I want to evaluate the change of temperature and energy loss during the flow through an expansion valve.
But the command fsolve this does not work with CoolProp.
The following command is just repeated, but gives no result.
fsolve({ThermophysicalData:-Property("D", "H2", "temperature" = TTT, "pressure" = ppp) = 31.13, ThermophysicalData:-Property("H", "H2", "temperature" = TTT, "pressure" = ppp) = 4.098640000*10^6}, {TTT, ppp})
Andreas
Assume that we have, in the cube C:=[-1,1]^N, for a fixed integer N>=2, a point X1  and   cosider the (closed) ball centered at X1 and radius R1:=0.6. Fixed an integer m>2, Somebody can indicate me how to compute the centers (belonging to C) and the radius of m disjoint balls with the above ball?
That is to say, compute points X2,...,Xm (in C) and positive numbers R2,...,Rm such that the intersection of the (closed) balls B(Xj,Rj) for j=1,...,m be empty.
Some suggestion?
If i have a function like: f(d) = 1- inf { a \in [0,1]: a = e^{d(a-1)} } how can i plot it in maple?
Or simple one function with a maximum over an intervall in it?
I have a problem in solving an integral in maple. I can't solve the below integral in maple and it returns the integral itself to me. I also attach an image from the integral if here is not clearly shown. I want maple to return me just a number. can anyone help me in this?
int(sin(beta)*(-0.4447569104e-1*beta(10)^3+1.846983291*beta(10)^2+78.88888890*beta(10)+620.4645491)/(9.+.6366197724*beta(10))^2, beta = 0 .. (1/2)*Pi)
T := mu+lambda*H(xi)+(v-1)*H(xi)^2;
               mu + lambda H(xi) + (v - 1) H(xi)
u[0] := a[0]+a[1]*(d+H(xi))+a[2]/(d+H(xi))+a[3]*(d+H(xi))^2+a[4]/(d+H(xi))^2;
                                a[2]                      2
    a[0] + a[1] (d + H(xi)) + --------- + a[3] (d + H(xi))
                              d + H(xi)
             a[4]
         (d + H(xi))
diff(u[0], xi);
                            / d        \
                       a[2] |---- H(xi)|
        / d        \        \ dxi      /
   a[1] |---- H(xi)| - -----------------
        \ dxi      /                2
                         (d + H(xi))
                                                 / d        \
                                          2 a[4] |---- H(xi)|
                           / d        \          \ dxi      /
      + 2 a[3] (d + H(xi)) |---- H(xi)| - -------------------
                           \ dxi      /                 3
                                             (d + H(xi))
collect(%, diff(H(xi), xi));
/           a[2]                               2 a[4]   \ / d
|a[1] - ------------ + 2 a[3] (d + H(xi)) - ------------| |---- H(xi
|                  2                                   3| \ dxi
\       (d + H(xi))                         (d + H(xi)) /
d[1] := (a[1]-a[2]/(d+H(xi))^2+2*a[3]*(d+H(xi))-2*a[4]/(d+H(xi))^3)*T;
 /           a[2]                               2 a[4]   \ /
 |a[1] - ------------ + 2 a[3] (d + H(xi)) - ------------| \mu
 |                  2                                   3|
                                  2\
    + lambda H(xi) + (v - 1) H(xi) /
diff(d[1], xi);
/       / d        \                                / d        \\
|2 a[2] |---- H(xi)|                         6 a[4] |---- H(xi)||
|       \ dxi      /          / d        \          \ dxi      /|
|------------------- + 2 a[3] |---- H(xi)| + -------------------|
|              3              \ dxi      /                 4    |
  /                                 2\   /           a[2]
  \mu + lambda H(xi) + (v - 1) H(xi) / + |a[1] - ------------
                                         |                  2
                                         \       (d + H(xi))
                             2 a[4]   \ /       / d        \
   + 2 a[3] (d + H(xi)) - ------------| |lambda |---- H(xi)|
                                     3| \       \ dxi      /
                          (d + H(xi)) /
                     / d        \\
   + 2 (v - 1) H(xi) |---- H(xi)||
                     \ dxi      //
//   2 a[2]                  6 a[4]   \ /
||------------ + 2 a[3] + ------------| \mu + lambda H(xi)
||           3                       4|
\\(d + H(xi))             (d + H(xi)) /
                  2\   /           a[2]
   + (v - 1) H(xi) / + |a[1] - ------------ + 2 a[3] (d + H(xi))
                       |                  2
                       \       (d + H(xi))
        2 a[4]   \                           \ / d        \
   - ------------| (lambda + 2 (v - 1) H(xi))| |---- H(xi)|
