Hi guys,
I know how to plot inequality system through using with(plots) and inequal term. however, I couldn't plot following system of inqulity equations:
alpha <= 0.0002500000000*(-18000.*m^2 + 47271.*m + 39514. + sqrt(3.24000000*10^8*m^4 - 1.701756000*10^9*m^3 - 4.266980559*10^9*m^2 - 3.036299412*10^9*m - 6.95987804*10^8))/(9.*m^2 + 12.*m + 4.), 0.00005000000000*(-90000.*m^2 + 237237.*m + 198158. + sqrt(8.100000000*10^9*m^4 - 4.270266000*10^10*m^3 - 1.069976858*10^11*m^2 - 7.612670111*10^10*m - 1.744924704*10^10))/(9.*m^2 + 12.*m + 4.) <= alpha, -0.6666666667 < m, m < -0.6665522013
please let me know how we can plot it.
with best
u(x,t)=sin(x)cos(t) exact solution
approxmation solution u(x,t) =sin(x)sin(t)
Using t=0 .. 3*Pi the plot is truncated. Changing the 3*Pi to a number, then the full plot shows.
Also keeping 3*Pi but changing y=-1..1 to y=-1.01 .. 1.01 now the full plot shows again.
Is the above normal behaviour or it it a bug?
ode := diff(y(t), t$2) + y(t)=0;
DEtools:-DEplot(ode, y(t), t=0 .. 3*Pi, y=-1 .. 1,[[y(0)=1,D(y)(0)=0]],linecolor=blue);
diff(diff(y(t), t), t)+y(t) = 0
#replacing 3*Pi by a number, then it shows the full plot
DEtools:-DEplot(ode, y(t), t=0 .. 10, y=-1 .. 1,[[y(0)=1,D(y)(0)=0]],linecolor=blue);
#keeping 3*Pi but changing the y range, it now also show the full plot
DEtools:-DEplot(ode, y(t), t=0 .. 3*Pi, y=-1.01 .. 1.01,[[y(0)=1,D(y)(0)=0]],linecolor=blue);
Download strange_result_of_DEplot.mw
hallo every body
please can you help me
how do i solve this differential linear system with respect lambda is positive number
i use maple 18
Let the differential system with $\lambda>0$
\begin{equation}
\begin{array}{ccc}
\dot{x}=y(t)\\
\dot{y}=z(t)\\
\dot{z}=-\lambda y(t)-h(t)
\end{array}
\end{equation}
prob.pdf
Is there any chance to sort the array in maple and add the non-zero values? PFA the screenshot. I actually intend to add the non-zero values (leaving behind the dumX entries). How can I add the numerical values only?
I installed just today the 15-day trial version of Maple Flow.
I could get simple 2D plots of functions but did not succeeded in using fieldplot.
Does fieldplot() work in Maple Flow?
.Hello everybody
.In the attached code how I can compute \lambda2(t,s) and Vbar(s) symbolically
 when I run them, some parts can't be computed. how should I solve this problem?
2.mw
Question 1: Given: c^3 = 1000
How can I have MapleFlow 2022 solve for c?
I can do this manually, of course... by entering...
c=1000^1/3 =
But I haven't been able to figgure out how to have MapleFlow solve for "c" automatically.
Question 2: How to find the log to the base 10?
As it  seems the default is base e.
Question 3: What is antilog function for a given base?
Thanks for any help.
Why maple give empty solutions? See ref. (12) in the attached wokrsheet. Is there anything missing when deriving Sols?
sols_tw.mw
hi im currently doing my thesis and can somebody help me to develope the code? pls im stuck..
