I need to solve or reduce (similar to the command Reduce in Mathematica) sets of nonlinear equations.  One such example is shown below:
eqns := {-1+theta[3, 6] = 0, 1-theta[3, 6] = 0, alpha+rho-theta[2, 2]+theta[3, 3] = 0, -theta[3, 6]^2+1 = 0, theta[2, 2]*theta[3, 6]-alpha = 0, theta[2, 2]*theta[3, 6]^2-alpha = 0, -2*theta[3, 3]*theta[3, 6]-2*rho = 0, theta[1, 2]*theta[2, 1]*theta[3, 6]^2+1 = 0, -alpha^2+rho^2+theta[2, 2]^2-theta[3, 3]^2 = 0, -theta[2, 2]^2*theta[3, 6]+2*theta[2, 2]*theta[3, 3]*theta[3, 6]+alpha^2+2*alpha*rho = 0, -theta[1, 3]*theta[2, 2]^2*theta[3, 0]+theta[1, 3]*theta[2, 2]*theta[3, 0]*theta[3, 3]-alpha^2*beta-alpha*beta*rho = 0, -theta[1, 2]*theta[2, 1]*theta[2, 2]*theta[3, 6]+2*theta[1, 2]*theta[2, 1]*theta[3, 3]*theta[3, 6]-alpha-2*rho = 0, -theta[1, 2]*theta[2, 1]*theta[2, 2]*theta[3, 3]+theta[1, 2]*theta[2, 1]*theta[3, 3]^2+theta[1, 3]*theta[2, 2]*theta[3, 0]*theta[3, 6]+alpha*beta+alpha*rho+rho^2 = 0, -alpha^2*rho-alpha*rho^2+theta[1, 2]*theta[2, 1]*theta[2, 2]-theta[1, 2]*theta[2, 1]*theta[3, 3]+theta[1, 3]*theta[3, 0]*theta[3, 6]-theta[2, 2]^2*theta[3, 3]+theta[2, 2]*theta[3, 3]^2+alpha+beta+rho = 0}
 and the indeterminates are:
fc := {theta[1, 2], theta[1, 3], theta[2, 1], theta[2, 2], theta[3, 0], theta[3, 3], theta[3, 6]}
Since I do know the solution, I issued the following command to check for typos.
seq(subs(theta[1,2]=-1,theta[1,3]=-1,theta[2,1]=1,theta[2,2]=alpha,theta[3,0]=beta,theta[3,3]=-rho,theta[3,6]=1,eqns[i]),i=1..nops(eqns))
and the outcome is zero for all equations.
When I try the command solve as follows:
solve(eqns,fc);
the result is
{theta[1, 2] = theta[1, 2], theta[1, 3] = theta[1, 3], theta[2, 1] = -1/theta[1, 2], theta[2, 2] = alpha, theta[3, 0] = -beta/theta[1, 3], theta[3, 3] = -rho, theta[3, 6] = 1}
that should be right but it is not what I am expecting.
How can maple return the solution needed?
Some sets of solutions do not have a solution as the one above.  Some indeterminates cannot be found, is there a way maple returns the solution of the ones that can be solved and reduced the set of equations into two parts, solved ones e non solved ones?  I can provide an example if needed.
Many thanks.
Ed
Non-Linear overdetermined equations - which is best method? with less number of iterations
When I use Jacobi it takes 25 iterations.
Any other method which takes less iterations?
I would like to know whether a local optimizer is combined with the present global optimization toolbox?. I read that toolbox has differential evolution and surrogate optimization techniques etc. These methods guarantee near-optimal solutions and it is often recommended to use a local optimization technique in conjunction with global optimization techniques.
I search saveplot and sleep function here
i had kept close filename function and move plot setup default to first line
but thread no sleep in maple 12
then I remove sleep and can save image file
but after I call it in a function and run a for loop for this function
the file is not updated after sleep 3 seconds
how to run a for loop call it and it can refresh
Is anyone accessing the https://www.mapleprimes.com/questions redirected to this page https://www.mapleprimes.com/errors/500.aspx?aspxerrorpath=/questions/default.aspx ?
I tried to control z-axes by writing
plot3d(sech((1/2)*sqrt(3/5)*(x-2*t)), x = -10 .. 10, t = -10 .. 10, scaling = constrained, style = patchnogrid)
but I could not change the height of z axes. I want to change the dimensions like in the following figure.
example-graph.pdfexample-graph.pdf
Although the range of z-axix is small but it appears very clear. Can anyone help me, please.
