I run the following command.
$ maple2022/bin/maple -q problem.mpl
where problem.mpl is the following:
with(Student[Calculus1]):
ShowSolution(Diff(ln(x),x));
I get the following output.
Differentiation Steps
    Diff(ln(x),x)
▫    1. Apply the natural logarithm rule
        ◦ Recall the definition of the natural logarithm rule
        Diff(ln(x),x) = x^(-1)
    This gives:
    x^(-1)
I want the solver to use 1/x instead of x^(-1) in the output. How can I achieve this?
P.S. I require the output to be parsable, so using output=print to show fractions in a multi-line fashion is not a solution for me.
I have this very simple intergral
((Int(sin(m*Pi*y/a), y = 0 .. b))
I want to solve it when m is even then when it is odd. Of course, a and b are real positive. Then I will do the same with the other side of the integral.
Int(sin(n*Pi*y/a)*sin(m*Pi*y/a), y = 0 .. b)
Thank you in advance.
Mario
document:Laplace_Problem.mw
I've been working on a file in Maple, and saved it yesterday - but now I am not able to open it, as it is corrupted. I have been able to find the back up file, HOWEVER I am not able to load half of the file as Maple comes up with a "there was a problem loading your file....". Is there anything I can do to repair the back up file?
Any help is greatly appreciated!
Back up file is here: C_Users_jonas_OneDrive_Skrivebord_Mat_B-A_Hjemmeopgavesæt_Opgavesæt_1115_MAS_-_Kopi.mw
Is it possible to graph multiple Niquist plots using DynamicSystems:-NiquistPlot() ? All my attemps have failed.
How I can ontain results without Rootof !!
help.mw
EQ1 := c[11]*exp(-n*Pi*a/b)+c[12]*exp(n*Pi*a/b) = 0
EQ2 := c[11]*n*Pi/b-c[12]*n*Pi/b+b^2*Q[0, 1]*sin(n*Pi*y[0, 1]/b)*(n*Pi*exp(-n*Pi*x[0, 1]/b)/b+n*Pi*exp(n*Pi*x[0, 1]/b)/b)/(n*Pi) = c[21]*n*Pi/b-c[22]*n*Pi/b
c[21] := -b^2*Q[0, 2]*sin(n*Pi*y[0, 2]/b)*exp(-n*Pi*x[0, 2]/b)/(n*Pi)
EQ3 := c[11]+c[12]+b^2*Q[0, 1]*sin(n*Pi*y[0, 1]/b)*(exp(-n*Pi*x[0, 1]/b)-exp(n*Pi*x[0, 1]/b))/(n*Pi) = lambda.(c[21]+c[22])
c[11]+c[12]+b^2*Q[0, 1]*sin(n*Pi*y[0, 1]/b)*(exp(-n*Pi*x[0, 1]/b)-exp(n*Pi*x[0, 1]/b))/(n*Pi) = lambda.(-b^2*Q[0, 2]*sin(n*Pi*y[0, 2]/b)*exp(-n*Pi*x[0, 2]/b)/(n*Pi)+c[22])
solve({EQ1, EQ2, EQ3}, {c[11], c[12], c[22]})
