Hello, I need help to find the real and Imaginary components of following complex model using maple, here q=u+iv,
The maple worksheet shows an incorrect evaluation of the integral in (1) which is a standard integral representation of a Bessel function.  Equations (2)-(5) along with the graph show the incorrectness of the evaluation.  What is going on?
Bessel.mw
This worksheet defines two physics problems and fails in the attempt to solve the first one.
How can these problems be solved?
Rolling_circle.mw
Hello, can somebody give some suggestions to speed up this summations? I am summing up to 10 and it take ages (about 10min).
Digits := 10;
n1 := 122;
x := 54;
n2 := 65;
y := 14;
alpha1 := 1.1;
beta1 := 1.1;
alpha2 := 1.1;
beta2 := 1.1;
Sigma2 := (j, l, psi0) -> Sum(Sum(Sum(psi0^(-y - alpha2 - l - alpha2*h - v)*pochhammer(beta2 - 1, h)*pochhammer(beta1 - 1, u)*pochhammer(y + alpha2 + l + alpha2*h, v)*2^(-y - alpha2 - l - alpha2*h - x - alpha1 - j - alpha1*u - v)*(psi0 - 1)^v/(h!*(y + alpha2 + l + alpha2*h)*u!*v!*(y + alpha2 + l + alpha2*h + x + alpha1 + j + alpha1*u + v)), u = 0 .. upto), h = 0 .. upto), v = 0 .. upto);
F2 := psi0 -> Sum(binomial(n1 - x, j)*Sum(binomial(n2 - y, l)*(-1)^(j + l)*Sigma2(j, l, psi0), l = 0 .. n2 - y), j = 0 .. n1 - x);
upto:=10;
F2(5.620);
Found this old procedure code and revived it
Trying to include an Exploreplot as well
a0,a1,a2,b1,b2 are coeifficents in a ode to construct
How about odetype when constructing a ode is this correct in code?
Odegenerator := proc(V, x, y, df, const_values)
    local input_args, xi, F, result, a0, a1, a2, b0, b1, sol, Fsol, rows, numrows, eq, count, odeplot_cmd, ode_type, row_number, values;
    uses plots, PDEtools;
       if nargs = 1 and V = "help" then
        printf("Use this procedure as follows:\n");
        printf("Define an ODE template:\n");
        printf("Odegenerator(V, x, y, df, const_values)\n");
        printf("V: A set of values for iteration over constants (if df > 0)\n");
        printf("x: The independent variable\n");
        printf("y: The function\n");
        printf("df: The row number in the DataFrame or 0 for manual input\n");
        printf("const_values: A list of values for the constants (used if df = 0)\n");
        return;
    if nargs < 4 or nargs > 5 then
        error "Incorrect number of arguments. Expected: V, x, y, df, [const_values (optional)]";
    # Determine the ODE type using odeadvisor for the global eq_template
    ode_type := odeadvisor(eq_template);
    # Display the ODE and its type
    print(eq_template, ode_type);
    rows := [];
    count := 0;
    ###################### BOF manuele invoer ###################
    if df = 0 then
    # If df = 0, use const_values for substitution
    if nargs < 5 or not type(const_values, list) then
        error "When df = 0, a list of constant values must be provided as the fifth argument.";
    # Assign constant values
    if nops(const_values) <> 5 then
        error "The list of constant values must contain exactly 5 elements.";
    # Find the corresponding row number by unique identification
    count := 1;
    for a0 in V do
        for a1 in V do
            for a2 in V do
                for b0 in V do
                    for b1 in V do
                        if [a0, a1, a2, b0, b1] = const_values then
                            row_number := sprintf("%d", count);  # Convert to string
                        count := count + 1;
    if not assigned(row_number) then
        row_number := "Unique (outside iterative rows)";  # Mark as unique
    # Substitute the given values
    eq := subs({'a__0' = const_values[1], 'a__1' = const_values[2], 'a__2' = const_values[3], 'b__0' = const_values[4], 'b__1' = const_values[5]}, eq_template);
    # Solve the equation
    sol := dsolve(eq, y(x));
    if type(sol, `=`) then
        Fsol := rhs(sol);
        Fsol := "No explicit solution";
    # Display the solution and its row number
    odeplot_cmd := DEtools[DEplot](eq, y(x), x = 0 .. 2, y = -10 .. 10, [[y(0) = 1]]);
    print(plots:-display(odeplot_cmd, size = [550, 550]));
    printf("The found function is:\n");
    print(Fsol);
    printf("The corresponding row number is: %s\n", row_number);
    # -- Start of Additional Functionality --
    # Optionally display the simplified ODE
    printf("The simplified ODE using the given coefficients is:\n");
    print(eq, ode_type);
    # -- End of Additional Functionality --
    return Fsol;
     ################# EOF manuele berekening ##################
     ############## BOF iterative berekening##############
        # Iterative approach for DataFrame generation
        for a0 in V do
            for a1 in V do
                for a2 in V do
                    for b0 in V do
                        for b1 in V do
                            xi := x;
                            F := y;
                            # Substitute constant values into the ODE
                            eq := subs({'a__0' = a0, 'a__1' = a1, 'a__2' = a2, 'b__0' = b0, 'b__1' = b1}, eq_template);
                            sol := dsolve(eq, F(xi));
                                Fsol := rhs(sol);
                            rows := [op(rows), [a0, a1, a2, b0, b1, Fsol]];
        numrows := nops(rows);
        result := DataFrame(Matrix(numrows, 6, rows), columns = ['a__0', 'a__1', 'a__2', 'b__0', 'b__1', y(x)]);
        interface(rtablesize = numrows + 10);
        if df > 0 and df <= numrows then
            a0 := result[df, 'a__0'];
            a1 := result[df, 'a__1'];
            a2 := result[df, 'a__2'];
            b0 := result[df, 'b__0'];
            b1 := result[df, 'b__1'];
            # Display the additional parameters
            print(eq, ode_type, [df], [a0, a1, a2, b0, b1]);
            # Retrieve the solution
            Fsol := result[df, y(x)];
            # Display the solution in DEplot
            printf("The found function for row number %d is:\n", df);
            print(Fsol);
            printf("The specified row (%d) is out of bounds for the DataFrame.\n", df);
        return result;
     ########## EOF iteratief bwrekening ########################
# Test cases
V := {0, 1};
eq_template := diff(y(t), t) = 'a__0'*sin(t) + 'a__1'*y(t) + 'a__2'*y(t)^2 + 'b__0'*exp(-t);
{0, 1}
diff(y(t), t) = a__0*sin(t)+a__1*y(t)+a__2*y(t)^2+b__0*exp(-t)
# Iterative test
result := Odegenerator(V, t, y, 25);
diff(y(t), t) = a__0*sin(t)+a__1*y(t)+a__2*y(t)^2+b__0*exp(-t), odeadvisor(diff(y(t), t) = a__0*sin(t)+a__1*y(t)+a__2*y(t)^2+b__0*exp(-t))
diff(y(t), t) = sin(t)+y(t), odeadvisor(diff(y(t), t) = a__0*sin(t)+a__1*y(t)+a__2*y(t)^2+b__0*exp(-t)), [25], [1, 1, 0, 0, 0]
The found function for row number 25 is:
-(1/2)*cos(t)-(1/2)*sin(t)+c__1*exp(t)
module DataFrame () description "two-dimensional rich data container"; local columns, rows, data, binder; option object(BaseDataObject); end module
# Manual input test
Odegenerator(V, t, y, 0, [1, 1, 0, 0, 0]); #0 after y is rownumber = 0 and [1, 1, 0, 0, 0] are coeifficents
The corresponding row number is: 25
Download ODEGENERATORFUNCTIE_opgepakt-uitgebreid_naar_MprimesDEF_14-1-2025.mw
How do I generate a plot within a plot as shown in my example below? The fundemental issue is plot structures like Histogram() etc are not images and so combining them in the way I imagine is non-trivial. I couldn't find a standard way to do this in the help section.
Plot_within_a_plot.mw
NULL``
with(plots)
Consider the two plots p1 and p2.
p1 := plot(sin(x), size = [300, 300])
p2 := plot(sin(x), view = [0 .. Pi, .5 .. 1], size = [300, 300], axes = boxed)
How do I generate a plot within a plot as shown below, if I calculated the plots ahead of time? Is there a standard way to do this?
Download Plot_within_a_plot.mw
Is there an easy way to get the midpoint and distance in maple?
