For making a Maple package, an mla file, I were always using a same 4 lines code in a Maple worksheet and it was fine, but in Maple 2022 I receive an error message instead with the same 4 lines of code. Here is a simple example. Let's say I have a directory on my computer "C:\Home\Maple projects\Test_package", inside this directory I have one file "main.mpl" and a folder called "Functions" with a single file "Test.mm". The content of these two files are in below.
main.mpl
# This is just to test savelib at Maple 2022
unprotect('testSavelin');
testSavelib := module()
	option package;
	description "This is just a test.";
	export ModuleCopy, ModuleApply, ModulePrint;
	export Test;
kernelopts( includepath = currentdir() ):
$include "Functions\\Test.mm"
end module;
protect('testSavelib');
Test.mm
Test := proc( x :: integer )
	description "prints a message saying what integer you have given to this function.";
	printf("You have inserted the integer %d.\n", x);
Now I open a Maple worksheet and do the followings.
kernelopts(includepath="C:\\Home\\Maple projects\\Test_package"):
read("C:\\Home\\Maple projects\\Test_package\\main.mpl");
LibraryTools:-Create("C:\\Home\\Maple projects\\Test_package\\test.mla");
savelib('testSavelib'," C:\\Home\\Maple projects\\Test_package\\test.mla ");
On previous versions of Maple the result would be a test.mla file with the testSavelib package in it. But in Maple 2022 I receive an error message instead, and the test.mla is an empty mla.
Error, could not open ` C:\Home\Maple projects\CAD project\test.mla \testSavelib.m` for writing
Here is a screenshot.
Maple is usually very fast, and I recently upgraded to 2022 edition.
However in the new version, I tried to solve this equation here.
solve(1 + 0.15 = (1 + r__x)^1.28858)
It took Maple 2022, 46 to 118 sec to come up with a solution to the above. I run Windows 11 latest version, have 32 GB of ram and dual NVME disks in my laptop.
Windows 11 uses almost a Gigabyte of memory do this calculation.
So what could be wrong? Is mserver not working proberly?
solve(9*log10(x + 1) = root[3](x), x);
How come maple can't solve this equation with the standard command?
And what can I do to find all the solutions?
EDIT: For some reason I can't repply.
@Kitonum , thanks for answer.
I suspect there may be more real solutions than the ones in your example, but if I change the range some of those in your example goes missing. Is that a bug?
Bonjour,
Comment transformer cette suite de résultat que renvoie Maple, en liste unique :
                               9
                               7
En une liste unique telle que :
L: = [
1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 2, 3, 1, 4,1, 11, 9, 7 ]
Merci
HELLO,
How to transform this result in one list :
                               9
                               7
In a simple list such that :
L: = [
Thank You
I want to extract the highest linear and non-linear terms in an equation without their coefficients
How I can do it?
For example in the following equation, the highest linear and nonlinear without coefficients are diff(u(T),T$3) and u(T)*diff(u(T),T), respectively.
w*a*diff(u(T),T)+a*u(T)*diff(u(T),T)-(b^2)*a*w*diff(u(T),T$3)=0
How can the Cartesian Product of sets be implemented recursively in Maple?
Let k be a positive integer and Si , i=1,...k be nonempty finite sets.
How can Mk:=S1 x S2 x ...x Sk be constructed with Maple by recursion?
Maple 2022:
It appears that one can use push_back() with an empty DEQueue(), but not push_front().
Since the queue is double-ended and empty, this doesn't make much sense to me. So should this be considered a "bug"?
See the attached
# This works
  A:=DEQueue();
  empty(A);
  push_back(A,2);
module DEQueue () local num, head, tail, storage, dsp; option object; end module
# But this results in an error!
  B:=DEQueue();
  empty(B);
  push_front(B,2);
Error, invalid return value from method moduledefinition: 'NULL'
Download DEQueue_Prob.mw
I have just started using the GR functions available in Maple and have struggled to implement locally flat coordinates whilst using an arbitrary metric. I would like Maple to know that the first partial of g_ is 0 but that the second may not be. This knowledge would help simplify down some of the bulky expressions for the Riemann tensor in terms of g_. Any suggestions would be great as I have very little background knowledge with the submodule.
For_mapleprimes.mw
g := 9.81;
with(DEtools);
odeplot(dsolve({diff(x(t), t, t) = 0, diff(y(t), t, t) = -g + y(t)^2, x(0) = 1, y(0) = 0, D(x)(0) = 0, D(y)(0) = 0}, numeric), numpoints = 1000);
Hi, do you know why this plot is ragged? and my second question do you know how to get a single function x(t) or y(t) from this numeric solution instead getting parametrization plot [x(t),y(t)]? Thanks in advance.
Hi Im not sure how to solve this issue, I am new to maple and can't figure out what is going wrong. Any help is very much appreciated.
I am trying to find the solution (\Psi) as approaches zero. However, after applying the limit the solution becomes zero. See the attached .mw file.limit.mw
A question by @Shameera  I was working on has disapeared meanwhile.
It was related to this previous thread 233822-How--To-Solve-This-Equation-By-Using but has not been displaced in it.
Did a regolaror do this or was it  @Shameera ?
Why do I get 2 wrong answers here?
I see that they are all false but the last answer is close enough for my purposes
  with(RealDomain)
"`f__1`(x):=6.-sqrt(-x^(2)+8*x+9.)" = proc (x) options operator, arrow, function_assign; 6.-RealDomain:-sqrt(-RealDomain:-`^`(x, 2)+8*x+9.) end procNULL
  l__ength := solve(10 = int(f__1(x), x = 0 .. l), l) = 8.855609656, -.4725737205, 6.810993084NULL
10 = int(f__1(x), x = 0 .. l__ength[1]) = 10 = 16.02268001"(->)"false
10 = int(f__1(x), x = 0 .. l__ength[2]) = 10 = -1.586294894"(->)"false``
10 = int(f__1(x), x = 0 .. l__ength[3]) = 10 = 10.00000001"(->)"false
Download Not_working.mw
I have a routine which returns a certain result. In the simplest case the result should be p[[1]].
The result is indeed p[[1]]. However, when I ask whether the result is equal to p[[1]], Maple says false.
Why does is not recognize these two things as being equal?
I have seen that this is possible (for example in the example:  2-D Flexible Spin-up Beam).
When I copy an image to the Windows10 clipboard it does paste to other applications but not to MapleSim. Instead, I get an audio notification from the system that is played on other instances when an action cannot be performed.
Within MapleSim copy and paste works (also between models). However, copying an image from a Maplesim Model to another Windows App does not work.
Can someone confirm that pasting images works in recent verions?
(Clearing the Clipboard removes images copied with MapleSim.
Observed on 2 Windows 10 installations with the version 2022 and 2021.)
First 327 328 329 330 331 332 333 Last Page 329 of 2428
