I am looking to develop a histogram from a random data set that contains integers that are approximately normally distributed.  The intent is to develop a histogram from the dataset that looks like a fairly decent-approximation of a normalized curve (but not necessarily perfect)....  the next stage to this is a second histogram that shows a bimodal distribution (but not necessarily perfect)
To this point I have...
with(Statistics);
randomize();
N := RandomVariable(Normal(300, 10));
A := [seq(MapleTA:-Builtin:-decimal(0, Sample(N, 500)[i]), i = 1 .. 500)];
Histogram(A, frequencyscale = absolute, bincount = 25, binwidth = 1, tickmarks = [default, default]);
I am certain you will find what I have thus far is far from ideal, as such any help is appreciated.
Mark
To restrict the domain of a vector field, I have multiplied a coordinate with a non-real complex number (namely a sqrt(of negative expression)). This does work, as shown in this Maple 2017 worksheet program (below). My question is whether this is the best technique of accomplishing this result, or else how to do it better? Would be interested in suggestions for improvements. Here is my program so far:
print(` ------- ------- ------- ------- ------- ------- -------`);
print(` Vector Field inside Torus`);
print(` Assignment:  `);
print(` In a circular pipe of radius (my2r), water is flowing in the direction `);
print(` of the pipe, with speed (my2r)^2-(mya)^2, where (mya) is the distance  `);
print(` to the axis of the pipe.  `);
print(` Depict the vector field describing the flow if the pipe goes around in `);
print(` the shape of a torus with major radius (my1r).  `);
print(`   `);
print(`   `);
print(`   `);
print(`\n(Section 1) major radius of torus:`);
my1r  := 5;
print(`\n(Section 2) minor radius of torus (pipe radius):`);
my2r := 4;
print(`\n(Section 3) definition of torus (polar coordinates):`);
c00 := [(my1r+my2r*cos(s))*cos(t),(my1r+my2r*cos(s))*sin(t),my2r*sin(s)];
print(`\n(Section 4) 3D plot of solid torus (polar coordinates):`);
plot3d({c00},scaling=constrained,color=red);
print(`\n(Section 5) 3D plot of wireframe torus (polar coordinates):`);
P1 := plot3d({c00},scaling=constrained,style=wireframe);
print(`\n(Section 6) implicit definition of torus (cartesian coordinates):`);
c01 := (sqrt(x^2+y^2)-my1r)^2+z^2-my2r^2;
print(`\n(Section 7) implicit 3D plot of solid torus (cartesian coordinates):`);
gx := my1r+my2r; # min and max of each coordinate
implicitplot3d(c01,x=-gx..gx,y=-gx..gx,z=-gx..gx,numpoints=9000);
print(`\n(Section 8) vector field definition (cartesian coordinates):`);
my1vfx := -y;
my1vfy := x;
my1vfz := 0;
my1fld := [my1vfx,my1vfy,my1vfz];
print(`\n(Section 9) 3D plot of vector field (cartesian coordinates):`);
fieldplot3d(my1fld,x=-gx..gx,y=-gx..gx,z=-gx..gx);
print(`\n(Section 10) definition of vector field with unit length vectors (cartesian coordinates):`);
my1vl := sqrt(my1vfx^2+my1vfy^2+my1vfz^2); # vector length
my2fld := [my1vfx/my1vl,my1vfy/my1vl,my1vfz/my1vl];
print(`\n(Section 11) 3D plot of vector field with unit length vectors (cartesian coordinates):`);
fieldplot3d(my2fld,x=-gx..gx,y=-gx..gx,z=-gx..gx);
print(`\n(Section 12) definition of vector field with asked for length vectors (cartesian coordinates):`);
mya := sqrt((sqrt(x^2+y^2)-my1r)^2+z^2);
c01r := sqrt(my2r^2-mya^2); # also used for domain restricting vector field below
my1tsz := solve([c01],[z]);
assign(my1tsz[1][1]);
my1tz := z;
unassign('z');
assign(my1tsz[2][1]);
my2tz := z;
unassign('z');
my1vp := c01r/my2r; # vector length (maximum one unit)
my3fld := [my1vp*my1vfx/my1vl,my1vp*my1vfy/my1vl,my1vp*my1vfz/my1vl];
print(`\n(Section 13) 3D plot of vector field with asked for length vectors (cartesian coordinates):`);
fieldplot3d(my3fld,x=-gx..gx,y=-gx..gx,z=-gx..gx);
print(`\n(Section 14) same asked for vector field with 3-D arrow vectors:`);
print(`   `);
print(` (to get this to display properly it was necessary to do:  `);
print(` -> Maple 2017 -> Preferences... -> Precision ->   `);
print(`   [unselect] Limit expression length to   `);
print(`   Apply to Session`);
print(`   `);
gr := 15;
P3 := fieldplot3d(my3fld,x=-gx..gx,y=-gx..gx,z=-gx..gx,arrows=`3-D`,grid=[gr,gr,gr]);
print(`\n display asked for vector field within wireframe torus:`);
display([P1,P3]);
However I run similar codes in Maple and Matlab, but the different results are observed.
