158222957859551043617221056103e-27, (8, 16) = 96.0000000000000000000000000002, (9, 1) = 0, (9, 2) = 0, (9, 3) = 0, (9, 4) = -0.773425795970180636575593526265e-28, (9, 5) = 0, (9, 6) = 0, (9, 7) = 0.285194655390087477280223771532e-28, (9, 8) = -0.241100887243597349107036806234e-27, (9, 9) = 0, (9, 10) = -0.257808598656726878858531175422e-28, (9, 11) = 32.0000000125000000000000000004, (9, 12) = 0.999999999843750000174507862823e-8, (9, 13) = 0.855583966170262431840671314596e-28, (9, 14) = -0.104420360226003256663758222866e-27, (9, 15) = 0.600000000000000000027497059897e-7, (9, 16) = 0.900000000046874999977170328969e-6, (10, 1) = 0, (10, 2) = 0, (10, 3) = 0, (10, 4) = 0.643380671224932994877201196193e-28, (10, 5) = 0, (10, 6) = 0, (10, 7) = 0.620412562284547562356437593923e-29, (10, 8) = -0.782971264706294608812923943602e-28, (10, 9) = 0, (10, 10) = 0.214460223741644331625733732064e-28, (10, 11) = -0.117716452160171050903010422567e-27, (10, 12) = -0.324249553007268016939337229307e-26, (10, 13) = 0.186123768685364268706931278177e-28, (10, 14) = 0.210791990319339808396292213890e-27, (10, 15) = 95.9999999999999999999999999990, (10, 16) = 0.601289924118833452883693495332e-26, (11, 1) = 0, (11, 2) = 0, (11, 3) = 0, (11, 4) = -0.145794923079456919867181504653e-28, (11, 5) = 0, (11, 6) = 0, (11, 7) = -0.485983076931523066223938348837e-29, (11, 8) = 0.703045314344404024740114826873e-28, (11, 9) = 0, (11, 10) = -0.485983076931523066223938348844e-29, (11, 11) = 0.154061910958820937154327251969e-28, (11, 12) = 0.586431085917646726477197552134e-27, (11, 13) = -0.145794923079456919867181504651e-28, (11, 14) = 0.327116591013740734656854347967e-28, (11, 15) = 0.186427448215109472676159333906e-27, (11, 16) = 0.727156843809743343593213639608e-26, (12, 1) = 0, (12, 2) = 0, (12, 3) = 0, (12, 4) = 0.654542236344866764687318521378e-30, (12, 5) = 0, (12, 6) = 0, (12, 7) = 0.382930495785563772474113758933e-30, (12, 8) = -0.765771840140216030924576968705e-29, (12, 9) = 0, (12, 10) = 0.218180745448288921562439507126e-30, (12, 11) = -0.591357855581324858104400230586e-30, (12, 12) = 0.164090126078907967224367765176e-28, (12, 13) = 0.114879148735669131742234127680e-29, (12, 14) = -0.733606589050003370341598338138e-29, (12, 15) = 0.279365514914751130455040418258e-28, (12, 16) = -0.138821502091830040436688448298e-26, (13, 1) = 0, (13, 2) = 0, (13, 3) = 0, (13, 4) = 0.797807313447167969819086050522e-29, (13, 5) = 0, (13, 6) = 0, (13, 7) = -0.128037344212226672551029214969e-29, (13, 8) = 0.262885403001488132812902903311e-28, (13, 9) = 0, (13, 10) = 0.265935771149055989939695350174e-29, (13, 11) = -0.349411324204567081081722661297e-28, (13, 12) = 31.9999999950000000007812499995, (13, 13) = -0.384112032636680017653087644907e-29, (13, 14) = 0.119403167752948354510697994999e-28, (13, 15) = -0.452504513537780686847551220204e-27, (13, 16) = 0.149999999976562500006592455374e-6, (14, 1) = 0, (14, 2) = 0, (14, 3) = 0, (14, 4) = -0.506951972202161632959380608780e-29, (14, 5) = 0, (14, 6) = 0, (14, 7) = -0.278532487328297250365487744273e-30, (14, 8) = 0.100313589069551339782957918087e-28, (14, 9) = 0, (14, 10) = -0.168983990734053877653126869593e-29, (14, 11) = 0.876003797684675659527198447426e-29, (14, 12) = 0.309396538522635365039103628797e-27, (14, 13) = -0.835597461984891751096463232820e-30, (14, 14) = -0.169500948608311509445295032991e-28, (14, 15) = 0.104005614175784513152332127959e-27, (14, 16) = 95.9999999999999999999999999996, (15, 1) = 0, (15, 2) = 0, (15, 3) = 0, (15, 4) = 0.114879148750778899237620653952e-29, (15, 5) = 0, (15, 6) = 0, (15, 7) = 0.218180745498654813213727928025e-30, (15, 8) = -0.867251219227502985269662069579e-29, (15, 9) = 0, (15, 