@ecterrab
Fetching package "Physics Updates" from MapleCloud...
Version: 1713
URL: https://maple.cloud
An error occurred, the package was not installed:
Could not open workbook: /tmp/cloudDownload3108059082303936092/Physics Updates_1712064079729.maple
Same problem on Maple 2024 for Windows and Linux!!!
I am trying to generate a plot using a procedure. A dummy code is as follows:
fun := piecewise(x+y > 1, (x+y)^2, x-y);
temp_proc := proc(x, y)
local out, ind:
ind := 9:
if x > y then ind := 1 else ind := 0 end if;
if ind = 1 then out := eval(5*fun, {:-x=x, :-y=y}) else out := eval(-5*fun, {:-x=x, :-y=y}) end if:
return(out);
xt := 5: yt := 2:
out1_fin := temp_proc(xt, yt);
plot(out1_fin, z=-2..3);
The issue is as follows:
1. I am getting an error message for the code above: "Error, (in temp_proc) cannot determine if this expression is true or false: 2 < z".
2. The entire procedure and the plot command work well for a fixed "z". However, it is not useful for me as I am looking for a plot for various values of z.
3. I hope I don't have to run the procedure by manually creating a list of z and then plotting the lists of z and out1_fin.
4. I am using the "ind" variable because it simplifies my actual code, which involves multiple conditions defining the function "fun" that I need to plot.
I would appreciate your input on how to resolve the issue.
Omkar
I am unable to change the font on the Palette menus or the pop up context boxes.
It is very frustrating, as I can hardly read them.
I am not sure if it is a computer setting or a Maple setting.
Any help would be appreciated
The following is a simple example of what I would like to do:
M := Array(1 .. 10, 1 .. 2);
for i to 10 do
    M[i, 1] := i;
    M[i, 2] := 3*i;
Mt := Interpolation:-LinearInterpolation(M);
E := t -> Mt(t);
diffeq := D(C)(t) = E(t);
dsolve({diffeq, C(0) = 0}, {C(t)}, numeric);
Error, (in dsolve/numeric/process_input) unknown Interpolation:-LinearInterpolation([Vector(10, [1.,2.,3.,4.,5.,6.,7.,8.,9.,10.], datatype = float[8], attributes = [source_rtable = (Vector(10, [1.,2.,3.,4.,5.,6.,7.,8.,9.,10.], datatype = float[8], attributes = [source_rtable = (Array(1..10, 1..2, [[1.,3.],[2.,6.],[3.,9.],[4.,12.],[5.,15.],[6.,18.],[7.,21.],[8.,24.],[9.,27.],[10.,30.]], datatype = float[8]))]))])],Vector(10, [3.,6.,9.,12.,15.,18.,21.,24.,27.,30.], datatype = float[8], attributes = [source_rtable = (Array(1..10, 1..2, [[1.,3.],[2.,6.],[3.,9.],[4.,12.],[5.,15.],[6.,18.],[7.,21.],[8.,24.],[9.,27.],[10.,30.]], datatype = float[8]))]),uniform = true,verify = false) present in ODE system is not a specified dependent variable or evaluatable procedure
I am struggling with the output of a procedure. A dummy code is as follows:
fun := x^2+y^2;
local out1, out2, out3:
if x > 0 then out1 := fun; out2 := 2*fun; out3 := k*fun;
elif x <= 0 then out1 := fun; out2 := -2*fun; out3 := -k*fun;
end if:
return(out1, out2, out3);
xt := -1: yt := 2:
out1_fin := temp_proc(xt, yt)[1];
out2_fin := temp_proc(xt, yt)[2];
out3_fin := temp_proc(xt, yt)[3];
xt and yt are numerical input parameters. I expect to obtain "out1_fin" and "out2_fin" in numerical form and "out3_fin" in symbolic form. All three outputs should substitute xt and yt for x and y, respectively, wherever relevant.
However, currently, the output I am getting is not after substituting the values of xy and yt. The output is as follows:
out1_fin := x^2+y^2
out2_fin := -2*x^2-2*y^2
out3_fin := -k*(x^2+y^2)
May I get some help in resolving the issue?
Also, would a procedure be a good idea for this task, or would a module be better?
I would appreciate any guidance in this regard. Thank you.
Omkar
I keep getting an error: invalid subscript selector on specifically this part of my code:
MuligIndgange := subsop(RemoveList\[i\]=NULL, MuligIndgange).
Whenever I comment out the MuligIndgange := part it works.
I can't for the life of me see why it's happening, and whenever I use this code outside my proc it works aswell.