By increasing number of basis (i.e. m) The convergence is observed, but results are different from each other.
The convergence for Maple: (m,P) =(10,10.8154),(20,10.8081),(30,10.8067),(50,10.8061)
The convergence for Matlab: (m,P) =(10,10.0474),(20,10.0194),(30,10.0143),(40,10.0125)
I have two questions:
1-which answer is correct?
2-why the different results for the same  number of basis  are obtained?
Maple code (Maple 2016)
tm := time():
Digits := 500:
beta := 1:
nu := 0.3:
lambda := 2:
G := 5:
ko := .5*0.1e7:
Ec := 0.380e12:
Em := 0.70e11:
ri := 0:
ro := 0.5:
ti := 0.1e-1:
K := 0.4e-1*0.1e10:
n := 1:
m := 20:
alpha := 0.1:
t := ti*(1+alpha*r/ro)^beta:
Er := (Ec-Em)*(r/ro)^n+Em:
W := simplify(add(a[n]*ChebyshevT(n, r), n = 0 .. m)):
sys := {eval(W, r = ro), eval(diff(W, r), r = ri)}:
W := subs(solve(sys, {a[0], a[1]}), W):
d1 := diff(W, r):
d2 := diff(d1, r):
W := subs(solve({eval(ko*d1-Ec*ti^3*(1+alpha)^(3*beta)*(d1*nu+d2*r)/(12*r*(-nu^2+1)), r = ro) = 0}, {a[2]}), W):
d1 := diff(W, r):
d2 := diff(d1, r):
Uf := int(K*(1+lambda*r/ro+G*(r/ro)^2)*W^2*r, r = ri .. ro):
NUM := int(((d2+d1/r)^2-(2*(1-nu))*d2*d1/r)*Er*t^3*r/(12*(-nu^2+1)), r = ri .. ro)+ko*ro*(eval(d1, r = ro))^2+Uf:
DEN := int(d1^2*r, r = ri .. ro):
PT := NUM-Em*ti^3*P*DEN/ro^2:
for c from 3 to m do
eq[c] := diff(PT, a[c]) end do:
MT := GenerateMatrix([seq(eq[j], j = 3 .. m)], [a[j]$j = 3 .. m])[1]:
solve(Determinant(MT)):
evalf[10](%[1]);
____________________________________________________________________________
Matlab Code (R2014a)
clear all;
digits(10);
tic
m = 20;
n = 1;
alpha = 0.1;
beta = 1;
nu = 0.3;
lambda = 2;
G = 5;
ko = 0.5*1e6;
Ec = 0.380e12;
Em = 0.70e11;
ro = 0.5;
ti = 0.1e-1;
K = 0.04*0.1e10;
ri=0;
syms r P;
c=sym('c%d',[1,m+1]);
c(1)=1;
c(2)=r;
for j=3:m+1
    c(j)=simplify(2*r*c(j-1)-c(j-2));
end
Er = (Ec-Em)*(r/ro)^n+Em;
a=sym('a%d',[1,m+1]);
t = ti*(1+alpha*r/ro)^beta;
W = simplify(a*transpose(c));
[a(1),a(2)] = solve(subs(W,r,ro)==0,subs(diff(W,r),r,ri)==0,a(1),a(2));
d1 = diff(W, r);
d2 = diff(d1, r);
a(3)=solve(subs(ko*d1-Ec*ti^3*(1+alpha)^(3*beta)*(d1*nu+d2*r)/(12*r*(-nu^2+1)),r,ro)==0,a(3));
d1 = diff(W, r);
d2 = diff(d1, r);
Uf = int(K*(1+lambda*r/ro+G*(r/ro)^2)*W^2*r,r,ri,ro);
NUM = int(((d2+d1/r)^2-(2*(1-nu))*d2*d1/r)*Er*t^3*r/(12*(-nu^2+1)),r,ri,ro)+ko*ro*(subs(d1,r,ro))^2+Uf;
DEN = int(d1^2*r, r , ri , ro);
PT = NUM-Em*ti^3*P*DEN/ro^2;
for q=1:m-2
    eq(q)= diff(PT, a(q+3));
end;
for q = 1:m-2
    for u = 1:m-2
        T = coeffs(eq(q),a(u+3));
        tt(q,u) = T(2);
    end;
end;
F=sort(vpa(solve(det(tt))));
F(1)
toc
how to find infinity norm for function of fraction exponenctial
I am wanting to plot a phase portrait of du/dt against u.
