I want to make from a procedure call a single argument function that can be used in function composition.
To illustrate this with a simple example, below the function pow[3] performs a cube operation
pow[3]:=x-> `^`(x,3):
(evalf[4]@pow[3]@sin)(Pi/6)
                             0.1250
To make the use of pow a bit more generic, I though about doing definitions for other powers in a loop with an inline assignement
for i from -1/2 to 5 by 1/2 do (power[i]:=x-> `^`(x,i)) end do;
This does not work because the i in the rigthhand side of power[i]:=x-> `^`(x,i) does not evaluate to the acutal value of the loop counter. I tried eval and evaln without success. How do I get full evaluation of the inline assignement?
How can I find a relation of a, b, c, d, t (a d <> 0) so that the function f(x) = (a x^2 + b x + c)/(d x +t) is a increasing function on the interval (m, n)? I know that, we have the conditions
f'(x) >=0 forall x in (m, n) and -t/d not in (m, n)
I have the following procedure that uses the Lie Derivatives of a vector field to build a set of equations.
LieDerList:=proc(h::symbol,f::list,vars::list)
description "This function returns the system of equations based on the Lie derivative.":
local i,n:=numelems(vars),L:=Array(0..n):
L[0]:=h:
for i from 1 to n do
    L[i]:=inner(f,map((a,b) -> diff(b,a),vars,L[i-1])):
return(zip((w,v)->simplify(w-v),[seq(L)],[seq](cat(h,i),i=0..n))):
Below it is an example on how to call the procedure.
I used CodeTools:-ThreadSafetyCheck to check all the procedures used within LieDerList and LieDerList itself, but nothing wrong came out. However when I try to run
LieEq4:=Threads:-Map(w->LieDerList(x,w,[x,y,z]),models4):
where models4 is a list of 1765 elements, maple returns "Error, (in factors) attempting to assign to `LinearAlgebra:-Modular:-Create` which is protected". If I change Threads to Grid, there is no problem at all.
What am I overlooking? Is there a method to ensure the procedure is thread-safe?
Many thanks.
PS.  I found one problem - inner, which is related to LinearAlgebra package, is not thread-safe.
This is not new in Maple 2024, and also happens in Maple 2023. But it causes the famous "kernel connection has been lost" each time.
I think many of the kernel connection has been lost problems I see might be related. It could be memory problem in this case. I wonder if someone will be able to track what causes it. Is it expected that server.exe crash on such input?
ps. Reported to Maplesoft support.
36292
`The "Physics Updates" version in the MapleCloud is 1708 and is the same as the version installed in this computer, created 2024, March 27, 16:20 hours Pacific Time.`
integrand:=(2*x^2022+1)/(x^2023+x);
int(integrand,x);
Download reproducible_server_crash_test.mw
For reference, another software give this result instantly and with no crash:
My PC is windows 10, with 128 GB RAM.
May be someone could find what causes this new internal error in Maple 2024.
I did report it already to Maplesoft. It does not happen in Maple 2023. Attached both worksheets.
integrand:=(d*x)^m/(a+b*arctanh(c*x^n))^2;
int(integrand,x);
Error, (in int/gparse/gmon) too many levels of recursion
Download int_gparse_gmon_error_maple_2024_march_27_2024.mw
130032
int(integrand,x);
2*x*(c*exp(n*ln(x))-1)*(c*exp(n*ln(x))+1)*exp(m*(ln(d)+ln(x)-((1/2)*I)*Pi*csgn(I*d*x)*(-csgn(I*d*x)+csgn(I*d))*(-csgn(I*d*x)+csgn(I*x))))/(b*c*n*exp(n*ln(x))*(-b*ln(1-c*exp(n*ln(x)))+b*ln(c*exp(n*ln(x))+1)+2*a))+int(-2*exp(m*(ln(d)+ln(x)-((1/2)*I)*Pi*csgn(I*d*x)*(-csgn(I*d*x)+csgn(I*d))*(-csgn(I*d*x)+csgn(I*x))))*(c^2*m*(exp(n*ln(x)))^2+c^2*n*(exp(n*ln(x)))^2+(exp(n*ln(x)))^2*c^2-m+n-1)/(b*c*n*exp(n*ln(x))*(-b*ln(1-c*exp(n*ln(x)))+b*ln(c*exp(n*ln(x))+1)+2*a)), x)
Download int_gparse_gmon_NO_error_maple_2023.mw
I setup my package to display the a message when it is loaded. It is quiet convienent but I don't need it all the time. Obviously I can "#" in the code to hide it premanently. I was wondering if there is away to optionally turn it off/on. Something along the lines.
with(RationalTrigonometry,false) or with(RationalTrigonometry)[false]....