Any help is appreciated, and if you need more context I'll be happy to give it.
for i to numelems(MuligIndgange) do
     if M1[MuligIndgange[i][1], MuligIndgange[i][2]] =/= 0 then
         RemoveList := [op(RemoveList), i];
for i from numelems(RemoveList) by -1 to 1 do
    MuligIndgange := subsop(RemoveList[i] = NULL, MuligIndgange);
When I use evala(Minpoly(sqrt(3) + sqrt(2), x)), then I get a right answer: x^4 - 10*x^2 + 1
But when I want to get the minimal polynomial of cos((2*Pi)/7) by evala(Minpoly(cos((2*Pi)/7), x)), I will get a result:
x - cos((2*Pi)/7)
It clearly does not follow the definition of a minimal polynomial. Is it a bug of Minpoly or I have missed something?
Question 1
Let theta a real number in the range 0..2*Pi.
Is there a way to "convert"
f := theta -> arccos(cos(theta))+arcsin(sin(theta))
into
f1 := theta -> piecewise(theta < 0, 0, theta < (1/2)*Pi, 2*theta, theta < Pi, Pi, theta <= (3/2)*Pi, 3*Pi-2*theta, 0)
Question 2
As f1 is  2*Pi periodic, is there a way to convert f into a periodic function where the "pattern" is f1(theta)?
To be clearer I thought to something close to what we get when we do this
solve(cos(x)=1, allsolutions);
                            2 Pi _Z2
about(_Z1);
Originally _Z1, renamed _Z1~:
  is assumed to be: integer
and I imagined
Some_Transformation(f(theta))
    f1(theta+2*Pi*_Z1~)
about(_Z1);
For the moment I build the periodized f1 this way
f2 := (theta, K) -> int(f1(theta-z)*add(Dirac(z-2*Pi*k), k=-K..K), z=-infinity..+infinity);
# or
f2 := (theta, K) -> sum(int(f1(theta-z)*Dirac(z-2*Pi*k), z=-infinity..+infinity), k=-K..K);
How do I solve the problem below using maple commands? I'm having trouble finding the commands and believe my answer is incorrect. I am currentley on maple 2022.
How would I find an equation of the line tangent to the graph of f(x) when x =3?
f(x)= (1-kx)/(1+x^2)
f := x -> x^2 + 2*x + 1;
I would like to generate a ColumnGraph such that the bars are centered over 1, 2, and 3. For example, I have a vector:
x:= Vector([1,2,3]);
When you execute ColumnGraph(x), you a get the first bar centered over 0.375, instead of 1, second bar centered over 1.375, instead of 2, and so on.
Thanks for your help.
I have seen this quite a bit in blocks of code. The `>` symbol seems to appear erratically. I don't know how to specifically reproduce this. Does it mean something? I would post the worksheet but it will not run without the package.
"restart: with(plots):with(DEtools):with(Student[ODEs]):infolevel[Student]:=3 ;"NULL
"maple.ini in users"
NULL#  plot  solutions to a system  of DEs
sys := {diff(x(t), t) = y(t), diff(y(t), t) = -x(t) - 1/2*y(t)}
{diff(x(t), t) = y(t), diff(y(t), t) = -x(t)-(1/2)*y(t)}
DEplot(sys, [x(t), y(t)], t = 0 .. 15, [[x(0) = 1, y(0) = 0]])
This is not working, seems to be simple ...
Have made an attempt to create a procedure from these two commands, but no success
Apparently, I need to learn to use a debugger to determine what is wrong, then?