Distance and Midpoint
Table 1: Key Skills
NULLdmf1 := [-3, 1]
[-3, 1]
dmf2 := [3, 2]
[3, 2]
dmf3 := [-2, -3]
[-2, -3]
dmf4 := [3, -2]
[3, -2]
dmf := [dmf1, dmf2, dmf3, dmf4]
[[-3, 1], [3, 2], [-2, -3], [3, -2]]
plot(dmf)
dme1a1 := [1, 3]
[1, 3]``
dme1a2 := [5, 6]
[5, 6]
dme1a3 := [5, 3]
[5, 3]
dme1 := [dme1a1, dme1a2, dme1a3]
[[1, 3], [5, 6], [5, 3]]
plot(dme1)
Download 2.1-Distance_and_Midpoint.mw
Hello everyone, I am facing problem to solve a system of partial differential equations of f, g & q in three variables x,y,t. I have attached the maple file and also a page that i am exploring, in attcahed page I need to find results given in (7) and (8). Maple file is also attached below, please help me to solve this system of PDEs for required results given in (7) and (8). Thanks
Download PDEs_system_solution.mw
with(PDEtools):
alias(u = u(x, y, t), f = f(x, y, t), g = g(x, y, t), q = q(x, y, t))
u, f, g, q
eq1 := 24*g*(diff(q, y))*(diff(q, x))^3-12*(diff(q, y))*(diff(q, x))^2*g^2 = 0
eq2 := 60*g*sigma*(diff(q, y))*(diff(q, x))^3-30*sigma*(diff(q, y))*(diff(q, x))^2*g^2+18*(diff(g, x))*(diff(q, y))*(diff(q, x))^2-15*(diff(q, y))*(diff(q, x))*(diff(g, x))*g+18*g*(diff(q, y))*(diff(q, x))*(diff(q, x, x))-3*(diff(q, y))*g^2*(diff(q, x, x))+6*(diff(g, y))*(diff(q, x))^3+18*g*(diff(q, x))^2*(diff(q, y, x))-9*(diff(g, y))*g*(diff(q, x))^2-3*g^2*(diff(q, x))*(diff(q, y, x)) = 0
60*g*sigma*(diff(q, y))*(diff(q, x))^3-30*sigma*(diff(q, y))*(diff(q, x))^2*g^2+18*(diff(g, x))*(diff(q, y))*(diff(q, x))^2-15*(diff(q, y))*(diff(q, x))*(diff(g, x))*g+18*g*(diff(q, y))*(diff(q, x))*(diff(diff(q, x), x))-3*(diff(q, y))*g^2*(diff(diff(q, x), x))+6*(diff(g, y))*(diff(q, x))^3+18*g*(diff(q, x))^2*(diff(diff(q, x), y))-9*(diff(g, y))*g*(diff(q, x))^2-3*g^2*(diff(q, x))*(diff(diff(q, x), y)) = 0
eq3 := 36*g*sigma*(diff(q, y))*(diff(q, x))*(diff(q, x, x))-27*sigma*(diff(q, y))*(diff(q, x))*(diff(g, x))*g-3*(diff(q, y))*(diff(g, x))^2+6*(diff(g, y, x))*(diff(q, x))^2-9*(diff(g, y))*(diff(g, x))*(diff(q, x))+2*g*(diff(q, y))*(diff(q, t))+2*g*(diff(q, y))*(diff(q, x, x, x))-6*(diff(f, y))*(diff(q, x))^2*g+12*(diff(g, y))*sigma*(diff(q, x))^3+6*(diff(g, x))*(diff(q, y))*(diff(q, x, x))-3*(diff(q, y, x))*(diff(g, x))*g-3*(diff(q, y))*(diff(g, x, x))*g+6*(diff(q, y))*(diff(g, x, x))*(diff(q, x))-3*(diff(q, x, x))*(diff(g, y))*g-3*g*(diff(q, x))*(diff(g, y, x))+12*(diff(q, x))*(diff(g, x))*(diff(q, y, x))+6*g*(diff(q, y, x))*(diff(q, x, x))+6*(diff(q, x))*g*(diff(q, y, x, x))+6*(diff(g, y))*(diff(q, x))*(diff(q, x, x))-6*sigma*(diff(q, x))*(diff(q, y, x))*g^2+50*g*sigma^2*(diff(q, y))*(diff(q, x))^3-24*sigma^2*(diff(q, y))*(diff(q, x))^2*g^2+36*(diff(g, x))*sigma*(diff(q, y))*(diff(q, x))^2-15*(diff(q, x))^2*sigma*(diff(g, y))*g-6*(diff(f, x))*(diff(q, y))*(diff(q, x))*g-6*sigma*(diff(q, y))*(diff(q, x, x))*g^2+36*g*sigma*(diff(q, x))^2*(diff(q, y, x)) = 0
50*g*sigma^2*(diff(q, y))*(diff(q, x))^3-24*sigma^2*(diff(q, y))*(diff(q, x))^2*g^2+36*(diff(g, x))*sigma*(diff(q, y))*(diff(q, x))^2-15*(diff(q, x))^2*sigma*(diff(g, y))*g-6*(diff(f, x))*(diff(q, y))*(diff(q, x))*g-6*sigma*(diff(q, x))*(diff(diff(q, x), y))*g^2-6*sigma*(diff(q, y))*(diff(diff(q, x), x))*g^2+36*g*sigma*(diff(q, x))^2*(diff(diff(q, x), y))-3*(diff(q, y))*(diff(g, x))^2+6*(diff(diff(g, x), y))*(diff(q, x))^2+6*(diff(g, y))*(diff(q, x))*(diff(diff(q, x), x))+6*(diff(g, x))*(diff(q, y))*(diff(diff(q, x), x))-3*(diff(diff(q, x), y))*(diff(g, x))*g-3*(diff(q, y))*(diff(diff(g, x), x))*g+6*(diff(q, y))*(diff(diff(g, x), x))*(diff(q, x))-3*(diff(diff(q, x), x))*(diff(g, y))*g-3*g*(diff(q, x))*(diff(diff(g, x), y))+12*(diff(q, x))*(diff(g, x))*(diff(diff(q, x), y))+6*g*(diff(diff(q, x), y))*(diff(diff(q, x), x))+6*(diff(q, x))*g*(diff(diff(diff(q, x), x), y))+2*g*(diff(q, y))*(diff(diff(diff(q, x), x), x))+2*g*(diff(q, y))*(diff(q, t))+12*(diff(g, y))*sigma*(diff(q, x))^3-9*(diff(g, y))*(diff(g, x))*(diff(q, x))-6*(diff(f, y))*(diff(q, x))^2*g-27*sigma*(diff(q, y))*(diff(q, x))*(diff(g, x))*g+36*g*sigma*(diff(q, y))*(diff(q, x))*(diff(diff(q, x), x)) = 0
eq4 := -3*g*(diff(f, y))*(diff(q, x, x))-3*(diff(q, y))*g*(diff(f, x, x))-3*g*(diff(q, x))*(diff(f, y, x))-3*g*(diff(q, y, x))*(diff(f, x))+15*g*sigma^3*(diff(q, y))*(diff(q, x))^3-6*sigma^3*(diff(q, y))*(diff(q, x))^2*g^2+21*(diff(g, x))*sigma^2*(diff(q, y))*(diff(q, x))^2-6*(diff(q, x))^2*sigma^2*(diff(g, y))*g-9*(diff(f, y))*(diff(q, x))^2*sigma*g+3*g*sigma*(diff(q, y))*(diff(q, t))-9*sigma*(diff(q, x))*(diff(g, x))*(diff(g, y))+9*(diff(g, y, x))*sigma*(diff(q, x))^2+7*(diff(g, y))*sigma^2*(diff(q, x))^3-3*sigma*(diff(q, y))*(diff(g, x))^2-6*(diff(g, x))*(diff(q, x))*(diff(f, y))-3*(diff(q, y))*(diff(g, x))*(diff(f, x))-3*(diff(g, y))*(diff(q, x))*(diff(f, x))-3*(diff(g, y, x))*(diff(g, x))-3*(diff(g, x, x))*(diff(g, y))+g*(diff(q, y, t))+9*g*sigma*(diff(q, y, x))*(diff(q, x, x))-3*sigma*(diff(q, x, x))*(diff(g, y))*g+9*sigma*(diff(q, x))*g*(diff(q, y, x, x))-3*sigma*(diff(q, y, x))*(diff(g, x))*g-3*sigma*(diff(q, x))*(diff(g, y, x))*g+9*(diff(g, y))*sigma*(diff(q, x))*(diff(q, x, x))+9*(diff(g, x))*sigma*(diff(q, y))*(diff(q, x, x))+3*g*sigma*(diff(q, y))*(diff(q, x, x, x))+18*sigma*(diff(q, x))*(diff(g, x))*(diff(q, y, x))+21*g*sigma^2*(diff(q, x))^2*(diff(q, y, x))-3*sigma^2*(diff(q, x))*(diff(q, y, x))*g^2+9*sigma*(diff(q, y))*(diff(g, x, x))*(diff(q, x))-3*sigma*(diff(q, y))*(diff(g, x, x))*g-3*sigma^2*(diff(q, y))*(diff(q, x, x))*g^2+21*g*sigma^2*(diff(q, y))*(diff(q, x))*(diff(q, x, x))-9*(diff(f, x))*(diff(q, y))*(diff(q, x))*sigma*g-12*sigma^2*(diff(q, y))*(diff(q, x))*(diff(g, x))*g+(diff(q, y))*(diff(g, t))+(diff(g, y))*(diff(q, t))+3*(diff(g, x, x))*(diff(q, y, x))+(diff(q, y))*(diff(g, x, x, x))+3*(diff(q, x))*(diff(g, y, x, x))+(diff(q, y, x, x, x))*g+3*(diff(g, x))*(diff(q, y, x, x))+(diff(g, y))*(diff(q, x, x, x))+3*(diff(g, y, x))*(diff(q, x, x)) = 0
