is it possible to change ODE to PDE?
the ODE has diff(a(t),t) and diff(b(t),t)
how to convert to diff(t, a), diff(t, b) ?
Is there a built-in function in Maple 2015 that identifies and prints prime numbers in a specified integer range?
How can I write and solve a dirac_delta function in maple, for example in below equations:
F[0]:=0;
F[1]:=a;
F[2]:=b;
eq1:=sum((k-m+2)*(k-m+1)*F[k-m+2]*Dirac[m-1], m = 0 .. k);
eq2:=(k+1)*F[k+1]-Dirac[k];
for k from 0 to 10 do
F[k+3]:=solve(F[k+3]=(eq1+eq2)/((k+3)*(k+2)*(k+1)),F[k+3]);
Hi everybody,
I'm kind of new to Maple and i'm trying to solve a system of trigonometric equations inequality as follow:
f:= {((2*a*sin(S)*cos(S)^(2)))/(1-sin(S)^(3))<1,90> S>-90,a>1};
solve(f,{a,S});
Error, (in PiecewiseTools:-Convert) unable to convert
How can I solve the system?
Thanks a lot.
Since I am a very recent Maple user, I do not know why I obtained a wrong answer with the following two comands:
Exp:= Psi(rho(x,t),theta(x,t));
                  Psi(rho(x, t), theta(x, t))
Exp1:= diff(Exp,t);
     / d           \
     |--- rho(x, t)| D[1](Psi)(rho(x, t), theta(x, t))
     \ dt          /
          / d             \
    + |--- theta(x, t)| Psi(rho(x, t) + 1, theta(x, t))
          \ dt            /
Can someone, please, help me?
I am using Maple to model Gaussian Wave Packets and the do loop creates an array of plots. I want to animate these plots to show the movement of the wave packet and was wondering if there is a way to animate the array or perhaps another way to produce the animation.
I have a function "L" which is mentioned in the worksheet. I want to obtain equation of motion by solving Euler-Lagrange equation. How I can do this by maple? Have Maple an instruction to solve Euler-Lagrange equation?        ELEOM.mw
how to add two algebaric equations? I have two equation (1) and (2). i simply wrote (1) + (2) instead of adding the eqautions i got result is 3. i think there is some mistake of writng text for calling equation that was in bold.
adding_two_equations.mw
I am trying to evaluate the following triple integral but it takes much time so i kill the job.
restart; R := 5; KK := proc (theta) options operator, arrow; evalf(int(int(int(1/(R*sin(theta)^2+(R*cos(theta)+Z)^2+(2*R*k.sin(theta))*cos(p))^2, p = 0 .. 2*Pi), Z = 0 .. 60), k = 1 .. 10, numeric)) end proc; evalf(KK((1/6)*Pi))
Download int_maple_prime2.mw
with(DEtools, buildsym, equinv, symtest):
ans := dsolve([eq2,eq3,eq4], Lie);
Error, (in dsolve) too many arguments; some or all of the following are wrong: [{a(t), b(t), c(t)}, Lie]
ans := dsolve([eq2+eq3+eq4 = exp(t)], Lie);
Error, (in PDEtools/sdsolve) too many arguments; some or all of the following are wrong: [{a(t), b(t), c(t)}, Lie]
ans := dsolve([eq2,eq3,eq4]);
sym2 := buildsym(ans);
Error, (in buildsym) invalid input: `ODEtools/buildsym` expects its 1st argument, sol, to be of type {algebraic, algebraic = algebraic}, but received [{c(t) = ...}, {b(t) = ...}, {a(t) = ...)}]
PDEtools[declare](a(t), b(t), c(t), prime = t):
symgen(eq2+eq3+eq4=0);
                       a(t) will now be displayed as a
                       b(t) will now be displayed as b
                       c(t) will now be displayed as c
   derivatives with respect to t of functions of one variable will now be
      displayed with 'symgen(....)'
update
if it can not do for 3 function a(t),b(t),c(t) system of differential equations
then
i change to use
eq2 := subs(b(t)=a(t),subs(c(t)=a(t),eq2));
eq3 := subs(b(t)=a(t),subs(c(t)=a(t),eq3));
eq4 := subs(b(t)=a(t),subs(c(t)=a(t),eq4));
ans := dsolve(eq2 = 0, Lie);
buildsym(ans[1], a(t));
buildsym(ans[2], a(t));
buildsym(ans[3], a(t));
there are 3 answers, can i use one of it to recover the equation eq2 or  eq3 or eq4?
