What is the default subinterval set in approximate int in Student[MultivariateCalculus] package? How can I change the subinterval number. Thank you.
How to draw graph when the matrix and the position is given in cartesius coordinate?
For example, I have this matrix and the following coordinate
Matrix(9, 9, [[0, 0, 1, 0, 1, 1, 1, 0, 0], [1, 0, 0, 0, 0, 0, 0, 0, 0], [0, 1, 0, 0, 0, 0, 0, 0, 0], [1, 0, 0, 0, 0, 0, 0, 0, 0], [1, 0, 0, 0, 0, 0, 0, 0, 0], [1, 0, 0, 0, 0, 0, 0, 0, 0], [0, 0, 0, 0, 0, 0, 0, 0, 1], [0, 0, 0, 1, 0, 0, 0, 0, 0], [0, 0, 0, 0, 0, 0, 0, 1, 0]])
#Coordinate
[40, 40], [22, 22], [36, 26], [21, 45], [45, 35], [55, 20], [55, 45], [26, 59], [55, 65]
For sure, we can use Graph package
GT := GraphTheory;
G := GT:-Graph(X);
GT:-DrawGraph(G):
How to assign the coordinate such that I get the result of drawing in cartesius ?
Thank you anyway
which Maple command gives the exact value of factorial (1/2)?   ``(1/2)!``
This is a minor issue, but I noticed using Maple 2019, with Physics cloud version 331 that it prints on the screen some results from internal computation on some calls to pdsolve
I have a ":" at the end of each command, so no output should go to the screen. In Maple 2018 this does not happen.
pde := a*diff(w(x,y),x) +  b*arctan(lambda*y)*diff(w(x,y),y) =  a*arctan(mu*x)^m+arctan(beta*y)^k:
sol := pdsolve(pde,w(x,y)):
#another example
pde := a*diff(w(x,y),x) +  b*arccot(lambda*y)*diff(w(x,y),y) =  a*arccot(mu*x)^m+arccot(beta*y)^k:
sol:=pdsolve(pde,w(x,y)):
Running the above on Maple 2019 and Maple 2018, here is screen shot. Notice the output in Maple 2019
In Maple 2019
Hello everyone!
I have the following Maple code:
with(CurveFitting); with(plottools); with(Statistics); A := [[1.364, 0.64765768e-1], [2.05, -.182176113], [2.664, -0.13914542e-1], [2.728, 0.2193938e-1], [4.092, -0.18349139e-1], [4.1, -.312968801], [5.328, -0.1819837e-2], [5.456, -.28840961], [6.15, -.57076866], [7.992, .175022254]];
F := LeastSquares(A, x);
plot([F, A], x = 0 .. 8, legend = ["Метод наименьших квадратов", "Экспериментальные данные"], legendstyle = [font = ["Roman", 15]], labels = ["d, ìì", "ln(I/I_0)"], labelfont = ["Roman", 15], labeldirections = ["horizontal", "vertical"], axesfont = ["ROMAN", "ROMAN", 15], color = [red, blue], style = [line, point], linestyle = [solid], symbolsize = 20, title = "Определение линейного коэффициента поглощения", titlefont = [Roman, bold, 20]);
This produces a plot:
How can I add error bars to the points that are colored in blue?
Thank you in advance for any help!
Having problems with solving PDE with symbolic BCs.
u(x,y,t,M,A);
 M,A,x are constants for this problem.
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>Code Starts
pde := diff(u(x, y, t), t)-.5*(diff(u(x, y, t), y, y))-A*sin(M*x-t) = 0
bc[1] := u(x, 0, t) = 0
bc[2] := u(x, 10, t) = A*sin(M*x-t)
sys := [pde, bc[1], bc[2]]
pdsolve(sys)
>>>>>>>>>>>>>>>>Code ends
I don't get any solution after this.
Moreover, in the second BC, I would like to change 10 to inifnity.
-(-u*(diff(v, x))+int((diff(v, x))*(diff(u, x)), x)+int((diff(v, x, x))*u, x))  how to simplify this expression to zero by any commands?
Error, module member referencing is not supported in evalhf
What is the solution for this error.
Also when I run job in command prompt I also getting following errors
Warning, the restart command only works at the top level. It cannot be executed within a procedure, or from a file being read by the read statement.
But the same code runs fine in GUI.
Hello everybody and thankyou in advance to answer my question.