7*(diff(g, y))*sigma^2*(diff(q, x))^3-3*sigma*(diff(q, y))*(diff(g, x))^2-6*(diff(g, x))*(diff(q, x))*(diff(f, y))-3*(diff(q, y))*(diff(g, x))*(diff(f, x))-3*(diff(g, y))*(diff(q, x))*(diff(f, x))-3*(diff(q, y))*g*(diff(diff(f, x), x))-3*g*(diff(q, x))*(diff(diff(f, x), y))-3*g*(diff(f, y))*(diff(diff(q, x), x))-3*g*(diff(diff(q, x), y))*(diff(f, x))+9*(diff(diff(g, x), y))*sigma*(diff(q, x))^2+15*g*sigma^3*(diff(q, y))*(diff(q, x))^3-6*sigma^3*(diff(q, y))*(diff(q, x))^2*g^2+21*(diff(g, x))*sigma^2*(diff(q, y))*(diff(q, x))^2-6*(diff(q, x))^2*sigma^2*(diff(g, y))*g-9*(diff(f, y))*(diff(q, x))^2*sigma*g+3*g*sigma*(diff(q, y))*(diff(q, t))-9*sigma*(diff(q, x))*(diff(g, x))*(diff(g, y))+9*g*sigma*(diff(diff(q, x), y))*(diff(diff(q, x), x))-3*sigma*(diff(diff(q, x), x))*(diff(g, y))*g+9*sigma*(diff(q, x))*g*(diff(diff(diff(q, x), x), y))-3*sigma*(diff(diff(q, x), y))*(diff(g, x))*g-3*sigma*(diff(q, x))*(diff(diff(g, x), y))*g+9*(diff(g, y))*sigma*(diff(q, x))*(diff(diff(q, x), x))+9*(diff(g, x))*sigma*(diff(q, y))*(diff(diff(q, x), x))+3*g*sigma*(diff(q, y))*(diff(diff(diff(q, x), x), x))+18*sigma*(diff(q, x))*(diff(g, x))*(diff(diff(q, x), y))+21*g*sigma^2*(diff(q, x))^2*(diff(diff(q, x), y))-3*sigma^2*(diff(q, x))*(diff(diff(q, x), y))*g^2+9*sigma*(diff(q, y))*(diff(diff(g, x), x))*(diff(q, x))-3*sigma*(diff(q, y))*(diff(diff(g, x), x))*g-3*sigma^2*(diff(q, y))*(diff(diff(q, x), x))*g^2-9*(diff(f, x))*(diff(q, y))*(diff(q, x))*sigma*g-12*sigma^2*(diff(q, y))*(diff(q, x))*(diff(g, x))*g+21*g*sigma^2*(diff(q, y))*(diff(q, x))*(diff(diff(q, x), x))+(diff(q, y))*(diff(g, t))+(diff(g, y))*(diff(q, t))-3*(diff(diff(g, x), y))*(diff(g, x))-3*(diff(diff(g, x), x))*(diff(g, y))+g*(diff(diff(q, t), y))+3*(diff(diff(g, x), x))*(diff(diff(q, x), y))+(diff(q, y))*(diff(diff(diff(g, x), x), x))+3*(diff(q, x))*(diff(diff(diff(g, x), x), y))+(diff(diff(diff(diff(q, x), x), x), y))*g+3*(diff(g, x))*(diff(diff(diff(q, x), x), y))+(diff(g, y))*(diff(diff(diff(q, x), x), x))+3*(diff(diff(g, x), y))*(diff(diff(q, x), x)) = 0
eq5 := (diff(g, y))*sigma*(diff(q, t))+(diff(g, t))*sigma*(diff(q, y))+(diff(g, y))*sigma^3*(diff(q, x))^3+3*(diff(g, x))*sigma^3*(diff(q, y))*(diff(q, x))^2+g*sigma^2*(diff(q, y))*(diff(q, t))+g*sigma^4*(diff(q, y))*(diff(q, x))^3-3*(diff(f, x))*sigma*(diff(q, y))*(diff(g, x))-3*(diff(f, x))*sigma*(diff(q, x))*(diff(g, y))-6*(diff(f, y))*sigma*(diff(q, x))*(diff(g, x))+3*g*sigma^3*(diff(q, x))^2*(diff(q, y, x))+g*sigma^2*(diff(q, y))*(diff(q, x, x, x))-3*(diff(f, x))*sigma*(diff(q, y, x))*g-3*(diff(f, y))*sigma*(diff(q, x, x))*g-3*g*sigma*(diff(q, y))*(diff(f, x, x))-3*sigma*(diff(q, x))*g*(diff(f, y, x))+3*(diff(g, x, x))*sigma^2*(diff(q, y))*(diff(q, x))+6*(diff(g, x))*sigma^2*(diff(q, x))*(diff(q, y, x))+diff(g, y, t)-3*(diff(f, x))*(diff(q, y))*(diff(q, x))*sigma^2*g+3*g*sigma^3*(diff(q, y))*(diff(q, x))*(diff(q, x, x))+3*g*sigma^2*(diff(q, x))*(diff(q, y, x, x))-3*(diff(f, y))*(diff(q, x))^2*sigma^2*g+3*(diff(g, y))*sigma^2*(diff(q, x))*(diff(q, x, x))+3*g*sigma^2*(diff(q, y, x))*(diff(q, x, x))+3*(diff(g, x))*sigma^2*(diff(q, y))*(diff(q, x, x))-3*(diff(g, y))*(diff(f, x, x))-3*(diff(f, y))*(diff(g, x, x))-3*(diff(g, x))*(diff(f, y, x))-3*(diff(f, x))*(diff(g, y, x))+diff(g, y, x, x, x)+3*(diff(g, y, x))*sigma^2*(diff(q, x))^2+3*(diff(g, x, x))*sigma*(diff(q, y, x))+3*(diff(g, y, x, x))*sigma*(diff(q, x))+(diff(g, x, x, x))*sigma*(diff(q, y))+g*sigma*(diff(q, y, t))+3*(diff(g, x))*sigma*(diff(q, y, x, x))+3*(diff(g, y, x))*sigma*(diff(q, x, x))+g*sigma*(diff(q, y, x, x, x))+(diff(g, y))*sigma*(diff(q, x, x, x)) = 0
(diff(g, t))*sigma*(diff(q, y))+(diff(g, y))*sigma^3*(diff(q, x))^3+(diff(g, y))*sigma*(diff(q, t))+3*(diff(diff(g, x), y))*sigma^2*(diff(q, x))^2+3*(diff(diff(g, x), x))*sigma*(diff(diff(q, x), y))+3*(diff(diff(diff(g, x), x), y))*sigma*(diff(q, x))+(diff(diff(diff(g, x), x), x))*sigma*(diff(q, y))+g*sigma*(diff(diff(q, t), y))+3*(diff(g, x))*sigma*(diff(diff(diff(q, x), x), y))+3*(diff(diff(g, x), y))*sigma*(diff(diff(q, x), x))+g*sigma*(diff(diff(diff(diff(q, x), x), x), y))+(diff(g, y))*sigma*(diff(diff(diff(q, x), x), x))-3*(diff(f, x))*(diff(q, y))*(diff(q, x))*sigma^2*g+3*g*sigma^3*(diff(q, y))*(diff(q, x))*(diff(diff(q, x), x))-3*(diff(f, y))*(diff(q, x))^2*sigma^2*g+6*(diff(g, x))*sigma^2*(diff(q, x))*(diff(diff(q, x), y))+3*g*sigma^2*(diff(q, x))*(diff(diff(diff(q, x), x), y))+3*(diff(g, y))*sigma^2*(diff(q, x))*(diff(diff(q, x), x))+3*g*sigma^2*(diff(diff(q, x), y))*(diff(diff(q, x), x))+3*(diff(g, x))*sigma^2*(diff(q, y))*(diff(diff(q, x), x))+3*g*sigma^3*(diff(q, x))^2*(diff(diff(q, x), y))+g*sigma^2*(diff(q, y))*(diff(diff(diff(q, x), x), x))-3*(diff(f, x))*sigma*(diff(diff(q, x), y))*g-3*(diff(f, y))*sigma*(diff(diff(q, x), x))*g-3*g*sigma*(diff(q, y))*(diff(diff(f, x), x))-3*sigma*(diff(q, x))*g*(diff(diff(f, x), y))+3*(diff(diff(g, x), x))*sigma^2*(diff(q, y))*(diff(q, x))+3*(diff(g, x))*sigma^3*(diff(q, y))*(diff(q, x))^2+g*sigma^2*(diff(q, y))*(diff(q, t))+g*sigma^4*(diff(q, y))*(diff(q, x))^3-3*(diff(f, x))*sigma*(diff(q, y))*(diff(g, x))-3*(diff(f, x))*sigma*(diff(q, x))*(diff(g, y))-6*(diff(f, y))*sigma*(diff(q, x))*(diff(g, x))+diff(diff(g, t), y)+diff(diff(diff(diff(g, x), x), x), y)-3*(diff(g, y))*(diff(diff(f, x), x))-3*(diff(f, y))*(diff(diff(g, x), x))-3*(diff(g, x))*(diff(diff(f, x), y))-3*(diff(f, x))*(diff(diff(g, x), y)) = 0
eq6 := -3*(diff(f, x))*(diff(f, y, x))-3*(diff(f, y))*(diff(f, x, x))+diff(f, y, x, x, x)+diff(f, y, t) = 0
-3*(diff(f, x))*(diff(diff(f, x), y))-3*(diff(f, y))*(diff(diff(f, x), x))+diff(diff(diff(diff(f, x), x), x), y)+diff(diff(f, t), y) = 0
pdsolve({eq1, eq2, eq3, eq4, eq5, eq6}, {f, g, q})
Can maple simplify a Combined Inequality? At best it outputs imho a more complicated solution.