Or put something in the .ini flie to set the default behaviour.
restart:with(RationalTrigonometry):
 "Default global settings:-
     GeomClr = "Blue",
      Prntmsg = true,
       Prjpsn = 3 can be set to 1,
      Normalgpt = 1 or set to 0,
    Metric is a 3 x3 symmetric matrix defaults to the Identity
    matrix "
For a lesson I'm preparing, I want to illustrate some probability concepts using Maple.
In particular, I need to use the fact that the Expectation operator(let say the Mean operator) is a linear operator with respect to random variables.
However, I don't want to particularize my demonstration by using this or that statistical distribution but simply the notion of random variable.
I have therefore created a specific Distribution named  MinimalAbstractDistribution in which only the mean and variance are defined.
When Statistics:-Mean is applied to the expression (A*p+q) where p and q are names and A is a random variable with distribution MinimalAbstractDistribution, linearity is effectively used.
But not when it is applied to A/p or A-q.
Why that?
Is there a way of defining a statistical distribution so that Mean behaves as expected?
(You will easily understand that no workaround of the form
Mean(A+q);
eval(%, q=-q);
# or
add(Mean~([op(A-q)]))
can be accepted in a lesson).
Thanks for your attention
with(Statistics):
MinimalAbstractDistribution := proc(i)
  Distribution(Mean=mu[i], Variance=sigma[i]^2)
A := RandomVariable(MinimalAbstractDistribution(1))
_R
[Mean, Variance](A);
[mu[1], sigma[1]^2]
Mean(p*A+q);
Mean(p*(A+q))
p*mu[1]+q
p*(mu[1]+q)
# But
Mean(A-q);
Mean(A/p)
FAIL
FAIL
Download Mean_operator.mw
How do we define a matrix or a vector of the partial differential operator?
Both uses of evalf
evalf(Pi, 20);
evalf[20](Pi);
work, but only the latter is documented. Is there a reason behind (maybe historical)? Any reason not to use evalf(...,n) any more? I am also reluctant to update old worksheets if there is no need for the indexed version.
Suppose I have, a row vector  R = [R1 , R2  , R] and a column vector C =  [C1 , C2  , C]. I need a multiplication like as follows
RC = [ R1 [C], R2[C], R3 [C]  ], so that RC will be a 3/3 matrix.
hi   is there any method to tell maple do a paticular auto substitution  ,see picture  below.
i hope  this substitution can be done automatically , instead of using algsubs(signum()^2=1,eq(2))
i have tried simplify()  , but did not work.
thanks!
Recognizing Handwritten Digits with Machine Learning
Introduction
Using the DeepLearning  package, this application trains a neural network to recognize the numbers in images of handwritten digits. The trained neural network is then applied to a number of test images.
The training and testing images are a very small subset of the MNIST database of handwritten digits; these consist of 28 x 28 pixel images of a handwritten digit, ranging from 0 to 9. A sample image for the digit zero is .
Ultimately, this application generates an vector of weights for each digit; think of weights as a marking grid for a multiple choice exam. When reshaped into a matrix, a weight vector for the digit 0 might look like this.
When attempting to recognize the number in an image
If a pixel with a high intensity lands in the red area, the evidence is high that the handwritten digit is zero
Conversely, if a pixel with a high intensity lands in the blue area, the evidence is low that the handwritten digit is zero
The DeepLearning package is a partial interface to Tensorflow, an open-source machine learning framework. To learn about the machine learning techniques used in this application, please consult these references (the next section, however, features a brief overview)
https://www.tensorflow.org/versions/r1.1/get_started/mnist/beginners
https://www.oreilly.com/learning/not-another-mnist-tutorial-with-tensorflow
Notes
Introduction
We first build a computational (or dataflow) graph. Then, we create a Tensorflow session to run the graph.
Tensorflow computations involve tensors; think of tensors as multidimensional arrays.
Images
Each 28 x 28 image is flattened into a list with 784 elements.
Once flattened, the training images are stored in a tensor x, with shape of [none, 784]. The first index is the number of training images ("none" means that we can use an arbitrary number of training images).
Labels
Each training image is associated with a label.