ans := dsolve(eq3=0, Lie);
sym2 := buildsym(ans[2], a(t));
sym := [_xi=rhs(sym2[2]),_eta=rhs(sym2[1])];
ODE := equinv(sym, a(t));
eq3 - ODE;
sym := [_xi=rhs(sym2[1]),_eta=rhs(sym2[2])];
eq3 - ODE;
but ODE is not equal to original eq3
ans := dsolve(eq4=0, Lie);
ans := dsolve(eq2+eq3+eq4=0, Lie);
sym := buildsym(ans[1], a(t));
eq2+eq3+eq4 - ODE;
sym := buildsym(ans[2], a(t));
eq2+eq3+eq4 - ODE;
sym := buildsym(ans[3], a(t));
simplify(eq2+eq3+eq4 - - ODE);
can not recover the original result
Maple newbie here.
I do not understand why algsubs do not replace the symbol in the denominator in the following example, but does replace it in the numerator. This is on Maple 2017 on windows 7
Here is the expression
sol := u(x, t) = Sum((2*cos((1/2)*Pi*_Z1)+
       2+4*(-1)^(1+_Z1))*sin(Pi*_Z1*x/L)*
       exp(-k*Pi^2*_Z1^2*t/L^2)/(Pi*_Z1),
       _Z1 = 1 .. infinity);
I wanted to replace _Z1  with n
But algsubs will not replace _Z1 in the denominator as seen in this screen shot but subs does:
From help, my impression is that algsubs is superset of subs. Only case where algsubs will not do what subs does is, according to help:
The algsubs command goes recursively through the expression . Unlike the subs command it does not substitute inside indexed names, and function calls are applied to the result of a substitution
But There is no indexed names here?
Can someone please explain why algsubs fails to do the substitution in the denominator in this example?
I am trying to evaluate the following function for which I am getting a result 0. I just need to make sure the approach as well as result is correct or not. Thanks in advance.
restart; Digits := 20; r := 5; Z := 0; KK := proc (phi) options operator, arrow; evalf(int(sin(phi)*sin(-arctan((p*cos(phi)+Z)/sqrt(p^2*sin(phi)^2+r^2)))*hypergeom([5/2, 3/2], [5/2], sin(-arctan((p*cos(phi)+Z)/sqrt(p^2*sin(phi)^2+r^2)))^2)/(p^2*sin(phi)^2+r)^2, p = -1 .. 1, numeric)) end proc; evalf(KK((1/6)*Pi))
0.
Download int(maple_prime).mw
I did change of variables as below:
Error, invalid input: with expects its 1st argument, pname, to be of type {`module`, package}, but received shareman
UP := Int(1/2*(K__ux0*u0(x, y, t)^2+K__vx0*v0(x, y, t)^2+K__wx0*w0(x, y, t)^2+`K__&phi;x0`*phi(x, y, t)^2+`K__&psi;x0`*psi(x, y, t)^2), y = 0 .. b)+Int(1/2*(K__uxa*u0(x, y, t)^2+K__vxa*v0(x, y, t)^2+K__wxa*w0(x, y, t)^2+`K__&phi;xa`*phi(x, y, t)^2+`K__&psi;xa`*psi(x, y, t)^2), y = 0 .. b)+Int(1/2*(K__uy0*u0(x, y, t)^2+K__vyb*v0(x, y, t)^2+K__wyb*w0(x, y, t)^2+`K__&phi;yb`*phi(x, y, t)^2+`K__&psi;y0`*psi(x, y, t)^2), x = 0 .. a)+Int(1/2*(K__uyb*u0(x, y, t)^2+K__vyb*v0(x, y, t)^2+K__wyb*w0(x, y, t)^2+`K__&phi;yb`*phi(x, y, t)^2+`K__&psi;yb`*psi(x, y, t)^2), x = 0 .. a):
varchange := {t = a*tau*sqrt(rho/A__ref), x = (1/2)*a*(Zeta+1), y = (1/2)*b*(eta+1), phi(x, y, t) = h*`#mover(mi("&phi;",fontstyle = "normal"),mo("&uminus0;"))`(Zeta, eta, tau), psi(x, y, t) = h*`#mover(mi("&psi;",fontstyle = "normal"),mo("&uminus0;"))`(Zeta, eta, tau), u0(x, y, t) = h*`#mover(mi("u"),mo("&uminus0;"))`(Zeta, eta, tau), v0(x, y, t) = h*`#mover(mi("v"),mo("&uminus0;"))`(Zeta, eta, tau), w0(x, y, t) = h*`#mover(mi("w"),mo("&uminus0;"))`(Zeta, eta, tau)}:
