Question: 2D Grid Interpolation
I'm solving a 2D grid with some finite-diference methods. The result is a surface, i.e f(x,y) = z. Where X and Y and points on a grid.
I then need to integrate over this grid, i.e
int(f(x,y),[x=0..10, y=0..10])
I have tried interpolating the grid. I've used CurveFitting:-ArrayInterpolation() to interpolate points in this 2D space and then integrate over them.
I'm using a 30x30 grid, but this interpolation scheme takes far too long. The function generated from the ArrayInterpolation creates an interpolation every time a point is evaluated, which I assume is why the integral is very computationally expensive.
I would like to create a piecewise analytic function from the 2-D grid, perhaps using CurveFitting:-Spline(), however from my understanding this only works for 1D objects?
Is there any better solution for integrating a 2D numeric grid?
Thanks in advance
