Question: integrate a numerical function
November 22 2012 bernie 20
Maple
Hi
I browsed the forums but could not find a solution to my problem. Ii have a system of differential equations; however, I have the solution to one of the functions as an integral of another function in the system, but since the solutions are all numerical I don't know how to implement this. Here's the system and what I tried at first
eq1 := diff(W(r), r) = -(1-beta*(W(r)-W0))*(M(r)+4*Pi*r^3*p(r))/(beta*r*(r-2*M(r)));
eq2 := diff(M(r), r) = 4*Pi*r^2*rho(r);
W0 := solve(thetaR = theta0-W0, W0);
ini := evalf({M(r0) = 0, W(r0) = W0});
thetadef := theta(r) = W(r)+thetaR;
pdef := p(r) = subs(thetadef, value((8*sqrt(2)*Pi*(1/3))*(beta/(1-beta*(W(r)-W0)))^(5/2)*ApproximateInt((1+(1/2)*beta*x/(1-beta*(W(r)-W0)))^(3/2)*x^(3/2)*(1-exp(x-W(r)))/(exp(x-theta(r))+1), x = 0 .. W(r), output = sum, partition = 50))):
rhodef := rho(r) = subs(thetadef, value(4*sqrt(2)*Pi*(beta/(1-beta*(W(r)-W0)))^(3/2)*ApproximateInt((1+(1/2)*beta*x/(1-beta*(W(r)-W0)))^(1/2)*(1+beta*x/(1-beta*(W(r)-W0)))^2*x^(1/2)*(1-exp(x-W(r)))/(exp(x-theta(r))+1), x = 0 .. W(r), output = sum, partition = 50))):
vraddef:=vrad(x)=(1+r)^(-1/2)*ApproximateInt((1+r)^(1/2)*M(r)/r^2,r=x..10^(20),output=sum,partition=50):
dsys := evalf(subs(pdef, rhodef, {eq1, eq2, op(ini)})):
dsol:=dsolve(dsys,numeric,output=listprocedure,range=r0..rf,parameters=[theta0,beta,thetaR]);
Wsol:=eval(W(r),dsol):
Msol:=eval(M(r),dsol):
vradsol := subs(M(r) = Msol(r), rhs(vraddef))
vproc1 := proc (X, Theta0, Beta, ThetaR) Wsol(parameters = ['theta0' = Theta0, 'beta' = Beta, 'thetaR' = ThetaR]); evalf[15](eval(vradsol, [x = X, 'theta0' = Theta0, 'beta' = Beta, 'thetaR' = ThetaR])) end proc
#########################à
this doesn't work. If I try to use the diff equation for vrad:
diff(vrad(r), r) = -(1+r)^(1/2)*M(r)/r^2
ini := evalf({M(r0) = 0, W(r0) = W0, vrad(rf)=0});
dsys := evalf(subs(pdef, rhodef, {eq1, eq2, eq3, op(ini)})):
it says it can't solve.
How to deal with this?
Thanks for the help
