This is really a question on getting index positions of a sub list from the main list.
Have a list of Vertices and a list of populations for each vertes.
Then from the Neighbours list I need the respective positions in the Vertex list to sum to corresponding values from the population list.
2nd Question  Can the population values be displayed near its vertex or in the vertes circle? e.g y=5
with(GraphTheory)
with(SpecialGraphs)
Vs := [x, y, z, w]
[x, y, z, w]
Popvs := [-2, 1, 6, 3]
[-2, 1, 6, 3]
newPopsvs := Popvs
[-2, 1, 6, 3]
X := Graph(Vs)
GRAPHLN(undirected, unweighted, [x, y, z, w], Array(1..4, {(1) = {}, (2) = {}, (3) = {}, (4) = {}}), `GRAPHLN/table/1`, 0)
AddEdge(X, {{w, y}, {w, z}, {x, y}, {y, z}})
GRAPHLN(undirected, unweighted, [x, y, z, w], Array(1..4, {(1) = {2}, (2) = {1, 3, 4}, (3) = {2, 4}, (4) = {2, 3}}), `GRAPHLN/table/1`, 0)
Nbs := [seq(Neighbors(X, Vs[i]), i = 1 .. nops(Vs))]
[[y], [x, z, w], [y, w], [y, z]]
vp := [[0, 0], [1, 0], [1.5, 1], [2, 0]]
SetVertexPositions(X, vp)
DrawGraph(X)
k := rand(1 .. 4)
for c to nops(Nbs) do Nbs[c]; select(proc (i) options operator, arrow; Vs[i] = Nbs[c, 1 .. -1] end proc, [`$`(1 .. nops(Vs))]) end do
Download Q_23-12-22_Test_Graph_indices_.mw
with(ImageTools);
U1 := Read("C:/Users/S/Desktop/StarPicture.jpg"):
ttt0 := textplot([0 + 0.5, (5 + 0) - 0.5, " Star ", color = "blue", font = ["times", "roman", "bold", 40]]):
display(ttt0, U1, axes = none, size = [400, 160]);
This is the error I get:
Error, (in plots:-display) cannot display array with other plots
I can see Maple doesn't allow adding images to plots. But is there a way around that?
I want to be able to virtually have a white box that I can add plots to such as curves, text, and images at certain locations etc? I want to do that with actual Maple code in the worksheet, without having to mouse-clicking Menu, insert, etc.
As we know, choosing different generators can all represent the same group. But how can I get the combination of these different generators by maple? For example, how do I get the following different combinations of generators of C6?
How do I characterize this equation set? I think it has 6 solutions, equal in pairs, or 3 distinct solutions.
eq1 := x = (((72*5^(3/2)+270)*a^2-1344*5^(3/2)*a)*w+(9*5^(5/2)-1485)*a^2-2016*5^(3/2)*a-12544*5^(5/2))/(((288*sqrt(5)+216)*a^2-5376*sqrt(5)*a)*w+(36*5^(3/2)-1188)*a^2-8064*sqrt(5)*a+6272*5^(3/2)):
eq2:= a^3 = -(128*5^(5/2)*w)/9+(1600*w)/3+(544*5^(3/2))/9+15200/27:
eq3:=1+w+w*w = 0:##   or w = (sqrt(3)*%i)/2-1/2;
for s1 in [solve(eq2,a)] do
    for s2 in [solve(eq3,w)] do
        subs(a=s1, eq1):
        subs(w=s2,%):
        lprint("sol",simplify(%));
The loop for HFS _data_2 and SFS_data_2 and the loop for HFS _data_3 and SFS_data_3 do not seem to be terminated. I do not know what it is the issue here. Anyone who can help this?
Negativity_(v12_beta_gamma_mu).mw
Thank you in advance,
simplify(sqrt((x^2 + y^2)/x)/sqrt(x^2 + y^2)) assuming x>0, y>0
is not sqrt(1/x), why?
If we have two univariate polynomials $f(x)$ and $g(x)$ such that
$gcd(f(x),g(x))=1$
then we know there exist two other polynomials $a(x)$ and $b(x)$ such that $a(x)f(x)+b(x)g(x)=1$. For example, if $f(x)=x^3−1$ and $g(x)=x^2+2$, then we can set
$a(x)=\frac{2x−1}{9}$, $b(x)=\frac{−2x^2+x+4}{9}$
Here the polynomials $a(x)$ and $b(x)$ are known as Bezout polynomials and they can be found using the extended Euclidean algorithm, which I know how to do using pen and paper, but not in Maple.
