I called an external function for Gauss elimination written in C in Linux. I successfully compiled and used following command in maple worksheet.
mygauss:=define_external('main',LIB="/home/user/Desktop/gauss.so"):
it gave the following output
cannot dynamically load executable
The C code is attached gauss1.txt.
 gauss1.txt
Hello. Found on this forum a program that rolls a cube. Is it possible to supplement the program with notation for vertices (A,B,C,D,A',B',C',D') and so that they move with the cube? Thanks!
cuberoll_(1).mw
i want to draw a truss with graph theory
n__a := Vector[row](10, [-35., -13., -19., 38., -47., -31., 81., 46., -80., -58.]), Vector[row](10, [36., 76., -74., -63., 87., -88., 25., 9., -92., -94.]), Vector[row](10, [71., 5., 83., 1., -99., 64., 65., 50., -29., -7.]), Vector[row](10, [75., -2., 95., -25., 77., -62., 98., -43., 96., 12.]), Vector[row](10, [47., 5., 25., -95., 8., 4., 51., -67., 89., -53.]), Vector[row](10, [-15., 92., -69., -77., -33., 69., 11., 19., -55., 21.]), Vector[row](10, [-48., 74., 27., -49., 49., -63., 51., 29., -67., -25.]), Vector[row](10, [-38., -24., 16., -24., -63., -87., 95., -12., 77., 40.]), Vector[row](10, [-80., -28., 83., -66., -25., -34., -11., 96., -70., 97.]), Vector[row](10, [48., -63., 81., -28., -1., 64., 34., 93., 13., 43.])
im trying to convert each vector in this list into a set making a list of sets. Also if you know a way to make a list of lists that might be useful
When i run seq(x__i, i = 1 .. 4) i get xi,xi,xi,xi instead of x1,x2,x3,x4.
please help i have no idea why its doing that.
How I can convert attached maple code into series form to the latex format.
I want to convert to this format series form) not for certain M and N.
Hi, all i am unable to plot the graphs ,can any one help me to overcome the error in plotting the graphs.I am using the maple 13. I am attaching the codes
with(IntegrationTools):
d1:=0.2:L1:=0.2:L2:=0.2:B1:=0.7:B:=1:beta:=0.01:
d2:=0.6:m:=0.1:k:=0.1:
h:=z->piecewise( z<=d1,    1,
                z<=d1+L1,   1-(gamma1/(2))*(1 + cos(2*(Pi/L1)*(z-d1-L1/2))),
                z<=B1-L2/2,  1 ,
                z<=B1,  1-(gamma2/(2))*(1 + cos(2*(Pi/L2)*(z - B1))),
                z<=B1+L2/2,  1-(gamma2/(2))*(1 + cos(2*(Pi/L2)*(z - B1))),
                 z<=B,    1):
A:=(-m^2/4)-(1/(4*k)):
S1:=(h(z)^2)/(4*A)-ln(A*h(z)^2+1)*(1+h(z)^2)/(4*A):
b1:=evalf((1/S1)):
c1:=evalf(Int(b1,z=0..1)):
plot([seq(eval(c1,gamma2=j),j in[0,0.02,0.06])],gamma1=0.02..0.1,legend = [gamma2 = 0.0, gamma2 = 0.02,gamma2 =0.04],linestyle = [solid,dash,dot],color = [black, black,black],axes=boxed);
Hi. what is reason maple unable to integral in answer of dsolve? when I try to use dsolve for solve my equation in answer of maple there are expressions of integral that isnot calculated
&int;(-625 R^2 ro (-2 cp3 x1 lambdaopt+sin((pi t)/10) cp2+(16 cp2)/5) (-cos((pi t)/10)+cos(2 pi)+((-t/5+4) x1+(8 t)/25-32/5) pi) lambdaopt pi b11 (e)^(-((16+5 sin((pi t)/10)) cp1)/(10 lambdaopt x1))+625 (-R^2 k11 (cos((pi t)/10))^3+k11 R^2 (cos(2 pi)-((t-20) (x1-8/5) pi)/5) (cos((pi t)/10))^2+((32 sin((pi t)/10) R^2 k11)/5+(281 R^2 k11)/25+4 lambdaopt^2 (a11 x1+a13 x3)) cos((pi t)/10)-(32 k11 R^2 (cos(2 pi)-((t-20) (x1-8/5) pi)/5) sin((pi t)/10))/5+(281 (x1-8/5) (R^2 k11+(100 lambdaopt^2 (a11 x1+a13 x3))/281) pi t)/125) x1^2)&DifferentialD;t
I'm trying to solve an expression with only one unknown variable, but for some reason solve and fsolve are unable to return a solution.
The expression I'm trying to solve is:
p := k*T*m__hhw*(ln(1+exp(E__fv-E__hh0)/(k*T))+ln(1+exp(E__fv-E__hh1)/(k*T)))/(Pi*h__bar^2*L__z) = 0.3e25
where all variables are predefined and am trying to solve for E__fv. However, when I use solve, I get the error: "Warning, solutions may have been lost", and when I try to use fsolve, it simply returns the expression as an answer and I am unable to find the numerical value for E__fv. Any helps or tips are appreciated.
If it helps, the defined variable values are:
k = 1.3806E-23;
T = 300;
h__bar = 1.05456E-34
L__z = 6E-9
m__hhw = 3.862216E-31;
E__hh0 = 3.012136E-21
E__hh1 = 1.185628E-20
A similar expression in the previous line was able to solve correctly and return a numerical value, so I'm not sure why solve/fsolve can't solve this one.