I am trying to answer this question:
“Find the solutions for x so that the sine of x degrees be equal to the sine of x radians in the interval [0, Pi].” I wrote this formula to solve it but without success:
solve(sin(x*degree)=sin(x),x) assuming 0<=x<=Pi
I expected a solution like:
{x=0, x=(180*Pi)/(180+Pi)} but not,
I somehow get a numeric solution for the first positive real number within the referred interval with this:
fsolve(sin(x*Pi/180) = sin(x), x, 0 .. Pi);
But if I change the interval for example [0, 3*Pi] I still only get one answer, not the four I spect.
I am struggling with statistical analysis of a dataset. I would appreciate help from the community. Let me describe what I am looking for.
1. The linear regression model that I am trying to use is Y=b1X1 + b2x2 + e. I am interested in estimating b1 and b2 so that the estimated error is the least.
2. I am trying to randomly select 25 percent of observations from the dataset and estimate b1 and b2.
3. The estimated coefficients are used to predict the Y values for the remainder of the 75 percent of the data and calculate the error. The idea is to use a subset to estimate coefficients, and check for the robustness of the estimates.
4. The process is iterated for say 100 times.
5. Each time, I would like to store the statistical results and export them to an excel file.
For some reason, each time I struggle with one or two steps mentioned above. Could anyone help me with the approach?
Thank you,
Omkar
I have a circle equation: F: = x^2+y^2 = 1.
I need to check: x^2+y^2 <= 1.
I tried to get this expression from F like this: lhs(F) <= rhs (F).
The content matches what I need but get: Error, cannot determine if this expression is true or false: x^2+y^2 <= 1.
When I specify just the if x^2+y^2 <= 1 then everything works fine. What am I doing wrong?
New to maple here. Having this problem for evaluating my function. If its relevant it is to solve the Ising model analytically. Whats the problem and how do I fix it? Thanks.
Hi all
We denote the collecction of sets determined by the first k coin tosses $F_k$
Suppose the imitial stock price is $S_0$ ,with up and down facter being $u$ and $d$.
Up : S1(H)=u S0 and S1(T)=d S0
S_{N+1}= alpha S_N
where alpha =u or d
Let the probability of each $H$ and $T$ be $p$ and $q=1-p$ and   $F_t$ the sigma-lgebra generated by the coin tosses up to (and inchudling) time t:
After three coin tosses.
Can we propose a code computing the element of the filtration F1 and F3 and sigma(S3) (the sigma algebra generated by S3).
For example by hand we have F1={ emptyset, Omega, AH, AT}
Where AH={ w: w1=H}
AT={w: w1=T}
Can we compute
$E[ S_2|F_3] \text { and } E[ S_2|\sigma(S_3) ] $
$$E[ \frac{S_2}{S_1} | F_1] \text { and } E[ \frac{S_2}{S_1} | \sigma(S_1) ] $$
with(Finance);
S := [7.9, 7.5, 7.1, 6.5, 5., 3.7, 3.3, 2.95, 2.8];
T := BinomialTree(3, S, .3);
TreePlot(T, thickness = 2, axes = BOXED, gridlines = true);
many thanks
Hi! For a process control exercise I'm trying to obtain the coefficients of different powers of the variable to design a PID controller. I have obtained the following equation :
Gc := (s^2*t^2+2*s*t*x+1)*(-b*s+1)/(k(-b*s+1)*s(tc+b))
I want to simplify it into an equation of the following form :
Gc = a( 1 + 1/(b*s) + c*s )
where a, b and c would be determined by Maple from the previous equation. I've tried using simplify() expand(simplify()) in different ways from the documentation and other threads, but to no avail. Any help would be greatly appreciated!
Thanks a lot!
Antoine.
Hello all,
I'm trying to do kinetic modeling of sequential dissociations with DE. I'm hitting a snag when modeling the third dissociation. The population should start at zero at t=0, but some of my model functions are non-zero at t=0. Is there anyway to fix this to force the funtions to go through zero?