The following message is displayed at the beginning of my worksheet when i reopen it, no data is lost because the nature of my code retrives it's optimal boundaries for the loops but i dont know what the hell this is telling me this for:
"Warning, .hdb help databases are deprecated, 'C:\Users\the_r\maple\toolbox\Syrup\lib\Syrup.hdb' will not be used, see ?HelpTools,Migrate help page for more information"
It appears in blue standard size courier font if that is help thank you
Is it asking me to migrate? My passport was stolen by clandestine pharmacists
 Dear fellows
I have the problme with first seq command.
for i while i <= M1-2 do for j while j <= M1-2 do for k while k <= M1 do Eq[i, jk] := simplify(eval(R, [x = i/(M1-2.), y = j/(M1-2.), t = k/(M1-1.)])) = 0 end do end do end do:
Sol := fsolve({seq(BC1[m8, m9]$m8 = 1 .. M1, m9 = 1 .. M1), seq(BC2[m10, m11]$m10 = 1 .. M1, m11 = 1 .. M1), seq(BC3[m12, m13]$m12 = 1 .. M1, m13 = 1 .. M1), seq(BC4[m14, m15]$m14 = 1 .. M1, m15 = 1 .. M1), seq(IC1[m4, m5]$m4 = 0 .. M1, m5 = 1 .. M1), seq(IC2[m6, m7]$m6 = 0 .. M1, m7 = 1 .. M1), seq(Eq[m1, m2, m3]$m1 = 1 .. M1-2, m2 = 1 .. M1-2, m3 = 1 .. M1-1)});
Got the following error.
Error, invalid input: seq expects its 3rd argument, step, to be of type numeric, but received m3 = 1 .. 1
Please help me in this regard.
Error, (in Optimization:-NLPSolve) the objective gradients at the initial point are too small
So this error indicates that the initial point is a local minimum or very very close to it right?
I'm very new to Maple (and coding in general). I'd like to know a very large coefficient of a certain 𝑞-series involving the Dedekind 𝜂-function. For example
s:=series(subs(q=q^6, eta^4), q, N);
where eta := series(q^(1/24)*product(1 - q^n, n = 1 .. 100), q, N). I know the command coeftayl(s, q=0, N) but for certain 𝑞-series it doesn't recognize the numerical value of this coefficient when 𝑁 is too large (even after subtracting the principal part of 𝑠, if there is any) - instead it realizes the coefficient as a HUGE limit of something. Cheers.
I need the final line of the uploaded worksheet to be the "Select Action", preprogrammed prior to the execution of the insert xml command, how do i do this?
Maple Worksheet - Error
Failed to load the worksheet /maplenet/convert/ASK.mw .
Download ASK.mw
I am trying to do matrix multiplication with Dirac gamma matrices, but am getting a recursion error.
the final input line, which is causing the error, doesn't seem to be inserted, but it is:
Library:-PerformMatrixOperations((mt . (Dgamma[2])) . m)
can anybody tell me what i'm doing wrong? i don't understand why
Dgamma[2] . m
works but
mw . Dgamma[2] . m
gets the recursion error.
then i saw something that made me think i needed to use 'matrix', instead of 'Matrix'. so i tried that(gamult2) - now the 2nd multiply works, and the first fails.
any help greatly appreciated!
thanks,
larry
with(Physics)
Physics:-Version()
`The "Physics Updates" version in the MapleCloud is 452 and is the same as the version installed in this computer, created 2019, October 23, 13:26 hours, found in the directory /Users/lstead/maple/toolbox/2019/Physics Updates/lib/`
with(LinearAlgebra)
m := Matrix(4, 1, {(1, 1) = 1, (2, 1) = 2, (3, 1) = 3, (4, 1) = 4})
Matrix(%id = 18446744078528784254)
mt := Transpose(m)
Matrix(%id = 18446744078392267830)
mt.m
Matrix(%id = 18446744078392260238)
Library:-PerformMatrixOperations(Dgamma[2].m)
Matrix(%id = 18446744078528770526)
Library:-PerformMatrixOperations(mt.Dgamma[2].m)
Error, (in Physics:-GetDefineINFO) too many levels of recursion
Download gammult.mw
gammult2.mw
hello
why this pdsolve not be answer
pde := diff(T(x, y, t), x, x)+diff(T(x, y, t), y, y) = (1/0.44e-2)*(diff(T(x, y, t), t));
conds := T(0, y, t) = 1, T(1, y, t) = 1, T(x, 0, t) = 1, T(x, 1, t) = 1, T(x, y, 0) = 0;
`assuming`([pdsolve([pde, conds])], [0 <= x and x <= 1, 0 <= y and y <= 1, t >= 0]);
I have a fourth-order PDEs, with some boundary condition, I would like to compute an explicit solution or plot the solution in the interval [0,2]
PDEsolve.mw
thinks
Say I have the differential equation:
x1'(t) = 3C1*cos(t) + 2C2*sin(t)
x2'(t) = 5C1*cos(t) + 1C2*sin(t)
How can one draw phase portraits in maple?
First 630 631 632 633 634 635 636 Last Page 632 of 2428