10) = 0.382930495835929664125402179841e-30, (15, 11) = -0.267864188359583543656192185112e-29, (15, 12) = -0.387791753042961333529856694716e-28, (15, 13) = 0.654542236495964439641183784074e-30, (15, 14) = -0.523627245808308931882255033583e-29, (15, 15) = 0.369199231034048272468531636165e-28, (15, 16) = -0.123439611085554953594747603640e-26, (16, 1) = 0, (16, 2) = 0, (16, 3) = 0, (16, 4) = -0.515746730509193430144544493936e-31, (16, 5) = 0, (16, 6) = 0, (16, 7) = -0.171915576836397810048181497977e-31, (16, 8) = 0.857347676859656256220355661580e-30, (16, 9) = 0, (16, 10) = -0.171915576836397810048181497979e-31, (16, 11) = 0.182597096197097886514765184582e-30, (16, 12) = -0.370616214664321329971866697584e-29, (16, 13) = -0.515746730509193430144544493932e-31, (16, 14) = 0.865925397235117524875431212196e-30, (16, 15) = -0.750058451906403875595888288641e-29, (16, 16) = 0.183460376006651920829411996611e-27}), Vector(16, {(1) = diff(A[0, 0](t), t), (2) = diff(A[0, 1](t), t), (3) = diff(A[0, 2](t), t), (4) = diff(A[0, 3](t), t), (5) = diff(A[1, 0](t), t), (6) = diff(A[1, 1](t), t), (7) = diff(A[1, 2](t), t), (8) = diff(A[1, 3](t), t), (9) = diff(A[2, 0](t), t), (10) = diff(A[2, 1](t), t), (11) = diff(A[2, 2](t), t), (12) = diff(A[2, 3](t), t), (13) = diff(A[3, 0](t), t), (14) = diff(A[3, 1](t), t), (15) = diff(A[3, 2](t), t), (16) = diff(A[3, 3](t), t)})
npts := Ntt:
Download Question1.mw
Suppose one has the following equation,
Based on that equation, I have two questions:
1. How may one solve it for \kappa using Maple?
2. How may we simplify it?
Ps: I have tried to use the "solve" and "simplify" commands. However, Maplesoft does not return a result but rather the same equation.
I'd like to sort variables which are non-commutative and obey certain commuting rules in a preferred order. Here is a minimal example
with(Physics)
Setup(mathematicalnotation = true):Setup(noncommutativeprefix = {q, w}, algebrarule = {%Commutator(q, w) = A})
If I want to rewrite q*w as A+w*q since I prefer the order w>q, what should I do? I tried sort(Simplify(q*w, algebrarules), [w, q]) but it doesn't work.
Thank you in advance.
I'm running Maple Flow 2022 on a Win10 Pro PC...
When looking at a Maple Flow worksheet I press Ctl-F to search for something on the worksheet ...
The search seems to work but the "found text" turns white ... so it is hard to see ... any fix for this?
Also, Is Dark Mode available for Maple Flow?
I read it somewhere along the way but can't find it now ...
When entering Text into a Text Container you can inter-mix math in the Text Container ...
I think it was some key-stroke that told Maple Flow that you were switchng to entering Math ...
Can someone please remind me how to do this.
Thanks for any Help.
Hello Guys
I got the Mapple 2022 Student version and I try a couple of time to firgure out why that doesn't work at my Student Version. Please, could anybody help me. Thx a lot.
Newton Method:
f(x) = x^2 assigned to function why I doesn't have right click for this function?
g(x) = x - f(x)/f'(x);
g(1.3) doesn't work because faild he want 2 arguments. That I figure out if I assigned like this
g(x) := x->x f(x)/f'(x) but he do not calc that right. It make me really creapy. Maybe tha Student version doesn't have this fearure is it possible?
This is another think.
a := x^2;
D(a);
                            2 D(x) x ???? why no 2x?
Next example:
f := x -> 5*x^3 + x - 7
D2f := x -> diff(f(x), x)
                         D2f:=x->d/dx f(x) ??? why not 15x^2+1?
Hello.
Is there a way to reduce the time of the process of calculations in maple?
I have 26 coupled simple algebraic equations. But still, I could not get any solution for them.