{c[11] = RootOf(exp(-n*Pi*x[0, 1]/b)*exp(n*Pi*a/b)*b^2*sin(n*Pi*y[0, 1]/b)*Q[0, 1]-exp(n*Pi*x[0, 1]/b)*exp(n*Pi*a/b)*b^2*sin(n*Pi*y[0, 1]/b)*Q[0, 1]-_Z*n*Pi*exp(-n*Pi*a/b)+_Z*n*Pi*exp(n*Pi*a/b)+(lambda.((exp(-n*Pi*x[0, 1]/b)*exp(n*Pi*a/b)*b^2*sin(n*Pi*y[0, 1]/b)*Q[0, 1]+exp(n*Pi*x[0, 1]/b)*exp(n*Pi*a/b)*b^2*sin(n*Pi*y[0, 1]/b)*Q[0, 1]+2*b^2*Q[0, 2]*sin(n*Pi*y[0, 2]/b)*exp(-n*Pi*x[0, 2]/b)*exp(n*Pi*a/b)+_Z*n*Pi*exp(-n*Pi*a/b)+_Z*n*Pi*exp(n*Pi*a/b))/(n*exp(n*Pi*a/b))))*n*exp(n*Pi*a/b)), c[12] = -RootOf(exp(-n*Pi*x[0, 1]/b)*exp(n*Pi*a/b)*b^2*sin(n*Pi*y[0, 1]/b)*Q[0, 1]-exp(n*Pi*x[0, 1]/b)*exp(n*Pi*a/b)*b^2*sin(n*Pi*y[0, 1]/b)*Q[0, 1]-_Z*n*Pi*exp(-n*Pi*a/b)+_Z*n*Pi*exp(n*Pi*a/b)+(lambda.((exp(-n*Pi*x[0, 1]/b)*exp(n*Pi*a/b)*b^2*sin(n*Pi*y[0, 1]/b)*Q[0, 1]+exp(n*Pi*x[0, 1]/b)*exp(n*Pi*a/b)*b^2*sin(n*Pi*y[0, 1]/b)*Q[0, 1]+2*b^2*Q[0, 2]*sin(n*Pi*y[0, 2]/b)*exp(-n*Pi*x[0, 2]/b)*exp(n*Pi*a/b)+_Z*n*Pi*exp(-n*Pi*a/b)+_Z*n*Pi*exp(n*Pi*a/b))/(n*exp(n*Pi*a/b))))*n*exp(n*Pi*a/b))*exp(-n*Pi*a/b)/exp(n*Pi*a/b), c[22] = -(exp(-n*Pi*x[0, 1]/b)*exp(n*Pi*a/b)*b^2*sin(n*Pi*y[0, 1]/b)*Q[0, 1]+exp(n*Pi*x[0, 1]/b)*exp(n*Pi*a/b)*b^2*sin(n*Pi*y[0, 1]/b)*Q[0, 1]+b^2*Q[0, 2]*sin(n*Pi*y[0, 2]/b)*exp(-n*Pi*x[0, 2]/b)*exp(n*Pi*a/b)+RootOf(exp(-n*Pi*x[0, 1]/b)*exp(n*Pi*a/b)*b^2*sin(n*Pi*y[0, 1]/b)*Q[0, 1]-exp(n*Pi*x[0, 1]/b)*exp(n*Pi*a/b)*b^2*sin(n*Pi*y[0, 1]/b)*Q[0, 1]-_Z*n*Pi*exp(-n*Pi*a/b)+_Z*n*Pi*exp(n*Pi*a/b)+(lambda.((exp(-n*Pi*x[0, 1]/b)*exp(n*Pi*a/b)*b^2*sin(n*Pi*y[0, 1]/b)*Q[0, 1]+exp(n*Pi*x[0, 1]/b)*exp(n*Pi*a/b)*b^2*sin(n*Pi*y[0, 1]/b)*Q[0, 1]+2*b^2*Q[0, 2]*sin(n*Pi*y[0, 2]/b)*exp(-n*Pi*x[0, 2]/b)*exp(n*Pi*a/b)+_Z*n*Pi*exp(-n*Pi*a/b)+_Z*n*Pi*exp(n*Pi*a/b))/(n*exp(n*Pi*a/b))))*n*exp(n*Pi*a/b))*Pi*n*exp(-n*Pi*a/b)+RootOf(exp(-n*Pi*x[0, 1]/b)*exp(n*Pi*a/b)*b^2*sin(n*Pi*y[0, 1]/b)*Q[0, 1]-exp(n*Pi*x[0, 1]/b)*exp(n*Pi*a/b)*b^2*sin(n*Pi*y[0, 1]/b)*Q[0, 1]-_Z*n*Pi*exp(-n*Pi*a/b)+_Z*n*Pi*exp(n*Pi*a/b)+(lambda.((exp(-n*Pi*x[0, 1]/b)*exp(n*Pi*a/b)*b^2*sin(n*Pi*y[0, 1]/b)*Q[0, 1]+exp(n*Pi*x[0, 1]/b)*exp(n*Pi*a/b)*b^2*sin(n*Pi*y[0, 1]/b)*Q[0, 1]+2*b^2*Q[0, 2]*sin(n*Pi*y[0, 2]/b)*exp(-n*Pi*x[0, 2]/b)*exp(n*Pi*a/b)+_Z*n*Pi*exp(-n*Pi*a/b)+_Z*n*Pi*exp(n*Pi*a/b))/(n*exp(n*Pi*a/b))))*n*exp(n*Pi*a/b))*Pi*n*exp(n*Pi*a/b))/(Pi*n*exp(n*Pi*a/b))}
Download help.mw
Can i use Maple to do satellite image classification . by implement the satellite image so the software will do the math processing ?