Ut := PDEtools:-dchange(varchange, UP, [`#mover(mi("u"),mo("&uminus0;"))`, `#mover(mi("v"),mo("&uminus0;"))`, `#mover(mi("w"),mo("&uminus0;"))`, `#mover(mi("&phi;",fontstyle = "normal"),mo("&uminus0;"))`, `#mover(mi("&psi;",fontstyle = "normal"),mo("&uminus0;"))`, Zeta, eta, tau], params = [a, b, rho, A__ref]):
Ut
Int((1/2)*((1/2)*K__ux0*h^2*`#mover(mi("u"),mo("&uminus0;"))`(Zeta, eta, tau)^2+(1/2)*K__vx0*h^2*`#mover(mi("v"),mo("&uminus0;"))`(Zeta, eta, tau)^2+(1/2)*K__wx0*h^2*`#mover(mi("w"),mo("&uminus0;"))`(Zeta, eta, tau)^2+(1/2)*`K__&phi;x0`*h^2*`#mover(mi("&phi;",fontstyle = "normal"),mo("&uminus0;"))`(Zeta, eta, tau)^2+(1/2)*`K__&psi;x0`*h^2*`#mover(mi("&psi;",fontstyle = "normal"),mo("&uminus0;"))`(Zeta, eta, tau)^2)*b, eta = -1 .. 1)+Int((1/2)*((1/2)*K__uxa*h^2*`#mover(mi("u"),mo("&uminus0;"))`(Zeta, eta, tau)^2+(1/2)*K__vxa*h^2*`#mover(mi("v"),mo("&uminus0;"))`(Zeta, eta, tau)^2+(1/2)*K__wxa*h^2*`#mover(mi("w"),mo("&uminus0;"))`(Zeta, eta, tau)^2+(1/2)*`K__&phi;xa`*h^2*`#mover(mi("&phi;",fontstyle = "normal"),mo("&uminus0;"))`(Zeta, eta, tau)^2+(1/2)*`K__&psi;xa`*h^2*`#mover(mi("&psi;",fontstyle = "normal"),mo("&uminus0;"))`(Zeta, eta, tau)^2)*b, eta = -1 .. 1)+Int((1/2)*((1/2)*K__uy0*h^2*`#mover(mi("u"),mo("&uminus0;"))`(Zeta, eta, tau)^2+(1/2)*K__vyb*h^2*`#mover(mi("v"),mo("&uminus0;"))`(Zeta, eta, tau)^2+(1/2)*K__wyb*h^2*`#mover(mi("w"),mo("&uminus0;"))`(Zeta, eta, tau)^2+(1/2)*`K__&phi;yb`*h^2*`#mover(mi("&phi;",fontstyle = "normal"),mo("&uminus0;"))`(Zeta, eta, tau)^2+(1/2)*`K__&psi;y0`*h^2*`#mover(mi("&psi;",fontstyle = "normal"),mo("&uminus0;"))`(Zeta, eta, tau)^2)*a, Zeta = -1 .. 1)+Int((1/2)*((1/2)*K__uyb*h^2*`#mover(mi("u"),mo("&uminus0;"))`(Zeta, eta, tau)^2+(1/2)*K__vyb*h^2*`#mover(mi("v"),mo("&uminus0;"))`(Zeta, eta, tau)^2+(1/2)*K__wyb*h^2*`#mover(mi("w"),mo("&uminus0;"))`(Zeta, eta, tau)^2+(1/2)*`K__&phi;yb`*h^2*`#mover(mi("&phi;",fontstyle = "normal"),mo("&uminus0;"))`(Zeta, eta, tau)^2+(1/2)*`K__&psi;yb`*h^2*`#mover(mi("&psi;",fontstyle = "normal"),mo("&uminus0;"))`(Zeta, eta, tau)^2)*a, Zeta = -1 .. 1)
simplify(Ut)
(1/4)*(b*(Int(K__ux0*`#mover(mi("u"),mo("&uminus0;"))`(Zeta, _a, tau)^2+K__vx0*`#mover(mi("v"),mo("&uminus0;"))`(Zeta, _a, tau)^2+K__wx0*`#mover(mi("w"),mo("&uminus0;"))`(Zeta, _a, tau)^2+`K__&phi;x0`*`#mover(mi("&phi;",fontstyle = "normal"),mo("&uminus0;"))`(Zeta, _a, tau)^2+`K__&psi;x0`*`#mover(mi("&psi;",fontstyle = "normal"),mo("&uminus0;"))`(Zeta, _a, tau)^2, _a = -1 .. 1))+b*(Int(K__uxa*`#mover(mi("u"),mo("&uminus0;"))`(Zeta, _a, tau)^2+K__vxa*`#mover(mi("v"),mo("&uminus0;"))`(Zeta, _a, tau)^2+K__wxa*`#mover(mi("w"),mo("&uminus0;"))`(Zeta, _a, tau)^2+`K__&phi;xa`*`#mover(mi("&phi;",fontstyle = "normal"),mo("&uminus0;"))`(Zeta, _a, tau)^2+`K__&psi;xa`*`#mover(mi("&psi;",fontstyle = "normal"),mo("&uminus0;"))`(Zeta, _a, tau)^2, _a = -1 .. 