My codes are as follows:
eq[1] := d[0] = 1:
eq[2] := d[0] + d[1] + d[2] + d[3] + d[4] + d[5] + d[6] + d[7] = 0:
eq[3] := b[0] = 1:
eq[4] := b[0] + b[1] + b[2] + b[3] + b[4] + b[5] + b[6] + b[7] = 0:
eq[5] := a[0] = -0.5:
eq[6] := d[1] = 1 + 1.0*a[2]:
eq[7] := a[0] + a[1] + a[2] + a[3] + a[4] + a[5] + a[6] + a[7] + a[8] + a[9] = 0.5:
eq[8] := d[1] + 2*d[2] + 3*d[3] + 4*d[4] + 5*d[5] + 6*d[6] + 7*d[7] = 1.0*a[2] + 3.0*a[3] + 6.0*a[4] + 10.0*a[5] + 15.0*a[6] + 21.0*a[7] + 28.0*a[8] + 36.0*a[9]:
eq[9] := 24*a[4] - 2.104513094*a[1]*a[2] + 6.313539282*a[0]*a[3] + 5.165076420*b[1] + 5.261282735*d[1] = 0:
eq[10] := -88.3895499*a[7]^2 - 191.5106915*a[7]*a[8] - 176.7790999*a[7]*a[9] - 117.8527333*a[8]^2 - 252.5415715*a[8]*a[9] - 151.5249428*a[9]^2 + 25.25415713*a[0]*a[4] + 63.13539282*a[0]*a[5] + 126.2707856*a[0]*a[6] + 220.9738749*a[0]*a[7] + 353.5581998*a[0]*a[8] + 530.3372997*a[0]*a[9] + 12.62707857*a[1]*a[4] + 42.09026188*a[1]*a[5] + 94.70308919*a[1]*a[6] + 176.7790999*a[1]*a[7] + 294.6318332*a[1]*a[8] + 454.5748283*a[1]*a[9] - 4.209026188*a[2]^2 - 12.62707857*a[2]*a[3] - 8.41805237*a[2]*a[4] + 10.52256547*a[2]*a[5] + 50.50831422*a[2]*a[6] + 117.8527333*a[2]*a[7] + 218.8693618*a[2]*a[8] + 359.8717391*a[2]*a[9] - 12.62707857*a[3]^2 - 31.56769641*a[3]*a[4] - 25.25415713*a[3]*a[5] + 50.5083143*a[3]*a[7] + 132.5843249*a[3]*a[8] + 252.5415713*a[3]*a[9] - 25.25415713*a[4]^2 - 58.92636665*a[4]*a[5] - 50.5083142*a[4]*a[6] - 18.9406178*a[4]*a[7] + 42.0902619*a[4]*a[8] + 138.8978642*a[4]*a[9] - 42.09026188*a[5]^2 - 94.7030892*a[5]*a[6] - 84.1805237*a[5]*a[7] - 46.2992881*a[5]*a[8] + 25.2541571*a[5]*a[9] - 63.1353929*a[6]^2 - 138.8978642*a[6]*a[7] - 126.2707857*a[6]*a[8] - 82.0760107*a[6]*a[9] - 2.104513094*a[1]*a[2] + 6.313539282*a[0]*a[3] + 26.30641368*d[5] + 31.56769641*d[6] + 36.82897914*d[7] + 15.78384820*d[3] + 21.04513094*d[4] + 5.261282735*d[1] + 10.52256547*d[2] + 36.15553494*b[7] + 25.82538210*b[5] + 30.99045852*b[6] + 10.33015284*b[2] + 15.49522926*b[3] + 20.66030568*b[4] + 5.165076420*b[1] + 3024.*a[9] + 360.*a[6] + 840.*a[7] + 1680.*a[8] + 24.*a[4] + 120.*a[5] = 0:
eq[11] := 120.*a[5] - 4.209026188*a[2]^2 + 25.25415713*a[0]*a[4] + 10.33015284*b[2] + 10.52256547*d[2] = 0:
eq[12] := -972.2850495*a[7]^2 - 2298.128299*a[7]*a[8] - 2298.128298*a[7]*a[9] - 1532.085532*a[8]^2 - 3535.581998*a[8]*a[9] - 2272.874142*a[9]^2 + 25.25415713*a[0]*a[4] + 126.2707856*a[0]*a[5] + 378.8123569*a[0]*a[6] + 883.8954995*a[0]*a[7] + 1767.790999*a[0]*a[8] + 3182.023798*a[0]*a[9] + 25.25415713*a[1]*a[4] + 126.2707856*a[1]*a[5] + 378.8123569*a[1]*a[6] + 883.8954995*a[1]*a[7] + 1767.790999*a[1]*a[8] + 3182.023798*a[1]*a[9] - 4.209026188*a[2]^2 - 25.25415713*a[2]*a[3] - 25.25415713*a[2]*a[4] + 42.09026184*a[2]*a[5] + 252.5415713*a[2]*a[6] + 707.1163996*a[2]*a[7] + 1532.085532*a[2]*a[8] + 2878.973912*a[2]*a[9] - 37.88123569*a[3]^2 - 126.2707857*a[3]*a[4] - 126.2707857*a[3]*a[5] + 353.5581998*a[3]*a[7] + 1060.674599*a[3]*a[8] + 