Labels are a 10-element list, where each element is either 0 or 1
All elements apart from one are zero
The location of the non-zero element is the "value" of the image
So for an image that displays the digit 5, the label is [ 0,0,0,0,0,1,0,0,0,0]. This is known as a one-hot encoding.
All the labels are stored in a tensor y_ with a shape of [none, 10].
Training
The neural network is trained via multinomial logistic regression (also known as softmax).
Step 1
Calculate the evidence that each image is in a selected class. Do this by performing a weighted sum of the pixel intensity for the flattened image.
e__i = sum(`W__i,j`*x__j, j = 1 .. 784)+b__i
where
Wi,j and bi are the weight and the bias for digit i and pixel j. Think of W as a matrix with 784 rows (one for each pixel) and 10 columns (one for each digit), and b is a vector with 10 columns (one for each digit)
xj is the intensity of pixel j
Step 2
Normalize the evidence into a vector of probabilities with softmax.
y__i = softmax*e__i and softmax*e__i = e^x__i/(sum(e^x__j, j = 1 .. 784))
Step 3
For each image, calculate the cross-entropy of the vector of predicted probabilities and the actual probabilities (i.e the labels)
H__y_(y) = -(sum(y_[i]*log(y__i), i = 1 .. 10))
where
y_ is the true distribution of probabilities (i.e. the one-hot encoded label)
y is the predicted distribution of probabilities
The smaller the cross entropy, the better the prediction.
Step 4
The mean cross-entropy across all training images is then minimized to find the optimum values of W and b
Testing
For each test image, we will generate 10 ordered probabilities that sum to 1. The location of the highest probability is the predicted value of the digit.
Miscellaneous
This application consists of
this worksheet
and a very small subset of images from the MNIST handwritten digit database
in a single zip file. The images are stored in folders; the folders should be extracted to the location as this worksheet.
Load Packages and Define Parameters
with(DeepLearning):
with(DocumentTools):
with(DocumentTools:-Layout):
with(ImageTools):
LEARNING_RATE := 0.01:
TRAIN_STEPS   := 40:
Number of training images to load for each digit (maximum of 100)
N := 22:
Number of labels (there are 10 digits, so this is always 10)
L := 10:
Number of test images
T := 50:
Import Training Images and Generate Labels
Import the training images, where images[n] is a list containing the images for digit n.
path := "C:/Users/Wilfried/Documents/Maple/Examples/ML/":
for j from 0 to L - 1 do
    images[j] := [seq(Import(cat(path, j, "/", j, " (", i, ").PNG")), i = 1 .. N)];
Generate the labels for digit j, where label[n] is the label for image[n].
   labels[j] := ListTools:-Rotate~([[1,0,0,0,0,0,0,0,0,0]$N],-j)[]:
Display training images
Embed([seq(images[i-1], i = 1 .. L)]);
Training
Flatten and collect images
x_train := convert~([seq(images[i - 1][], i = 1 .. L)], list):
Collect labels
y_train := [seq(labels[i - 1], i = 1 .. L)]:
Define placeholders x  and y to feed the training images and labels into
SetEagerExecution(false):
x  := Placeholder(float[4], [none, 784]):
y_ := Placeholder(float[4], [none, L]):
Define weights and bias
W := Variable(Array(1 .. 784, 1 .. L), datatype = float[4]):
b := Variable(Array(1 .. L), datatype = float[4]):
Define the classifier using multinomial logistic regression
y := SoftMax(x.W + b):
Define the cross-entropy (i.e. the cost function)
cross_entropy := ReduceMean(-ReduceSum(y_ * log(y), reduction_indicies = [1])):
Get a Tensorflow session
sess := GetDefaultSession():
Initialize the variables
init := VariablesInitializer():
sess:-Run(init):
Define the optimizer to minimize the cross entropy
optimizer := Optimizer(GradientDescent(LEARNING_RATE)):
training  := optimizer:-Minimize(cross_entropy):
Repeat the optimizer many times
for i from 1 to TRAIN_STEPS do
   sess:-Run(training, {x in x_train, y_ in y_train}):
   if i mod 200 = 0 then
      print(cat("loss = ", sess:-Run(cross_entropy, {x in x_train, y_ in y_train})));
   end if:
Import Test Images and Predict Numbers
Randomize the order of the test images.