Thanks in Advance.
sl10 := -1 <= (3-5*x)*(1/2) and (3-5*x)*(1/2) <= 9
0 <= 5/2-(5/2)*x and -(5/2)*x <= 15/2
The output should be:
-3 <= x and x <= 1
Download Combined_Inequality.mw
Here's a puzzle for geometry lovers. It has a very short manual solution, but it's not that easy to find. Of course, you can solve it in Maple using coordinates. You need to find the radius of these two identical circles.
I am using the tab key to complete commands. Often I have to add a module to the command. On my keyboard typing ":-" is slow (for me) and interrupts the flow. I was wondering whether there is not a undocumented key or shortcut to insert ":-".
(I tried a second time hitting tab but this did not do anything. Would this be a good way to speed up typing?)
I wanted to derive the q(w) term in the following expression to get ∂ f/∂q(w), but I got an error
every thing is correct but i dont know why my PDE is not be zero, i did by another way is satidy but i change whole equation by sabstitutiin then i did ode test is satisfy by putting case in equation and solution with condition but when i want to use pdetest  test in pde is not satisfy ?
_local(gamma)
with(PDEtools)
undeclare(prime)
declare(Omega(x, t)); declare(U(xi)); declare(V(xi)); declare(Theta(x, t))
Omega(x, t)*`will now be displayed as`*Omega
U(xi)*`will now be displayed as`*U
V(xi)*`will now be displayed as`*V
Theta(x, t)*`will now be displayed as`*Theta
xi := -t*tau+x
-t*tau+x
lambda := -tau/c; epsilon := -tau/c; delta := (2*c^2-gamma*tau)/(gamma-2*tau)
-tau/c
-tau/c
case1 := [c = RootOf(-gamma^3*tau+2*_Z^2+2*gamma*tau-4*tau^2)/gamma, A[0] = 0, A[1] = RootOf(_Z^2*gamma+2*tau), B[1] = 0]
K := Omega(x, t) = RootOf(_Z^2*gamma+2*tau)*tanh(xi)*exp(I*gamma*(delta*t+x))
Omega(x, t) = -RootOf(_Z^2*gamma+2*tau)*tanh(t*tau-x)*exp(I*gamma*((2*c^2-gamma*tau)*t/(gamma-2*tau)+x))
pde1 := I*(diff(Omega(x, t), `$`(t, 2))-c^2*(diff(Omega(x, t), `$`(x, 2))))+diff(U(-t*tau+x)^2*Omega(x, t), t)-lambda*c*(diff(U(-t*tau+x)^2*Omega(x, t), x))+(1/2)*(diff(Omega(x, t), `$`(x, 2), t))-(1/2)*epsilon*c*(diff(Omega(x, t), `$`(x, 3))) = 0
I*(diff(diff(Omega(x, t), t), t)-c^2*(diff(diff(Omega(x, t), x), x)))-2*U(-t*tau+x)*Omega(x, t)*(D(U))(-t*tau+x)*tau+U(-t*tau+x)^2*(diff(Omega(x, t), t))+tau*(2*U(-t*tau+x)*Omega(x, t)*(D(U))(-t*tau+x)+U(-t*tau+x)^2*(diff(Omega(x, t), x)))+(1/2)*(diff(diff(diff(Omega(x, t), t), x), x))+(1/2)*tau*(diff(diff(diff(Omega(x, t), x), x), x)) = 0
subs(case1, pde1)
I*(diff(diff(Omega(x, t), t), t)-RootOf(-gamma^3*tau+2*_Z^2+2*gamma*tau-4*tau^2)^2*(diff(diff(Omega(x, t), x), x))/gamma^2)-2*U(-t*tau+x)*Omega(x, t)*(D(U))(-t*tau+x)*tau+U(-t*tau+x)^2*(diff(Omega(x, t), t))+tau*(2*U(-t*tau+x)*Omega(x, t)*(D(U))(-t*tau+x)+U(-t*tau+x)^2*(diff(Omega(x, t), x)))+(1/2)*(diff(diff(diff(Omega(x, t), t), x), x))+(1/2)*tau*(diff(diff(diff(Omega(x, t), x), x), x)) = 0
T := simplify(I*(diff(diff(Omega(x, t), t), t)-RootOf(-gamma^3*tau+2*_Z^2+2*gamma*tau-4*tau^2)^2*(diff(diff(Omega(x, t), x), x))/gamma^2)-2*U(-t*tau+x)*Omega(x, t)*(D(U))(-t*tau+x)*tau+U(-t*tau+x)^2*(diff(Omega(x, t), t))+tau*(2*U(-t*tau+x)*Omega(x, t)*(D(U))(-t*tau+x)+U(-t*tau+x)^2*(diff(Omega(x, t), x)))+(1/2)*(diff(diff(diff(Omega(x, t), t), x), x))+(1/2)*tau*(diff(diff(diff(Omega(x, t), x), x), x)) = 0)
(1/2)*(2*gamma^2*(tau*(diff(Omega(x, t), x))+diff(Omega(x, t), t))*U(-t*tau+x)^2+(diff(diff(diff(Omega(x, t), t), x), x))*gamma^2+tau*(diff(diff(diff(Omega(x, t), x), x), x))*gamma^2-(4*I)*((1/4)*gamma^3+tau-(1/2)*gamma)*tau*(diff(diff(Omega(x, t), x), x))+(2*I)*(diff(diff(Omega(x, t), t), t))*gamma^2)/gamma^2 = 0
pdetest(K, T)
-(1/2)*2^(1/2)*(-tau/gamma)^(1/2)*(-32*gamma^4*tau^3*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+4*gamma*t*tau-8*t*tau^2+2*x*gamma-4*x*tau)/(gamma-2*tau))+16*gamma^5*c^2*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+2*gamma*t*tau-4*t*tau^2+4*x*gamma-8*x*tau)/(gamma-2*tau))-8*gamma^6*tau*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+2*gamma*t*tau-4*t*tau^2+4*x*gamma-8*x*tau)/(gamma-2*tau))+32*gamma^5*tau^2*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+2*gamma*t*tau-4*t*tau^2+4*x*gamma-8*x*tau)/(gamma-2*tau))-32*gamma^4*tau^3*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+2*gamma*t*tau-4*t*tau^2+4*x*gamma-8*x*tau)/(gamma-2*tau))+16*gamma^4*tau*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+4*gamma*t*tau-8*t*tau^2+2*x*gamma-4*x*tau)/(gamma-2*tau))-96*gamma^3*tau^2*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+4*gamma*t*tau-8*t*tau^2+2*x*gamma-4*x*tau)/(gamma-2*tau))+192*gamma^2*tau^3*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+4*gamma*t*tau-8*t*tau^2+2*x*gamma-4*x*tau)/(gamma-2*tau))-128*tau^4*gamma*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+4*gamma*t*tau-8*t*tau^2+2*x*gamma-4*x*tau)/(gamma-2*tau))+16*gamma^4*tau*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+2*gamma*t*tau-4*t*tau^2+4*x*gamma-8*x*tau)/(gamma-2*tau))-96*gamma^3*tau^2*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+2*gamma*t*tau-4*t*tau^2+4*x*gamma-8*x*tau)/(gamma-2*tau))+192*gamma^2*tau^3*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+2*gamma*t*tau-4*t*tau^2+4*x*gamma-8*x*tau)/(gamma-2*tau))-128*tau^4*gamma*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+2*gamma*t*tau-4*t*tau^2+4*x*gamma-8*x*tau)/(gamma-2*tau))+16*gamma^5*c^2*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+4*gamma*t*tau-8*t*tau^2+2*x*gamma-4*x*tau)/(gamma-2*tau))-8*gamma^6*tau*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+4*gamma*t*tau-8*t*tau^2+2*x*gamma-4*x*tau)/(gamma-2*tau))-(4*I)*U(-t*tau+x)^2*gamma^4*c^2*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+6*x*gamma-12*x*tau)/(gamma-2*tau))+(4*I)*U(-t*tau+x)^2*gamma^4*tau^2*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+6*x*gamma-12*x*tau)/(gamma-2*tau))-(8*I)*U(-t*tau+x)^2*gamma^3*tau^3*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+6*x*gamma-12*x*tau)/(gamma-2*tau))-(12*I)*gamma^5*c^2*tau*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+6*x*gamma-12*x*tau)/(gamma-2*tau))+(4*I)*U(-t*tau+x)^2*gamma^4*c^2*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+6*gamma*t*tau-12*t*tau^2)/(gamma-2*tau))-(4*I)*U(-t*tau+x)^2*gamma^4*tau^2*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+6*gamma*t*tau-12*t*tau^2)/(gamma-2*tau))+(8*I)*U(-t*tau+x)^2*gamma^3*tau^3*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+6*gamma*t*tau-12*t*tau^2)/(gamma-2*tau))+(12*I)*gamma^5*c^2*tau*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+6*gamma*t*tau-12*t*tau^2)/(gamma-2*tau))+(4*I)*U(-t*tau+x)^2*gamma^4*c^2*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+4*gamma*t*tau-8*t*tau^2+2*x*gamma-4*x*tau)/(gamma-2*tau))-(4*I)*U(-t*tau+x)^2*gamma^4*tau^2*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+4*gamma*t*tau-8*t*tau^2+2*x*gamma-4*x*tau)/(gamma-2*tau))+(8*I)*U(-t*tau