Scheme:
PPPP -> intermediates -> PPP -> intermediates -> PP -> intermediates -> P
(where P is a subunit and intermediates are confirmational changes before dissociation of a subunit)
a'..d' is the first dissociation
e' is the second dissociation
f'..l' is the third dissociation
Fits are evaluated by the residual sum of squares.
sol := dsolve([a' = -k1*a(x), b' = k1*a(x)-k1*b(x), c' = k1*b(x)-k1*c(x), d' = k1*c(x)-k1*d(x),
e' = k1*d(x)-k2*e(x),
f' = k2*e(x)-k3*f(x), g' = k3*f(x)-k3*g(x), h' = k3*g(x)-k3*h(x), i' = k3*h(x)-k3*i(x), j' = k3*i(x)-k3*j(x), k' = k3*j(x)-k3*k(x), l' = k3*k(x)-k3*l(x),
a(0) = 1, b(0) = 0, c(0) = 0, d(0) = 0, e(0) = 0, f(0) = 0, g(0) = 0, h(0) = 0, i(0) = 0, j(0) = 0, k(0) = 0, l(0) = 0],
{a(x), b(x), c(x), d(x), e(x), f(x), g(x), h(x), i(x), j(x), k(x), l(x)}, method = laplace);
f1 := sol[6];
f1 := rhs(f1);
g1 := sol[7];
g1 := rhs(g1);
h1 := sol[8];
h1 := rhs(h1);
i1 := sol[9];
i1 := rhs(i1);
j1 := sol[10];
j1 := rhs(j1);
kk := sol[11];
kk := rhs(kk);
l1 := sol[12];
l1 := rhs(l1);
xdata := Vector([0,10,20,30,40,50,60,70,80,90,100,110,120,130,140,150,160,170,180,200,210,220,230,240,250,260,270,280,290,300,310,320,330,340,350,360,370,380,390,400], datatype = float);
ydata := Vector([0.0034,0.00392,0.00184,0.00782,0.01873,0.03683,0.11016,0.09838,0.18402,0.24727,0.20901,0.2972,0.37635,0.49235,0.57845,0.4457,0.50285,0.5672,0.62783,0.57264,0.54918,0.44792,0.49795,0.55218,0.47512,0.46473,0.37989,0.32236,0.3323,0.20894,0.28473,0.21273,0.19855,0.13548,0.12725,0.13277,0.0784,0.07969,0.06162,0.03855], datatype = float);
k1 := 0.391491454107626e-1;
k2 := 0.222503562261129e-1;
z1:=f1;
z2:=f1+g1;
z3:=f1+g1+h1;
z4:=f1+g1+h1+i1;
z5:=f1+g1+h1+i1+j1;
z6:=f1+g1+h1+i1+j1+kk;
z7:=f1+g1+h1+i1+j1+kk+l1;
Statistics[NonlinearFit](z1,xdata, ydata, x, initialvalues = [k3=0.1], output = [parametervalues, residualsumofsquares]);
A:=plot(xdata, ydata, style=point, symbol=solidcircle, color=blue, symbolsize=12,labels = ["time (minutes)", "Relative Abundance"], labeldirections = [horizontal, vertical]):
F:=Statistics[NonlinearFit](z1,xdata, ydata, x,initialvalues = [k3=0.1]):
B:=plot(F, x=xdata[1]..xdata[-1], color=red):
plots[display](A, B);
Statistics[NonlinearFit](z2,xdata, ydata, x, initialvalues = [k3=0.1], output = [parametervalues, residualsumofsquares]);
F:=Statistics[NonlinearFit](z2,xdata, ydata, x,initialvalues = [k3=0.1]):
Statistics[NonlinearFit](z3,xdata, ydata, x, initialvalues = [k3=0.1], output = [parametervalues, residualsumofsquares]);
F:=Statistics[NonlinearFit](z3,xdata, ydata, x,initialvalues = [k3=0.1]):
Statistics[NonlinearFit](z4,xdata, ydata, x, initialvalues = [k3=0.1], output = [parametervalues, residualsumofsquares]);
F:=Statistics[NonlinearFit](z4,xdata, ydata, x,initialvalues = [k3=0.1]):
Statistics[NonlinearFit](z5,xdata, ydata, x, initialvalues = [k3=0.1], output = [parametervalues, residualsumofsquares]);
F:=Statistics[NonlinearFit](z5,xdata, ydata, x,initialvalues = [k3=0.1]):
Statistics[NonlinearFit](z6,xdata, ydata, x, initialvalues = [k3=0.1], output = [parametervalues, residualsumofsquares]);
F:=Statistics[NonlinearFit](z6,xdata, ydata, x,initialvalues = [k3=0.1]):
Statistics[NonlinearFit](z7,xdata, ydata, x, initialvalues = [k3=0.1], output = [parametervalues, residualsumofsquares]);
F:=Statistics[NonlinearFit](z7,xdata, ydata, x,initialvalues = [k3=0.1]):
3rd_diss.mw
First 711 712 713 714 715 716 717 Last Page 713 of 2428