_local(I);
Digits := 15;
de1 := (1 - p)*(diff(S(t), t) + mu*S(t)) + p*(diff(S(t), t) + mu*S(t) + beta*S(t)*I(t) - rho*R(t) - varepsilon);
de2 := (1 - p)*(diff(E(t), t) + (alpha1 + mu)*E(t)) + p*(diff(E(t), t) + (alpha1 + mu)*E(t) - beta*S(t)*I(t));
de3 := (1 - p)*(diff(I(t), t) + (alpha2 + delta + mu)*I(t)) + p*(diff(I(t), t) + (alpha2 + delta + mu)*I(t) - alpha1*E(t));
de4 := (1 - p)*(diff(R(t), t) + (mu + rho)*R(t)) + p*(diff(R(t), t) + (mu + rho)*R(t) - alpha2*I(t));
ibvc := S(0) = 2304219, E(0) = 84929, I(0) = 299, R(0) = 71411;
sys1 := eval([de1, de2, de3, de4], p = 1);
dsolve(sys1);
sys0 := eval~(sys1, [{I = 0, R = 0}, {I = 0, S = 0}, {E = 0}, {I = 0}]);
sys_p := `*`~(1 - p, sys0) +~ `*`~(p, sys1);
ode1, ode2, ode3, ode4 := seq(sys_p[j], j = 1 .. 4);
ode1;
de1;
collect(expand(ode1 - de1), S(t), factor);
ode2 - de2;
ode3 - de3;
ode4 - de4;
mu := 0.133*10^(-5);
varepsilon := 0.99879;
delta := 0.004554;
beta := 0.1009*10^(-6);
alpha1 := 0.0008999;
alpha2 := 0.1997;
rho := 0.00090021;
res := dsolve({ibvc, ode1, ode2, ode3, ode4}, numeric, parameters = [p], abserr = 0.1*10^(-14), relerr = 0.1*10^(-12));
res(parameters = [0.5]);
res(50);
plots:-odeplot(res, [t, S(t)], 0 .. 100);
res(parameters = [1]);
Q := proc(p, {scene::list := [t, S(t)], range::range := 0 .. 100}) if not p::realcons then return 'procname(_passed)'; end if; res(parameters = [p]); plots:-odeplot(res, scene, range, _rest); end proc;
Q(0.5, color = blue);
plots:-animate(Q, [p, range = 0 .. 50], p = 0 .. 1, trace = 24);
n := 4;
s := unapply(add(g[k](t)*p^k, k = 0 .. n), t);
e := unapply(add(h[k](t)*p^k, k = 0 .. n), t);
i := unapply(add(i[k](t)*p^k, k = 0 .. n), t);
r := unapply(add(j[k](t)*p^k, k = 0 .. n), t);
Error, (in i[0]) too many levels of recursion
DE1 := series(eval(ode1, {E = e, I = i, R = r, S = s}), p = 0, n + 1);
DE2 := series(eval(ode2, {E = e, I = i, R = r, S = s}), p = 0, n + 1);
DE3 := series(eval(ode3, {E = e, I = i, R = r, S = s}), p = 0, n + 1);
DE4 := series(eval(ode4, {E = e, I = i, R = r, S = s}), p = 0, n + 1);
M := eval([ibvc], {E(0) = e(0), I(0) = i(0), R(0) = r(0), S(0) = s(0)});
I have say  I am taking for example purpose only i need in general
v:="1:1":
k:=4
printf("%s]  is %g, v, k)
Now i want the %s] part in some other color say green or red some dark color.
the %s is inside which need to replaced by the v which will keep coming
I want it for a general say for some part of the printf in some color
At present atleast i want
let F be a function say F(v,k) and it prints out
printf("%s]  is %g, v, k)  where it prints out the %s] part in dark color
I want to collect up the equation terms by the numerical value of the terms coefficient? Have tried sort collect combine...
So far the best I have come up with is nops(indets(on each term). And put them in seperate lists. This still doesn't quiet do the trick.
I am looking to achieve. Would to happy to have then as seperate lists or equations.