+x)^2*gamma^3*tau^3*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+4*gamma*t*tau-8*t*tau^2+2*x*gamma-4*x*tau)/(gamma-2*tau))+(12*I)*gamma^5*c^2*tau*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+4*gamma*t*tau-8*t*tau^2+2*x*gamma-4*x*tau)/(gamma-2*tau))-(4*I)*U(-t*tau+x)^2*gamma^4*c^2*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+2*gamma*t*tau-4*t*tau^2+4*x*gamma-8*x*tau)/(gamma-2*tau))+(4*I)*U(-t*tau+x)^2*gamma^4*tau^2*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+2*gamma*t*tau-4*t*tau^2+4*x*gamma-8*x*tau)/(gamma-2*tau))-(8*I)*U(-t*tau+x)^2*gamma^3*tau^3*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+2*gamma*t*tau-4*t*tau^2+4*x*gamma-8*x*tau)/(gamma-2*tau))-(12*I)*gamma^5*c^2*tau*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+2*gamma*t*tau-4*t*tau^2+4*x*gamma-8*x*tau)/(gamma-2*tau))+(32*I)*gamma^3*c^2*tau*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+4*gamma*t*tau-8*t*tau^2+2*x*gamma-4*x*tau)/(gamma-2*tau))-(32*I)*gamma^3*c^2*tau*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+2*gamma*t*tau-4*t*tau^2+4*x*gamma-8*x*tau)/(gamma-2*tau))-64*gamma^4*c^2*tau*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+2*gamma*t*tau-4*t*tau^2+4*x*gamma-8*x*tau)/(gamma-2*tau))+64*gamma^3*tau^2*c^2*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+2*gamma*t*tau-4*t*tau^2+4*x*gamma-8*x*tau)/(gamma-2*tau))+I*tau*gamma^7*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+4*gamma*t*tau-8*t*tau^2+2*x*gamma-4*x*tau)/(gamma-2*tau))-64*gamma^4*c^2*tau*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+4*gamma*t*tau-8*t*tau^2+2*x*gamma-4*x*tau)/(gamma-2*tau))+64*gamma^3*tau^2*c^2*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+4*gamma*t*tau-8*t*tau^2+2*x*gamma-4*x*tau)/(gamma-2*tau))+I*tau*gamma^7*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+6*gamma*t*tau-12*t*tau^2)/(gamma-2*tau))+(192*I)*tau^3*gamma*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+2*gamma*t*tau-4*t*tau^2+4*x*gamma-8*x*tau)/(gamma-2*tau))-(8*I)*c^4*gamma^4*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+4*gamma*t*tau-8*t*tau^2+2*x*gamma-4*x*tau)/(gamma-2*tau))-(2*I)*c^2*gamma^6*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+4*gamma*t*tau-8*t*tau^2+2*x*gamma-4*x*tau)/(gamma-2*tau))-(4*I)*tau^2*gamma^6*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+4*gamma*t*tau-8*t*tau^2+2*x*gamma-4*x*tau)/(gamma-2*tau))+(8*I)*c^4*gamma^4*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+2*gamma*t*tau-4*t*tau^2+4*x*gamma-8*x*tau)/(gamma-2*tau))+(2*I)*c^2*gamma^6*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+2*gamma*t*tau-4*t*tau^2+4*x*gamma-8*x*tau)/(gamma-2*tau))-I*tau*gamma^7*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+2*gamma*t*tau-4*t*tau^2+4*x*gamma-8*x*tau)/(gamma-2*tau))+(4*I)*tau^2*gamma^6*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+2*gamma*t*tau-4*t*tau^2+4*x*gamma-8*x*tau)/(gamma-2*tau))-(16*I)*gamma^4*c^2*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+4*gamma*t*tau-8*t*tau^2+2*x*gamma-4*x*tau)/(gamma-2*tau))+(6*I)*tau*gamma^5*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+4*gamma*t*tau-8*t*tau^2+2*x*gamma-4*x*tau)/(gamma-2*tau))-(20*I)*gamma^4*tau^2*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+4*gamma*t*tau-8*t*tau^2+2*x*gamma-4*x*tau)/(gamma-2*tau))+(40*I)*gamma^3*tau^3*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+4*gamma*t*tau-8*t*tau^2+2*x*gamma-4*x*tau)/(gamma-2*tau))-(48*I)*gamma^2*tau^4*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+4*gamma*t*tau-8*t*tau^2+2*x*gamma-4*x*tau)/(gamma-2*tau))+(16*I)*gamma^4*c^2*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+2*gamma*t*tau-4*t*tau^2+4*x*gamma-8*x*tau)/(gamma-2*tau))-(6*I)*tau*gamma^5*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+2*gamma*t*tau-4*t*tau^2+4*x*gamma-8*x*tau)/(gamma-2*tau))+(20*I)*gamma^4*tau^2*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+2*gamma*t*tau-4*t*tau^2+4*x*gamma-8*x*tau)/(gamma-2*tau))-(40*I)*gamma^3*tau^3*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+2*gamma*t*tau-4*t*tau^2+4*x*gamma-8*x*tau)/(gamma-2*tau))+(48*I)*gamma^2*tau^4*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+2*gamma*t*tau-4*t*tau^2+4*x*gamma-8*x*tau)/(gamma-2*tau))-(16*I)*gamma^3*tau*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+4*gamma*t*tau-8*t*tau^2+2*x*gamma-4*x*tau)/(gamma-2*tau))+(96*I)*gamma^2*tau^2*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+4*gamma*t*tau-8*t*tau^2+2*x*gamma-4*x*tau)/(gamma-2*tau))-(192*I)*tau^3*gamma*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+4*gamma*t*tau-8*t*tau^2+2*x*gamma-4*x*tau)/(gamma-2*tau))+(16*I)*gamma^3*tau*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+2*gamma*t*tau-4*t*tau^2+4*x*gamma-8*x*tau)/(gamma-2*tau))-(96*I)*gamma^2*tau^2*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+2*gamma*t*tau-4*t*tau^2+4*x*gamma-8*x*tau)/(gamma-2*tau))-I*tau*gamma^7*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+6*x*gamma-12*x*tau)/(gamma-2*tau))+(4*I)*tau^2*gamma^6*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+6*x*gamma-12*x*tau)/(gamma-2*tau))-(8*I)*c^4*gamma^4*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+6*gamma*t*tau-12*t*tau^2)/(gamma-2*tau))-(2*I)*c^2*gamma^6*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+6*gamma*t*tau-12*t*tau^2)/(gamma-2*tau))-(4*I)*tau^2*gamma^6*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+6*gamma*t*tau-12*t*tau^2)/(gamma-2*tau))+(8*I)*c^4*gamma^4*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+6*x*gamma-12*x*tau)/(gamma-2*tau))+(2*I)*tau*gamma^5*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+6*x*gamma-12*x*tau)/(gamma-2*tau))-(12*I)*gamma^4*tau^2*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+6*x*gamma-12*x*tau)/(gamma-2*tau))+(24*I)*gamma^3*tau^3*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+6*x*gamma-12*x*tau)/(gamma-2*tau))-(16*I)*gamma^2*tau^4*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+6*x*gamma-12*x*tau)/(gamma-2*tau))-(2*I)*tau*gamma^5*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+6*gamma*t*tau-12*t*tau^2)/(gamma-2*tau))+(12*I)*gamma^4*tau^2*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+6*gamma*t*tau-12*t*tau^2)/(gamma-2*tau))-(24*I)*gamma^3*tau^3*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+6*gamma*t*tau-12*t*tau^2)/(gamma-2*tau))+(16*I)*gamma^2*tau^4*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+6*gamma*t*tau-12*t*tau^2)/(gamma-2*tau))+(2*I)*c^2*gamma^6*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+6*x*gamma-12*x*tau)/(gamma-2*tau))+32*gamma^5*tau^2*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+4*gamma*t*tau-8*t*tau^2+2*x*gamma-4*x*tau)/(gamma-2*tau))+(128*I)*tau^4*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+4*gamma*t*tau-8*t*tau^2+2*x*gamma-4*x*tau)/(gamma-2*tau))-(128*I)*tau^4*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+2*gamma*t*tau-4*t*tau^2+4*x*gamma-8*x*tau)/(gamma-2*tau))-(8*I)*tau*c^2*U(-t*tau+x)^2*gamma^3*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+6*gamma*t*tau-12*t*tau^2)/(gamma-2*tau))+(8*I)*tau*c^2*U(-t*tau+x)^2*gamma^3*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+6*x*gamma-12*x*tau)/(gamma-2*tau))-(8*I)*tau*c^2*U(-t*tau+x)^2*gamma^3*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+4*gamma*t*tau-8*t*tau^2+2*x*gamma-4*x*tau)/(gamma-2*tau))+(8*I)*tau*c^2*U(-t*tau+x)^2*gamma^3*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+2*gamma*t*tau-4*t*tau^2+4*x*gamma-8*x*tau)/(gamma-2*tau)))/(gamma^2*(gamma-2*tau)^2*(exp(2*t*tau)+exp(2*x))^3)