I have attempted to draw this on maple however am having great difficulty. Can anyone recommend what I may be doing wrong or how I should go about doing this?
Load the Tetrads package, and choose Schwarzshild spacetime:
with(Physics):
with(Tetrads):
Setup(metric = schwarzschild,quiet):
Consider then the following code/output:
expr := D_[~mu](e_[mu,a]);
seq(simplify(SumOverRepeatedIndices(expr             )),a = 1..4);
seq(simplify(SumOverRepeatedIndices(D_[~mu](e_[mu,a]))),a = 1..4);
In my mind, the last two code lines are entirely identical, but their corresponding outputs are certainly not. I don't get it. The above can be compared with the following code/output in which the vierbein indices mu and a have been interchanged:
expr := D_[~mu](e_[a,mu]);
seq(simplify(SumOverRepeatedIndices(D_[~mu](e_[a,mu]))),a = 1..4);
Here, the outputs are identical. The mystery becomes total when realizing that according to Maple, e_[a,mu] and e_[mu,a] are considered completely identical [a notational choice I do not find reassuring].
I've been doing some soul searching and started to think that the maple interface and i are kindred spirts, conjoined spirit twins if you will, and i can confirm this if this is the manner in which the totient function is calculated:
For example how to input the mixed fraction 3 1/7? What are keys for super- and subscript?
I've keep checking in every 18 months or so for the last 10 years... since Maple got a sort-of-notebook interface. I keep hopeing for a MathCad-like true notebook, where I can organize my document the way I want, instead of the clunky console I/O based interface. But every time I check, its not quite there.
Are we there yet?
I got decimal places problem,
not known correct or not
the value are different but difference is constant
i do not know how many places needed to get exact result
i do not believe the difference is constant
because the matrix are different
but even if using 36 decimal places still constant,
i notice increasing decimal places , the constant difference is changed
is it possible  to output fraction when calculate eigenvector?
Partial_for_R0.mw
Anybody knows what happen to this coding?
unprotect(Pi)
k := .5;
.5
.95
0.1e-1
116.1
0.8e-2
0.25e-2
0.2e-2
0.5e-1
0.115e-1
0.598e-2
.5
.2
.1
0.57e-1
.2
1.2
R := k*tau*(rho*(Upsilon*(mu+alpha+eta)+chi)+(1-rho)*(Upsilon*(1-q)*eta+mu+beta+chi))*(Pi*(-mu*p+mu+phi)/(mu*(vartheta+mu+phi))+epsilon*Pi*(mu*p+vartheta)/(mu*(vartheta+mu+phi)))/((mu+beta+chi)*(mu+alpha+eta)-chi*eta*(1-q))
65688.31239
diff(k*tau*(rho*(Upsilon*(mu+alpha+eta)+chi)+(1-rho)*(Upsilon*(1-q)*eta+mu+beta+chi))*(Pi*(-mu*p+mu+phi)/(mu*(`ϑ`+mu+phi))+`ε`*Pi*(mu*p+`ϑ`)/(mu*(`ϑ`+mu+phi)))/((mu+beta+chi)*(mu+alpha+eta)-chi*eta*(1-q)), k)
Error, invalid input: diff received .5, which is not valid for its 2nd argument