                3|                           | \ dxi      /
     (d + H(xi)) /                           /
d[2] := ((2*a[2]/(d+H(xi))^3+2*a[3]+6*a[4]/(d+H(xi))^4)*(mu+lambda*H(xi)+(v-1)*H(xi)^2)+(a[1]-a[2]/(d+H(xi))^2+2*a[3]*(d+H(xi))-2*a[4]/(d+H(xi))^3)*(lambda+(2*(v-1))*H(xi)))*T;
||           3                       4|
                  2\   /           a[2]
                       |                  2
                       \       (d + H(xi))
        2 a[4]   \                           \ /
   - ------------| (lambda + 2 (v - 1) H(xi))| \mu + lambda H(xi)
                3|                           |
     (d + H(xi)) /                           /
                  2\
   + (v - 1) H(xi) /
eq := (2*k*k)*w*beta*d[2]-(2*alpha*k*k)*d[1]-2*w*u[0]+k*u[0]*u[0];
   2        //   2 a[2]                  6 a[4]   \ /
2 k  w beta ||------------ + 2 a[3] + ------------| \mu
            ||           3                       4|
                                 2\   /           a[2]
                                      |                  2
                                      \       (d + H(xi))
                             2 a[4]   \
   + 2 a[3] (d + H(xi)) - ------------| (lambda + 2 (v - 1) H(xi)
                                     3|
                          (d + H(xi)) /
   \ /                                 2\            2 /
  )| \mu + lambda H(xi) + (v - 1) H(xi) / - 2 alpha k  |a[1]
         a[2]                               2 a[4]   \ /
                2                                   3|
                                 2\       /
   + lambda H(xi) + (v - 1) H(xi) / - 2 w |a[0]
                          a[2]                      2
                        d + H(xi)
         a[4]    \     /                            a[2]
   + ------------| + k |a[0] + a[1] (d + H(xi)) + ---------
                2|     |                          d + H(xi)
     (d + H(xi)) /     \
                     2       a[4]    \
   + a[3] (d + H(xi))  + ------------|^2
                                    2|
                         (d + H(xi)) /
value(%);
            ||           3                       4|
                                 2\   /           a[2]
                                      |                  2
                                      \       (d + H(xi))
                             2 a[4]   \
                                     3|
                          (d + H(xi)) /
   \ /                                 2\            2 /
         a[2]                               2 a[4]   \ /
                2                                   3|
                                 2\       /
                          a[2]                      2
                        d + H(xi)
         a[4]    \     /                            a[2]
                2|     |                          d + H(xi)
     (d + H(xi)) /     \
                     2       a[4]    \
                                    2|
                         (d + H(xi)) /
expr := simplify(%);
Error, (in simplify) too many levels of recursion
temp := algsubs(d+H(xi) = freeze(d+H(xi)), numer(expr));
                              expr
thaw(collect(temp, freeze(d+H(xi)))/denom(expr));
                              expr
collect(%, H(xi));
Can someone please explain to me why this occurs:
with(StringTools):
Join(["H:\\USB 1 BACKUP\\ESD-USB\\", "Chemical Engineering"])
"H:\USB 1 BACKUP\ESD-USB\ Chemical Engineering"
convert("H:\\USB 1 BACKUP\\ESD-USB\\ Chemical Engineering", 'symbol')
`H:\USB 1 BACKUP\ESD-USB\ Chemical Engineering`
convert('`H:\USB 1 BACKUP\ESD-USB\ Chemical Engineering`', 'string')
"H:USB 1 BACKUPESD-USBChemical Engineering"
Download this_makes_me_grumpy.mw
I'm struggling to solve inequalities with conditions.
I have this inequality with 4 variables, which I have some conditions. However, I can't implement this conditions to the inequality and solve using the 'solve' command.
Can anybody help me?
inequality.mw
I'm surprised by the result of the procedure VectorCalculus:-Curvature which is always a positive scalar quantity:
For instance
c := VectorCalculus:-Curvature(<x, sin(x)>, x):
plot(c, x=0..2*Pi)
# c >=0 for all x in [0, 2*Pi]
In the help pages it's written that the (signed) curvature for a function y(x) is y''/(1+y' 2)(3/2).
y := sin(x):
c := diff(y, x$2) / (1+diff(y,x)^2)^(3/2):
plot(c,  x=0..2*Pi)
# c < 0 if x in (0, Pi)  and  c > 0 if x in (Pi, 2*Pi)
Could you please help me to understand this?