I want to plot the Tsai Wu failure envelope for a given
composite. The Tsai Wu failure criterion (for a pure biaxial
state of stress) is given by:
F1*x+F2*y+F11*x^2+F22*y^2+F12*x*y=1
can someone help me?please.
Can Maple carry around an unevaluated/inert  Matrix-Vector product(A matrix product without executing the matrix multiplication)? See Maple sheet.
inert_matrix_products.mw
with(LinearAlgebra)
NULLNULL
Can Maple carry around an unevaluated/inert explicit Matrix-Vector product?
Define a matrix K and vector U as:
U := `<,>`(u1, u2)
Vector[column](%id = 36893490583464982996)
K := Matrix(2, 2, symbol = k)
Matrix(%id = 36893490583464975884)
I can take their product using MatrixVectorMultiply( ) I get,
MatrixVectorMultiply(K, U)
Vector[column](%id = 36893490583464964812)
however output I am really looking for is
(Matrix(2, 2, {(1, 1) = k[1, 1], (1, 2) = k[1, 2], (2, 1) = k[2, 1], (2, 2) = k[2, 2]})).(Vector(2, {(1) = u1, (2) = u2}))
In the later case, K.U is still a product however the actual matrix multiplication is not carried out. Sure, eventually I will want to evaluate the matrix-vector product but sometimes when setting up a problem I want to look at the explicit matrix equation before any explicit matrix multiplication is carried out.NULL
Here I show some ideas that don't work but may give a sense of what I am going for. I am essentially trying to mute the computation of the product while keeping the elements of the product together for further substitutions elsewhere. This there a standardized way to complish this? Or do I have to write my own procedure for something like this?
`&MatrixVectorMultiply`(K, U)
`&MatrixVectorMultiply`(Matrix(%id = 36893490583464975884), Vector[column](%id = 36893490583464982996))
%MatrixVectorMultiply(K, U)
%MatrixVectorMultiply(Matrix(%id = 36893490583464975884), Vector[column](%id = 36893490583464982996))
`&.`(K, U)
`&.`(Matrix(%id = 36893490583464975884), Vector[column](%id = 36893490583464982996))
K*%.U
`&.`(Matrix(%id = 36893490583464975884), Vector[column](%id = 36893490583464982996))*Matrix(%id = 36893490583464939756).Vector[column](%id = 36893490583464982996)
NULLNULL
Download inert_matrix_products.mw
I'm having trouble performing a direct operation, involving DotProduct, in the piecewise function. Attached is a document. I appreciate any contribution.
Oliveira
Example2.mw
I am new to Maple and I couldn't really find anything about this problem. Why doesn't Maple automatically simplify the last expression in the following? (see for example the first and last terms, as well as other terms)