diff(k*tau*(rho*(Upsilon*(mu+alpha+eta)+chi)+(1-rho)*(Upsilon*(1-q)*eta+mu+beta+chi))*(Pi*(-mu*p+mu+phi)/(mu*(`ϑ`+mu+phi))+`ε`*Pi*(mu*p+`ϑ`)/(mu*(`ϑ`+mu+phi)))/((mu+beta+chi)*(mu+alpha+eta)-chi*eta*(1-q)), `ε`)
Error, invalid input: diff received 0.2e-2, which is not valid for its 2nd argument
diff(k*tau*(rho*(Upsilon*(mu+alpha+eta)+chi)+(1-rho)*(Upsilon*(1-q)*eta+mu+beta+chi))*(Pi*(-mu*p+mu+phi)/(mu*(`ϑ`+mu+phi))+`ε`*Pi*(mu*p+`ϑ`)/(mu*(`ϑ`+mu+phi)))/((mu+beta+chi)*(mu+alpha+eta)-chi*eta*(1-q)), tau)
Error, invalid input: diff received .95, which is not valid for its 2nd argument
diff(k*tau*(rho*(Upsilon*(mu+alpha+eta)+chi)+(1-rho)*(Upsilon*(1-q)*eta+mu+beta+chi))*(Pi*(-mu*p+mu+phi)/(mu*(`ϑ`+mu+phi))+`ε`*Pi*(mu*p+`ϑ`)/(mu*(`ϑ`+mu+phi)))/((mu+beta+chi)*(mu+alpha+eta)-chi*eta*(1-q)), phi)
Error, invalid input: diff received 0.25e-2, which is not valid for its 2nd argument
diff(k*tau*(rho*(Upsilon*(mu+alpha+eta)+chi)+(1-rho)*(Upsilon*(1-q)*eta+mu+beta+chi))*(Pi*(-mu*p+mu+phi)/(mu*(`ϑ`+mu+phi))+`ε`*Pi*(mu*p+`ϑ`)/(mu*(`ϑ`+mu+phi)))/((mu+beta+chi)*(mu+alpha+eta)-chi*eta*(1-q)), chi)
Error, invalid input: diff received 0.598e-2, which is not valid for its 2nd argument
diff(k*tau*(rho*(Upsilon*(mu+alpha+eta)+chi)+(1-rho)*(Upsilon*(1-q)*eta+mu+beta+chi))*(Pi*(-mu*p+mu+phi)/(mu*(`ϑ`+mu+phi))+`ε`*Pi*(mu*p+`ϑ`)/(mu*(`ϑ`+mu+phi)))/((mu+beta+chi)*(mu+alpha+eta)-chi*eta*(1-q)), p)
Error, invalid input: diff received .2, which is not valid for its 2nd argument
diff(k*tau*(rho*(Upsilon*(mu+alpha+eta)+chi)+(1-rho)*(Upsilon*(1-q)*eta+mu+beta+chi))*(Pi*(-mu*p+mu+phi)/(mu*(`ϑ`+mu+phi))+`ε`*Pi*(mu*p+`ϑ`)/(mu*(`ϑ`+mu+phi)))/((mu+beta+chi)*(mu+alpha+eta)-chi*eta*(1-q)), `ϑ`)
Error, invalid input: diff received 0.8e-2, which is not valid for its 2nd argument
diff(k*tau*(rho*(Upsilon*(mu+alpha+eta)+chi)+(1-rho)*(Upsilon*(1-q)*eta+mu+beta+chi))*(Pi*(-mu*p+mu+phi)/(mu*(`ϑ`+mu+phi))+`ε`*Pi*(mu*p+`ϑ`)/(mu*(`ϑ`+mu+phi)))/((mu+beta+chi)*(mu+alpha+eta)-chi*eta*(1-q)), mu)
Error, invalid input: diff received 0.1e-1, which is not valid for its 2nd argument
diff(k*tau*(rho*(Upsilon*(mu+alpha+eta)+chi)+(1-rho)*(Upsilon*(1-q)*eta+mu+beta+chi))*(Pi*(-mu*p+mu+phi)/(mu*(`ϑ`+mu+phi))+`ε`*Pi*(mu*p+`ϑ`)/(mu*(`ϑ`+mu+phi)))/((mu+beta+chi)*(mu+alpha+eta)-chi*eta*(1-q)), alpha)
Error, invalid input: diff received 0.57e-2, which is not valid for its 2nd argument
diff(k*tau*(rho*(Upsilon*(mu+alpha+eta)+chi)+(1-rho)*(Upsilon*(1-q)*eta+mu+beta+chi))*(Pi*(-mu*p+mu+phi)/(mu*(`ϑ`+mu+phi))+`ε`*Pi*(mu*p+`ϑ`)/(mu*(`ϑ`+mu+phi)))/((mu+beta+chi)*(mu+alpha+eta)-chi*eta*(1-q)), rho)
Error, invalid input: diff received 0.5e-1, which is not valid for its 2nd argument
diff(k*tau*(rho*(Upsilon*(mu+alpha+eta)+chi)+(1-rho)*(Upsilon*(1-q)*eta+mu+beta+chi))*(Pi*(-mu*p+mu+phi)/(mu*(`ϑ`+mu+phi))+`ε`*Pi*(mu*p+`ϑ`)/(mu*(`ϑ`+mu+phi)))/((mu+beta+chi)*(mu+alpha+eta)-chi*eta*(1-q)), beta)
Error, invalid input: diff received 0.115e-1, which is not valid for its 2nd argument