(a_1^5+a_2^5...)+5(a_1^4a_2+a_1^4a_3....)+10(a_1^3a_2^2 ....)+20(  ....   )+......+60(a_1^2a_2a_3a_4+ a_1a_2^2a_3a_4....)
pn := (a[1]+a[2]+a[3]+a[4])^5
pn1 := expand(pn)
a[1]^5+5*a[1]^4*a[2]+5*a[1]^4*a[3]+5*a[1]^4*a[4]+10*a[1]^3*a[2]^2+20*a[1]^3*a[2]*a[3]+20*a[1]^3*a[2]*a[4]+10*a[1]^3*a[3]^2+20*a[1]^3*a[3]*a[4]+10*a[1]^3*a[4]^2+10*a[1]^2*a[2]^3+30*a[1]^2*a[2]^2*a[3]+30*a[1]^2*a[2]^2*a[4]+30*a[1]^2*a[2]*a[3]^2+60*a[1]^2*a[2]*a[3]*a[4]+30*a[1]^2*a[2]*a[4]^2+10*a[1]^2*a[3]^3+30*a[1]^2*a[3]^2*a[4]+30*a[1]^2*a[3]*a[4]^2+10*a[1]^2*a[4]^3+5*a[1]*a[2]^4+20*a[1]*a[2]^3*a[3]+20*a[1]*a[2]^3*a[4]+30*a[1]*a[2]^2*a[3]^2+60*a[1]*a[2]^2*a[3]*a[4]+30*a[1]*a[2]^2*a[4]^2+20*a[1]*a[2]*a[3]^3+60*a[1]*a[2]*a[3]^2*a[4]+60*a[1]*a[2]*a[3]*a[4]^2+20*a[1]*a[2]*a[4]^3+5*a[1]*a[3]^4+20*a[1]*a[3]^3*a[4]+30*a[1]*a[3]^2*a[4]^2+20*a[1]*a[3]*a[4]^3+5*a[1]*a[4]^4+a[2]^5+5*a[2]^4*a[3]+5*a[2]^4*a[4]+10*a[2]^3*a[3]^2+20*a[2]^3*a[3]*a[4]+10*a[2]^3*a[4]^2+10*a[2]^2*a[3]^3+30*a[2]^2*a[3]^2*a[4]+30*a[2]^2*a[3]*a[4]^2+10*a[2]^2*a[4]^3+5*a[2]*a[3]^4+20*a[2]*a[3]^3*a[4]+30*a[2]*a[3]^2*a[4]^2+20*a[2]*a[3]*a[4]^3+5*a[2]*a[4]^4+a[3]^5+5*a[3]^4*a[4]+10*a[3]^3*a[4]^2+10*a[3]^2*a[4]^3+5*a[3]*a[4]^4+a[4]^5
els := convert({op(pn1)}, list)
[a[1]^5, a[2]^5, a[3]^5, a[4]^5, 5*a[1]*a[2]^4, 5*a[1]*a[3]^4, 5*a[1]*a[4]^4, 10*a[1]^2*a[2]^3, 10*a[1]^2*a[3]^3, 10*a[1]^2*a[4]^3, 10*a[1]^3*a[2]^2, 10*a[1]^3*a[3]^2, 10*a[1]^3*a[4]^2, 5*a[1]^4*a[2], 5*a[1]^4*a[3], 5*a[1]^4*a[4], 5*a[2]*a[3]^4, 5*a[2]*a[4]^4, 10*a[2]^2*a[3]^3, 10*a[2]^2*a[4]^3, 10*a[2]^3*a[3]^2, 10*a[2]^3*a[4]^2, 5*a[2]^4*a[3], 5*a[2]^4*a[4], 5*a[3]*a[4]^4, 10*a[3]^2*a[4]^3, 10*a[3]^3*a[4]^2, 5*a[3]^4*a[4], 20*a[1]*a[2]*a[3]^3, 20*a[1]*a[2]*a[4]^3, 30*a[1]*a[2]^2*a[3]^2, 30*a[1]*a[2]^2*a[4]^2, 20*a[1]*a[2]^3*a[3], 20*a[1]*a[2]^3*a[4], 20*a[1]*a[3]*a[4]^3, 30*a[1]*a[3]^2*a[4]^2, 20*a[1]*a[3]^3*a[4], 30*a[1]^2*a[2]*a[3]^2, 30*a[1]^2*a[2]*a[4]^2, 30*a[1]^2*a[2]^2*a[3], 30*a[1]^2*a[2]^2*a[4], 30*a[1]^2*a[3]*a[4]^2, 30*a[1]^2*a[3]^2*a[4], 20*a[1]^3*a[2]*a[3], 20*a[1]^3*a[2]*a[4], 20*a[1]^3*a[3]*a[4], 20*a[2]*a[3]*a[4]^3, 30*a[2]*a[3]^2*a[4]^2, 20*a[2]*a[3]^3*a[4], 30*a[2]^2*a[3]*a[4]^2, 30*a[2]^2*a[3]^2*a[4], 20*a[2]^3*a[3]*a[4], 60*a[1]*a[2]*a[3]*a[4]^2, 60*a[1]*a[2]*a[3]^2*a[4], 60*a[1]*a[2]^2*a[3]*a[4], 60*a[1]^2*a[2]*a[3]*a[4]]