simplify(-(1/2)*2^(1/2)*(-tau/gamma)^(1/2)*((8*I)*tau*c^2*U(-t*tau+x)^2*gamma^3*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+6*x*gamma-12*x*tau)/(gamma-2*tau))+(8*I)*tau*c^2*U(-t*tau+x)^2*gamma^3*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+2*gamma*t*tau-4*t*tau^2+4*x*gamma-8*x*tau)/(gamma-2*tau))-(8*I)*tau*c^2*U(-t*tau+x)^2*gamma^3*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+6*gamma*t*tau-12*t*tau^2)/(gamma-2*tau))-(8*I)*tau*c^2*U(-t*tau+x)^2*gamma^3*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+4*gamma*t*tau-8*t*tau^2+2*x*gamma-4*x*tau)/(gamma-2*tau))-(128*I)*tau^4*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+2*gamma*t*tau-4*t*tau^2+4*x*gamma-8*x*tau)/(gamma-2*tau))+32*gamma^5*tau^2*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+4*gamma*t*tau-8*t*tau^2+2*x*gamma-4*x*tau)/(gamma-2*tau))+192*gamma^2*tau^3*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+2*gamma*t*tau-4*t*tau^2+4*x*gamma-8*x*tau)/(gamma-2*tau))-128*tau^4*gamma*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+2*gamma*t*tau-4*t*tau^2+4*x*gamma-8*x*tau)/(gamma-2*tau))+16*gamma^5*c^2*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+4*gamma*t*tau-8*t*tau^2+2*x*gamma-4*x*tau)/(gamma-2*tau))-8*gamma^6*tau*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+4*gamma*t*tau-8*t*tau^2+2*x*gamma-4*x*tau)/(gamma-2*tau))+32*gamma^5*tau^2*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+2*gamma*t*tau-4*t*tau^2+4*x*gamma-8*x*tau)/(gamma-2*tau))-32*gamma^4*tau^3*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+2*gamma*t*tau-4*t*tau^2+4*x*gamma-8*x*tau)/(gamma-2*tau))+16*gamma^4*tau*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+4*gamma*t*tau-8*t*tau^2+2*x*gamma-4*x*tau)/(gamma-2*tau))-96*gamma^3*tau^2*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+4*gamma*t*tau-8*t*tau^2+2*x*gamma-4*x*tau)/(gamma-2*tau))+192*gamma^2*tau^3*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+4*gamma*t*tau-8*t*tau^2+2*x*gamma-4*x*tau)/(gamma-2*tau))-128*tau^4*gamma*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+4*gamma*t*tau-8*t*tau^2+2*x*gamma-4*x*tau)/(gamma-2*tau))+16*gamma^4*tau*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+2*gamma*t*tau-4*t*tau^2+4*x*gamma-8*x*tau)/(gamma-2*tau))-96*gamma^3*tau^2*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+2*gamma*t*tau-4*t*tau^2+4*x*gamma-8*x*tau)/(gamma-2*tau))+(128*I)*tau^4*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+4*gamma*t*tau-8*t*tau^2+2*x*gamma-4*x*tau)/(gamma-2*tau))-32*gamma^4*tau^3*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+4*gamma*t*tau-8*t*tau^2+2*x*gamma-4*x*tau)/(gamma-2*tau))+16*gamma^5*c^2*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+2*gamma*t*tau-4*t*tau^2+4*x*gamma-8*x*tau)/(gamma-2*tau))-8*gamma^6*tau*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+2*gamma*t*tau-4*t*tau^2+4*x*gamma-8*x*tau)/(gamma-2*tau))-(32*I)*gamma^3*c^2*tau*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+2*gamma*t*tau-4*t*tau^2+4*x*gamma-8*x*tau)/(gamma-2*tau))+(4*I)*U(-t*tau+x)^2*gamma^4*tau^2*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+6*x*gamma-12*x*tau)/(gamma-2*tau))+(4*I)*U(-t*tau+x)^2*gamma^4*c^2*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+6*gamma*t*tau-12*t*tau^2)/(gamma-2*tau))+(8*I)*U(-t*tau+x)^2*gamma^3*tau^3*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+6*gamma*t*tau-12*t*tau^2)/(gamma-2*tau))+(12*I)*gamma^5*c^2*tau*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+6*gamma*t*tau-12*t*tau^2)/(gamma-2*tau))+(4*I)*U(-t*tau+x)^2*gamma^4*c^2*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+4*gamma*t*tau-8*t*tau^2+2*x*gamma-4*x*tau)/(gamma-2*tau))+(8*I)*U(-t*tau+x)^2*gamma^3*tau^3*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+4*gamma*t*tau-8*t*tau^2+2*x*gamma-4*x*tau)/(gamma-2*tau))+(12*I)*gamma^5*c^2*tau*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+4*gamma*t*tau-8*t*tau^2+2*x*gamma-4*x*tau)/(gamma-2*tau))+(4*I)*U(-t*tau+x)^2*gamma^4*tau^2*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+2*gamma*t*tau-4*t*tau^2+4*x*gamma-8*x*tau)/(gamma-2*tau))+(32*I)*gamma^3*c^2*tau*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+4*gamma*t*tau-8*t*tau^2+2*x*gamma-4*x*tau)/(gamma-2*tau))-(4*I)*U(-t*tau+x)^2*gamma^4*c^2*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+6*x*gamma-12*x*tau)/(gamma-2*tau))-(8*I)*U(-t*tau+x)^2*gamma^3*tau^3*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+6*x*gamma-12*x*tau)/(gamma-2*tau))-(12*I)*gamma^5*c^2*tau*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+6*x*gamma-12*x*tau)/(gamma-2*tau))-(4*I)*U(-t*tau+x)^2*gamma^4*tau^2*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+6*gamma*t*tau-12*t*tau^2)/(gamma-2*tau))-(4*I)*U(-t*tau+x)^2*gamma^4*tau^2*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+4*gamma*t*tau-8*t*tau^2+2*x*gamma-4*x*tau)/(gamma-2*tau))-(4*I)*U(-t*tau+x)^2*gamma^4*c^2*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+2*gamma*t*tau-4*t*tau^2+4*x*gamma-8*x*tau)/(gamma-2*tau))-(8*I)*U(-t*tau+x)^2*gamma^3*tau^3*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+2*gamma*t*tau-4*t*tau^2+4*x*gamma-8*x*tau)/(gamma-2*tau))-(12*I)*gamma^5*c^2*tau*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+2*gamma*t*tau-4*t*tau^2+4*x*gamma-8*x*tau)/(gamma-2*tau))-(8*I)*c^4*gamma^4*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+4*gamma*t*tau-8*t*tau^2+2*x*gamma-4*x*tau)/(gamma-2*tau))-(2*I)*c^2*gamma^6*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+4*gamma*t*tau-8*t*tau^2+2*x*gamma-4*x*tau)/(gamma-2*tau))-(4*I)*tau^2*gamma^6*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+4*gamma*t*tau-8*t*tau^2+2*x*gamma-4*x*tau)/(gamma-2*tau))-I*tau*gamma^7*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+2*gamma*t*tau-4*t*tau^2+4*x*gamma-8*x*tau)/(gamma-2*tau))-(16*I)*gamma^4*c^2*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+4*gamma*t*tau-8*t*tau^2+2*x*gamma-4*x*tau)/(gamma-2*tau))-(20*I)*gamma^4*tau^2*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+4*gamma*t*tau-8*t*tau^2+2*x*gamma-4*x*tau)/(gamma-2*tau))-(48*I)*gamma^2*tau^4*