2272.874141*a[3]*a[9] - 126.2707857*a[4]^2 - 353.5581998*a[4]*a[5] - 353.5581998*a[4]*a[6] - 151.5249424*a[4]*a[7] + 378.812357*a[4]*a[8] + 1388.978642*a[4]*a[9] - 294.6318332*a[5]^2 - 757.6247134*a[5]*a[6] - 757.624714*a[5]*a[7] - 462.992880*a[5]*a[8] + 277.795729*a[5]*a[9] - 568.2185354*a[6]^2 - 1388.978642*a[6]*a[7] - 1388.978642*a[6]*a[8] - 984.912128*a[6]*a[9] + 105.2256547*d[5] + 157.8384820*d[6] + 220.9738748*d[7] + 31.56769640*d[3] + 63.13539282*d[4] + 10.52256547*d[2] + 216.9332096*b[7] + 103.3015284*b[5] + 154.9522926*b[6] + 10.33015284*b[2] + 30.99045852*b[3] + 61.98091704*b[4] + 15120.*a[9] + 720.*a[6] + 2520.*a[7] + 6720.*a[8] + 120.*a[5] = 0:
eq[13] := 720.*a[6] - 25.25415713*a[2]*a[3] + 25.25415713*a[1]*a[4] + 126.2707856*a[0]*a[5] + 30.99045852*b[3] + 31.56769640*d[3] = 0:
eq[14] := -9722.850492*a[7]^2 - 25279.41129*a[7]*a[8] - 27577.53959*a[7]*a[9] - 18385.02639*a[8]^2 - 45962.56593*a[8]*a[9] - 31820.23799*a[9]^2 + 126.2707856*a[0]*a[5] + 757.6247138*a[0]*a[6] + 2651.686498*a[0]*a[7] + 7071.163996*a[0]*a[8] + 15910.11899*a[0]*a[9] + 25.25415713*a[1]*a[4] + 252.5415712*a[1]*a[5] + 1136.437071*a[1]*a[6] + 3535.581998*a[1]*a[7] + 8838.954995*a[1]*a[8] + 19092.14279*a[1]*a[9] - 25.25415713*a[2]*a[3] - 50.50831424*a[2]*a[4] + 126.2707856*a[2]*a[5] + 1010.166285*a[2]*a[6] + 3535.581998*a[2]*a[7] + 9192.513195*a[2]*a[8] + 20152.81739*a[2]*a[9] - 75.76247138*a[3]^2 - 378.8123569*a[3]*a[4] - 505.0831425*a[3]*a[5] + 2121.349198*a[3]*a[7] + 7424.722196*a[3]*a[8] + 18182.99313*a[3]*a[9] - 505.0831426*a[4]^2 - 1767.790999*a[4]*a[5] - 2121.349199*a[4]*a[6] - 1060.674600*a[4]*a[7] + 3030.498859*a[4]*a[8] + 12500.80778*a[4]*a[9] - 1767.790999*a[5]^2 - 5303.372998*a[5]*a[6] - 6060.997709*a[5]*a[7] - 4166.935929*a[5]*a[8] + 2777.95729*a[5]*a[9] - 4545.748282*a[6]^2 - 12500.80779*a[6]*a[7] - 13889.78642*a[6]*a[8] - 10834.03341*a[6]*a[9] + 315.6769641*d[5] + 631.3539280*d[6] + 1104.869374*d[7] + 31.56769640*d[3] + 126.2707856*d[4] + 1084.666048*b[7] + 309.9045852*b[5] + 619.8091704*b[6] + 30.99045852*b[3] + 123.9618341*b[4] + 60480.*a[9] + 720.*a[6] + 5040.*a[7] + 20160.*a[8] - 2.*10^(-7)*a[3]*a[6] = 0:
eq[15] := 2.*d[2] + 5.261282735*a[0]*d[1] - 2.630641368*d[0] = 0:
eq[16] := 17.36935863*d[5] + 27.36935863*d[6] + 39.36935863*d[7] + 3.369358632*d[3] + 9.369358632*d[4] - 2.630641368*d[0] - 2.630641368*d[1] - 0.630641368*d[2] + 36.82897914*a[6]*d[7] + 5.261282735*a[7]*d[1] + 10.52256547*a[7]*d[2] + 15.78384820*a[7]*d[3] + 21.04513094*a[7]*d[4] + 26.30641368*a[7]*d[5] + 31.56769641*a[7]*d[6] + 36.82897914*a[7]*d[7] + 5.261282735*a[8]*d[1] + 10.52256547*a[8]*d[2] + 15.78384820*a[8]*d[3] + 21.04513094*a[8]*d[4] + 26.30641368*a[8]*d[5] + 31.56769641*a[8]*d[6] + 36.82897914*a[8]*d[7] + 5.261282735*a[9]*d[1] + 10.52256547*a[9]*d[2] + 15.78384820*a[9]*d[3] + 21.04513094*a[9]*d[4] + 26.30641368*a[9]*d[5] + 31.56769641*a[9]*d[6] + 36.82897914*a[9]*d[7] + 10.52256547*a[0]*d[2] + 15.78384820*a[0]*d[3] + 