add(els[i], i = 1 .. nops(els))
L1 := []; L2 := []; L3 := []; L4 := []; for i to nops(els) do if nops(indets(els[i])) = 1 then L1 := [op(L1), els[i]] elif nops(indets(els[i])) = 2 then L2 := [op(L2), els[i]] elif nops(indets(els[i])) = 3 then L3 := [op(L3), els[i]] else L4 := [op(L4), els[i]] end if end do; L1; L2; L3; L4
[60*a[1]*a[2]*a[3]*a[4]^2, 60*a[1]*a[2]*a[3]^2*a[4], 60*a[1]*a[2]^2*a[3]*a[4], 60*a[1]^2*a[2]*a[3]*a[4]]
indets(els[7])
{a[1], a[4]}
indets(els(5))
`~`[op](1 .. -1, L2)
[5, a[1], a[2]^4, 5, a[1], a[3]^4, 5, a[1], a[4]^4, 10, a[1]^2, a[2]^3, 10, a[1]^2, a[3]^3, 10, a[1]^2, a[4]^3, 10, a[1]^3, a[2]^2, 10, a[1]^3, a[3]^2, 10, a[1]^3, a[4]^2, 5, a[1]^4, a[2], 5, a[1]^4, a[3], 5, a[1]^4, a[4], 5, a[2], a[3]^4, 5, a[2], a[4]^4, 10, a[2]^2, a[3]^3, 10, a[2]^2, a[4]^3, 10, a[2]^3, a[3]^2, 10, a[2]^3, a[4]^2, 5, a[2]^4, a[3], 5, a[2]^4, a[4], 5, a[3], a[4]^4, 10, a[3]^2, a[4]^3, 10, a[3]^3, a[4]^2, 5, a[3]^4, a[4]]
op(2, L2[1])
a[1]
op(3, L2[1])
a[2]^4``
Download 30-7-22_Q_sort_equation_by_numerical_coeffs.mw
Why maple return trivial solution after integration (see (11) in the attached .mw))? The result should be some non-trivial solution.
solutionsg.mw
Hello everybody.
I wrote the attached code. this code gives a good result when "H" parameter is equal to 0.5. Even in this condition if I change other parameters, I can get a true result as well. But when I change "H" parameter to 0.6,0.7,0.8 or 0.9 the code can't be executed anymore and I can't get a result.
based on the paper, for H=0.6,0.7,0.8 or 0.9. we have a result.
what's the problem?
can anyone please help me to solve this problem?
thank you for your help in advance.
1.mw
First 291 292 293 294 295 296 297 Last Page 293 of 2428
