I usually piecewise functions in my maple codes. I want to export  the my maple code to a Matlab code in order to utilize advantages of plots of Matlab.
What methods would you recommend me?
For example:
Suppose that I have a piecewise u function.
u:=1/(1. + exp(x))^2 + 1/(1. + exp(-5.*t))^2 - 0.2500000000 + x*(1/(1. + exp(1 - 5*t))^2 - 1./((1. + exp(-5*t))^2) + 0.1776705118 + 0.0415431679756514*piecewise(0. <= t and t <= 0.5000000000, 1.732050808, 0.) + 0.00922094377856479*piecewise(0. <= t and t <= 0.5000000000, 30.98386677*t - 7.745966692, 0.) + 0.0603742508215732*piecewise(0.5000000000 <= t and t <= 1., 1.732050808, 0.) - 0.00399645630498528*piecewise(0.5000000000 <= t and t <= 1., 30.98386677*t - 23.23790008, 0.)) + (-0.00243051684581302*piecewise(0. <= x and x <= 0.5000000000, 1.732050808, 0.) - 0.000809061198761621*piecewise(0. <= x and x <= 0.5000000000, 30.98386677*x - 7.745966692, 0.) - 0.0152377552205917*piecewise(0.5000000000 <= x and x <= 1., 1.732050808, 0.) - 0.00195593427342862*piecewise(0.5000000000 <= x and x <= 1., 30.98386677*x - 23.23790008, 0.))*piecewise(0. <= t and t <= 0.5000000000, 1.732050808, 0.) + (-0.000433590063316381*piecewise(0. <= x and x <= 0.5000000000, 1.732050808, 0.) - 0.000146112803263678*piecewise(0. <= x and x <= 0.5000000000, 30.98386677*x - 7.745966692, 0.) - 0.00319022339097685*piecewise(0.5000000000 <= x and x <= 1., 1.732050808, 0.) - 0.000477063086307787*piecewise(0.5000000000 <= x and x <= 1., 30.98386677*x - 23.23790008, 0.))*piecewise(0. <= t and t <= 0.5000000000, 30.98386677*t - 7.745966692, 0.) + (-0.00276114805649180*piecewise(0. <= x and x <= 0.5000000000, 1.732050808, 0.) - 0.000933166016624500*piecewise(0. <= x and x <= 0.5000000000, 30.98386677*x - 7.745966692, 0.) - 0.0207984584912892*piecewise(0.5000000000 <= x and x <= 1., 1.732050808, 0.) - 0.00314360556336114*piecewise(0.5000000000 <= x and x <= 1., 30.98386677*x - 23.23790008, 0.))*piecewise(0.5000000000 <= t and t <= 1., 1.732050808, 0.) + (0.000172746997599710*piecewise(0. <= x and x <= 0.5000000000, 1.732050808, 0.) + 0.0000586775450031145*piecewise(0. <= x and x <= 0.5000000000, 30.98386677*x - 7.745966692, 0.) + 0.00136190009033518*piecewise(0.5000000000 <= x and x <= 1., 1.732050808, 0.) + 0.000211410172315387*piecewise(0.5000000000 <= x and x <= 1., 30.98386677*x - 23.23790008, 0.))*piecewise(0.5000000000 <= t and t <= 1., 30.98386677*t - 23.23790008, 0.);
I use the following code to transform a Matlab code, but the output is not working in Matlab.
with(CodeGeneration):
Matlab(u,resultname="w");
Using solve on this example:
eq:=x^3 - 3*x^2 + 3*x - 1=0;
solve(eq,x);
gives solution x=1, with multiplicty 3
              1, 1, 1
When using PDEtools:-Solve
solve(eq,x);
PDEtools:-Solve(eq,x);
it gives
         x = 1
How can one make it show x=1, x=1, x=1 ?
Found that only when using PDEtools:-Solve(eq,x,numeric) it gives
           x = 1., x = 1., x = 1.
How to make it do the same without using numeric?
Maple 2020.1.1
What is the reason that error accepts its arguments without being inside paranthesis? This is different from all other Maple functions I've seen. For example, both these below work the same
f := proc (x)
     if x<0 then
        error "invalid x: %1", x;
        x^(1/2);
     end if
And
g := proc (x)
     if x<0 then
        error("invalid x: %1", x);
        x^(1/2)
     end if
One can't do for other Maple functions. For example sin x  gives an error. It must be sin(x)
Looked at help page for error and did not see something about this difference.
I have been having difficulty with plotting these graphs from Cartesian to Polar. I know that with double integrals there is an inclusion of r when you go from Cartesian to Polar. I think my graph of the function being integrated is correct. I am having difficulty with the command for the shaded region. I know with Cartesian, I can use inequal command to get the right shaded area. Will this command work with polar coordinates?
I attached the Maple worksheet.
Thank you all for help in advance!