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+4*gamma*t*tau-8*t*tau^2+2*x*gamma-4*x*tau)/(gamma-2*tau))-(6*I)*tau*gamma^5*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+2*gamma*t*tau-4*t*tau^2+4*x*gamma-8*x*tau)/(gamma-2*tau))-(40*I)*gamma^3*tau^3*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+2*gamma*t*tau-4*t*tau^2+4*x*gamma-8*x*tau)/(gamma-2*tau))-(16*I)*gamma^3*tau*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+4*gamma*t*tau-8*t*tau^2+2*x*gamma-4*x*tau)/(gamma-2*tau))-(192*I)*tau^3*gamma*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+4*gamma*t*tau-8*t*tau^2+2*x*gamma-4*x*tau)/(gamma-2*tau))-(96*I)*gamma^2*tau^2*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+2*gamma*t*tau-4*t*tau^2+4*x*gamma-8*x*tau)/(gamma-2*tau))-I*tau*gamma^7*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+6*x*gamma-12*x*tau)/(gamma-2*tau))-(8*I)*c^4*gamma^4*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+6*gamma*t*tau-12*t*tau^2)/(gamma-2*tau))-(2*I)*c^2*gamma^6*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+6*gamma*t*tau-12*t*tau^2)/(gamma-2*tau))-(4*I)*tau^2*gamma^6*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+6*gamma*t*tau-12*t*tau^2)/(gamma-2*tau))-(12*I)*gamma^4*tau^2*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+6*x*gamma-12*x*tau)/(gamma-2*tau))-(16*I)*gamma^2*tau^4*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+6*x*gamma-12*x*tau)/(gamma-2*tau))-(2*I)*tau*gamma^5*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+6*gamma*t*tau-12*t*tau^2)/(gamma-2*tau))-(24*I)*gamma^3*tau^3*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+6*gamma*t*tau-12*t*tau^2)/(gamma-2*tau))-64*gamma^4*c^2*tau*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+2*gamma*t*tau-4*t*tau^2+4*x*gamma-8*x*tau)/(gamma-2*tau))+64*gamma^3*tau^2*c^2*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+2*gamma*t*tau-4*t*tau^2+4*x*gamma-8*x*tau)/(gamma-2*tau))-64*gamma^4*c^2*tau*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+4*gamma*t*tau-8*t*tau^2+2*x*gamma-4*x*tau)/(gamma-2*tau))+64*gamma^3*tau^2*c^2*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+4*gamma*t*tau-8*t*tau^2+2*x*gamma-4*x*tau)/(gamma-2*tau))+(8*I)*c^4*gamma^4*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+6*x*gamma-12*x*tau)/(gamma-2*tau))+(2*I)*tau*gamma^5*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+6*x*gamma-12*x*tau)/(gamma-2*tau))+(24*I)*gamma^3*tau^3*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+6*x*gamma-12*x*tau)/(gamma-2*tau))+(12*I)*gamma^4*tau^2*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+6*gamma*t*tau-12*t*tau^2)/(gamma-2*tau))+(16*I)*gamma^2*tau^4*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+6*gamma*t*tau-12*t*tau^2)/(gamma-2*tau))+(2*I)*c^2*gamma^6*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+6*x*gamma-12*x*tau)/(gamma-2*tau))+(48*I)*gamma^2*tau^4*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+2*gamma*t*tau-4*t*tau^2+4*x*gamma-8*x*tau)/(gamma-2*tau))+(96*I)*gamma^2*tau^2*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+4*gamma*t*tau-8*t*tau^2+2*x*gamma-4*x*tau)/(gamma-2*tau))+(16*I)*gamma^3*tau*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+2*gamma*t*tau-4*t*tau^2+4*x*gamma-8*x*tau)/(gamma-2*tau))+(4*I)*tau^2*gamma^6*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+6*x*gamma-12*x*tau)/(gamma-2*tau))+(2*I)*c^2*gamma^6*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+2*gamma*t*tau-4*t*tau^2+4*x*gamma-8*x*tau)/(gamma-2*tau))+(4*I)*tau^2*gamma^6*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+2*gamma*t*tau-4*t*tau^2+4*x*gamma-8*x*tau)/(gamma-2*tau))+(6*I)*tau*gamma^5*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+4*gamma*t*tau-8*t*tau^2+2*x*gamma-4*x*tau)/(gamma-2*tau))+(40*I)*gamma^3*tau^3*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+4*gamma*t*tau-8*t*tau^2+2*x*gamma-4*x*tau)/(gamma-2*tau))+(16*I)*gamma^4*c^2*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+2*gamma*t*tau-4*t*tau^2+4*x*gamma-8*x*tau)/(gamma-2*tau))+(20*I)*gamma^4*tau^2*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+2*gamma*t*tau-4*t*tau^2+4*x*gamma-8*x*tau)/(gamma-2*tau))+I*tau*gamma^7*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+4*gamma*t*tau-8*t*tau^2+2*x*gamma-4*x*tau)/(gamma-2*tau))+I*tau*gamma^7*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+6*gamma*t*tau-12*t*tau^2)/(gamma-2*tau))+(192*I)*tau^3*gamma*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+2*gamma*t*tau-4*t*tau^2+4*x*gamma-8*x*tau)/(gamma-2*tau))+(8*I)*c^4*gamma^4*exp(((2*I)*gamma*c^2*t-I*gamma^2*t*tau+I*x*gamma^2-(2*I)*gamma*x*tau+2*gamma*t*tau-4*t*tau^2+4*x*gamma-8*x*tau)/(gamma-2*tau)))/(gamma^2*(gamma-2*tau)^2*(exp(2*tau*t)+exp(2*x))^3))
-(-tau/gamma)^(1/2)*((I*gamma^3*(-(1/2)*gamma+tau)*(c-tau)*(c+tau)*U(-t*tau+x)^2-((1/8)*I)*tau*gamma^7+(((1/4)*I)*c^2+((1/2)*I)*tau^2-tau)*gamma^6+(4*tau^2+(-((3/2)*I)*c^2-(3/4)*I)*tau+2*c^2)*gamma^5+(-4*tau^3+((5/2)*I)*tau^2+(-8*c^2+2)*tau+I*(c^2+2)*c^2)*gamma^4-4*(((5/4)*I)*tau^2+(-2*c^2+3)*tau+I*c^2-(1/2)*I)*tau*gamma^3+6*(I*tau^2-2*I+4*tau)*tau^2*gamma^2+((24*I)*tau^3-16*tau^4)*gamma-(16*I)*tau^4)*exp((I*(t*tau-x)*gamma^2+2*((I*x-t)*tau-I*c^2*t-2*x)*gamma+4*t*tau^2+8*x*tau)/(-gamma+2*tau))+(-I*gamma^3*(-(1/2)*gamma+tau)*(c-tau)*(c+tau)*U(-t*tau+x)^2+((1/8)*I)*tau*gamma^7+(-((1/4)*I)*c^2-((1/2)*I)*tau^2-tau)*gamma^6+(4*tau^2+(((3/2)*I)*c^2+(3/4)*I)*tau+2*c^2)*gamma^5+(-4*tau^3-((5/2)*I)*tau^2+(-8*c^2+2)*tau-I*(c^2+2)*c^2)*gamma^4+4*(((5/4)*I)*tau^2+tau*(2*c^2-3)+I*c^2-(1/2)*I)*tau*gamma^3-6*(I*tau^2-2*I-4*tau)*tau^2*gamma^2+(-(24*I)*tau^3-16*tau^4)*gamma+(16*I)*tau^4)*exp((I*(t*tau-x)*gamma^2+2*((I*x-2*t)*tau-I*c^2*t-x)*gamma+8*t*tau^2+4*x*tau)/(-gamma+2*tau))+I*gamma^2*(exp((I*(t*tau-x)*gamma^2+2*(-I*c^2*t+I*x*tau-3*x)*gamma+12*x*tau)/(-gamma+2*tau))-exp((I*(t*tau-x)*gamma^2+2*((I*x-3*t)*tau-I*c^2*t)*gamma+12*t*tau^2)/(-gamma+2*tau)))*(gamma*(-(1/2)*gamma+tau)*(c-tau)*(c+tau)*U(-t*tau+x)^2-(1/8)*tau*gamma^5+((1/4)*c^2+(1/2)*tau^2)*gamma^4+tau*(-(3/2)*c^2+1/4)*gamma^3+(c^4-(3/2)*tau^2)*gamma^2+3*tau^3*gamma-2*tau^4))*2^(1/2)/(gamma^2*(exp(2*t*tau)+exp(2*x))^3*(-(1/2)*gamma+tau)^2)
Download pdetest.mw
Is there something one can do to make Maple give same result each time? It seems all random.
Calling odetest sometimes gives internal error.
            Error, (in trig/normal/sincosargs) too many levels of recursion
But it is random when and how it happens. Worksheet below shows that sometimes when adding infolevel[odetest]:=5; make the error go away. sometimes trying 2 or 3 times also makes the error go away.
This makes it impossible to reason about things, as sometimes I get different result using same exact code.
Is there something one can do to remove this internal error? Why it happens sometimes only?  Do I need to clear something before calling odetest to make sure same result is obtained each time?
