E-_Original_RSA.pdf
If I want to calculate and know the exact time duration of running step 8, do the current algorithm,
st := time();
elapsed_time := (time() - st)*sec
is good enough? precise enough? or accurate enough?
Any other recommendations?
https://math.stackexchange.com/questions/301068/how-do-you-find-a-corresponding-recurrence-relation-for-some-random-algorithm/301709
according to this link, how to parse or walk through the algorithm in maple to generate recurrence relation formula?
How to remove all punctuation marks in a string read from a text file
and then store in a list of words according to the ordering of the original text?
Ahead of the upcoming deadline 14 jan 2020 for switching from Windows 7 to Windows 10,  I am investigating whether Maple 2019 will run on an HP Stream laptop: Celeron CPU N3060 @ 1.6GHz, RAM 2GB, 64 bit.running Windows 10.
My guess is that the above spec is too low to successfully run Maple 2019.  But if anyone has had success running Maple on a similar spec device please let me know.
Melvin
I am trying to do a small procedure which converts an input of degrees into the sin function into its corresponding unit-circle value. I can get this to work.
Sinus:= proc(g::unit)
return evalf(sin(g*Pi/180));
but is there a more elegant way to do it? Using maybe Units package ? Thanks in advance :)
How can I make MAPLE to put out the numerical solution of the following system?
(a =0.12, c = 47.04)  Neither solve nor fsolve does the job!
Thank for your help!
>restart:
>S:=t->c*exp(-a*t)+18;
                      S := t -> c*exp(-a*t)+18
> sys:={S(2)=55,S(8)=36};
        sys := {c*exp(-8*a)+18 = 36, c*exp(-2*a)+18 = 55}
> solve(sys);
         {a = -1/2*ln(18/37*RootOf(18*_Z^3-37)^2), c = 37*RootOf(18*_Z^3-37)}
> fsolve(sys);
         fsolve({c*exp(-8*a)+18 = 36, c*exp(-2*a)+18 = 55},{a, c})
I have a differential equation involving several functions of the following form:
diff(h,z) = iAf + iBg,
where h, f and g are functions of the Cartesian coordinates x, y and R and the third coordinate corresponds to z = R for some fixed constant value R.  The derivative is then with respect to the coordinate z and A and B are constants, with i the usual imaginary unit.  Is there some way this equation could be solved explicitly with Maple?
I have a system of nonlinear differential equations with initial conditions:
de0 := {(1-p)*(diff(f(x), x, x))+p*(beta*[5]*f(x)*(diff(f(x), x))^2+beta[11]*f(x)^7+beta[6]*(diff(f(x), x))^3+beta[7]*f(x)^5+f(x)+diff(f(x), x, x)+beta[3]*f(x)^3+beta[1]*f(x)+beta[2]*(diff(f(x), x))+mu[1]*(diff(f(x), x))+(3/4)*rho*f(x)^3+beta[9]*f(x)^2*(diff(f(x), x))^3+beta[12]*f(x)^4*(diff(f(x), x))^3+beta[13]*f(x)*(diff(f(x), x))^6+beta[10]*f(x)*(diff(f(x), x))^4+beta[8]*f(x)^4*(diff(f(x), x))+beta[4]*f(x)^2*(diff(f(x), x))-(1/4)*rho*(g(x)^3-3*f(x)^2*g(x))*sin(4*Omega*x)-alpha[2]*f(x)^3*cos(2*Omega*x)-(1/4)*rho*(3*f(x)*g(x)^2-f(x)^3)*cos(4*Omega*x)-alpha[1]*g(x)*sin(2*Omega*x)-(1/2)*alpha[2]*(f(x)^3+3*f(x)^2*g(x))*sin(2*Omega*x)+(3/4)*rho*f(x)*g(x)^2-alpha[1]*f(x)*cos(2*Omega*x)-F*Omega^2*cos(Omega*x+theta)), (1-p)*(diff(g(x), x, x))+p*(diff(g(x), x, x)+beta[11]*g(x)^7+beta[7]*g(x)^5+beta[6]*(diff(g(x), x))^3+beta[1]*g(x)+beta[2]*(diff(g(x), x))+beta[3]*g(x)^3+mu[2]*(diff(g(x), x))+(3/4)*rho*g(x)^3+g(x)+beta[9]*g(x)^2*(diff(g(x), x))^3+beta[13]*g(x)*(diff(g(x), x))^6+beta[8]*g(x)^4*(diff(g(x), x))+beta[10]*g(x)*(diff(g(x), x))^4+beta[4]*g(x)^2*(diff(g(x), x))+beta[12]*g(x)^4*(diff(g(x), x))^3+beta[5]*g(x)*(diff(g(x), x))^2-(1/4)*rho*(3*f(x)*g(x)^2-f(x)^3)*sin(4*Omega*x)+(3/4)*rho*g(x)*f(x)^2-F*Omega^2*sin(Omega*x+theta)-(1/2)*alpha[2]*(f(x)^3+3*f(x)*g(x)^2)*sin(2*Omega*x)-alpha[2]*g(x)^3*cos(2*Omega*x)-(1/4)*rho*(3*f(x)^2*g(x)-g(x)^3)*cos(4*Omega*x)-alpha[1]*f(x)*sin(2*Omega*x)+alpha[1]*g(x)*cos(2*Omega*x))}:
ibvc0 := {f(0), g(0), (D(f))(0), (D(g))(0)}:
n := 3:
F := unapply(add(b[k](x)*p^k, k = 0 .. n), x):
de := map(series, eval(de0, {f = F, g = G}), p = 0, n+1):
for k from 0 to n do if k = 0 then ibvc := expand(eval[recurse](ibvc0, {f = F, g = G, p = 0})) else ibvc := {b[k](0)-1, (D(b[k]))(0)-1, (D(c[k]))(0)-1, ((D@@2)(b[k]))(0)-1, ((D@@2)(c[k]))(0)-1, c[k](0) = 1} end if; sys := `union`(simplify(map(coeff, de, p, k)), ibvc); soln := dsolve(sys); b[k] := unapply(eval(b[k](x), soln), x); c[k] := unapply(eval(c[k](x), soln), x) end do; 'F(x)' = F(x); 'G(x)' = G(x)
Error, (in dsolve) invalid input: `PDEtools/NumerDenom` expects its 1st argument, ee, to be of type algebraic, but received [0]
F(x) = b[1](x)*p+b[2](x)*p^2+b[3](x)*p^3
G(x) = c[1](x)*p+c[2](x)*p^2+c[3](x)*p^3
How would I deal with this error message
Download 6_11_2019_nonlinear_d_e.mw
Basically it spits out the subset of values for which a division by zero error will occur for the function you specify on  range you specify for each of it's arguments, but I get an ambigous error when ever exponentiation features in the function I specify, which of course dramatically reduces the application of the calculator. Division,addition,substraction and multiplication are currently the only available arithmetic operators availble for the function window that I know the error will not occur.
If some one can help it is much appriciated
DIVISION_BY_ZERO_CALCULATOR.mw
I have an first-order ode
y'(x) =0, for x in [0,1] but x different to 1/2
and we define a function y(x)= 2   if 0<=x<0.5  and y(x)=0 for 0.5<=x <=1
The attached code define these function ( maybe piecewise function is not welle defined) and how can we show that y is solution or not of the differential equation
ode.mw
many thanks
I was playing around with some of the maple examples(specifically the knots) and all the plots seem difficult to visualize in 3D... well, more difficult than they should.
In some cases the plots look more like projections and 2D because the graphical representation does seem to project in to the depth of the screen in a natural way.
Mainly it happens when rotating when some of the curve's appear to stay in front due to the highlighting and size issues.
I'm not sure exactly what the problem is but I imagine it definitely can be improved. It may be simply that there are no other depth cues in the plot to make things more real.
1. I'd like anti-aliased edges. The edges of the plot are hard and not correct coloring wise(do not fade like in real life).
2. Some type of depth perspective where the size changes with depth in to the screen in a meaningful way.
3. Proper coloring of this. Maple seems to handle the lighting correctly but it is far too weak to give the impresson of depth
I think maple essentially does all this(except probably AA, although there is probably a setting somewhere) but it seems they are not properly tweaked for maximum realism. I played with the lighting and projection and it seems to help a little but not much.
Any ideas on how to improve this? Ideally something that doesn't have to be set every plot.
hello everyone,
   INGT.mw
L__d := 100:
L__b := 200:
L__c := L__d+(1/2)*L__b;
200
X := .3;
.3
Error, (in plot) procedure expected, as range contains no plotting variable
`&Delta;E__g` := 1.155*X+.37*X^2;
.3798
V__0 := .6*`&Delta;E__g`;
.22788
m__D := 0.67e-1*m[e];
0.67e-1*m[e]
m__B := (0.67e-1+0.83e-1*X)*m[e];
0.919e-1*m[e]
Sol := solve(2*cos(L__d*sqrt(E__x))+(m__D*sqrt((V__0-E__x)/E__x)/m__B-m__B*sqrt(E__x/(V__0-E__x))/m__D)*sin(L__d*sqrt(E__x))-(m__D*sqrt((V__0-E__x)/E__x)/m__B+m__B*sqrt(E__x/(V__0-E__x))/m__D)*sin(L__d*sqrt(E__x))*exp(-sqrt(V__0-E__x)*L__b) = 0, E__x);
0.1110897170e-2, 0.3531161505e-2, -.2585338615+0.9991335677e-27*I
E__1 := 0.1110897170e-2:
K__1 := sqrt(E__1);
0.3333012406e-1
