I am trying to derive solutions for cubic equation using Maple.
Problem I encountered is it automatically cancles and simplifies, I cannot reach to the final form using Maple commands except modifying the equation by myself.
like,
(-108*q - 12*sqrt(12*p^3 + 81*q^2))^(1/3)/6 into (-q/2 + sqrt(p^3/27 + q^2/4))^(1/3)
Another one, even though I want this fractional form, it becomes other form automatically
(-q/2 + sqrt(p^3/27 + q^2/4))^(1/3) into (-q/2 + sqrt(12*p^3 + 81*q^2)/18)^(1/3)
how can i find the answer if this integral analytically
int(exp(-b*x)/(exp(-2*b*x)*a+exp(-4*x)),x);
Hi! my name is Euge, i live in Argentina!
I´m solving a problem that ask me to find an ODE from a family of curves,
I know this is pretty simple, I have to derive the equation two times, but i can´t find a comand in maple that helps me do that. Is there any?
Hey there.
I've been using the threads package to parallelize some code. It's going well for the most part - my code runs way faster and I can observe with my System Monitor (ubuntu) that multiple cores are indeed being used. However, ~ 4 of every 5 times I try to run the exact same code, Maple will get stuck on a threaded calculation. If I follow the CPU usage in these instances, I see that one of the CPUs is maxed out at 100%. I am forced to quit Maple and kill the kernel process. Has anyone seen something like this before?
how can i solve this
dx+4*x*dy/y = dy*a*y^(-6*b-1)
to find x in terms of y
Hey everone, im trying to get 2 legends to apear on my plot im animateing. The problem here is that it just wont. Could you guys help me ?
Heres the code
c := x -> piecewise(0 <= x and x <= 450000, 0.37*x, 450000 < x, 0.37*x + 0.06*(x - 450000));
g := x -> piecewise(0 <= x and x <= 558000, 0.37*x, 558000 < x, 0.37*x + 0.12*(x - 558000));
A1 := plots:-animate(plot, [g(x), x = 0 .. skat, color = blue], frames = 20, skat = 0 .. 1000000);
A2 := plots:-animate(plot, [c(x), x = 0 .. skat, color = red], frames = 20, skat = 0 .. 1000000);
Do(%Plot2 = plots:-display([A1, A2], size = [1000, 700], gridlines = true, legend=["Line 1","Line 2"],legendstyle=[font=[Lucida, roman, 14], location=bottom]));
SetProperty("Plot2", ':-play', true, ':-refresh' = true);
Hi everybody,
Im trying to solve the following trivial pde using Maple 2018
pdsolve([diff(Y(x, t), t, t) = 0, Y(x, 0) = 0, (D[2](Y))(x, 1) = 0]);
Obviuosly the solution is Y(x, t) = 0, but Mapple 2018 is not giving any answer.
This works in Maple 2015.
Why is not working in Maple 2018?
Javier
I have the equation y^2=𝑎𝑥^3+𝑏𝑥^2+𝑐𝑥+𝑑.
How do I plot y against x as the coefficients a, b, c and d vary?
Thank you for your help.
hi
how can i write a number or word on the column or right the row of matrix as this pic
hi, I am trying to evaluate the following integrations (Note that; the values of alpha, lambda_1 and lambda_2) are random and they change with every iteration
`&lambda;1_B`[so] := 10.94:
W[1] := evalf[4](int(`&alpha;_B`[so]^2/((z-1+`&alpha;_B`[so])^2*(z^(`&lambda;2_B`[so]/`&lambda;1_B`[so])-1+`&alpha;_B`[so])), z = 1 .. infinity)); W[2] := evalf[4](int(z^(`&lambda;2_B`[so]/`&lambda;1_B`[so])*ln(z)/((z-1+`&alpha;_B`[so])^2*(z^(`&lambda;2_B`[so]/`&lambda;1_B`[so])-1+`&alpha;_B`[so])^2), z = 1 .. infinity)); W[3] := evalf[4](int(1/((z-1+`&alpha;_B`[so])^2*(z^(`&lambda;2_B`[so]/`&lambda;1_B`[so])-1+`&alpha;_B`[so])^2), z = 1 .. infinity)); W[4] := evalf[4](int(z^(`&lambda;2_B`[so]/`&lambda;1_B`[so])*ln(z)^2/((z-1+`&alpha;_B`[so])^2*(z^(`&lambda;2_B`[so]/`&lambda;1_B`[so])-1+`&alpha;_B`[so])^2), z = 1 .. infinity)); W[5] := evalf[4](int(1/((z-1+`&alpha;_B`[so])^3*(z^(`&lambda;2_B`[so]/`&lambda;1_B`[so])-1+`&alpha;_B`[so])), z = 1 .. infinity)); W[6] := evalf[4](int((z^(`&lambda;2_B`[so]/`&lambda;1_B`[so]))^2*ln(z)^2/((z-1+`&alpha;_B`[so])^2*(z^(`&lambda;2_B`[so]/`&lambda;1_B`[so])-1+`&alpha;_B`[so])^3), z = 1 .. infinity)); W[7] := evalf[4](int(z^(`&lambda;2_B`[so]/`&lambda;1_B`[so])*ln(z)/((z-1+`&alpha;_B`[so])^2*(z^(`&lambda;2_B`[so]/`&lambda;1_B`[so])-1+`&alpha;_B`[so])^3), z = 1 .. infinity)); W[8] := evalf[4](int(1/((z-1+`&alpha;_B`[so])^2*(z^(`&lambda;2_B`[so]/`&lambda;1_B`[so])-1+`&alpha;_B`[so])^3), z = 1 .. infinity)); W[9] := evalf[4](int(z^(`&lambda;2_B`[so]/`&lambda;1_B`[so])*ln(z)/((z-1+`&alpha;_B`[so])^3*(z^(`&lambda;2_B`[so]/`&lambda;1_B`[so])-1+`&alpha;_B`[so])^2), z = 1 .. infinity)); W[10] := evalf[4](int(1/((z-1+`&alpha;_B`[so])^4*(z^(`&lambda;2_B`[so]/`&lambda;1_B`[so])-1+`&alpha;_B`[so])), z = 1 .. infinity)); W[11] := evalf[4](int(1/((z-1+`&alpha;_B`[so])^3*(z^(`&lambda;2_B`[so]/`&lambda;1_B`[so])-1+`&alpha;_B`[so])^2), z = 1 .. infinity))
int(79.977249/((z+7.943)^2*(z^.1408592322+7.943)), z = 1 .. infinity)
0.1744e-1
0.3348e-2
Download ask_maple.mw
What means, please, this error
Error, (in RootFinding:-Analytic) Maple was unable to allocate enough memory to complete this computation.  Please see ?alloc
What should I to do to overcome this error?
Hi guys,
I'm fairly new to programming as a whole, but I've currently set up a script which creates a matrix and then fills it in given a  condition. i.e if the x and y indices of the matrix are the same it has been told to add m^2F. If the y and x index differs by 3 is has been asked to fill in V3/4 and if they differ by 6 it has been asked to fill in V6/4. After the matrix is created it will then calculate the eigenvalues.
My question is as follows:
m^F is a constant and V3 and V6 are variables. I currently, manually, set a value of V3 and V6 at the top of the script and then calculate the eigenvalues. How would one go about reversing this process - i.e provide a set of eigenvalues and then perform a fit to find the best values of V3 and V6. Is this 'doable' in Maple or would it be best to use something else.
I have attached a copy of the script for viewing purposes in case what I have written is not very clear - Hindered_rotor.mw
Thanks for your time,
David
How 2 solve summation when M,  Z,  X are given with mixed conditions?
Hello everyone, I'm trying to run a simple calculation (Water flowing out of a pressurised container) using a combination of conservation of energy and conservation of mass. I have working models of the same system without pressurisation (purely gravity working) which work fine in Maple, but when re-writing the pressure as a function of the height of the water I receive the error:
"Error, (in DEtools/convertsys) unable to convert to an explicit first-order system".
The formula used is:
"Eq1:= -Rho_Water * A_Barrell * v_Barrel = Rho_Water * A_Nozzle * v_Nozzle"
Which returns:
"Eq1:= -25.23733555 * d/dt h_Water(t) = 0.5982 * (-190.1309944 - 13.64385474 * h_Water(t) + (d/dt h_Water(t))2)1/2"
With initial condition:
"ics1:= h_Water(0) = 0.2"
After giving the command:
"Sol1:= dsolve({Eq1, ics1}, numeric)"
Maple returns the aforementioned error. When trying to solve non-numerically the output is a list filled with "RootOf" and "_Z". Instinctively I would say the square root in the second part of the equation is the problem here, but I would not know how to fix this. Does anybody have a quick fix for this problem? Or is there a fundamental issue with the equation? Thank you in advance!
I have matrix:
m1 := Matrix([[x[0,0]=1,x[0,1]=1,x[0,2]=0,x[0,3]=0,x[0,4]=0,x[0,5]=0],[x[1,0]=0,x[1,1]=0,x[1,2]=1,x[1,3]=1,x[1,4]=0,x[1,5]=0],[x[2,0]=0,x[2,1]=0,x[2,2]=0,x[2,3]=0,x[2,4]=1,x[2,5]=1]]);
How to get values on the rhs of x without using for loops and create a matrix using these values?.
Results should be:
m2 := Matrix([[1,1,0,0,0],[0,0,1,1,0,0],[0,0,0,0,1,1]]);
First 677 678 679 680 681 682 683 Last Page 679 of 2428
