x0 := x - Pi/4;
y0 := y - Pi/4;
z0 := z - Pi/4;
f := (x, y, z) -> 10*sin(x0)*sin(y0)*sin(z0) + 10*sin(x0)*cos(y0)*cos(z0) + 10*cos(x0)*sin(y0)*cos(z0) + 10*cos(x0)*cos(y0)*sin(z0) - 7/10*cos(4*x) - 7/10*cos(4*y) - 7/10*cos(4*z);
implicitplot3d(evalc(f(x, y, z) = 9), x = -4.5 .. 4.5, y = -4.5 .. 4.5, z = -4.5 .. 4.5, grid = [60, 60, 60], style = patchnogrid);
Hi, do you know how can I restrict this plot using another implicitplot3d let's say sphere given by x^2+y^2+z^2<=4.5?
Look at the following Maple code and output, from Maple 2020. Can you explain the results? I know returning an uninitiated local variable is bad practice, but I cannot make sense of what happens when I do it anyway (just to understand the internals of the Maple language). Should I simply consider the results as undefined behavior?
> f:=proc()
>     local x;
>     return x;
> end proc:
> a1 := f() + f();
                                   a1 := 2 x
> a2 := f() - f();
                                  a2 := x - x
> a1 + a2;
                                  2 x + x - x
> a3 := f() + f() + f();
                                   a3 := 3 x
> a4 := f() + f() + f() - f();
                                 a4 := 3 x - x
f := z -> 1 + z/(1 + z^2/(1 + z^3/(1 + z^4/(1 + z^5/(1 + z^6/(1 + z^7))))))
Hi,do you know how to write a loop that would create such a continued fraction?
How to simplify the product of 4x4 matrices and how can we take out the expression that appears in each entry of the matrix?
MLM-1.mw
I'm trying to use an older package but the results of the author's own example returns the error:
"Error, (in SumTools:-DefiniteSum:-ClosedForm) summand is singular in the interval of summation"
I don't have access to the source coude, but by looking at other similar issues it seems to be happening when "sum" function is used. Is there a way to force Maple use "add" instead?
What im trying to do is build a 14 faced polyhedron from 9 vertices however when i try to plot 1 of these faces as defined by these vectors using polygonplot3d,
A1 := Vector([17/2, 0, 0]); A2 := Vector([-17/2, 0, 0]); B1 := Vector([0, 11/2, sqrt(166/4)]);
polygonplot3d(A1, A2, B1) polygonplot3d(A1, A2, B1)
the resulting graph plots the points, [17/2,-17/2,0],[0,0,11/2],[0,0,sqrt(166/4)] instead of how they are given by their vectors. It plots correctly if i use "polygonplot3d(Matrix([A1, A2, B1]))" but this does not scale well to my full polyhedron as Im not sure how to choose my faces in that regard. Is there any way I can force polygonplot3d to actually plot the vectors as points properly. Or is it simplist to convert all my vectors to lists first before plotting?
Thanks a lot, Seb
Hello there,
Would you tell me how to treat differentiation as an operator?
Here is a simple example:
(The content of the worksheet is supposed to be here, but that did not work)
Download Q20210407.mw
The 'coeff' operation shows 'psi__d0' as the only coefficient of 'Delta__delta(t)', while what I wanted to see is the 'Desired' expression in the worksheet, '(psi__d0 + psi__q0 / omega__0 * D)' as the coefficients. Here, 'D' represents the differentiation.
Thank you,
In Kwon Park
EssayTools command SpellCorrectWord("trnu") will return "run" and not return "turn".
Is there a way for Maple to only find anagrams with the same length as the given string?
Can Maple do this referencing an external dictionary located on the internet e.g. a complete Websters?
Hello all,
I am very new to Maple but it looks like a wonderful symbolic computing tool.  I am hoping to gain some familiarity with it and one of my first questions is this:  I have identified a nice formula refered to as a modified inverse gamma function.  This is a "peak function" with a couple nice features.  Firstly, it can describe both positively and negatively skewed distributions, and secondly its mode and amplitude are easily recognized as (X0,Ym).  I have entered it into a Maple 2019 notebook as so:
Y = Ym*(c/((d + 1)*(X - X__0) + c))^(d + 1)*exp((X - X__0)*(d + 1)^2/((d + 1)*(X - X__0) + c))
What I would like to do is calculate the positions, X, of the two points where it is half-maximal.  That is, where Y=1/2Ym.  I would like to assume that all numbers are real, etc.  I should point out that in the real world, I will have optimized the values of Ym, X0, c and d by first fitting to actual data, so this may helpfully constrain the problem.
Can someone explain how I might go about this?  If you assume I know nothing, I will not be offended.
I was trying to get an aproximation of an expression, but it doesnt seem to provide the correct answer. for the following
((12*sqrt(13))/13 - 3/4)/(1 + ((12*sqrt(13))/13)(3/4))
 maple provides 0.59568 and the actual answer is 0.73744
I dont know what I am doing wrong
It was interesting not to miss the solutions of such a test equation  x * (1 + 1.0001 * sin (x ^ 2)) = 0 on a fairly large arbitrary segment using NextZero.
It turned out that NextZero skips solutions.
For example, solutions in the range from 7.5 to 10 are skipped.  And two more specific solutions skipped 21.232154952 and 21.232821004.
I took Digits to help, but it didn't affect anything. Most likely the reason is that I am a bad user.  The example seems to be a good one.
#Digits := 30;
f := proc (x) options operator, arrow; x*(1+1.0001*sin(x^2)) end proc;
RootFinding:-NextZero(f, 1.0):
for j to 154 do RootFinding:-NextZero(f, %) end do
Let L be list say
L:=[[[1,2],3],[[1,3],4],[[1,4],4],[[1,7],7]]
The list is of this type it can be any list type and can be of any size it should be exported to excel like a table like this
A        B
(1,2)    3
(1,3)    4
(1,4)    4
(1,7)    7
First is in column A
and second is in column B
See brackets changed
kind help with the needul
Hi, dear community,
I have a Maple package "rath" for finding the traveling wave solution of differential equations. But I am not able to loading in Maple 18. Please see this attached zip folder and need help in this regard.
Kind regard
inform.txt,
PaperExp.mws
rath.txt
Anyone else experiencing problems uploading Workbooks as MaplePackage to MapleCloud.
Very often it is not possible to upload a workbook as a package, but just as a normal Maple file. Takes a couple of tries with opening the file until it is possible.
First 418 419 420 421 422 423 424 Last Page 420 of 2427