i_rand := combinat:-randperm([seq(i, i = 1 .. 100)]);
[13, 71, 67, 52, 81, 37, 46, 6, 39, 77, 36, 21, 49, 95, 62, 26, 44, 65, 90, 72, 70, 5, 4, 54, 31, 23, 63, 18, 22, 38, 27, 53, 50, 17, 47, 51, 78, 79, 92, 20, 28, 34, 60, 80, 58, 87, 86, 93, 84, 12, 59, 98, 97, 56, 75, 10, 29, 61, 7, 66, 100, 42, 91, 43, 89, 76, 11, 74, 8, 96, 64, 94, 68, 48, 33, 24, 40, 30, 57, 73, 99, 15, 19, 1, 3, 41, 85, 83, 35, 14, 45, 2, 88, 9, 16, 32, 69, 25, 55, 82]
(6.1)
Load and flatten test images.
path:= "C:/Users/Wilfried/Documents/Maple/Examples/ML/test_images":
x_test_images := [seq(Import(cat(path,"/","test (", i, ").png")), i in i_rand[1 .. T])]:
x_train:= convert~(x_test_images, list):
For each test image, generate 10 probabilities that the digit is a number from 1 to 10
pred := sess:-Run(y, {x in x_train})
_rtable[36893490552617628484]
(6.2)
For each test image, find the predicted digit associated with the greatest probability
predList := seq( max[index]( pred[i, ..] ) - 1, i = 1 .. T )
9, 1, 0, 5, 3, 4, 5, 2, 8, 3, 8, 2, 5, 2, 4, 6, 8, 4, 1, 1, 1, 6, 7, 5, 7, 7, 4, 7, 7, 8, 7, 5, 5, 7, 5, 5, 3, 3, 0, 6, 7, 7, 4, 3, 4, 0, 3, 2, 3, 7
(6.3)
L := []; for i to 50 do L := [op(L), max(pred[i])] end do
Val:=Vector(10,0):
Val_mean:=Vector(10,0):
for k from 1 to 10 do:
  L1:=[]:
 for i from 1 to 50 do:
  if predList[i]=k-1 then L1:=[op(L1),L[i]] end if:
 Val(k):=evalf(L1,3):
 Val_mean(k):=Statistics:-Mean(Array(L1)):
Val,Val_mean
Vector[column](%id = 36893490552619428548), Vector[column](%id = 36893490552619428668)
(6.4)
Consider the first test image
Embed(x_test_images[1])
The ten probabilities associated with this image are
pred[1, ..]
Vector[row](10, {(1) = 0.1176837849925505e-4, (2) = .3597199022769928, (3) = 0.8788742707110941e-3, (4) = 0.14628235250711441e-1, (5) = .16885940730571747, (6) = 0.10462711565196514e-1, (7) = 0.16997022554278374e-1, (8) = 0.5874206870794296e-1, (9) = 0.20698020234704018e-2, (10) = .3676302134990692})
(6.5)
Confirm that the probabilities add up to 1
add(i, i in pred[1, ..])
HFloat(1.0000000058325895)
(6.6)
The maximum probability occurs at this index
maxProbInd := max[index](pred[1, ..])
10
(6.7)
Hence the predicted number is
maxProbInd - 1
9
(6.8)
Embed(x_test_images[1 .. 25])
Embed(x_test_images[26 .. 50])
We now display all the predictions
T1 := Table(Row(seq(predList[k],k = 1.. 25)),Row( seq(predList[k],k = 26 .. 50 ))
InsertContent(Worksheet(T1)):
Visualize Weights
I have problmes running the file with Maple 2024. It runs fine with Maple 2020.2 (execpt the very last part, which is not essential). The problem occurs at the SoftMax command, even if I use Softmax. It seems to be a Python conersion problem in Maple 2024. Please let me know what the remidy is. You need to modify the data path because it is set to my computer.
Wilfried
Download HDR.mw
Can I draw such figures using Maple?
If possible please guide how I can do it.
How to evaluate the right eigenvector of a given matrix in maple?
This is just cosmotics, but it looks ugly for me. For some reason Maple converts exp(2*a) to (exp(a))^2 under certain operations such as expand
expr:=exp(2*a);
expand(%);
simplify(%);
expand(%)
This happens in worksheet under typesetting level extends or standard.
Any specific reason why Maple likes to rewrite exp(2*a) as (exp(a))^2  and is there a way to tell it not to do that?
ps. it is little more than cosmotic actually, it affects the Latex generated
latex(expr)
{\mathrm e}^{2 a}
latex(expand(expr))
\left({\mathrm e}^{a}\right)^{2}
Maple 2024 on windows 10
First 118 119 120 121 122 123 124 Last Page 120 of 2427
