I'm trying to compute the numerical solution for a PDE using the numerical solution of a first-order ODE. I looked at the INTEGRATE keyword of the pdsolve function, but I'm not sure how to use it. Can someone show an example of how to use this keyword?
I'm new at Maple, so I'm still trying to figure out basic stuff. I have solved an ode with t as independent variable and x as dependent one and I have used plots[odeplot] to plot x over t, but I also need to plot t over x. Any ideas how I can do that? Here's my code:
ode := diff(x(t), t) = 16250.25391*(1 - (487*x(t))/168 + 4*Pi*x(t)^(3/2) + (274229*x(t)^2)/72576 - (254*Pi*x(t)^(5/2))/21 + (119.6109573 - (856*ln(16*x(t)))/105)*x(t)^3 + (30295*Pi*x(t)^(7/2))/1728 + (7.617741607 - 23.53000000*ln(x(t)))*x(t)^4 + (535.2001594 - 102.446*ln(x(t)))*x(t)^(9/2) + (413.8828821 + 323.5521650*ln(x(t)))*x(t)^5 + (1533.899179 - 390.2690000*ln(x(t)))*x(t)^(11/2) + (2082.250556 + 423.6762500*ln(x(t)) + 33.2307*ln(x(t)^2))*x(t)^6)*x(t)^5
ics := x(0) = xlow
solx := dsolve({ics, ode}, numeric, range = 0 .. tfin)
plots[odeplot](solx, 0 .. tfin)
I have the following fractional  system of differential equation. How to plot it for alpha=0.5, beta=0.5?
eq1:=diff(y1(t),t$alpha)=0.04-(0.09*y1(t)*y2(t))-(0.00250*y1(t)*y2(t))/((0.03500+y2(t)))-0.04*y1(t);
eq2:=diff(y2(t),t$beta)=(0.09*y1(t)*y2(t))+(0.00250*y1(t)*y2(t))/((0.035+y2(t)))-(0.02+0.04)*y2(t);
I have a funtion defined as
a := diff(u*ln(m__o/(-q*t + m__o)) - g*t, t)
where m_0, q, g, and u are constants with dimensions. T is the variable and has dimensions as well. I need to print out columns of this function and other similar functions, v and h, in 4 seconds intervals of t. So what I have is this:
for i from -4 by 4 to 80 do
    if i = -4 then printf("%12s %18s %15s %15s \n", "time", "acceleration", "velocity", "altitude"); else printf("%10d %c %10.2f  %s %10.2f  %s %10.2f  %s \n", i, "s", eval(a, t = i), "ft/s^2", eval(v, t = i), "ft/s", eval(h, t = i), "mi"); end if;
end do
this works perfectly fine until I assign units to the constants and t. Then I get the error: Error, (in fprintf) number expected for floating point format.
Then I also need to plot a v and h against t. Seems like plot doesn't work either with units.
So what do i do?
Hello. I have the equations written into the arrays. I want to combine them into a common system and solve it. I gave a simple example of what I need. How do I perform this operation?
T1 := array(1 .. 2);
array( 1 .. 2, [ ] )
x = 1
y = 2
T2 := array(1 .. 2);
z = 3
r = x+y+z
solve({T1, T2}, {r, x, y, z});
Download 4.mw
restart; with(Student[LinearAlgebra]); A := Matrix([[2, 3, -4], [0, -4, 2], [1, -1, 5]]); for i to 3 do for j to 3 do print((-1)^(i+j)*Minor(A, i, j)) end do end do; How to code to get that is egal to Adjoint(A)? Thank you.
Whenever I open Maple 2020 and type one single letter or number (doesn't matter) Maple 2020 will "freeze" and load forever (i have had it open for a long time, just watching that f**king blue circle spin...
I have tried reinstalling, repairing, running as admin, and changing the compatibility mode, still, nothing works:(
I run Maple 2020 as a Student with WithGym
Pc specs:
Intel i5-10300h 2.6 ghz
Geforce 1660 ti 6gb
Windows 10 x64
Hello there,
Would you tell me how to check if the two expressions presented below are the same?
My simple attempt (at the end of the worksheet below) failed.
This page might be helpful to check the equality: https://www.myphysicslab.com/springs/trig-identity-en.html
subexpx := Ls*cos(omega*t + phi__l + theta)*omega + sin(omega*t + phi__l + theta)*Rs;
Ls*cos(omega*t+phi__l+theta)*omega+sin(omega*t+phi__l+theta)*Rs
subexpx2 := sqrt((omega*Ls)^2+Rs^2)*sin(omega*t + phi__l + theta + arctan(omega*Ls/Rs));
(Ls^2*omega^2+Rs^2)^(1/2)*sin(omega*t+phi__l+theta+arctan(omega*Ls/Rs))
is(subexpx - subexpx2 = 0) assuming omega::positive, Ls::positive, Rs::positive;
Thank you,
Download Q20201108.mw
I want to say maple convert this radicals to a single radical expr.
cos(sqrt(Lr1+Lr2)*t/(sqrt(Cr)*sqrt(Lr1)*sqrt(Lr2)))
convert to :
cos(sqrt((Lr1+Lr2)/(Cr*Lr1*Lr2))*t)
thank u .
I don't speak well in english but I 'll try
I can't print a matrix multiplication without maplke simplify it
i want
A*b=x
so
|1 2 3|     |x|        |1|
|4 5 6|  * |y|    =   |2|
|7 8 9|     |z|        |3|
but maple simplify A*x
so i have something like
|1x 2y 3z|            |1|
|4x 5y 6z|       =   |2|
|7x 8y 9z|            |3|
Thank a lot.
In this ODE
dsolve gives
When A=3 but  not when A=1 or A=2
ode:=(1+y(x))*diff(y(x),x$2)-A*diff(y(x),x)^2=x;
A:=1;
dsolve(ode):
A:=2;
dsolve(ode):
A:=3;
dsolve(ode):
The problem is not with the particular solution. Maple can find that
DEtools:-particularsol(ode,y(x))
And it can solve the homogeneous ODE for any A:
ode:=(1+y(x))*diff(y(x),x$2)-A*diff(y(x),x)^2=0;
A:=1;
dsolve(ode):
A:=2;
dsolve(ode):
A:=3;
dsolve(ode);
Is this a known issue and why it happens on some values?
Maple 2020.1 and Physics 861 on windows 10
i try to calculate the sum of  Eff elements , but i receive this message?
SumQuestion.mw
I try to remove first column from my df variable, but the command Remove(df,1) don't work. Ideas ?
SérieTabulateStat.mw
hello
I am beginner in maple.
I have a differential equation system with 17 equations. I used dsolve() function and my code worked.
Now, I want to integral from the dsolve answer.but I dont know how?
Hi, how to generate a matrix ( 6X2) with different random integers  ( between 10 and 20) in the first column and others random integers ( between 50 and 100) in the second column ?
First 511 512 513 514 515 516 517 Last Page 513 of 2459