Thank in advance
Some years ago it was promised that expansion of capabilities of Heun functions was imminent, but nothing has appeared.  Other functions long overdue for inclusion as special functions in Maple are the Lame functions, which arise as special cases of Heun's differential equation and therefore of Heun functions.  Lame's differential equation appears in Abramowitz and Stegun, but has long been neglected in Maple.  These spectial functions are much more generally useful to users of Maple than, for instance, esoteric parts of the physics package.
I remember there was a command that used to start an independent java session each time. I thought it's "xmaple -singlemode" but it's not. So could anybody please remind me what was the command. I just killed a second java session after losing kernel connection and java running wild. I'd be very happy to do my calculation in another java session so that if anything goes bad II won't have to open all my 5 tabs again.
I am sorry. There is no 'tag' button on my computer, so I can't ask question here. I don't know the reason.
So I ask here. Now, my real question is:
sum(subs(x = 0, diff(x^2, x $ k)), k = 1 .. 2);
subs(x = 0, diff(x^2, x $ 2));
I think the first result should be 2, but it gives me 0.
Dear Users!
Hope you would be fine with everything. I want to find the solution of linear algebric equations but fsolve command not working please see and fix this problem. I shall be very thankful.
C[0] := 3.19153824321146142351956847947*tau[1]-19.1492294592687685411174108768*tau[2]+111.703838512401149823184896781*tau[3]+3.19153824321146142351956847947*tau[4]-44.6815354049604599292739587124*tau[5]+622.349957426234977586315853494*tau[6];
C[1] := 51.0646118913833827763130956714*tau[2]-612.775342696600593315757148056*tau[3]+51.0646118913833827763130956714*tau[5]-1429.80913295873471773676667880*tau[6];
C[2] := -1.06073680388443795908856507616+3.19153824321146142351956847947*tau[1]+53.1609155734306093706448370717*tau[2]+1672.89412862088744108725223170*tau[3]+3.19153824321146142351956847947*tau[4]+27.6286096277389179824882892361*tau[5]+1026.57792701153122226218722129*tau[6];
C[3] := -1.08847004231036963538035920033+3.19153824321146142351956847947*tau[1]+62.6399144226357196540662623767*tau[2]+2040.52109049201342887896297462*tau[3]+3.19153824321146142351956847947*tau[4]+37.1076084769440282659097145411*tau[5]+1242.54090729537544551915515930*tau[6];
C[4] := -1.05523181556926815105314303389+3.19153824321146142351956847947*tau[1]+72.7671212023804312453829273862*tau[2]+2472.93216226733267613216245895*tau[3]+3.19153824321146142351956847947*tau[4]+47.2348152566887398572263795506*tau[5]+1512.91667059477930731128800348*tau[6];
C[5] := -.922876006485286011069063957991+3.19153824321146142351956847947*tau[1]+82.9822841707707093164204255644*tau[2]+2971.36790137532483139495115633*tau[3]+3.19153824321146142351956847947*tau[4]+57.4499782250790179282638777288*tau[5]+1847.90980220852701343747673000*tau[6];
fsolve({seq(`$`(C[l1], l1 = 0 .. 5))});
Special request to:
@acer @Carl Love @Kitonum @Preben Alsholm
Please help...
answer := 5*exp(7.5*t);
response := subs(a = exp(1), 5*a^(7.5*t));
a := evalf(subs(t = Pi, answer));
b := evalf(subs(t = Pi, response));
evalf(a-b);
Any explanations as to why the last line is not zero?  any workarounds?
