Is there a way to execute an entire worksheet for a list of values of a parameter.
Sometimes executing in the standard loop can be cumbersome given you have to add catch statements for errors to prevent the loop from stopping.
I'm not able to find a way to bring an equation into it's "polynomial" form:
I'd like this expression in the form of:
c1*v^3+c2*v^2+c1*v+c0 = 0
where c1...c4 are my coefficients
How can I do that?
Hello guys
I'm having trouble converting the RootOf function. Attached is a simple notebook.
Sincerely,
Oliveira
Example.mw
Dear Maple Users:
Could you help in the following question?
How do I use a symbol as a subscript, e.g.  A_*, to label an axis?
X := vector([seq(x, x = 1 .. 5)]);
Y := vector([seq(x, x = 6 .. 10)]);
X[1];
Y[1];
Yfactor := evalf(X[`1`])/Y[`1`];
evalf(Yfactor);
                      X := [1, 2, 3, 4, 5]
                     Y := [6, 7, 8, 9, 10]
                                         X[1]
                        Yfactor := -------
                                         Y[1]
                              X[1]
                              Y[1]
m := 1;
Yfactor := X[m]/Y[m];
evalf(Yfactor);
                             m := 1
                          Yfactor := ---
                                           6
                          0.1666666667
hi guys,
suppose we have general metric form in 4-D. I want to calculate Covariant derivative of Riemann, Ricci and Weyl tensors.
please help me.
with best,
I dont know why I could not solve this problem.
I have attached my worksheet.
Please anyone help me to get solution to this problem.
Thank you so much
fypppp.mw
DLMF offers different encodings for mathematical expressions. Example:
I was wondering if TeX or pMML (never seen before)  can be imported into Maple and subsequently be used as  Maple Input.
When taking notes I sometimes use the palette to insert a matrix into a worksheet. When I do this, the main aspect that is useful to me is being able to visualize matrix expressions as I would write them.
I would like to do the same but for determinants of matrices. Is there a way to get almost the same thing as with the matrix palette, but with vertical bars denoting a determinant rather than the brackets used for matrices?
How do we compute integrals of functions or expressions that have units attached?
For example
v__1 := proc (t) options operator, arrow; 3*Unit('m'/'s') end proc
v__2 := 4*Unit('m'/'s')
4*Units:-Unit(m/s)
s__1 := int(v__1(t), t = 0 .. 5)
15*Units:-Unit(m/s)
s__2 := int(v__2, t = 0 .. 5)
20*Units:-Unit(m/s)
The results of the integrals have the wrong units.
Download integration_with_units.mw
I have X=+-1,
and I want to calculate X^n.
 Thank's
Dear members of the forum, please tell me if it is possible to calculate the series presented below by Maple 2022. As far as I understand, first you need to calculate the inner and then the outer sum, but I don’t know how to do this with the help of the program, this series does not converge, as it seems to me, but I can be wrong, if the series diverges, then I need to show it.
Sorry for my ignorance, but maybe I wrong apply such commands for calculation this sums:
Sum(F, a = 1 .. infinity, b = 1 .. infinity) = DefiniteSummation(F, a = 1 .. infinity, b = 1 .. infinity)
I understand, that Sum () not be able to recive more than one args, but I don't understand how to make this calculation...
Any idea? Thanks for advices and help!
I have an executable program which I have generated with Fortran. Is it possible to run such a program from Maple? It sounds a bit weird but that would simplify my computation, since I would not need to use scripts in Linux. Thank you very much.
Cheers.
Let's say we have four equations and four unknowns and we use solve to find a solution.
The return value of solve is a set.
Here is an example
solve({T__1 = m__1*a, a = R*alpha, -R*T__1+R*T__2 = I__s*a/R, g*m__2-T__2 = m__2*a}, {T__1, T__2, a, alpha})
{T__1 = R^2*g*m__2*m__1/(R^2*m__1+R^2*m__2+I__s), T__2 = m__2*g*(R^2*m__1+I__s)/(R^2*m__1+R^2*m__2+I__s), a = R^2*g*m__2/(R^2*m__1+R^2*m__2+I__s), alpha = R*g*m__2/(R^2*m__1+R^2*m__2+I__s)}
If we want to make the four expressions above procedures, the manual way is to basically copy the right-hand side of each expression and then write
T__1 := (R,m__1, m__2, g, I__s) -> ...
T__2 := (R,m__1, m__2, g, I__s) -> ...
a := (R,m__1, m__2, g, I__s) -> ...
alpha := (R,m__1, m__2, g, I__s) -> ...
Is there a way to do this automatically from the return value of solve?
If the return value were a list, I would use something like
T__1 := unapply(result[1], R, m__1, m__2, g, I__s)
T__2 := unapply(result[2], R, m__1, m__2, g, I__s)
a := unapply(result[3], R, m__1, m__2, g, I__s)
alpha := unapply(result[4], R, m__1, m__2, g, I__s)
But the return value is not a list.
So, in summary my quesions are
1) what, in general, is the best way to obtain the desired procedures?
2) is there a way to use the strategy I suggested if the result were a list, but for sets?
Download solveEqs.mw
i need to differentiate this equation
Potential energy eq:
p := (m1*a1 + m2*(a123 + z(t)))*sin(theta(t))*g + m3*(sin(theta(t))*(a1234 + z(t)) + cos(theta(t))*a5)*g;
  p := (m1 a1 + m2 (a123 + z(t))) sin(theta(t)) g    + m3 (sin(theta(t)) (a1234 + z(t)) + cos(theta(t)) a5) g
i have tried these 2 methods
diff(p, theta)
diff(p, theta(t))
but both of them comes out 0
where they should give
diff((m1*a1 + m2*(a123 + z))*sin(theta)*g + m3*(sin(theta)*(a1234 + z) + cos(theta)*a5)*g, theta);
       (m1 a1 + m2 (a123 + z)) cos(theta) g + m3 (cos(theta) (a1234 + z) - sin(theta) a5) g
how is the syntax for partial differentiating a pre defined equation dependent on time.
First 239 240 241 242 243 244 245 Last Page 241 of 2428