So my question is: in Maple, is there a way, given $f(x)$ and $g(x)$, to solve for $a(x)$ and $b(x)$?
Another training example (number 2 and last) for finding all solutions to a system of equations:
f1 := x3^2-0.1*x1^4-0.05*x2^4+1;
f2 := x1^3+x2^3+0.05*x3^3-1;
f3 := -2*cos(3*x1)+2*cos(3*x2)-2*cos(3*x3)+1;
In my version, there are 116 solutions.
Is it so?
What kind of solution is it (see (3))? Why is there no solution when I put the initial condition v(0)=C1? Secondly, eq. (2) can be reduced to a first-order differential equation?
interface(showassumed = 0)
declare(v(y))
q := v(y)*(diff(diff(diff(v(y), y), y), y))+(2*v(y)-(diff(v(y), y)))*(diff(diff(v(y), y), y))+(diff(v(y), y))*(v(y)^3+v(y)-(diff(v(y), y))) = 0
dsolve(q)
v(y) = ODESolStruc(_a, [{(diff(diff(_b(_a), _a), _a))*_b(_a)^2+_b(_a)*((diff(_b(_a), _a))^2*_a+_a^3-(diff(_b(_a), _a))*_b(_a)+2*(diff(_b(_a), _a))*_a-_b(_a)+_a)/_a = 0}, {_a = v(y), _b(_a) = diff(v(y), y)}, {y = Int(1/_b(_a), _a)+_C1, v(y) = _a}])
dsolve({q, v(0) = C1})
v(y) = C1
Download CD_ode.mw
File:
PCA.mw
I am a student in the middle of a projekt, where math is an essential part of the task. I have done a lot of work in a maple document, but this document suddenly became corrupted. I've tried restarting and loading backups and f ollowed Can I repair a corrupted Maple document/worksheet file? (maplesoft.com) but the solutions didn't work on my document.
Also tried the DeleteBadCharacters() proccess, but i get the error "Error, (in XMLTools:-ParseString) Element type "Equation" must be followed by either attribute specifications, ">" or "/>"."
Is there a way to fix this issue, and prevent the same issue occuring in the future?
Thanks in advance!
This is a training example for finding all solutions to a system of equations. If you look at the graph, you can count 36 solutions, but I managed to find 20 relatively good approximations. No attempts to get more solutions, which are also visible as intersections of graphs, did not lead to success. Therefore, there is a suspicion that there are only 20 solutions.
Is it so?
 restart: with(plots):
 a:=8.:
 f1 := x1^4-1.999*x1^2*x2^2+x2^4-1;
 f2 := tan(x1+x2)-x2*sin(x1);
 implicitplot([f1, f2], x1 = -a .. a, x2 = -a .. a, numpoints = 25000, scaling = constrained,  color = [red, blue], thickness = 1);
   1, (3.192246883291975), (-3.0395187374365404)
   2, (3.0952031367176476), (-3.2447717313041897)
   3, (0.5881900748267959), (-1.160066226905079)
   4, (-0.936866718243322), (-1.3700058362814254)
   5, (-2.555853694651265), (-2.7399958564861953)
  6, (-3.2556241416421168), (-3.3964651254113774)
   7, (-3.583319843955091), (-3.7077839724189228)
   8, (-5.364827188794712), (-5.401998918608201)
   9, (-5.398295356665546), (-5.360818510223991)
  10, (-3.769206506106412), (-3.6477855329362683)
  11,(-1.3978806247566642), (-0.9772190664843745)
   12, (-1.192159295544978),(0.6492335177657542)
   13, (-3.0867255059416623),(2.927375855548188)
    14, (-3.18519036357835), (3.329801919022179)
   15, (2.0108268901120754), (2.243492422396739)
   16, (3.1133812329649766), (3.261937603184373)
   17, (4.0265558604742715), (4.130826167761226)
    18, (4.124539552922121), (4.019977762680433)
    19, (3.172338340844501), (3.018365965761908)
   20, (2.1945695320368097), (1.9558412553082192)
Hi !
I want to create a notation for a function, let's say :
f:=(x,y,z)->something
such that when I ask for
f(x,y,z)
Maple returns
fx,y(z) or anyother "nicer view" of that expression.
This is (I think) a similar action of replacing BesselJ(n,x) by Jn(x).
Many thanks for your answers !
Kevin
First 248 249 250 251 252 253 254 Last Page 250 of 2428