21.04513094*a[0]*d[4] + 26.30641368*a[0]*d[5] + 31.56769641*a[0]*d[6] + 36.82897914*a[0]*d[7] + 5.261282735*a[1]*d[1] + 10.52256547*a[1]*d[2] + 15.78384820*a[1]*d[3] + 21.04513094*a[1]*d[4] + 26.30641368*a[1]*d[5] + 31.56769641*a[1]*d[6] + 36.82897914*a[1]*d[7] + 5.261282735*a[2]*d[1] + 10.52256547*a[2]*d[2] + 15.78384820*a[2]*d[3] + 21.04513094*a[2]*d[4] + 26.30641368*a[2]*d[5] + 31.56769641*a[2]*d[6] + 36.82897914*a[2]*d[7] + 5.261282735*a[3]*d[1] + 10.52256547*a[3]*d[2] + 15.78384820*a[3]*d[3] + 21.04513094*a[3]*d[4] + 26.30641368*a[3]*d[5] + 31.56769641*a[3]*d[6] + 36.82897914*a[3]*d[7] + 5.261282735*a[4]*d[1] + 10.52256547*a[4]*d[2] + 15.78384820*a[4]*d[3] + 21.04513094*a[4]*d[4] + 26.30641368*a[4]*d[5] + 31.56769641*a[4]*d[6] + 36.82897914*a[4]*d[7] + 5.261282735*a[5]*d[1] + 10.52256547*a[5]*d[2] + 15.78384820*a[5]*d[3] + 21.04513094*a[5]*d[4] + 26.30641368*a[5]*d[5] + 31.56769641*a[5]*d[6] + 36.82897914*a[5]*d[7] + 5.261282735*a[6]*d[1] + 10.52256547*a[6]*d[2] + 15.78384820*a[6]*d[3] + 21.04513094*a[6]*d[4] + 26.30641368*a[6]*d[5] + 31.56769641*a[6]*d[6] + 5.261282735*a[0]*d[1] = 0:
eq[17] := 6.*d[3] + 5.261282735*a[1]*d[1] + 10.52256547*a[0]*d[2] - 2.630641368*d[1] = 0:
eq[18] := 46.84679316*d[5] + 104.2161518*d[6] + 191.5855104*d[7] - 1.891924104*d[3] + 13.47743453*d[4] - 2.630641368*d[1] - 5.261282736*d[2] + 441.9477498*a[6]*d[7] + 36.82897914*a[7]*d[1] + 84.18052376*a[7]*d[2] + 142.0546338*a[7]*d[3] + 210.4513094*a[7]*d[4] + 289.3705504*a[7]*d[5] + 378.8123569*a[7]*d[6] + 478.7767289*a[7]*d[7] + 42.09026188*a[8]*d[1] + 94.70308923*a[8]*d[2] + 157.8384820*a[8]*d[3] + 231.4964403*a[8]*d[4] + 315.6769641*a[8]*d[5] + 410.3800533*a[8]*d[6] + 515.6057081*a[8]*d[7] + 47.35154462*a[9]*d[1] + 105.2256547*a[9]*d[2] + 173.6223302*a[9]*d[3] + 252.5415713*a[9]*d[4] + 341.9833778*a[9]*d[5] + 441.9477497*a[9]*d[6] + 552.4346872*a[9]*d[7] + 10.52256547*a[0]*d[2] + 31.56769641*a[0]*d[3] + 63.13539282*a[0]*d[4] + 105.2256547*a[0]*d[5] + 157.8384820*a[0]*d[6] + 220.9738749*a[0]*d[7] + 5.261282735*a[1]*d[1] + 21.04513094*a[1]*d[2] + 47.35154461*a[1]*d[3] + 84.18052376*a[1]*d[4] + 131.5320684*a[1]*d[5] + 189.4061784*a[1]*d[6] + 257.8028540*a[1]*d[7] + 10.52256547*a[2]*d[1] + 31.56769641*a[2]*d[2] + 63.13539282*a[2]*d[3] + 105.2256547*a[2]*d[4] + 157.8384820*a[2]*d[5] + 220.9738748*a[2]*d[6] + 294.6318332*a[2]*d[7] + 15.78384820*a[3]*d[1] + 42.09026188*a[3]*d[2] + 78.91924103*a[3]*d[3] + 126.2707856*a[3]*d[4] + 184.1448957*a[3]*d[5] + 252.5415712*a[3]*d[6] + 331.4608123*a[3]*d[7] + 21.04513094*a[4]*d[1] + 52.61282735*a[4]*d[2] + 94.70308923*a[4]*d[3] + 147.3159166*a[4]*d[4] + 210.4513094*a[4]*d[5] + 284.1092676*a[4]*d[6] + 368.2897915*a[4]*d[7] + 26.30641368*a[5]*d[1] + 63.13539282*a[5]*d[2] + 110.4869374*a[5]*d[3] + 168.3610475*a[5]*d[4] + 236.7577231*a[5]*d[5] + 315.6769640*a[5]*d[6] + 405.1187706*a[5]*d[7] + 31.56769641*a[6]*d[1] + 73.65795829*a[6]*d[2] + 126.2707856*a[6]*d[3] + 189.4061784*a[6]*d[4] + 263.0641367*a[6]*d[5] + 347.2446605*a[6]*d[6] = 0:
eq[19] := 24.*d[4] + 10.52256547*a[2]*d[1] + 21.04513094*a[1]*d[2] + 31.56769641*a[0]*d[3] - 5.261282736*d[2] = 0:
eq[20] := 67.38717264*d[5] + 281.0807590*d[6] + 729.5130625*d[7] - 15.78384821*d[3] - 7.56769641*d[4] - 5.261282736*d[2] + 4861.425246*a[6]*d[7] + 220.9738749*a[7]*d[1] + 589.2636663*a[7]*d[2] + 1136.437070*a[7]*d[3] + 1894.061785*a[7]*d[4] + 2893.705504*a[7]*d[5] + 4166.935926*a[7]*d[6] + 5745.320746*a[7]*d[7] + 294.6318332*a[8]*d[1] + 757.6247138*a[8]*d[2] + 1420.546338*a[8]*d[3] + 2314.964404*a[8]*d[4] + 3472.446605*a[8]*d[5] + 4924.560640*a[8]*d[6] + 6702.874204*a[8]*d[7] + 378.8123569*a[9]*d[1] + 947.0308923*a[9]*d[2] + 1736.223302*a[9]*d[3] + 2777.957285*a[9]*d[4] + 4103.800534*a[9]*d[5] + 5745.320747*a[9]*d[6] + 7734.085620*a[9]*d[7] + 31.56769641*a[0]*d[3] + 126.2707856*a[0]*d[4] + 315.6769641*a[0]*d[5] + 631.3539282*a[0]*d[6] + 1104.869374*a[0]*d[7] + 21.04513094*a[1]*d[2] + 94.70308923*a[1]*d[3] + 252.5415712*a[1]*d[4] + 526.1282735*a[1]*d[5] + 947.0308923*a[1]*d[6] + 1546.817124*a[1]*d[7] + 10.52256547*a[2]*d[1] + 63.13539282*a[2]*d[2] + 189.4061784*a[2]*d[3] + 420.9026188*a[2]*d[4] + 789.1924103*a[2]*d[5] + 1325.843249*a[2]*d[6] + 2062.422832*a[2]*d[7] + 31.56769641*a[3]*d[1] + 126.2707856*a[3]*d[2] + 315.6769641*a[3]*d[3] + 631.3539281*a[3]*d[4] + 1104.869374*a[3]*d[5] + 1767.790999*a[3]*d[6] + 2651.686498*a[3]*d[7] + 63.13539282*a[4]*d[1] + 210.4513094*a[4]*d[2] + 473.5154462*a[4]*d[3] + 883.8954995*a[4]*d[4] + 1473.159166*a[4]*d[5] + 2272.874141*a[4]*d[6] + 3314.608123*a[4]*d[7] + 105.2256547*a[5]*d[1] + 315.6769641*a[5]*d[2] + 662.9216246*a[5]*d[3] + 1178.527333*a[5]*d[4] + 1894.061784*a[5]*d[5] + 2841.092676*a[5]*d[6] + 4051.187706*a[5]*d[7] + 157.8384820*a[6]*d[1] + 441.9477497*a[6]*d[2] + 883.8954995*a[6]*d[3] + 1515.249428*a[6]*d[4] + 2367.577230*a[6]*d[5] + 3472.446605*a[6]*d[6] = 0:
eq[21] := 2.119408818*b[2] + 6.176017503*a[0]*b[1] + 42.07215928*a[2] + 0.5*d[0] = 0:
eq[22] := 0.5*d[5] + 0.5*d[6] + 0.5*d[7] + 0.5*d[3] + 0.5*d[4] + 0.5*d[0] + 0.5*d[1] + 0.5*d[2] + 44.50758518*b[7] + 21.19408818*b[5] + 31.79113227*b[6] + 2.119408818*b[2] + 6.358226454*b[3] + 12.71645291*b[4] + 1514.597734*a[9] + 631.0823892*a[6] + 883.5153448*a[7] + 1178.020460*a[8] + 126.2164778*a[3] + 252.4329557*a[4] + 420.7215928*a[5] + 42.07215928*a[2] + 12.35203501*a[0]*b[2] + 18.52805251*a[0]*b[3] + 24.70407001*a[0]*b[4] + 30.88008752*a[0]*b[5] + 37.05610502*a[0]*b[6] + 43.23212252*a[0]*b[7] + 6.176017503*a[1]*b[1] + 12.35203501*a[1]*b[2] + 18.52805251*a[1]*b[3] + 24.70407001*a[1]*b[4] + 30.88008752*a[1]*b[5] + 37.05610502*a[1]*b[6] + 43.23212252*a[1]*b[7] + 6.176017503*a[2]*b[1] + 12.35203501*a[2]*b[2] + 18.52805251*a[2]*b[3] + 24.70407001*a[2]*b[4] + 30.88008752*a[2]*b[5] + 37.05610502*a[2]*b[6] + 43.23212252*a[2]*b[7] + 6.176017503*a[3]*b[1] + 12.35203501*a[3]*b[2] + 18.52805251*a[3]*b[3] + 24.70407001*a[3]*b[4] + 30.88008752*a[3]*b[5] + 