In the worksheet below I produce a sequence of frames for an animation by distributing the task into several threads.  The result has strange artifacts as we see in the sample.  The artifacts vary randomly from run to run.  Am I doing something wrong?
kernelopts(version);
`Maple 2018.2, X86 64 LINUX, Oct 23 2018, Build ID 1356656`
kernelopts(numcpus);
4
Draw a simple picture:
frame := proc(t)
  plot(x^2 + t, x=-1..1, title=typeset("t = %1", t));
Generate a sequence of pictures:
frames := Threads:-Seq(frame(t), t=0..1, 0.05):
Animate the sequence:
plots:-display([frames], insequence);
Download theads.mw
I have a data set (see .txt file attached) to be fit to the model function A*sin(B*x+C)+D. Calculating the parameters A, B, C, and D is easy enough, but is there a way to have Maple return their standard errors?
Data.txt
I can’t perform the last command (GridPlot) on my worksheet
IRISdata.mw
I am new to Maple and have some problems with fonts in Maple's forms. How can I increase the size of the monospaced font? (see the screenshot).
How would I go about getting true or false returned on these propositions?
I have tried just about every eval and various syntax methods, but nothing has worked so far.
I know most can easilly be done by hand/thinking, but I'm sure Maple should have a way to do this as well.
∀n∈Z:2n>n+2   ,   ∃n∈Z:2|(3n+1)    ,   ∃k∈Z:∀n∈Z:n=kn   ,   ∃k∈Z:∀n∈Z:2|(n+k)   ,   ∀n∈Z:∀k∈Z:(n>k∨k≥n)
How to view all  statistical bank of data in Maple ? ( for example , Iris data)
I am trying to find coodinates projection H(x,y, z)  of the point P :=<x3, y3, z3> on the line AB, where A:= <x1,y1,z1>, B:= <x2,y2,z2>. I tried
with(LinearAlgebra);
A:= <x1,y1,z1>:
B:= <x2,y2,z2>:
P :=<x3, y3, z3>:
H:=<x,y,z>;
solve([DotProduct(B-A, H-P, conjugate = false) = 0, B-A = k*(H-A)], [x, y, z, k]);
I can not get the result. How can I get the coordinates of the point H?
I have a hard to understand quotient of multivariate polynomials- my intuition is that the denominator nearly divides the numerator - and it could be rewritten as:
remainder+(much simpler numerator)/denominator
as far as I can see the functions quo and rem aren't designed for this - but I'm certain that people in the maple community must have overcome this kind of problem before
MVP_quotient.mw
I am trying to run maple program in a workstation using 20-40 processor for a job. I have no idea how to do this. Thank you.
how i can solve the eqution by ritz methode codes?
For example...
Using a $2 calculator I get that rad(2470) it is approximately 49.699094.
I haven't used Maple in several months and was surprised to see that I couldn't easily search the answer to this question. Something like eval() does not work on this.
There is a time difference variation between two clocks (0.124, 0.120) and between the same clocks for the same calculations at different times(0.07, 0.124 and 0.120, 68. What is the reason?
Thanks for answering.
Ramakrishnan V
restart; t1 := time[real]()
2344.956
t1PC := Now(ProcessClock)
_m1718422690432
"for i = 1 to 1000  i:=i+1  end;"
t2 := time[real]()
2345.080
t2PC := Now(ProcessClock)
_m1718421822656
tdiff := t2-t1
.124
tdiffPC := t2PC-t1PC
120*Units:-Unit(ns)
I redo the same programm again to see the time of performance
t1 := time[real]()
2345.253
_m1718419758016
t2 := time[real]()
2345.323
_m1718418631616
tdiff := t2-t1
0.70e-1
68*Units:-Unit(ns)
Now I again recall the stored time values. (unit: milliseconds). t1 and t2 are retained for ever until unassigned.
t1
2345.253
t2
2345.323
(14)
t2-t1
0.70e-1
(15)
t2PC-t1PC
68*Units:-Unit(ns)
(16)
Download timeToRunDifference.mw
There  are commands tic and toc in matlab program.
tic
toc
toc - tic
This gives the run time for the program.
Even in excel, we can find the difference between clock times at the start and end using NOW commands.
Is there a similar way to use maple commands to find the running time of a program.
 I want to find the time taken by the student to solve the quiz questions in the enclosed doc.
Could anyone help please?
Chapter 1 -  SubChapter 1 - Precalculus - Quiz 1 (15 questions - Duration - 1 hour)
                Factor 3*x^2-10*x-8
(3x + 2)(x - 4)
Press your option above for Answer
              Solve "x^(2) - 4 x - 5 = 0 by factoring"
-1, 5
                Roots of the equation x^2-8*x-20 = 0*are
- 2, 10
Correct Answer
Correct Answer
Correct Answer
Correct Answer
Correct Answer
Correct Answer
Correct Answer
Correct Answer
Correct Answer
Correct Answer
Correct Answer
Correct Answer
QuizNULL
Go to Chapter1 - SubChapter 2
Home
Download Commands_for_Time_Taken_to_Answer_Please.mw
So I'm running into the problem that when I use an assumption, to say automate dsolving, the solution functions I end up defining, has the 'tilde' variable in it. which doesn't seem to be redefinable. How do I get rid of the assumption, in a defined function, or alternatively, how to do I redefine the variable so the function will use it?
Dear friends, I have made a doc using embedded components to plot a curve. What commands should I do to animate (and pause and play using a custom play/pause button inserted in the table) the plot. Normally I have to use explore animate command, but it requires the user to use animation tools. There must be a way to do the same using play = true; loop = true commands. I donot know its use. Can any one help. Thanks.
use DocumentTools in
Do(q = %MathContainer0);
Do(p = eval(q));
# Do(%Plot0 = plot(p, x = 0..2*Pi));
Do(%Plot0 = plot(p, x = 0..10));
end use;
 Write the expression in textarea and click the button to see the plot in plot area and expression in math container
Thanks for helping out. Ramakrishnan V
Download animation_CommandPlease.mw
First 730 731 732 733 734 735 736 Last Page 732 of 2428
