Ok embarassing I posted this one and now it outputs this java error file log and yep i dont know that much about java at all.
Sometimes it works, sometimes it closes maple automatically and spits out the .txt error log i have attached if thats any help... MAPLE_EXAMPLE_16.mw  i honestly have never ever seen maple behave this way in more than a decade of playing around in it with stuff like this.
EDIT: Here is a version with smaller plot components that seems to be working.... MAPLE_EXAMPLE_17.mw
It says i am not allowed to upload a log file but this is what it looks like:
# A fatal error has been detected by the Java Runtime Environment:
# java.lang.OutOfMemoryError: requested 1024000 bytes for GrET in C:\BUILD_AREA\jdk6_18\hotspot\src\share\vm\utilities\growableArray.cpp. Out of swap space?
V  [jvm.dll+0x15df8a]
V  [jvm.dll+0x1e1e14]
V  [jvm.dll+0x1a1aad]
V  [jvm.dll+0xc834f]
V  [jvm.dll+0xca01c]
V  [jvm.dll+0xca370]
V  [jvm.dll+0xce42a]
V  [jvm.dll+0x1d8592]
V  [jvm.dll+0xc9398]
V  [jvm.dll
Java Threads: ( => current thread )
  0x522e7c00 JavaThread "Timer-28" [_thread_blocked, id=23236, stack(0x5f2f0000,0x5f6f0000)]
  0x522e7400 JavaThread "Timer-22" [_thread_blocked, id=24248, stack(0x6b440000,0x6b840000)]
  0x522e2c00 JavaThread "WMI:MapleClientSocket:Kernel Connection " daemon [_thread_blocked, id=11140, stack(0x6a2d0000,0x6a6d0000)]
  0x522e7000 JavaThread "WMI:MapleClientSocket:Kernel Connection " daemon [_thread_blocked, id=6792, stack(0x64d30000,0x65130000)]
  0x522e6400 JavaThread "WMI:MapleClientSocket:Kernel Connection " daemon [_thread_blocked, id=20280, stack(0x6a6d0000,0x6aad0000)]
  0x522e4400 JavaThread "Timer-18" daemon [_thread_blocked, id=23888, stack(0x63f20000,0x64320000)]
  0x522e6800 JavaThread "Timer-17" [_thread_blocked, id=17320, stack(0x69ed0000,0x6a2d0000)]
  0x522e5000 JavaThread "WMI:MapleClientSocket:Kernel Connection " daemon [_thread_blocked, id=13480, stack(0x69ad0000,0x69ed0000)]
  0x522e4800 JavaThread "Timer-16" daemon [_thread_blocked, id=18184, stack(0x68ed0000,0x692d0000)]
  0x522e3000 JavaThread "Timer-15" [_thread_blocked, id=23296, stack(0x692d0000,0x696d0000)]
  0x522e3800 JavaThread "WMI:MapleClientSocket:Kernel Connection " daemon [_thread_blocked, id=16388, stack(0x66820000,0x66c20000)]
  0x522e1400 JavaThread "Timer-14" daemon [_thread_blocked, id=24500, stack(0x61c50000,0x62050000)]
  0x522e0c00 JavaThread "Timer-13" [_thread_blocked, id=15848, stack(0x659b0000,0x65db0000)]
  0x522e0000 JavaThread "WMI:MapleClientSocket:Kernel Connection " daemon [_thread_blocked, id=7260, stack(0x655b0000,0x659b0000)]
  0x466cb000 JavaThread "Timer-12" daemon [_thread_blocked, id=1112, stack(0x64320000,0x64720000)]
  0x4699b800 JavaThread "Timer-11" [_thread_blocked, id=24540, stack(0x64930000,0x64d30000)]
  0x4699b400 JavaThread "Timer-10" daemon [_thread_blocked, id=21144, stack(0x60bf0000,0x60ff0000)]
  0x4699d400 JavaTh
Hi. I have an excel data file.
IDEALLY, I want to import the results of the formula in cells C3:C7.
But it doesn't like it. Reports 0's
When I convert the range to result to values in cells D3:D7 it imports no problem. But I don't want to do this step.
any ideas?
Book1.xls
import.mw
Lett_L_rot_AL_MapleQuestion.mws
If the attached program is run, at the end are two animation outputs.  One is of two letters A; the other of the single second A being animated.   The second letter A animation works fine, but in the former it "blips" on Continuous animation, and on 'single cycle' the A totally disappears.  I'm using the same number of frames, 48, for each.
   Prior to that is the letter L which is meant to give the illusion of it rotating, and the letters A getting out of the way.
   Any help on ridding the "blip" most appreciated.
I have this code to solve partial equation, and I need to writdata in file .dat or.txt using table and loops or if there is another way
Any help please,
eq := diff(Tf(x, y), x) = diff(Tf(x, y), y, y):
Cl := {1 = Tf(0, y), (D[2](Tf))(x, 0) = 1, (D[2](Tf))(x, 1) = 1};
pds := pdsolve(eq, Cl, numeric);
_m221385792
Download mapleprime.mw
is there a command line method for exporting plots as jpg files and gif files?
