I've just installed Maple latest + MapleSim with the license provided by my university (I use VPN with a secure key to remotely access server license. Everything works fine, except for the context menu. It seems that the context menu module is missing! I tried uninstalling and reinstalling, but did not help.
I went back to the campus and checked Maple installation on computers there, and this problem is absent (context menu is working fine).
I can only use the context menu toolbar on the right... but this is not very convenient.
What could be the problem? See the attached image.
"for k from 0 to 1 do;    u(t,x):=1+x;  u[k+1](t,x):=1+x-(∫)[0]^(t)(diff(u[k],x) +2+s+x)ⅆs;  U[k+1](t,x)=u[k+1 ](t,x)-(u[k](t,0)-(1+t));  end      "
Error, invalid operator parameter name
> restart;
> with(LinearAlgebra);
> for k from 0 to 1 do;    u(t,x):=1+x;  u[k+1](t,x):=1+x-(∫)[0]^(t)(diff(u[k],x) +2+s+x)ⅆs;  U[k+1](t,x)=u[k+1 ](t,x)-(u[k](t,0)-(1+t));  end      ;
Download ITRATIVE.mw
 PLS
HOW CAN I ITERATE THIS PDE IN THE FORM OF PICARD ITERTION.
ATTACHED IS THE MAPLECODE  STARTED WITH.
How we can integrate this matrix from -1 to 1 w.r.t   't'  ?
I have a PDE system that relates four functions: sht1, svt1, Lt1, Jirt1.
I'm trying to solve this system numerically, but the pdsolve command returns an error (this error does not make sense to me).
Where am I going wrong?
Test.mw
How to calculate  a value in MAPLE:
My code:
evalf(eval(diff(n*Zeta(n, 3), n), n = 3)); give me:
#-0.3740436824 + 3.*eval(diff(Zeta(n, 3), n), {n = 3}) ,it should be only:-0.3740436824
OR:
fdiff(n*Zeta(n, 3), [n], n = 3);
#fdiff(n -> n*Zeta(n, 3), [1], [3]) ???
It's a Bug  or (As Designed / Not a Bug) ?
Mathematica code:
D[n*Derivative[n][Zeta][3], n] /. n -> 3 // N;
(* -0.374044*)
I am very interested in using the "phc.module", which is a module to work with "polynomial homotopy continuation" method. Please, see this paper
I have downloaded the following files: [copied without permission, deleted by moderator]
Then, I open (as an "ordinary" maple worksheet) the file "phc_savelib.maple" and execute it, but it seems that I can not use their functions and procedures because it returns errors.
For instance, follwing the attached PDF,  in the phc_savelib.maple file, define the polynomial system:
T := makeSystem([x, y], [], [x^2+y^2-1, x^3+y^3-1])
and try to solve the above system
sols := solve(T)
but returns the error
Error, (in fopen) file or directory does not exist
Many thanks in advance for your help!
Hi! I have some problems with solving convection-diffusion equation. The liquid phase move up with velocity W. And displace vapor phase. C - molar concentration of gas. z - coordinate. w - velocity. h - height of tank. t - time.
Its not clear to me how to set moving boundary condition on bottom boundary, so C(0,t)=cs must move up with w velocity.
May be maple have some procedures to make moving boundary or adaptive mesh??? thank you!