total := (((((D^2/(alpha^2*mu^2) + D^2*exp(2*(-t + t1)*alpha*mu)/(alpha^2*mu^2)) + D^2*exp(2*(-t + t1)*alpha*mu)/(alpha^2*mu^2)) + D1*D/((alpha*mu*tau0 + 1)*alpha^2*mu^2) - (-alpha*mu*tau0*exp((-t + t1)*(alpha*mu*tau0 + 1)/tau0) + exp(2*(-t + t1)*alpha*mu))*D*D1/(mu^2*alpha^2*(alpha^2*mu^2*tau0^2 - 1)) + (alpha*mu*tau0*exp((-t + t1)*(alpha*mu*tau0 + 1)/tau0) - exp(2*(-t + t1)*alpha*mu))*D1*D/(alpha^2*mu^2*(alpha^2*mu^2*tau0^2 - 1))) - (-alpha*mu*tau0*exp((-t + t1)*(alpha*mu*tau0 + 1)/tau0) + exp(2*(-t + t1)*alpha*mu))*D*D1/(mu^2*alpha^2*(alpha^2*mu^2*tau0^2 - 1))) + (alpha*mu*tau0*exp((-t + t1)*(alpha*mu*tau0 + 1)/tau0) - exp(2*(-t + t1)*alpha*mu))*D1*D/(alpha^2*mu^2*(alpha^2*mu^2*tau0^2 - 1)) + D1*D/((alpha*mu*tau0 + 1)*alpha^2*mu^2) + D1^2/((alpha*mu*tau0 + 1)^2*alpha^2*mu^2) - (alpha*mu*tau0*exp(-(-t + t1)*(alpha*mu*tau0 - 1)/tau0) + alpha*mu*tau0*exp((-t + t1)*(alpha*mu*tau0 - 1)/tau0) - alpha^2*mu^2*tau0^2 - 1)*D1^2/(alpha^2*mu^2*(alpha^4*mu^4*tau0^4 - 2*alpha^2*mu^2*tau0^2 + 1))) - (alpha*mu*tau0*exp(-(-t + t1)*(alpha*mu*tau0 - 1)/tau0) + alpha*mu*tau0*exp((-t + t1)*(alpha*mu*tau0 - 1)/tau0) - alpha^2*mu^2*tau0^2 - 1)*D1^2/(alpha^2*mu^2*(alpha^4*mu^4*tau0^4 - 2*alpha^2*mu^2*tau0^2 + 1))
D1^2/((alpha*mu*tau0 + 1)^2*alpha^2*mu^2) + 2*D1*D/((alpha*mu*tau0 + 1)*alpha^2*mu^2) + D^2/(alpha^2*mu^2)
r2r2 := %;
total - r2r2;
((((((D^2/(alpha^2*mu^2) + D^2*exp(2*(-t + t1)*alpha*mu)/(alpha^2*mu^2)) + D^2*exp(2*(-t + t1)*alpha*mu)/(alpha^2*mu^2)) + D1*D/((alpha*mu*tau0 + 1)*alpha^2*mu^2) - (-alpha*mu*tau0*exp((-t + t1)*(alpha*mu*tau0 + 1)/tau0) + exp(2*(-t + t1)*alpha*mu))*D*D1/(mu^2*alpha^2*(alpha^2*mu^2*tau0^2 - 1)) + (alpha*mu*tau0*exp((-t + t1)*(alpha*mu*tau0 + 1)/tau0) - exp(2*(-t + t1)*alpha*mu))*D1*D/(alpha^2*mu^2*(alpha^2*mu^2*tau0^2 - 1))) - (-alpha*mu*tau0*exp((-t + t1)*(alpha*mu*tau0 + 1)/tau0) + exp(2*(-t + t1)*alpha*mu))*D*D1/(mu^2*alpha^2*(alpha^2*mu^2*tau0^2 - 1))) + (alpha*mu*tau0*exp((-t + t1)*(alpha*mu*tau0 + 1)/tau0) - exp(2*(-t + t1)*alpha*mu))*D1*D/(alpha^2*mu^2*(alpha^2*mu^2*tau0^2 - 1)) + D1*D/((alpha*mu*tau0 + 1)*alpha^2*mu^2) + D1^2/((alpha*mu*tau0 + 1)^2*alpha^2*mu^2) - (alpha*mu*tau0*exp(-(-t + t1)*(alpha*mu*tau0 - 1)/tau0) + alpha*mu*tau0*exp((-t + t1)*(alpha*mu*tau0 - 1)/tau0) - alpha^2*mu^2*tau0^2 - 1)*D1^2/(alpha^2*mu^2*(alpha^4*mu^4*tau0^4 - 2*alpha^2*mu^2*tau0^2 + 1))) - (alpha*mu*tau0*exp(-(-t + t1)*(alpha*mu*tau0 - 1)/tau0) + alpha*mu*tau0*exp((-t + t1)*(alpha*mu*tau0 - 1)/tau0) - alpha^2*mu^2*tau0^2 - 1)*D1^2/(alpha^2*mu^2*(alpha^4*mu^4*tau0^4 - 2*alpha^2*mu^2*tau0^2 + 1))) - D1^2/((alpha*mu*tau0 + 1)^2*alpha^2*mu^2) - 2*D1*D/((alpha*mu*tau0 + 1)*alpha^2*mu^2) - D^2/(alpha^2*mu^2)
couldnt insert "r2r2" properly...
