Let be the sequence (an) so that a1 = 1, a(n+1) = 5*a(n) + sqrt(k*a(n)^2 -8), for all n >=1. I know that, the answer is k = 24.  How can I choice number k so that the sequence is an integer sequence?
I am trying to export the data list to .dat but i received that error. New with coding and Maple.
a := sin(x^(1/3))+sin(x)^(1/3);
                      / (1/3)\         (1/3)
                   sin\x     / + sin(x)
b := diff(a, x);
                     / (1/3)\
                  cos\x     /      cos(x)
                      (2/3)             (2/3)
                   3 x          3 sin(x)
output := fopen("Ospino.dat", WRITE);
for x by .5 to 50 do fprintf(output, "%f\t %f\t \n", x, b) end do;
Error, (in fprintf) number expected for floating point format
fclose(output);
add(q[k],k=1..5)
I'd like to be able to display a general result such as
q_1 + q_2 + ... + q_n
ideally maple would do all the special stuff for me, e.g., somehow I could do
add(q[k],k=1..2..n)
but I can't even seem to get a nice output manually that doesn't involve a lot of printing code.
Can maple compute the following integral
Integral ( z^(-0.5), z in M) where  M is the lower half-unit circle from +1 to -1
Many thanks
How I can apply the condition or assuming (a>0) in ?
I want to have a plot according to the attached figure.
restart; A5 := 2.4821; A3 := .8417; A4 := -.1384; K := 0.3e-2; `σσ` := (9*A3*A5*a^2-10*A4^2*a^2)/(24*A3^(3/2))+K/(2*a*A3^(1/2))
2.4821
.8417
-.1384
1.004210973*a^2+0.1634980569e-2/a
solve(sigma = 1.004210973*a^2+0.1634980569e-2/a, a)
solve(sigma = 1.004210973*a^2-0.1634980569e-2/a, a)
plot({1.079801433*10^(-25)*(-6.465854665*10^71+1.058832302*10^46*sqrt(-2.057991547*10^56*sigma^3+3.729044048*10^51))^(1/3)+3.074042610*10^24*sigma/(-6.465854665*10^71+1.058832302*10^46*sqrt(-2.057991547*10^56*sigma^3+3.729044048*10^51))^(1/3), 1.079801433*10^(-25)*(6.465854665*10^71+1.058832302*10^46*sqrt(-2.057991547*10^56*sigma^3+3.729044048*10^51))^(1/3)+3.074042610*10^24*sigma/(6.465854665*10^71+1.058832302*10^46*sqrt(-2.057991547*10^56*sigma^3+3.729044048*10^51))^(1/3)}, sigma = -.2 .. .2)
Download plot
Normally the wheel mouse will scroll a file like it does in just about every other program... but when the mouse is over a code edit region it does nothing ;/ As one is scrolling with the wheel and a code edit region pops up this breaks the flow and requires hoops, I don't like hoops!
Seems most mouse funcitons do not work well in the region. Just trying to select and drag doesn't scroll the region.
I was writing in a maple document when suddently all the text and equations collapsed into a single line at the top, making it unreadable and unusuable. I was not able to restore a previous backup of the file, however i did manage to salvage a smaller part of the document. Both files are included.
corrupted.mw
what_i_managed_to_save.mw
ModularSquareRoot can't handle a really big n because of the factorization problem. But I would like to know if there is any other function than can use as parameters the factorization of n.
I already have an algorithm that does that for n=pq with p, q primers, and could generalize it, but I was wondering whether there was a built-in function that does that.
The Folium of Descartes (see the wikipedia page about this curve) is an algebraic curve defined by the equation 𝑥 ^3 + 𝑦 ^3 − 3𝑎𝑥𝑦 = 0, where 𝑎 is a constant. You will need the information on this wikipedia page in order to plot the following graphs. plot them for 𝑎 = 1,  Graph the curve with 𝑎 = 1 using the command implicitplot in the range of −3 ≤ 𝑥 ≤ 3 and −3 ≤ 𝑦 ≤ 3. (which i have already done)
However i am unable to Add a plot of the line 𝑥 + 𝑦 + 𝑎 = 0 on the same graph but dashed and with a different color (set numpoints as 10000).
Does global optimization toolbox has randomization option it gives same value every time
In addition to defining a function in a standard way, a fast and convenient way to turn a formula (an expression) into a function is to use unapply command (check Maple help center for this command). The following items are about defining functions.
  1. Define a function midpoint, which returns the average of two arguments given on input. For example, midpoint(2,3) returns 2.5, midpoint(a,b) returns 𝑎+𝑏2.
  2. b) For two positive natural numbers 𝑎 and 𝑏 we can define the least common multiple lcm(𝑎,𝑏) via their greatest common divisor gcd (𝑎,𝑏), i.e.: lcm(𝑎,𝑏) = 𝑎𝑏gcd (𝑎,𝑏). When 𝑎 and/or 𝑏 are zero, lcm(𝑎; 𝑏)=0. Use the arrow operator and piecewise to define the function my_lcm which returns the least common multiple of two natural numbers.
  3. c) The quadratic formula allows to write the roots of 𝑝 = 𝑎𝑥2+𝑏𝑥+𝑐 explicitly in terms of 𝑎,𝑏, and 𝑐.