lambda := 1;
mu := 1;
v := 2;
r := lambda*(v-1);
g := mu*(v-1);
a[2] := 0;
omega := -(1/2)*alpha*l[1]*l[2]*lambda^2+2*alpha*l[1]*l[2]*mu*v-2*alpha*l[1]*l[2]*mu-alpha*h[1]*h[2];
              - alpha l[1] l[2] - alpha h[1] h[2]
a[0] := -(1/2)*(2*d*v-2*d-lambda)*alpha*l[1]*l[2]/(h[1]*beta*(sqrt(h[1]*beta*alpha*l[1]*l[2])/(h[1]*beta)));
                    (2 d - 1) alpha l[1] l[2]
                                             (1/2)
                2 (h[1] beta alpha l[1] l[2])
a[1] := sqrt(h[1]*beta*alpha*l[1]*l[2])*(v-1)/(beta*h[1]);
                                           (1/2)
                           beta h[1]
Omega := lambda^2-4*mu*v+4*mu;
                               -3
H := (-lambda+sqrt(-Omega)*{tan(sqrt(-Omega)*xi)+sec(sqrt(-Omega)*xi)})/(2*(v-1));
         1   1  (1/2)  /   / (1/2)   \      / (1/2)   \\
       - - + - 3      { tan\3      xi/ + sec\3      xi/ }
         2   2         \                               /
u := a[0]+a[1]*(d+H)+a[2]/(d+H);
            (2 d - 1) alpha l[1] l[2]            1     /
                                     (1/2)   beta h[1] \
                                   (1/2) /    1
        (h[1] beta alpha l[1] l[2])      |d - -
                                         \    2
           1  (1/2)  /   / (1/2)   \      / (1/2)   \\ \\
         + - 3      { tan\3      xi/ + sec\3      xi/ }||
           2         \                               / //
f := diff(u, xi);
        1      |                           (1/2)  (1/2) { |
   ----------- \(h[1] beta alpha l[1] l[2])      3       \\1
   2 beta h[1]
                      2\
           / (1/2)   \ |  (1/2)
      + tan\3      xi/ / 3
           / (1/2)   \    / (1/2)   \  (1/2) }|
      + sec\3      xi/ tan\3      xi/ 3     / /
S := diff(f, xi);
      1      |                           (1/2)  (1/2) {      /
 ----------- \(h[1] beta alpha l[1] l[2])      3       \6 tan\
 2 beta h[1]
              /                  2\
    (1/2)   \ |       / (1/2)   \ |
   3      xi/ \1 + tan\3      xi/ /
           / (1/2)   \    / (1/2)   \
    + 3 sec\3      xi/ tan\3      xi/
                       /                  2\\ \
           / (1/2)   \ |       / (1/2)   \ | }|
    + 3 sec\3      xi/ \1 + tan\3      xi/ // /
eq := -(alpha*h[1]*h[2]+omega)*u-(2*beta*h[1]*u*u)*u+alpha*l[1]*l[2]*S;
  3                 /      (2 d - 1) alpha l[1] l[2]
- - alpha l[1] l[2] |- ---------------------------------- +
  2                 |                               (1/2)
                    \  2 (h[1] beta alpha l[1] l[2])
      1     /                           (1/2) /    1
  --------- |(h[1] beta alpha l[1] l[2])      |d - -
  beta h[1] \                                 \    2
     1  (1/2)  /   / (1/2)   \      / (1/2)   \\ \\\
   + - 3      { tan\3      xi/ + sec\3      xi/ }||| - 2 beta h[1
     2         \                               / //|
    /      (2 d - 1) alpha l[1] l[2]            1     /
    |                               (1/2)   beta h[1] \
                             (1/2) /    1
                                   \    2
   + - 3      { tan\3      xi/ + sec\3      xi/ }|||^3 +
     2         \                               / //|
       1      |                                           (1/2)
  ----------- \alpha l[1] l[2] (h[1] beta alpha l[1] l[2])
  2 beta h[1]
          /                 /                  2\
   (1/2) {      / (1/2)   \ |       / (1/2)   \ |
  3       \6 tan\3      xi/ \1 + tan\3      xi/ /
          / (1/2)   \    / (1/2)   \
                      /                  2\\ \
value(%);
  2                 |                               (1/2)
      1     /                           (1/2) /    1
  beta h[1] \                                 \    2
     2         \                               / //|
    |                               (1/2)   beta h[1] \
                             (1/2) /    1
                                   \    2
     2         \                               / //|
       1      |                                           (1/2)
  2 beta h[1]
          /                 /                  2\
          / (1/2)   \    / (1/2)   \
                      /                  2\\ \
simplify(%);
Error, (in simplify/power) invalid input: ln expects its 1st argument, x, to be of type algebraic, but received {(sin(3^(1/2)*xi)+1)/cos(3^(1/2)*xi)}
First 653 654 655 656 657 658 659 Last Page 655 of 2434
