File:
Solution_Methods.mw
Download Solution_Methods.mw
So i have an exam right around the corner, and maple decided to corrupt my file. I get the error "There was a problem in the loading process, you worksheet may be incomplete." I've tried the following troubleshooting:
Restart - No luck
Other computer - No luck
Checked the backupfolder. - 10 backups have been made, but they are all corupt aswell
I've Followed Can I repair a corrupted Maple document/worksheet file? (maplesoft.com) It didn't really do anything
Also tried the DeleteBadCharacters() proccess, but i get the error "Error, (in XMLTools:-ParseString) Element type "Equation" must be followed by either attribute specifications, ">" or "/>"."
Anyone who can help me out here?
Please Help! I am a beginner in using maple, I am getting  error in theta(k+2).How to get  m1,m2,m3 values from theta(k+2) and how to plot a curve theta(eta) like,f(eta). pp_DTM.mw
Download pp_DTM.mw
Hi there,
I updated to Maple 2022 recently. One problem I am facing is how after I write the code and get the output, which can be text or equations or plots, etc, when I try to copy it to MS Word for example, I don't have the option of "Copy as Image" anymore. This option was available in previous versions. So was it taken out in this version? If yes, what's a subtitue for that?
I am using Maple for a school project and need to be able to copy the 2D output to MS Word just like the previous versions of Maples did.
I'm trying to get familiar with the Physics package. It's huge.  Since I know vector projection, I can guess what a projected vector might be. But what would a non-projected vector be in a physical context?
A web search for non-projected vectors was unsuccessful.
My best guess is that non-projected vectors in Maple are those where no coordinate system is specified for vectors in an expression for a physical law. Like here in Maxwell equations. Am I correct?
To distinguish between these vectors the Physics[Vector] package uses an underscore “_”.
If my understanding is correct so far, I have three questions:
  • Can I replace the unit vectors of implemented projected vectors to something else (e.g. _i to e__x)
  • Is it possible to define projected vectors beyond what is implemented in Maple?
  • Can I use the packages VectorCalculus and Physics[Vector] at the same time?
Hi friends
Could you please give hints to solve the integral
int(exp(I*k*x)*sech(x),x=-infinity..infinity)
I am trying to run this procedure, but am getting an "Error, missing operation", highlighting the conditional break:
is_prime := proc()
     local i, x_check;
     printf(`Enter an integer to check if it is a prime number...`);
     x_check:=parse(readline(terminal));
     if x_check<=2 then
         printf(cat(x_check,` is a prime number.`));
         for i from 2 to x_check-1 do
               if (irem(x_check,i)=0) then
                  printf(cat(x_check,` is not a prime number.`));
                  break 2;
If I don't include the integer, I am able to run the procedure, but it does not function like I would like it to. I am running Maple 2022, and can sucessfully run the example conditional break code in the Help. What is wrong with my use of break?
Does Maple 2017 have cwmaple.exe?
GraphTheory/IsHamiltonian says that the method can be one of legacy, sat, or tsp. But why method = tsp brings about an error?
GraphTheory:-IsHamiltonian(GraphTheory:-CompleteGraph(3, 3), method = tsp); # Maple 2022.2
Attachment: HamiltonianGraphQ.mws
I am trying to use the perpendicular symbol &bot; as a superscript. Can this be done? For somereason the document will not displat?
Maple Worksheet - Error
Failed to load the worksheet /maplenet/convert/Q_10-12-22_Polar_point_line_symbol.mw .
Download Q_10-12-22_Polar_point_line_symbol.mw
I read the article "Approximate Symmetries and Infinite Series Symmetry Reduction Solutions to Perturbed Kuramoto–Sivashinsky Equation", and also searched out in Maplesoft website, but couldn't found. Does anyone have the package?
I have a problem in my document (MapletsDisplayError.mw) with the following four lines of code
with(Maplets[Elements]);
maplet3 := Maplet(MessageDialog(warning, "No file containing dissociation constants found.", 'onapprove' = Shutdown()));
Maplets[Display](maplet3);
Attached are two documents.  The first contains just the lines above and works fine.  The second generates an error when run if you choose No to both dialogs, and the error appears to be with the same four lines of code (if I comment those lines I do not get an error).
ThisWorksWithoutError.mw
Please help! How to solve this?
pp-velocity.mw
Hello.
I was wondering if it was possible for maple to automatically type in the values of the variables when calculating like
U:=50V
R:=10ohm
U/R=50V/10ohm=5A
instead of just typing
U/R=5A
hope my question makes sense :D
Let x, y, z be nonnegative real numbers. Obviously, x3+y3+z3-4xyz is not always nonnegative, since its value is -1 when x=y=z=1. But why Maple's minimize gives wrong result?
minimize(x^3 + y^3 + z^3 - 4*x*y*z, x = 0 .. infinity, y = 0 .. infinity, z = 0 .. infinity);
Attachment: MinValue.mws.
MMA's Minimize finds correct infimum:
So, can Maple always find correct exact (i.e., not just numerical) global minima (or maxima) at least for such problems with a small number of variables as well?
When you use
with(Physics):
Setup(mathematicalnotation=true):
diff(x(t), t)
the output is $\dot{x}(t)$
When you write
alias(x=x(t)):
diff(x, t)
the output is $\frac{\partial}{\partiall t} x$
Is it possible to "mix" these two in such a way that diff(x, t) appears as $\dot{x}$ ?
Notation.mw
First 251 252 253 254 255 256 257 Last Page 253 of 2428