37.05610502*a[3]*b[6] + 43.23212252*a[3]*b[7] + 6.176017503*a[4]*b[1] + 12.35203501*a[4]*b[2] + 18.52805251*a[4]*b[3] + 24.70407001*a[4]*b[4] + 30.88008752*a[4]*b[5] + 37.05610502*a[4]*b[6] + 43.23212252*a[4]*b[7] + 6.176017503*a[5]*b[1] + 12.35203501*a[5]*b[2] + 18.52805251*a[5]*b[3] + 24.70407001*a[5]*b[4] + 30.88008752*a[5]*b[5] + 37.05610502*a[5]*b[6] + 43.23212252*a[5]*b[7] + 6.176017503*a[6]*b[1] + 12.35203501*a[6]*b[2] + 18.52805251*a[6]*b[3] + 24.70407001*a[6]*b[4] + 30.88008752*a[6]*b[5] + 37.05610502*a[6]*b[6] + 43.23212252*a[6]*b[7] + 6.176017503*a[7]*b[1] + 12.35203501*a[7]*b[2] + 18.52805251*a[7]*b[3] + 24.70407001*a[7]*b[4] + 30.88008752*a[7]*b[5] + 37.05610502*a[7]*b[6] + 43.23212252*a[7]*b[7] + 6.176017503*a[8]*b[1] + 12.35203501*a[8]*b[2] + 18.52805251*a[8]*b[3] + 24.70407001*a[8]*b[4] + 30.88008752*a[8]*b[5] + 37.05610502*a[8]*b[6] + 43.23212252*a[8]*b[7] + 6.176017503*a[9]*b[1] + 12.35203501*a[9]*b[2] + 18.52805251*a[9]*b[3] + 24.70407001*a[9]*b[4] + 30.88008752*a[9]*b[5] + 37.05610502*a[9]*b[6] + 43.23212252*a[9]*b[7] + 6.176017503*a[0]*b[1] = 0:
eq[23] := 6.358226454*b[3] + 6.176017503*a[1]*b[1] + 12.35203501*a[0]*b[2] + 126.2164778*a[3] + 0.5*d[1] = 0:
eq[24] := 2.5*d[5] + 3.0*d[6] + 3.5*d[7] + 1.5*d[3] + 2.0*d[4] + 0.5*d[1] + d[2] + 222.5379259*b[7] + 63.58226454*b[5] + 127.1645291*b[6] + 6.358226454*b[3] + 25.43290582*b[4] + 10602.18414*a[9] + 2524.329557*a[6] + 4417.576724*a[7] + 7068.122760*a[8] + 126.2164778*a[3] + 504.8659114*a[4] + 1262.164778*a[5] + 12.35203501*a[0]*b[2] + 37.05610502*a[0]*b[3] + 74.11221004*a[0]*b[4] + 123.5203501*a[0]*b[5] + 185.2805251*a[0]*b[6] + 259.3927351*a[0]*b[7] + 6.176017503*a[1]*b[1] + 24.70407002*a[1]*b[2] + 55.58415753*a[1]*b[3] + 98.81628005*a[1]*b[4] + 154.4004376*a[1]*b[5] + 222.3366301*a[1]*b[6] + 302.6248576*a[1]*b[7] + 12.35203501*a[2]*b[1] + 37.05610502*a[2]*b[2] + 74.11221004*a[2]*b[3] + 123.5203501*a[2]*b[4] + 185.2805251*a[2]*b[5] + 259.3927351*a[2]*b[6] + 345.8569801*a[2]*b[7] + 18.52805251*a[3]*b[1] + 49.40814003*a[3]*b[2] + 92.64026255*a[3]*b[3] + 148.2244201*a[3]*b[4] + 216.1606126*a[3]*b[5] + 296.4488402*a[3]*b[6] + 389.0891027*a[3]*b[7] + 24.70407001*a[4]*b[1] + 61.76017503*a[4]*b[2] + 111.1683151*a[4]*b[3] + 172.9284901*a[4]*b[4] + 247.0407002*a[4]*b[5] + 333.5049452*a[4]*b[6] + 432.3212252*a[4]*b[7] + 30.88008752*a[5]*b[1] + 74.11221004*a[5]*b[2] + 129.6963676*a[5]*b[3] + 197.6325601*a[5]*b[4] + 277.9207877*a[5]*b[5] + 370.5610502*a[5]*b[6] + 475.5533477*a[5]*b[7] + 37.05610502*a[6]*b[1] + 86.46424505*a[6]*b[2] + 148.2244201*a[6]*b[3] + 222.3366301*a[6]*b[4] + 308.8008752*a[6]*b[5] + 407.6171552*a[6]*b[6] + 518.7854702*a[6]*b[7] + 43.23212252*a[7]*b[1] + 98.81628005*a[7]*b[2] + 166.7524726*a[7]*b[3] + 247.0407001*a[7]*b[4] + 339.6809627*a[7]*b[5] + 444.6732602*a[7]*b[6] + 562.0175927*a[7]*b[7] + 49.40814002*a[8]*b[1] + 111.1683151*a[8]*b[2] + 185.2805251*a[8]*b[3] + 271.7447701*a[8]*b[4] + 370.5610502*a[8]*b[5] + 481.7293652*a[8]*b[6] + 605.2497153*a[8]*b[7] + 55.58415753*a[9]*b[1] + 123.5203501*a[9]*b[2] + 203.8085776*a[9]*b[3] + 296.4488401*a[9]*b[4] + 401.4411377*a[9]*b[5] + 518.7854703*a[9]*b[6] + 648.4818378*a[9]*b[7] = 0:
eq[25] := 25.43290582*b[4] + 12.35203501*a[2]*b[1] + 24.70407002*a[1]*b[2] + 37.05610502*a[0]*b[3] + 504.8659114*a[4] + d[2] = 0:
eq[26] := 10.0*d[5] + 15.0*d[6] + 21.0*d[7] + 3.0*d[3] + 6.0*d[4] + d[2] + 890.1517036*b[7] + 127.1645291*b[5] + 381.4935873*b[6] + 25.43290582*b[4] + 63613.10484*a[9] + 7572.988671*a[6] + 17670.30690*a[7] + 35340.61380*a[8] + 504.8659114*a[4] + 2524.329556*a[5] + 37.05610502*a[0]*b[3] + 148.2244201*a[0]*b[4] + 370.5610502*a[0]*b[5] + 741.1221004*a[0]*b[6] + 1296.963676*a[0]*b[7] + 24.70407002*a[1]*b[2] + 111.1683151*a[1]*b[3] + 296.4488402*a[1]*b[4] + 617.6017504*a[1]*b[5] + 1111.683151*a[1]*b[6] + 1815.749146*a[1]*b[7] + 12.35203501*a[2]*b[1] + 74.11221005*a[2]*b[2] + 222.3366301*a[2]*b[3] + 494.0814003*a[2]*b[4] + 926.4026256*a[2]*b[5] + 1556.356411*a[2]*b[6] + 2420.998862*a[2]*b[7] + 37.05610502*a[3]*b[1] + 148.2244201*a[3]*b[2] + 370.5610503*a[3]*b[3] + 741.1221006*a[3]*b[4] + 1296.963676*a[3]*b[5] + 2075.141881*a[3]*b[6] + 3112.712822*a[3]*b[7] + 74.11221004*a[4]*b[1] + 247.0407002*a[4]*b[2] + 555.8415753*a[4]*b[3] + 1037.570941*a[4]*b[4] + 1729.284901*a[4]*b[5] + 2668.039561*a[4]*b[6] + 3890.891028*a[4]*b[7] + 123.5203501*a[5]*b[1] + 370.5610502*a[5]*b[2] + 778.1782055*a[5]*b[3] + 1383.427921*a[5]*b[4] + 2223.366301*a[5]*b[5] + 3335.049452*a[5]*b[6] + 4755.533478*a[5]*b[7] + 185.2805251*a[6]*b[1] + 518.7854703*a[6]*b[2] + 1037.570941*a[6]*b[3] + 1778.693041*a[6]*b[4] + 2779.207876*a[6]*b[5] + 4076.171553*a[6]*b[6] + 5706.640175*a[6]*b[7] + 259.3927351*a[7]*b[1] + 691.7139604*a[7]*b[2] + 1334.019781*a[7]*b[3] + 2223.366302*a[7]*b[4] + 3396.809627*a[7]*b[5] + 4891.405863*a[7]*b[6] + 6744.211115*a[7]*b[7] + 345.8569802*a[8]*b[1] + 889.3465205*a[8]*b[2] + 1667.524727*a[8]*b[3] + 2717.447702*a[8]*b[4] + 4076.171553*a[8]*b[5] + 5780.752383*a[8]*b[6] + 7868.246300*a[8]*b[7] + 444.6732602*a[9]*b[1] + 1111.683151*a[9]*b[2] + 2038.085777*a[9]*b[3] + 3260.937242*a[9]*b[4] + 4817.293653*a[9]*b[5] + 6744.211114*a[9]*b[6] + 9078.745732*a[9]*b[7] = 0:
solve([seq(eq[i], i = 1 .. 26)],{seq(a[i], i = 0 .. 9),seq(b[i], i = 0 .. 7),seq(d[i], i = 0 .. 7)});
Thanks a lot.
Suppose I have a list of 10 thousand expressions containing the symbol x. I would like to integrate all of them in the range x=0..1 and store the result in a new list or array of 10 thousand elements. I run Maple on a server with 32 CPUs and would like to parallelize the computation. Could you give some code samples showing how this can be done? Since the starting expressions vary greatly in complexity, some kind of dynamics load balancing (rather than dividing the calculation "equally") would be also very useful. Thanks for any help!
First 348 349 350 351 352 353 354 Last Page 350 of 2464