1))+a*(Int(K__uy0*`#mover(mi("u"),mo("&uminus0;"))`(_a, eta, tau)^2+K__vyb*`#mover(mi("v"),mo("&uminus0;"))`(_a, eta, tau)^2+K__wyb*`#mover(mi("w"),mo("&uminus0;"))`(_a, eta, tau)^2+`K__&phi;yb`*`#mover(mi("&phi;",fontstyle = "normal"),mo("&uminus0;"))`(_a, eta, tau)^2+`K__&psi;y0`*`#mover(mi("&psi;",fontstyle = "normal"),mo("&uminus0;"))`(_a, eta, tau)^2, _a = -1 .. 1)+Int(K__uyb*`#mover(mi("u"),mo("&uminus0;"))`(_a, eta, tau)^2+K__vyb*`#mover(mi("v"),mo("&uminus0;"))`(_a, eta, tau)^2+K__wyb*`#mover(mi("w"),mo("&uminus0;"))`(_a, eta, tau)^2+`K__&phi;yb`*`#mover(mi("&phi;",fontstyle = "normal"),mo("&uminus0;"))`(_a, eta, tau)^2+`K__&psi;yb`*`#mover(mi("&psi;",fontstyle = "normal"),mo("&uminus0;"))`(_a, eta, tau)^2, _a = -1 .. 1)))*h^2
Download simplifyss.mw
But I amezed when I use simplify command deteriorate my eq.
Why?
UPDATE
Thanks for checking. I verify I get the error and made screen shots below
When I add the convert() command, the error goes away. Here is screen shot
I am using Maple 2017, student version, on windows 7, 64 bit, home edition.
Original post
This is using Maple 2017 on windows.
With the following input, Maple pdsolve gives an error
pde:=diff(u(x,t),t)=k*diff(u(x,t),x$2);
bc:=D[1](u)(0,t)=0,D[1](u)(L,t)=0:
assume(L>0):
ic:=u(x,0)=piecewise(0<x and x<=L/2,0,L/2<x and x<L,1):
sol:=pdsolve([pde,bc,ic],u(x,t)):
However, if I add one line to convert the piecewise function above to piecewise, then pdsolve no longer gives an error. So the following input works
assume(L>0):
ic:=convert(ic,piecewise,x):
Notice the extra line. Why does one have to convert piecewise to piecewise to make pdsolve accept the input?
sorry did not write down the error message and I am writing this from school library PC. But if you try the first case, you'll see the error.
Hi! I have the system of differential equations
restart; with(plots); with(DEtools);
a := 1;
deq1 := u(s)*(diff(varphi(s), s, s))+2*(diff(u(s), s))*(diff(varphi(s), s))+sin(varphi(s)) = 0;
deq2 := diff(u(s), s, s)-u(s)*(diff(varphi(s), s))^2-cos(varphi(s))+a*(u(s)-1) = 0;
sol := dsolve({deq1, deq2, u(0) = 1, varphi(0) = (1/4)*Pi, (D(u))(0) = 0, (D(varphi))(0) = 0}, {u(s), varphi(s)}, numeric)
which is perfectly solved, but I need to convert it to Cartesian coordinates and draw a plot, so what I tried is
x := u(s)*sin(varphi(s));
y := -u(s)*cos(varphi(s));
plot([x, y, s = 0 .. 20])
But I'm getting an error "Warning, expecting only range variable s in expressions [u(s)*sin(varphi(s)), -u(s)*cos(varphi(s))] to be plotted but found names [u, varphi]"
I don't know why is this happens if I have a solution. For example, I can get solution for 2 seconds:
sol(2)
[s = 2., u(s) = 2.33095721668252, diff(u(s), s) = 1.02513293353371, varphi(s) = .213677391510693, diff(varphi(s), s) = -.242430995691885]
First 974 975 976 977 978 979 980 Last Page 976 of 2434