Similar solved expression:
solve(0.3e25 = m__cw*k*T*ln(1+exp(E__fc-E__c0)/(k*T))/(Pi*h__bar^2*L__z), E__fc);
                          -42.88488490
Hai, any one can help me to rectify my error
 I have evaluate the codes in maple and got different answer.
epsilon:=0.2:z:=0.9:m:=10:k:=0.8:
h(z):=1+epsilon*sin(2*Pi*z):
g1:=evalf((1/S1));
g1 := 8.821345336-11.12386331*I
but in mathematica i am getting  answer as (27.8647 + 35.2042 I)
ClearAll;
\[Epsilon] = 0.2;
h[z_] = 1 + \[Epsilon]*Sin[2*Pi*z];
m = 10;
k = 0.8;
A = -(m^2/4) - (1/4 k);
S1[z_] = (h[z]^2/4*A) - ((1 + h[z]^2)/4*A)*
    Log[(A*h[z]^2) + 1] /. {z -> 0.9}
Hi all, I want to evaluate the integral G2. I am using the evalf command, but maple is unable to evaluate it. What am I missing here?
G2 := -.5*(int(Re(-(0.8823529412e-2*(-16.19435640-30.82287308*exp(-.2960360476-(1.*I)*theta)))*exp(.1480180238-(1.*I)*(.5*theta-0.6282080040e-1*ln(-1.*sin(-.3926990818+.5*theta)/sin(.3926990818+.5*theta))))*(-.5*cos(.3926990818+.5*theta)*sin(-.3926990818+.5*theta)+.5*sin(.3926990818+.5*theta)*cos(-.3926990818+.5*theta))/sqrt(-1.*sin(.3926990818+.5*theta)*sin(-.3926990818+.5*theta))-0.1764705882e-1*sqrt(-1.*sin(.3926990818+.5*theta)*sin(-.3926990818+.5*theta))*(1.017602550-3.872635115*exp(-.2960360476-(1.*I)*theta))*exp(.1480180238-(1.*I)*(.5*theta-0.6282080040e-1*ln(-1.*sin(-.3926990818+.5*theta)/sin(.3926990818+.5*theta))))-0.1764705882e-1*sqrt(-1.*sin(.3926990818+.5*theta)*sin(-.3926990818+.5*theta))*(-16.19435640-30.82287308*exp(-.2960360476-(1.*I)*theta))*(-0.6282080040e-1-(0.6282080040e-1*I)*(.5*cos(-.3926990818+.5*theta)/sin(.3926990818+.5*theta)+.5*sin(-.3926990818+.5*theta)*cos(.3926990818+.5*theta)/sin(.3926990818+.5*theta)^2)*sin(.3926990818+.5*theta)/sin(-.3926990818+.5*theta))*exp(.1480180238-(1.*I)*(.5*theta-0.6282080040e-1*ln(-1.*sin(-.3926990818+.5*theta)/sin(.3926990818+.5*theta)))))*(-.5-.5*cos(2.*theta))+.5*Im(-(0.8823529412e-2*(-16.19435640-30.82287308*exp(-.2960360476-(1.*I)*theta)))*exp(.1480180238-(1.*I)*(.5*theta-0.6282080040e-1*ln(-1.*sin(-.3926990818+.5*theta)/sin(.3926990818+.5*theta))))*(-.5*cos(.3926990818+.5*theta)*sin(-.3926990818+.5*theta)+.5*sin(.3926990818+.5*theta)*cos(-.3926990818+.5*theta))/sqrt(-1.*sin(.3926990818+.5*theta)*sin(-.3926990818+.5*theta))-0.1764705882e-1*sqrt(-1.*sin(.3926990818+.5*theta)*sin(-.3926990818+.5*theta))*(1.017602550-3.872635115*exp(-.2960360476-(1.*I)*theta))*exp(.1480180238-(1.*I)*(.5*theta-0.6282080040e-1*ln(-1.*sin(-.3926990818+.5*theta)/sin(.3926990818+.5*theta))))-0.1764705882e-1*sqrt(-1.*sin(.3926990818+.5*theta)*sin(-.3926990818+.5*theta))*(-16.19435640-30.82287308*exp(-.2960360476-(1.*I)*theta))*(-0.6282080040e-1-(0.6282080040e-1*I)*(.5*cos(-.3926990818+.5*theta)/sin(.3926990818+.5*theta)+.5*sin(-.3926990818+.5*theta)*cos(.3926990818+.5*theta)/sin(.3926990818+.5*theta)^2)*sin(.3926990818+.5*theta)/sin(-.3926990818+.5*theta))*exp(.1480180238-(1.*I)*(.5*theta-0.6282080040e-1*ln(-1.*sin(-.3926990818+.5*theta)/sin(.3926990818+.5*theta)))))*sin(2.*theta), theta = 0. .. .7853981635))
Hello, and thank you for your time!
I can´t seem to find the way to simplify the result of this vector´s norm. I need to find the final value of it.
Any idea to do it simpler?
I use indices of Table
6,6,3,3,3
but it return 3,6
how to keep [3,3,3,6,6]?
any other method for indices?
any non hash table which map value to value?
Why doesn't
f:=ln(s + 2)^2 + 2*polylog(2, -1 - s) + 2*polylog(2, (1 + s)/(s + 2))
simplify to zero assuming s>0?
I have this polynomial equation: (x-2)^2*(x-3)+epsilon =0, I want to draw a bifurcation diagram in the (epsilon , x) plane.
How to implement this in maple 2018?
First 673 674 675 676 677 678 679 Last Page 675 of 2428