dv_systeemplot:= proc ( DV1,DV2 ,RV1,RV2 )
                 local t, sys,systeemplot;
                 sys := {DV1 , DV2 }:
                 systeemplot:= DEplot(sys, [x(t), y(t)], t = 0 .. 15, [[RV1 , RV2]]);
                 return systeemplot;
proc (DV1, DV2, RV1, RV2) local t, sys, systeemplot; sys := {DV1, DV2}; systeemplot := DEplot(sys, [x(t), y(t)], t = 0 .. 15, [[RV1, RV2]]); return systeemplot end proc
DV1 := diff(x(t), t) = y(t)
DV2 := diff(y(t), t) = -x(t)-(1/2)*y(t)
RV1 := x(0) = 1
x(0) = 1
RV2 := y(0) = 0
y(0) = 0
dv_systeemplot( DV1,DV2 ,RV1,RV2 );
Error, (in DEtools/DEplot/CheckDE) inputs must be ODEs
Ask AI to get some code: never i got the right Maple code ! :)
"restart: with(plots):with(DEtools):with(Student[ODEs]):infolevel[Student]:=3 ;"``
systeem := proc(eq1, eq2, beginwaarden)
  local x, y, oplossing;
  x := unapply(rhs(dsolve({eq1, eq2, beginwaarden}, {x(t), y(t)})), t);
  y := unapply(rhs(dsolve({eq1, eq2, beginwaarden}, {x(t), y(t)})), t);
  oplossing := DEplot([x(t), y(t)], t = 0 .. 10, beginwaarden);
  oplossing;
# Definieer de differentiaalvergelijkingen
eq1 := diff(x(t), t) = y(t);
eq2 := diff(y(t), t) = -x(t);
# Geef de beginwaarden op
beginwaarden := [x(0) = 1, y(0) = 0];
# Roep de procedure aan met de differentiaalvergelijkingen en beginwaarden
systeem(eq1, eq2, beginwaarden);
proc (eq1, eq2, beginwaarden) local x, y, oplossing; x := unapply(rhs(dsolve({eq1, eq2, beginwaarden}, {x(t), y(t)})), t); y := unapply(rhs(dsolve({eq1, eq2, beginwaarden}, {x(t), y(t)})), t); oplossing := DEplot([x(t), y(t)], t = 0 .. 10, beginwaarden); oplossing end proc
Error, (in dsolve) invalid input: PDEtools/sdsolve expects its 1st argument, SYS, to be of type Or(set({`<>`, `=`, algebraic}),list({`<>`, `=`, algebraic}),`casesplit/ans`(list,list)), but received {diff(x(t),t) = y(t), diff(y(t),t) = -x(t), [x(0) = 1, y(0) = 0]}
Probably i do need to work with a debugger here?
Download dv_systeem_via_mapleprimes_.mw
If we write
restart: alias(po=pochhammer):
assume(abs(z)<1);  F:=z->sum(po(1,n)^2/po(1/2,n)^2*z^n/(n+1),n=1..infinity);
Then the output of F(z) is a hypergeometric series, and
A=subs(z=4, F(z);
evalf(A)
gives the correct output. But, why do we need to assume that abs(z)<1 if we are evaluating at abs(z)>1?. Observe that if we do not assume it, then the output we get is wrong, why?
I recently watched a video in which the speaker asked the following question: "How many seconds are there in 42 days?".
I think I've done what anyone would do: trying to quickly find an order of magnitude for this number.
But the speaker's answer was both remarkable and obvious when you think of it: "Exactly 10! seconds".
So my question: Given the number 3628800, is there a way to identify it (in the  identify's sense) to 10!  ?
Or maybe some trick to force identify to answer 10! ?
Well , honestly I can't make sense of how to do this.
Interactive can be done step by step , but now generalize via a procedure , but can't get a handle on it
How to get the right procedure ?
" restart: with(plots):with(DEtools):with(Student[ODEs]):infolevel[Student]:=3 ;"
DV := y(x)*(diff(y(x), x)) = exp(x)
opl_1 := dsolve({DV, RV1}, y(x))
y(x) = (1-2*exp(1)+2*exp(x))^(1/2)
opl_2 := dsolve({DV, RV2}, y(x))
y(x) = -(1-2*exp(1)+2*exp(x))^(1/2)
opl := plot({rhs(opl_1), rhs(opl_2)}, x = 0 .. 5, y = -10 .. 10, thickness = 3)
lijnelement := dfieldplot(DV, y(x), x = 0 .. 5, y = -10 .. 10, title = "lijnelementveld met intergaalkromme door (1,1)(1,-1)")
display({opl, lijnelement})
DV, RV1, RV2
y(x)*(diff(y(x), x)) = exp(x), y(1) = 1, y(1) = -1
"restart: with(plots):with(DEtools):with(Student[ODEs]):infolevel[Student]:=3 ; "
DVplot:=proc(DVA,RV1A,RV2A)
          local DV;RV1;RV2;opl_1;opl_2;opl;lijnelement;
          DV:
          RV1:
          RV2:
          opl_1 := dsolve({DV, RV1}, y(x)):
          opl_2 := dsolve({DV, RV2}, y(x)):
          opl:= plot({rhs(opl_1), rhs(opl_2)}, x = 0 .. 5, y = -10 .. 10, thickness = 3):
          lijnelement:=dfieldplot(DV, y(x), x = 0 .. 5, y = -10 .. 10, title = "lijnelementveld met                intergaalkromme door (1,1)(1,-1)"):
          display({opl, lijnelement});
DVA := y(x)*(diff(y(x), x)) = exp(x)
RV1A := y(1) = 1
y(1) = 1
RV2A := y(1) = -1
y(1) = -1
DVplot(DVA, RV1A, RV2A)
Error, (in dsolve) not a system with respect to the unknowns [y(x)]
Download DV_plotten-_procedure.mw
First 117 118 119 120 121 122 123 Last Page 119 of 2427