When I select "oldest first", the first post shown is the newest.  Vice-versa when selecting "newest first".  Am I misunderstanding the meaning of the term?  I suppose it doesn't matter as both options are available but it's weird.
eqell := expand((x+(1/2)*R1-(1/2)*R)^2/a^2+y^2/b^2-1); geometry:-ellipse(ell, eqell, [x, y]); detail(ell); ellipse: hint: unable to determine if 1/(1/2*R+1/2*R1)^2*(1/(-8*R^3*R1+14*R^2*R1^2-3*R*R1^3)*R^2+2/(-8*R^3*R1+14*R^2*R1^2-3*R*R1^3)*R1*R+1/(-8*R^3*R1+14*R^2*R1^2-3*R*R1^3)*R1^2) is zero Error, (in geometry:-ellipse) the given polynomial/equation is not an algebraic representation of a ellipse. How to manage this error ? Thank you.
The expressions f(1), f(1,2,3), or f with any number of arguments, all match the type specfunc(f), while the expression f(g(1), 2 ,3) matches the type f(g(anything), anything, anything). However, is there a type which is matched by expressions like f(g(1), 2, 3 ...), with an arbitrary number of arguments after g(something)?
The command Typesetting:-Settings(prime=x,typesetprime=true):  makes diff(y(x),x) gives the latex as y'(x) which is what I wanted.
But I'd like to also be able to turn this off.  The reason is that in my program, I could have different variables in different places, and need to be able to turn this off/on as the program runs.
I know I can change the setting, by calling the above command again, with different variable. But I was looking for a way to turn it off as well.
Similar to Typesetting:-Suppress
Is there a way to do that? Actually the best solution would be, is to have the effect of Typesetting:-Settings(prime=x,typesetprime=true): be local to the proc. So if this command is used inside a proc, when leaving the proc, its effect will be automatically removed, as if this command was never issued.
Only when it is issued in global context, it will remain in effect until one does a restart.   Right now, the effect of Typesetting:-Settings(prime=x,typesetprime=true): is global. Even when called from inside a proc.  But this might be hard to implement. Therefore, being just able to turn it off is good for now.
Here is an example
foo:=proc(expr,x,y)
   print(Physics:-Latex(expr));
   #How to turn off the effect of above Typesetting command now?
   #so the following command works as the default setting?
expr:=diff(y(x),x)=3:
foo(expr,x,y);
I am trying to implement a recursive algorithm for matrix inverses, its a seventh-order method
for n to 7 do
    new := (1/16*old) . (120*I + ((A . old) . (735*I + ((A . old) . (-861.*I + ((A . old) . (651*I + ((A . old) . (93*I + (A . (old(-15*I + (A . old)))))))))))));
    old := new;
    print(n);
end do
However I get a error informing me that this is a recursive statment. Which it is, but maple thinks this is a bad thing.
So it is clear that I am doing somthing wrong, Can anyone help me by explaining what I am doing wrong?
Mvh
Eric Ragnarsson
I have questions about linestyle in maple, how to change solid and Dash whatever  to line with cross or line with plus
Please see a plot attached.
Look forward to hearing from you as soon as possible.
Mathastr
plots.pdf
I am new to Maple. I attempted to write a procedure that takes another procedure as input. It is not working correctly. As you can see from the output of a call to procedure A that something went wrong.
How do I do this correctly?
H := proc (n::integer)::real; local s, i; s := 0; for i by 2 to n do if i <= n-1 then s := s+1./((i*(i+1))) else s := s+1./i end if end do; return s end proc
A := proc (n::integer, T::procedure)::real; local d1, d2, s; d1 = T(n+1)-T(n); d2 = T(n+2)-T(n); s := T(n+1)-d1*d2/(d2-d1); return s end proc
H(11)
.7365440115
A(10, H)
.7365440115-d1*d2/(d2-d1)
Download st.mw
Maple Apps-Venn Diagrams does not work.  In box on the right there is an error message.
How do I calculate the first 5 values of the bisection method using the starting values of 4 and 5 of the function f(x) = (5 - x) * (e^x)-5
a := 4;
b := 5;
nStep := 5;
                               4
                               5
                               5
To obtain the columns of matrix as a list, this is what I currently do
A:=Matrix([[1,2,1,3,2],[3,4,9,0,7],[2,3,5,1,8],[2,2,8,-3,5]]);
Now
[seq(A[..,i],i=1..4)];
Also this does it
map(i->A[..,i],[$1..4]);
Is there a "shorter" way to do it?  For example, A[..,[$1..4]] does not do it ofcourse, it just gives the matrix itself back.
To solve this, I got this far but am not sure where to go next?
f2 := x^2 - 3;
f2d := diff(f2, x);
                             x  - 3
                              2 x
set value for x0, number precision
x0 := 3;
eps := 0.1*10^(-5);
                            0.000001
First 489 490 491 492 493 494 495 Last Page 491 of 2427