problemfilepdsolve.mw
eq1 := diff(p(x, t), x)-p(x, t)*(1/(p(x, t)^2*q(x, t)^(1/3)))
diff(p(x, t), x)-1/(p(x, t)*q(x, t)^(1/3))
eq2 := diff(q(x, t), x)-(-3*q(x, t))*(1/(p(x, t)^2*q(x, t)^(1/3)))
diff(q(x, t), x)+3*q(x, t)^(2/3)/p(x, t)^2
pdsolve({eq1, eq2})
Error, (in pdsolve/sys) found the element '_F2' repeated in the indication of blocks variables
eq3 := diff(p(x), x)-p(x)*(1/(p(x)^2*q(x)^(1/3)))
diff(p(x), x)-1/(p(x)*q(x)^(1/3))
eq4 := diff(q(x), x)-(-3*q(x))*(1/(p(x)^2*q(x)^(1/3)))
diff(q(x), x)+3*q(x)^(2/3)/p(x)^2
dsolve({eq3, eq4})
[{q(x) = -27/(_C1*x+_C2)^3}, {p(x) = (-3*(diff(q(x), x))*q(x)^(2/3))^(1/2)/(diff(q(x), x)), p(x) = -(-3*(diff(q(x), x))*q(x)^(2/3))^(1/2)/(diff(q(x), x))}]
eq5 := diff(p(x, t), x)-x = 0
pdsolve(eq5)
p(x, t) = (1/2)*x^2+_F1(t)
eq6 := diff(p(x), x)-x = 0
diff(p(x), x)-x = 0
dsolve(eq6)
p(x) = (1/2)*x^2+_C1
Help me in finding the solution of system eq1 and eq2.
Download problemfilepdsolve.mw
Hope the resolution of the images which come via Plot3d and plot commands are atleast 300 dpi
If not how to make them
I previously asked the following question, and a primes member dharr  provided a perfect answer. The question I asked today is slightly different.
An edge cut of a graph G induced by a partition of G's vertices into sets X and Y is the set of all edges with one endpoint in X and another endpoint in Y.
An edge separator is a set of edges whose removal will increase the number of connected components in the graph.
Note that these are two distinct concepts and cannot be considered equivalent.
An edge separator is not necessarily an edge cut. For example, for the complete bipartite graph K3,3, a set of any seven edges of K3,3 is an edge separator, but a set of any seven edges of K3,3 is not an edge cut.
It is easy to determine whether a set of edges is an edge separator.
with(GraphTheory):
with(combinat):
G:=CompleteGraph(3,3);
edge:=choose(Edges(G), 7):
seq(nops(ConnectedComponents(DeleteEdge(G,s,inplace= false))),s in edge)
4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4
For another exmaple,
In  the left  figure,  the brown edges highlighted represent an edge-separating set, but it is not an edge cut. The set of brown edges on the right is an edge cut.
But how to determine if a set of edges is an edge cut of a graph? I don't have a good idea yet, but I have a rough idea which is to color the set of vertex-ends of edges under consideration and then see if a partition as defined by the edge cut can be found.
I am converting some code from Mathematica. In it there is this solution
eqs={2c2+c0==1,6c3+2c1==2,3c2+12c4==1};
FindInstance[eqs,{c0,c1,c2,c3,c4}]
Which gives
{{c0 -> 0, c1 -> 0, c2 -> 1/2, c3 -> 1/3, c4 -> -(1/24)}}
Maple's solve gives
eqs := [2*c2 + c0 = 1, 6*c3 + 2*c1 = 2, 3*c2 + 12*c4 = 1];
sol:=solve(eqs, {c0, c1, c2, c3, c4})
Gives
sol := {c0 = 1/3 + 8*c4, c1 = -3*c3 + 1, c2 = 1/3 - 4*c4, c3 = c3, c4 = c4}
I know that both are correct solutions. But I'am asking if there is a command or an option I overlooked that will generate the same result as the above from FindInstance, which will make it easier for me.
May be there is another solver package or command I could try?
I am not sure what algorithm FindInstance uses. The documentation page does not say.
First 227 228 229 230 231 232 233 Last Page 229 of 2428