diff(k*tau*(rho*(Upsilon*(mu+alpha+eta)+chi)+(1-rho)*(Upsilon*(1-q)*eta+mu+beta+chi))*(Pi*(-mu*p+mu+phi)/(mu*(`ϑ`+mu+phi))+`ε`*Pi*(mu*p+`ϑ`)/(mu*(`ϑ`+mu+phi)))/((mu+beta+chi)*(mu+alpha+eta)-chi*eta*(1-q)), eta)
diff(k*tau*(rho*(Upsilon*(mu+alpha+eta)+chi)+(1-rho)*(Upsilon*(1-q)*eta+mu+beta+chi))*(Pi*(-mu*p+mu+phi)/(mu*(`ϑ`+mu+phi))+`ε`*Pi*(mu*p+`ϑ`)/(mu*(`ϑ`+mu+phi)))/((mu+beta+chi)*(mu+alpha+eta)-chi*eta*(1-q)), q)
Download Partial_for_R0.mw
unprotect(Pi)
k := .5;
.5
.95
0.1e-1
116.1
0.8e-2
0.25e-2
0.2e-2
0.5e-1
0.115e-1
0.598e-2
.5
.2
.1
0.57e-1
.2
1.2
65688.31239
Basic_Reproduction_Number.mw
Hello, anybody knows how to compute sensitivity analysis for basic reproduction number using Maple coding? By taking the partial derivatives of all the parameters involved in the basic reproduction number using normalised forward sensitivity index formula. Thanks.
unprotect(Pi)
R[0] := k*tau*[(rho*(Upsilon*(mu+alpha+eta)+chi)+(1-rho)*(Upsilon*(1-q)*eta+mu+beta+chi))/((mu+beta+chi)*(mu+alpha+eta)-chi*eta*(1-q))]*(Pi*(-mu*p+mu+phi)/(mu*(vartheta+mu+phi))+epsilon*Pi*(mu*p+vartheta)/(mu*(vartheta+mu+phi)))
Download Basic_Reproduction_Number.mw
I am having difficulties with a recursive function call with named parameters.
The proc is defind as follows:
Subs:=proc(eqn::seq(equation),elemt::Element,{num::boolean:=false},$) option remember;
qs[i]=Subs(eqn,elemt[qs[i]]); # This is where I need to add something like 'num'=num
My difficulty is with the "num" flag. In the code this flag governs whether to try to evalf() certain results or not. That and the recursion per se all works. What does not work is when I add the num option to the internal call. I have been trying 'num'=num, ''num''=num, "num"=num and `num`=num.  I either get an error that something like true=true is not a valid argument here, or that "num" is not valid.
Any hint?
Mac Dude
Let G be a permutation group like S3. I have a loop in which x runs over the elements of this group.
When I ask the cycle type of x or the number of orbits of x, Maple gives an incorrect result in some cases. This is because when x=(12), for example, Maple considers x to be an element of the permutation group S2 instead of S3, i.e. it fails to understand that (12) should really be (12)(3) in this case.
Is there a way I can instruct Maple to consider the permutation (12) as a member of S3 instead of S2?
I am posting the code as requested. Something like this:
with(GroupTheory);
for x in Elements(S3) do print(x, numelems(Orbits(PermutationGroup(x)))) end do;
(I don't know how to format this, sorry)
This code is simply asking how many orbits exist in the action of each element of S3. The result will be 1 for x=(12), however, because Maple will assume that (12) is acting on the set {1,2}, even though I am considering (12) as an element of S3. I want it to consider (12)=(12)(3) and let it act on the set {1,2,3}, thereby producing 2 orbits, not 1.
First 890 891 892 893 894 895 896 Last Page 892 of 2459