 Define a piecewise function of 𝑥 so that the value of the function is 0, if 𝑥<−(𝑟1+ 𝑟2+𝑟3) or 𝑥>𝑟1+ 𝑟2+𝑟3, and it is equal to the area of confined region if −(𝑟1+ 𝑟2+𝑟3)<𝑥<𝑟1+ 𝑟2+𝑟3.
a) Given real values 𝑟1,𝑟2,𝑟3>0, consider the curve of the positive part of the circle with radius 𝑟1+ 𝑟2+𝑟3 and center at the origin and three semi-circles below with radii 𝑟1,𝑟2,𝑟3 so that they are arranged from left to right like the following graph. Define proper functions and plot this graph in Maple for 𝑟1=10,𝑟2=2,𝑟3=8.
Cursor jumping to end of sheet/page when pressing enter (calculating).
How do I change the settings in maple 2019 so that the cursor doesnt jump to the end of the page/document everytime I make a calculation.
Jeppe
I don't understand why Maple gives me the following error:
Error, (in fsolve/Iterators) unrecognized form
The full maple file:
mbal := 0.28e-2:
rbal := 0.2e-1:
Cw := .47:
g := 9.81:
A := Pi*rbal^2:
beta := 3.33*Pi*(1/180):
s0x := .2:
s0y := .25:
rho := 1.293:
l := 2:
vx := diff(sx(t), t);
diff(sx(t), t)
vy := diff(sy(t), t);
diff(sy(t), t)
ax := diff(sx(t), `$`(t, 2));
diff(diff(sx(t), t), t)
ay := diff(sy(t), `$`(t, 2));
diff(diff(sy(t), t), t)
v0x := cos(beta)*v0;
cos(0.1850000000e-1*Pi)*v0
v0y := sin(beta)*v0;
sin(0.1850000000e-1*Pi)*v0
`&Sigma;Fx` := -Fdx = mbal*ax;
-Fdx = 0.28e-2*(diff(diff(sx(t), t), t))
`&Sigma;Fy` := -Fz-Fdy = mbal*ay;
-Fz-Fdy = 0.28e-2*(diff(diff(sy(t), t), t))
Fz := mbal*g;
0.27468e-1
Fdx := .5*rho*vx^2*A*Cw;
0.1215420e-3*(diff(sx(t), t))^2*Pi
Fdy := .5*rho*vy^2*A*Cw;
0.1215420e-3*(diff(sy(t), t))^2*Pi
ics1 := sx(0) = s0x, (D(sx))(0) = v0x;
sx(0) = .2, (D(sx))(0) = cos(0.1850000000e-1*Pi)*v0
ics2 := sy(0) = s0y, (D(sy))(0) = v0y;
sy(0) = .25, (D(sy))(0) = sin(0.1850000000e-1*Pi)*v0
verplaatsingx := dsolve({ics1, `&Sigma;Fx`}, sx(t));
sx(t) = (1400000/60771)*ln((60771/1400000)*cos((37/2000)*Pi)*v0*exp((60771/7000000)*Pi)*t*Pi+exp((60771/7000000)*Pi))/Pi
(14)
verplaatsingy := dsolve({ics2, `&Sigma;Fy`});
sy(t) = (1/243084)*(60771*Pi+2800000*ln((1/92736546000)*(20257*Pi^(1/2)*sin((37/2000)*Pi)*v0*sin((3/70000)*231841365^(1/2)*Pi^(1/2)*t)+20*231841365^(1/2)*cos((3/70000)*231841365^(1/2)*Pi^(1/2)*t))^2))/Pi
(15)
eindy := rhs(verplaatsingy) = rbal;
(1/243084)*(60771*Pi+2800000*ln((1/92736546000)*(20257*Pi^(1/2)*sin((37/2000)*Pi)*v0*sin((3/70000)*231841365^(1/2)*Pi^(1/2)*t)+20*231841365^(1/2)*cos((3/70000)*231841365^(1/2)*Pi^(1/2)*t))^2))/Pi = 0.2e-1
(16)
eindx := rhs(verplaatsingx) = l;
(1400000/60771)*ln((60771/1400000)*cos((37/2000)*Pi)*v0*exp((60771/7000000)*Pi)*t*Pi+exp((60771/7000000)*Pi))/Pi = 2
(17)
t := solve(eindy, t);
RootOf(1397733*Pi+70000000*ln((1/92736546000)*(20257*Pi^(1/2)*sin((37/2000)*Pi)*v0*sin((3/70000)*231841365^(1/2)*Pi^(1/2)*_Z)+20*231841365^(1/2)*cos((3/70000)*231841365^(1/2)*Pi^(1/2)*_Z))^2))
(18)
t := evalf(t[1]);
RootOf(1397733*Pi+70000000*ln((1/92736546000)*(20257*Pi^(1/2)*sin((37/2000)*Pi)*v0*sin((3/70000)*231841365^(1/2)*Pi^(1/2)*_Z)+20*231841365^(1/2)*cos((3/70000)*231841365^(1/2)*Pi^(1/2)*_Z))^2))[1]
(19)
v0 := fsolve(eindx, v0)
Download ttbuddymaple.mw
First 627 628 629 630 631 632 633 Last Page 629 of 2428