K__2 := sqrt(V__0-E__1);
.4762027959
C := cosh((1/2)*K__2*L__b);
0.2399908351e21
beta := m__D*K__2/(m__B*K__1);
10.41631973
B := -beta*sinh((1/2)*K__2*L__b);
-0.2499821271e22
A := -B*sin(K__1*L__d)+C*cos(K__1*L__d);
-0.7112056933e21
(14)
h := proc (x) options operator, arrow; piecewise(x <= -L__c, A*exp(K__2*(x+L__c)), -L__c < x and x < -(1/2)*L__b, -B*sin(K__1*(x+(1/2)*L__b))+C*cos(K__1*(x+(1/2)*L__b)), abs(x) <= (1/2)*L__b, (1/2)*exp(K__2*x)+(1/2)*exp(-K__2*x), (1/2)*L__b < x and x < L__c, -B*sin(K__1*(x-(1/2)*L__b))+C*cos(K__1*(x-(1/2)*L__b)), L__c <= x, A*exp(K__2*(x-L__c))) end proc:
'h(x)' = h(x);
h(x) = piecewise(x <= -200, -7.112056933*10^20*exp(95.24055918+.4762027959*x), -200 < x and x < -100, 2.499821271*10^21*sin(3.333012406+0.3333012406e-1*x)+2.399908351*10^20*cos(3.333012406+0.3333012406e-1*x), abs(x) <= 100, (1/2)*exp(.4762027959*x)+(1/2)*exp(-.4762027959*x), 100 < x and x < 200, 2.499821271*10^21*sin(0.3333012406e-1*x-3.333012406)+2.399908351*10^20*cos(0.3333012406e-1*x-3.333012406), 200 <= x, -7.112056933*10^20*exp(-95.24055918+.4762027959*x))
(15)
L__y := 200:
L__z := 200:
P := proc (x, y, z) options operator, arrow; h(x)*cos(Pi*y/L__y)*cos(Pi*z/L__z) end proc:
'Psi(x, y, z)' = P(x, y, z);
Psi(x, y, z) = piecewise(x <= -200, -7.112056933*10^20*exp(95.24055918+.4762027959*x), -200 < x and x < -100, 2.499821271*10^21*sin(3.333012406+0.3333012406e-1*x)+2.399908351*10^20*cos(3.333012406+0.3333012406e-1*x), abs(x) <= 100, (1/2)*exp(.4762027959*x)+(1/2)*exp(-.4762027959*x), 100 < x and x < 200, 2.499821271*10^21*sin(0.3333012406e-1*x-3.333012406)+2.399908351*10^20*cos(0.3333012406e-1*x-3.333012406), 200 <= x, -7.112056933*10^20*exp(-95.24055918+.4762027959*x))*cos((1/200)*Pi*y)*cos((1/200)*Pi*z)
(16)
INGT := proc (x__i) `assuming`([evalf(int(int(int(P(x, y, z)^2*exp(-lambda*sqrt((x-x__i)^2+y^2+z^2)), x = -infinity .. infinity), y = -L__y .. L__y), z = -L__z .. L__z))], [0 < lambda]) end proc
evalf(INGT(2))
Download INGT.mw
L__d := 100:
L__b := 200:
200
X := .3;
.3
.3798
.22788
0.67e-1*m[e]
0.919e-1*m[e]
K__1 := sqrt(E__1);
0.3333012406e-1
.4762027959
0.2399908351e21
10.41631973
-0.2499821271e22
-0.7112056933e21
(14)
'h(x)' = h(x);
(15)
L__y := 200:
L__z := 200:
(16)
evalf(INGT(2))
Download INGT.mw
I'm trying to calculate a triple integral complicated by a procedure that changes each time a variable xi, while the program takes a lot of time and it gives me the message "Warning, computation interrupted". If anyone can help me I will be very happy
Is there something I should be doing whenever I use simplify to avoid things like this, or should I stop using the "is" function all together?
interface(showassumed = 0):
sum(binomial(k+j, k), j = 0 .. n-k) = binomial(n+1, k+1)
(n-k+1)*binomial(n+1, k)/(k+1) = binomial(n+1, k+1)
#And we have:
is(sum(binomial(k+j, k), j = 0 .. n-k) = binomial(n+1, k+1))
FAIL
#And since:
is(simplify(convert(sum(binomial(k+j, k), j = 0 .. n-k) = binomial(n+1, k+1), 'factorial')))
is(sum(binomial(k+j, k), j = 0 .. n-k) = binomial(n+1, k+1)) = is(simplify(convert(sum(binomial(k+j, k), j = 0 .. n-k) = binomial(n+1, k+1), 'factorial')))
Download main.mw
Can I know how to write code about to solve the second kind of linear Fredholm and also Volterra approximation integral by Simpson's method and Galerkin method, and I need a book about advance math to the integral equation, thanks.
  1. Does it have any detail manual for Matlab programming using Maple symbolic engine? (Except help documentation of Maple Symbolic Toolbox in Matlab).
  2. How to maximize the running speed of the codes programmed by Maple symbolic toolbox? Any Notes?
  3. How to use the function 'GenerateMatrix' of Maple in Matlab? What's the syntax to use this function in Matlab?
Best Regards.
Si
First 623 624 625 626 627 628 629 Last Page 625 of 2428