eq1 := diff(c(z, t), t)+diff(w*c(z, t), z) = d*(diff(c(z, t), z$2));
IBC := { c(z, 0) = 0, c(0, t) = cs, (D[1](c))(h, t) = 0}
T := -S(xi)*S(xi)+mu*R(xi)-lambda;
                  -S(xi)  + mu R(xi) - lambda
Q := -S(xi)*R(xi);
                          -S(xi) R(xi)
u := a[0]+a[1]*S(xi)+b[1]*R(xi);
                 a[0] + a[1] S(xi) + b[1] R(xi)
diff(u, xi);
                  / d        \        / d        \
             a[1] |---- S(xi)| + b[1] |---- R(xi)|
                  \ dxi      /        \ dxi      /
Fr := Q*b[1]+T*a[1];
                         /      2                    \
     -S(xi) R(xi) b[1] + \-S(xi)  + mu R(xi) - lambda/ a[1]
diff(Fr, xi);
       / d        \                    / d        \
      -|---- S(xi)| R(xi) b[1] - S(xi) |---- R(xi)| b[1]
       \ dxi      /                    \ dxi      /
           /         / d        \      / d        \\
         + |-2 S(xi) |---- S(xi)| + mu |---- R(xi)|| a[1]
           \         \ dxi      /      \ dxi      //
d := -T*R(xi)*b[1]-S(xi)*Q*b[1]+(-2*S(xi)*T+mu*Q)*a[1];
 /      2                    \                   2
-\-S(xi)  + mu R(xi) - lambda/ R(xi) b[1] + S(xi)  R(xi) b[1]
     /         /      2                    \                 \
   + \-2 S(xi) \-S(xi)  + mu R(xi) - lambda/ - mu S(xi) R(xi)/ a[
  1]
diff(d, xi);
 /         / d        \      / d        \\
-|-2 S(xi) |---- S(xi)| + mu |---- R(xi)|| R(xi) b[1]
 \         \ dxi      /      \ dxi      //
     /      2                    \ / d        \
   - \-S(xi)  + mu R(xi) - lambda/ |---- R(xi)| b[1]
                                   \ dxi      /
                        / d        \        2 / d        \        /
   + 2 S(xi) R(xi) b[1] |---- S(xi)| + S(xi)  |---- R(xi)| b[1] + |
                        \ dxi      /          \ dxi      /        \
   / d        \ /      2                    \
-2 |---- S(xi)| \-S(xi)  + mu R(xi) - lambda/
   \ dxi      /
             /         / d        \      / d        \\
   - 2 S(xi) |-2 S(xi) |---- S(xi)| + mu |---- R(xi)||
             \         \ dxi      /      \ dxi      //
        / d        \                  / d        \\
   - mu |---- S(xi)| R(xi) - mu S(xi) |---- R(xi)|| a[1]
        \ dxi      /                  \ dxi      //
h := -(-2*S(xi)*T+mu*Q)*R(xi)*b[1]-(-S(xi)^2+mu*R(xi)-lambda)*Q*b[1]+2*S(xi)*R(xi)*b[1]*T+S(xi)^2*Q*b[1]+(-2*T*(-S(xi)^2+mu*R(xi)-lambda)-2*S(xi)*(-2*S(xi)*T+mu*Q)-mu*T*R(xi)-mu*S(xi)*Q)*a[1];
 /         /      2                    \                 \
-\-2 S(xi) \-S(xi)  + mu R(xi) - lambda/ - mu S(xi) R(xi)/ R(xi)
           /      2                    \
  b[1] + 3 \-S(xi)  + mu R(xi) - lambda/ S(xi) R(xi) b[1]
                         /                                2
          3              |   /      2                    \
   - S(xi)  R(xi) b[1] + \-2 \-S(xi)  + mu R(xi) - lambda/  - 2 S(xi
    /         /      2                    \                 \
  ) \-2 S(xi) \-S(xi)  + mu R(xi) - lambda/ - mu S(xi) R(xi)/
        /      2                    \                 2      |
   - mu \-S(xi)  + mu R(xi) - lambda/ R(xi) + mu S(xi)  R(xi)/ a[
  1]
collect(expand(h+3*Fr*Fr+(4*omega+3)*Fr), S(xi), R(xi));
     /      2         \      4
R(xi)\3 a[1]  - 6 a[1]/ S(xi)
                                                  3        /
   + R(xi)(6 R(xi) a[1] b[1] - 6 b[1] R(xi)) S(xi)  + R(xi)\3
       2     2                  2
  R(xi)  b[1]  - 6 R(xi) mu a[1]  + 12 a[1] mu R(xi)
                  2                                        \
   + 6 lambda a[1]  - 8 a[1] lambda - 4 omega a[1] - 3 a[1]/
       2        /        2                       2
  S(xi)  + R(xi)\-6 R(xi)  mu a[1] b[1] + 6 R(xi)  mu b[1]
   + 6 R(xi) lambda a[1] b[1] - 5 R(xi) lambda b[1]
                                      \              /      2   2
   - 4 R(xi) omega b[1] - 3 b[1] R(xi)/ S(xi) + R(xi)\3 a[1]  mu
       2            2      2         2
  R(xi)  - 3 a[1] mu  R(xi)  - 6 a[1]  mu R(xi) lambda
   + 5 a[1] mu R(xi) lambda + 4 omega a[1] mu R(xi)
           2       2                                  2
   + 3 a[1]  lambda  + 3 a[1] mu R(xi) - 2 a[1] lambda
   - 4 omega a[1] lambda - 3 a[1] lambda/
Generally when I respond to questions on this site, I make sure that I tick the checkbox requesting that I get an email when updates are made to the thread.
