Question: Gram-Schmidt problem
Use the Gram-Schmidt process to transform the basis
{Vector(3, {(1) = 0, (2) = 1, (3) = 1}),
Vector(3, {(1) = 1, (2) = 1, (3) = 1}),
Vector(3, {(1) = 1, (2) = 2, (3) = 3})}
for the Euclidean space R3 into an orthonormal basis for R3
Show 3D result.
This is what was given to solve the problem, but it is not working.
> GramSchmidt2 := proc ()
local M, rows, numV, v, seqL, lstL, i, j, vlength;
numV := nargs;
print('Original set');
    seqL := NULL;
if type(args[1], Matrix) and numV = 1 then
    M := args[1];
   numV := LinearAlgebra[ColumnDimension](M);
   rows := LinearAlgebra[RowDimension](M);
   if rows < numV then
       WARNING("input  is a set of Linearly Dependent Vectors") end if;
   for i to numV do
      vi := Column(M, i);
      vi:= convert(vi, Vector);
      seqL := seqL, vi :
end do:
else
  rows := nops(args[1]);
  if rows < numV then
         WARNING("input  is a set of Linearly Dependent Vectors");
end if;
 for i to numV do vi:= args[i];
vi := convert(vi, Vector);
if nops(vi) ≠ rows then
error "the lenght of inputed Vectors sould be the same";
 end if;
seqL := seqL, vi;
end do;
 end if;
print([seqL]);
print('Orthogonal set');
if Norm(vi, 2) ≠ 0 then
seqL := vi;
else
 seqL := NULL;
 end if;
for j from 2 to numV do
for i to j-1 do
vj := vj-Proj(vi, vj);
 end if;
 end do;
if Norm(vj, 2) ≠ 0 then
seqL := seqL, vj;
end if;
 end do;
print([seqL]);
print('Orthonormal set');
seqL := NULL;
for j to numV do
vj:= vj/Norm(vj, 2);
seqL := seqL, vj;
end if;
 end do;
print([seqL]);
lstL := [seqL];
return lstL;
 end proc;
> Proj := proc (u, v)
return (u.v)*u/(u.u);
end proc;
> w1 :=<(0,1,1)> ;
> w2 := <(1,1,1)>;
> w3 := <(1,2,3)>;
>GramSchmidt2(w1, w2, w3)
> vectordisplay := proc ()
local numV, v, a, seqA, lstL, i, j;
numV := nargs; with(plots);
setoptions(color = red, scaling = constrained, style = line);
numV := nargs;
seqA := NULL;
for i to numV do
vi:= args[i];
if nops(vi) = 3 then
ai:= arrow(vi, shape = arrow, axes = normal) else error "only display 3d vectors" end if;
seqA := seqA, ai;
end do;
display(seqA);
 end proc;
> w1 := ;
> w2 := ;
> w3 := ;
> printf("Before ... ");
vectordisplay(w1, w2, w3);
printf("Normalizing...");
lstW := GramSchmidt2(w1, w2, w3);
printf("After...");
vectordisplay(op(lstW));