`The "Physics Updates" version in the MapleCloud is 1841 and is the same as the version installed in this computer, created 2025, January 3, 8:59 hours Pacific Time.`
libname;
sol:=y(x) = 1/2*x*(-1-(1+I*3^(1/2))*((I*2^(1/2)-1+I)*(I*2^(1/2)+1+I)^2)^(2/3)-2*((I*
2^(1/2)-1+I)*(I*2^(1/2)+1+I)^2)^(1/3)-I*((I*2^(1/2)+I)^2-1)*3^(1/2)+(I*2^(1/2)+
I)^2)/((I*2^(1/2)-1+I)*(I*2^(1/2)+1+I)^2)^(1/3)/(I*2^(1/2)+I);
ode:=x^3+3*x*y(x)^2+(y(x)^3+3*x^2*y(x))*diff(y(x),x) = 0
y(x) = (1/2)*x*(-1-(1+I*3^(1/2))*((I*2^(1/2)+(-1+I))*(I*2^(1/2)+1+I)^2)^(2/3)-2*((I*2^(1/2)+(-1+I))*(I*2^(1/2)+1+I)^2)^(1/3)-I*((I*2^(1/2)+I)^2-1)*3^(1/2)+(I*2^(1/2)+I)^2)/(((I*2^(1/2)+(-1+I))*(I*2^(1/2)+1+I)^2)^(1/3)*(I*2^(1/2)+I))
x^3+3*x*y(x)^2+(y(x)^3+3*x^2*y(x))*(diff(y(x), x)) = 0
odetest(sol,ode,y(x));
odetest(sol,ode);
5
odetest(sol,ode);
odetest: Performing an implicit solution test
odetest: Performing an explicit (try hard) solution test
odetest: Performing an implicit solution (II) test
odetest: Performing another explicit (try soft) solution test
infolevel[odetest]:=0;
Download why_odetest_sometimes_fail_internal.mw
Add tracelast; after an error gives long output with this at end
#(\`trig/normal\`,8): sincosargs := [\`trig/normal/sincosargs\`(a)];
 \`trig/normal/sincosargs\` called with arguments: ((-2472*2^(1/2)+3496)*3^(1/2)-4288*2^(1/2)+6064)*(10+7*2^(1/2))^(1/2)+(6008*6^(1/2)-8496*3^(1/2)+10408*2^(1/2)-14720)*cos((1/24)*Pi)
 #(\`trig/normal/sincosargs\`,2): return op(map(procname,{op(x)}))
 \`trig/normal/sincosargs\` called with arguments: (-2472*2^(1/2)+3496)*3^(1/2)-4288*2^(1/2)+6064
 \`trig/normal/sincosargs\` called with arguments: -2472*2^(1/2)+3496
Not only is it random error, it also can not be cought using try/catch. So the whole program now stop and there is no way around it. If it was at least possible to trap the error, then it will not be a big deal. But when not even possible to trap Maple errors, then what is one to do?
Update Jan 18, 2025
I did not want to make new post on this, even though the error is different, but it is similar issue to this post.
I found another example of this random failure of odetest using same input.  May be this will help Maplesoft find the cause.
The internal error this time is Error, (in depends) too many levels of recursion
In this worksheet below. the same ode and 3 solutions were used. As you see, sometimes odetest do not generate internal error, and sometimes it does. All happen on 3rd call to odetest.
So it is completely random why this happen. The first and 4ht tries generate no error, but the second and the third do. All were run after restart is called. So one would expect same output from each try,
First Try
ode:=1+y(x)^2+(x-exp(-arctan(y(x))))*diff(y(x),x) = 0;
sol_1:=y(x) = -tan(LambertW(-x/exp(_C1))+_C1);
timelimit(30,odetest(sol_1,ode,y(x)));
sol_2:=x*exp(arctan(y(x)))-arctan(y(x)) = _C1;
timelimit(30,odetest(sol_2,ode,y(x)));
sol_3:=y(x) = tan(-LambertW(-x*exp(_C2))+_C2);
timelimit(30,odetest(sol_3,ode,y(x)));
1+y(x)^2+(x-exp(-arctan(y(x))))*(diff(y(x), x)) = 0
4*LambertW(-x*exp(-c__1))*exp(-I*arctanh(exp((2*I)*LambertW(-x*exp(-c__1))+(2*I)*c__1)/(exp((2*I)*LambertW(-x*exp(-c__1))+(2*I)*c__1)+1)-1/(exp((2*I)*LambertW(-x*exp(-c__1))+(2*I)*c__1)+1))+(2*I)*LambertW(-x*exp(-c__1))+(2*I)*c__1)/((exp((2*I)*LambertW(-x*exp(-c__1))+(2*I)*c__1)+1)^2*x*(1+LambertW(-x*exp(-c__1))))+4*exp((2*I)*LambertW(-x*exp(-c__1))+(2*I)*c__1)/((exp((2*I)*LambertW(-x*exp(-c__1))+(2*I)*c__1)+1)^2*(1+LambertW(-x*exp(-c__1))))
x*exp(arctan(y(x)))-arctan(y(x)) = c__1
Second Try
4*exp((2*I)*LambertW(-x*exp(-c__1))+(2*I)*c__1)/((exp((2*I)*LambertW(-x*exp(-c__1))+(2*I)*c__1)+1)^2*(1+LambertW(-x*exp(-c__1))))+4*LambertW(-x*exp(-c__1))*exp(-I*arctanh(exp((2*I)*LambertW(-x*exp(-c__1))+(2*I)*c__1)/(exp((2*I)*LambertW(-x*exp(-c__1))+(2*I)*c__1)+1)-1/(exp((2*I)*LambertW(-x*exp(-c__1))+(2*I)*c__1)+1))+(2*I)*LambertW(-x*exp(-c__1))+(2*I)*c__1)/((1+LambertW(-x*exp(-c__1)))*x*(exp((2*I)*LambertW(-x*exp(-c__1))+(2*I)*c__1)+1)^2)
4*LambertW(-x*exp(c__2))*exp((2*I)*LambertW(-x*exp(c__2))+(2*I)*c__2+I*arctanh(-exp((2*I)*LambertW(-x*exp(c__2)))/(exp((2*I)*LambertW(-x*exp(c__2)))+exp((2*I)*c__2))+exp((2*I)*c__2)/(exp((2*I)*LambertW(-x*exp(c__2)))+exp((2*I)*c__2))))/((exp((2*I)*LambertW(-x*exp(c__2)))+exp((2*I)*c__2))^2*(1+LambertW(-x*exp(c__2)))*x)+4*exp((2*I)*c__2+(2*I)*LambertW(-x*exp(c__2)))/((exp((2*I)*LambertW(-x*exp(c__2)))+exp((2*I)*c__2))^2*(1+LambertW(-x*exp(c__2))))
Third  Try
4*LambertW(-x*exp(-c__1))*exp(-I*arctanh(exp((2*I)*LambertW(-x*exp(-c__1))+(2*I)*c__1)/(exp((2*I)*LambertW(-x*exp(-c__1))+(2*I)*c__1)+1)-1/(exp((2*I)*LambertW(-x*exp(-c__1))+(2*I)*c__1)+1))+(2*I)*LambertW(-x*exp(-c__1))+(2*I)*c__1)/((1+LambertW(-x*exp(-c__1)))*x*(exp((2*I)*LambertW(-x*exp(-c__1))+(2*I)*c__1)+1)^2)+4*exp((2*I)*LambertW(-x*exp(-c__1))+(2*I)*c__1)/((exp((2*I)*LambertW(-x*exp(-c__1))+(2*I)*c__1)+1)^2*(1+LambertW(-x*exp(-c__1))))
4th  Try
4*exp((2*I)*c__2+(2*I)*LambertW(-x*exp(c__2)))/((exp((2*I)*LambertW(-x*exp(c__2)))+exp((2*I)*c__2))^2*(1+LambertW(-x*exp(c__2))))+4*LambertW(-x*exp(c__2))*exp((2*I)*LambertW(-x*exp(c__2))+(2*I)*c__2+I*arctanh(-exp((2*I)*LambertW(-x*exp(c__2)))/(exp((2*I)*LambertW(-x*exp(c__2)))+exp((2*I)*c__2))+exp((2*I)*c__2)/(exp((2*I)*LambertW(-x*exp(c__2)))+exp((2*I)*c__2))))/((exp((2*I)*LambertW(-x*exp(c__2)))+exp((2*I)*c__2))^2*(1+LambertW(-x*exp(c__2)))*x)
Download bug_odetest_jan_18_2025.mw
Following on from my earlier question:
https://www.mapleprimes.com/questions/239620-Round-Robin-With-Double-Bye
a colleague has produced (admittedly hurriedly) a sports schedule over 14 weeks for a 8-team double bye, and a 10-team over 15 weeks.
Looking at it, and counting the possible combinations, neither seem optimal...
The 8 team has equal byes, the 10 uneven.
Edit. Ideally no team would have 2 byes in a row.
Is there a solution in maple over these weeks? given the min duration would be 13 weeks and the max 15 weeks?
In the previous solution by mmcdara the 8 bye schedule each team has played 6 times after week 8, but since the roster is truncated to 14 or 15, there will be some weeks when no byes are required (all teams playing) to even things up.
Similarly, the 10 bye each team has played 8 times after week 10, but since the roster is truncated to 14 or 15, there will be some weeks when no byes are required.
Any help would be welcome!
double_bye.xls
Edit: I made some counting errors. It's 28 and 45 as Carl pointed out
double_bye_revised.xls
First 39 40 41 42 43 44 45 Last Page 41 of 2425