I've just realised that I have been receiving no such updates for a week or so. Two possibilities
  1. Problem with Mapleprimes website, meaning that email updates aren't being generated/sent
  2. Problem with my ISP
Before I try investigating (2) above, I'd just like to know if anyone else has seen any issue which might be explained by (1) above
For what ever reason I found myself curious to know more about how random number generators work, rand() being one of my favourite tools in the shed to call apon when conducting one of my hobbyist number investigations. So reviewing the output from commands:
with(RandomTools[LinearCongruence]);
showstat(GetState);
Which was:
RandomTools:-LinearCongruence:-GetState := proc($)
        1   return LCState
        end proc
Due to my lack of understanding as to how the maple kernel is designed, I am struggling to understand how the end of parameters marker is able to be accepted alone as the parameter sequence for proc, and was unable to find a help page for "LCState". I'm in such a state of confusion on this matter, it's really difficult to present the forum with a concise question, I really only have a request for a direction to go to understand this package further more.
car_2som_opp := proc (U::list, V::list)  #construction d'un carré connaissant 2 sommets opposés
local dist, eqCerU, eqCerV, r, sol, X, Y;
dist := proc (M, N) sqrt(add((M[i]-N[i])^2, i = 1 .. 2)) end proc;
r := dist(U, V)/sqrt(2);
eqCerU := (x-U[1])^2+(y-U[2])^2 = r^2;
eqCerV := (x-V[1])^2+(y-V[2])^2 = r^2;
sol := solve([eqCerU, eqCerV], [x, y],allsolutions,explicit);
map(allvalues,sol):
X := [subs(op(sol[1]), x), subs(op(sol[1]), y)];
Y := [subs(op(sol[2]), x), subs(op(sol[2]), y)];
display(plot([U, X, V, Y, U],scaling = constrained, axes = none))
car_2som_opp([-5,6],[7,-3]);"error
I have an ODE with 3 parameters
diff(B[1](t), t) = piecewise(t < 1000, kaC*(R-B[1](t))-k[d1]*B[1](t), 1000 < t, -k[d1]*B[1](t))
I'd like to make a graph that shows how its solution vary as Kac and Kd vary. This could have an axis of the form:
            | /k[d]
  B(t)  |/_ __
                t
which could contain a surface composed of the solutions as k[d] varies. Then a series of surfaces could be put together on the same axis to show what happens as kaC varies.
Some typical values are:
kaC = 6*10^(-2),
k[d1] = 7*10^(-3),
R = 1
I'd like to graph everything  in two orders of magnitude of these values for KaC and k[d1].
Currently I think the key obstacle is making a surface of solutions to the ODE; as once I can do that I think making a sequence of them on the same axis should be quite simple with Display
Could you help me make this code work?
Maple Worksheet - Error
Failed to load the worksheet /maplenet/convert/Matrix.mw .
Download Matrix.mw
A := 8; B := 5;
q := .4; p := .2; r := 1-p-q;
dimP := A+B+1;
P := Matrix(dimP, dimP, [0$dimP*dimP]);
P[1, 1] := 1; P[1, 2] := 0;
P[dimP, dimP] := 1; P[dimP, dimP-1] := 0;
for i from 2 to dimP-1 do P[i, i-1] := q; P[i, i] := r; P[i, i+1] := p end do;
p0 := Matrix(dimP, 1, [0$dimP]);
p0[A+1, 1] := 1;
pV[0] := p0;
PT := Transpose(P);
for n to 200 do pV[n] := PT . pV[n-1] end do;
map(proc (x) options operator, arrow; evalf(x, 3) end proc, Transpose(pV[5]));
Could you help me fix this code?
with(Statistics)
Wpath := proc (steps, t) local walk, i, N, ww; N := nops(steps); walk[0] := 0; for i from 0 to N-1 do walk[i+1] := walk[i]+steps[i+1]*sqrt(t/N) end do; ww := seq(plot(walk[i], t*i/N .. t*(i+1)/N), i = 0 .. N-1); plots[display]([ww]) end proc
N := 400
numbers := [random[empirical[.5, .5]](N)]
st1 := map(proc (x) options operator, arrow; 2*x-3 end proc, numbers)
list_of_k := [40, 20, 10, 5, 2, 1]
for j to nops(list_of_k) do k := list_of_k[j]; st[k] := [seq((sum(st1[p], p = i*k-k+1 .. k*i))/sqrt(k), i = 1 .. N/k)] end do
Error, (in limit/mrv/limsimpl) too many levels of recursion
Download Wiener_process.mw
How to calculate potential function of Maxwell equations?
is there calculation examples of strong and weak force examples too?
which library can calculate intersection numbers of familes of potential function of Maxwell equations?
is there any examples?
First 671 672 673 674 675 676 677 Last Page 673 of 2428
