Question: Local/ global/ export variables for modules with submodules
I have a quite big program designed with packages and subpackages.
I realized that i'm not to well understand the operation of local/ global/ export variables in this case.
Let's detail the issue.
I consider a package like this :
MAIN PACKAGE:=module()
local XM
global YM
export ZM
      SUBPACKAGE1:=module()
      local X1
      global Y1
      export Z1
      end module;
      SUBPACKAGE2:=module()
      local X2
      global Y2
      export Z2
      end module;
end module;
Question:
Can you describe in the simpliest way the rules for accessing to the variables in the case the variables are local/ global/ export and in the case you are writting procedures inside the MAINPACKAGE or the SUBPACKAGEs ?
In others words may you help me to answer to these questions  ?
Is the local variable XM accessible to the procedures used in SUBPACKAGE1? no
Is the local variable X1 accessible to the procedure used in MAINPACKAGE ? no
Is the global variable YM accessible to the procedures used in SUBPACKAGE1? yes
Is the global variable Y1 accessible to the procedure used in MAINPACKAGE ? yes
Is the export variable ZM accessible to the procedures used in SUBPACKAGE1? yes
Is the export variable Z1 accessible to the procedure used in MAINPACKAGE ? yes with the syntax SUBPACKAGE:-Z1
I let my opinion but i need certainty on these points...
I attach a first draft that i would like you help me.
AboutModuleLocalGlobalExport.mw
I thank you in advance for your help.