How do I create a wave in Maple such that the end which the wave hits of (fixed boundary condition) is formed of triangles rather than just a straight line. I have,
animate(plot3d,[sin(Pi*(t-x))sin(Piy)Heaviside(t-x)-sin(Pi(t+x))sin(Piy)*Heaviside(t+x),x=0..4,y=0..1],t=-2*Pi..2*Pi);
Would I have to create a whole new formula or can I just add something to the code to give this different boundary? Or maybe I can use a different software other than maple, I just want to know which directions the waves will travel when they hit a ridged surface.
Say I wanted to create a five sides polygon, so the wave hits these two boundary conditions so i can see what happens next. (I added the two black lines in paint so it was easier to visualise)
How to translate the elliptic curve from the 4th to the 3rd curve with maple?
thanks.
Hi, I am using fsolve to find the roots x of a nonpolynomial expression f(x,a) = 0, using a loop for do to vary the values of the parameter a in small identical steps. At some stage, fsolve cannot find a solution. According to the Maple help, in this case fsolve returns a NULL sequence. I would like to know how to use the fact that fsolve cannot find a solution to break the loop with an if-then statement.
How can plot  f := proc (x, y) options operator, arrow; sin(x)*cos(y) end proc
as surface and contour (contour is project on xy plan)
HOW I can find the function that satisfies these boundary conditions?
please help me.
FUNCTION.mw
Download FUNCTION.mw
I am trying to find a minimizer for the functional E (see Maple code), where u is in L2([0,rmax]) (Constraint) and u is approximated by a finite set of fourier coefficients in the basis {n*exp(ikx)}.
I don't have much expirience with maple so I could use some help solving this.
The codes I tried either show an erroer( unexpected parameters) or run a very long time until I interupt.
Do I have something wrong or can I reformulate the problem?
Kainmuth
Minimizetest2.mw
with(Optimization);
[ImportMPS, Interactive, LPSolve, LSSolve, Maximize, Minimize, NLPSolve, QPSolve]
rmax := 20;
20
n := 1/sqrt(rmax);
(1/10)*5^(1/2)
const := abs(c1)^2+abs(c2)^2+abs(c3)^2 = 1;
f := proc (x) options operator, arrow; n*c1+n*c2*exp(I*x)+n*c3*exp((2*I)*x) end proc;
E := proc (c1, c2, c3) options operator, arrow; int(abs(diff(f(x), x))^2, x = 0 .. rmax)+.5*(int(abs(f(x))^2*w(x-y)*abs(f(y))^2, x = 0 .. rmax)) end proc;
Optimization:-Minimize(E(f(x)), const);
Download Minimizetest2.mw
Is there any way to get random numbers in Maple with the Sobol method?
How to make Maple determine whether the following is a sequence with a rule behind it or just random fractions:
3^893/2^1415, 3^1040/2^1648, 3^2192/2^3474, 3^3776/2^5984, 3^3910/2^6197, 3^5514/2^8739
equation of ellipse
eqn := (1/32)*(x-16)^2+(1/2025)*(y+0)^2 = 1
only interested in the positive section
plots[implicitplot]([(1/32)*(x-16)^2+(1/2025)*(y+0)^2 = 1], x = 0 .. 18, y = 0 .. 60, scaling = constrained)
equation for arch length of function
int(sqrt(1+(diff(eqn, x))^2), x = 0 .. 16)
Doesn't seem like the best way to solve this.
Wanting to generate a general fomula I can then use in excel to calculate the arch length of the positive only section of the ellipse
any ideas of what the assumptions could be to have maple solve this?
eqn2 := (x-h)^2/a^2+(y-k)^2/b^2 = 1;
                               2          2
                        (x - h)    (y - k)
                eqn2 := -------- + -------- = 1
                            2          2
                           a          b
     [[                                            (1/2)]
     [[          / 2  2    2  2      2        2  2\     ]
     [[    a k + \a  b  - b  h  + 2 b  h x - b  x /     ]
     [[y = ---------------------------------------------],
     [[                          a                      ]
       [                                            (1/2)]]
       [          / 2  2    2  2      2        2  2\     ]]
       [    a k - \a  b  - b  h  + 2 b  h x - b  x /     ]]
       [y = ---------------------------------------------]]
       [                          a                      ]]
eqn3 := (a*k+sqrt(a^2*b^2-b^2*h^2+2*b^2*h*x-b^2*x^2))/a;
                                                     (1/2)
                   / 2  2    2  2      2        2  2\
     eqn3 := ---------------------------------------------
                                   a
diff(eqn3, x);
                           2        2
                        2 b  h - 2 b  x
                                              (1/2)
            / 2  2    2  2      2        2  2\
          2 \a  b  - b  h  + 2 b  h x - b  x /      a
`assuming`([int(sqrt(1+(diff(eqn3, x))^2), x = c .. d)], [a > 0, b > 0, c >= 0, d > c]);
Hi, I would like to plot multiple curves with arrows pointed at each curve. I don't know how to plot the arrows with values. A similar figure is attached. Thanks for helping . . .
First 891 892 893 894 895 896 897 Last Page 893 of 2459
