I need the Infinitesimals(Lie group analysis) of the system of PDE. I have attached below the system of PDE in MAPLE given below.MAPLE_Help.mw
I have code which in module which does this
           DEtools:-kovacicsols(ode,func)
Where ode is some ode and func is y(x).  When I step in the debugger, I get exception at this. It says
       DBG> DEtools:-kovacicsols(ode,func)
       Error, `DEtools` does not evaluate to a module
Same exact code works OK from worksheet as expected.   SO for some reason, inside this module it does not see DEtools and I have no idea why.
Then I tried with :-  before DEtools, but this did not help. it gives
DBG> :-DEtools:-kovacicsols(ode,func)
Error, `table([(dperiodic_sols)=proc () `DEtools/init`() <> 0; `ODEtools/intfactor`(_passed); end etc...
In a worksheet, it all works OK
ode:=diff(diff(y(x),x),x) = (-3/16/x^2-2/9/(x-1)^2+3/16/x/(x-1))*y(x);
func:=y(x);
Gives the solution with no error.
Any suggestion what could be the cause and what to try next? I never seen anything like this. I am running this code using
interface(warnlevel=4);
kernelopts('assertlevel'=2):
I am able to make a MWE. It seems this always happens in the debugger.  But if  I let it run, it works somehow. Only when I try to step into it, it gives error. Here is MWE
foo:=proc(ode,func)
   local result;
    DEBUG();
    result:=DEtools:-kovacicsols(ode,func);
    return result;
And now
func:=y(x);
foo(ode,y(x))
Now in the debugger if I do DEtools:-kovacicsols(ode,func) or if I stepin the call, I get the error. But I hit the continue botton, I do not get the error and it gives solution.
Why this happens?
Maple 2021.2 on windows 10
as the cuts show,  i build a simple  system to check how does the "edge with init" work? The switch is "ideal opening switch". the rising edge is always "0" while the voltage is always 1v, it seems that the "edge with init" doesn't work. Please give me some explaintion of the problem.
here is thetest.msim
@acer,
In the past, you had shown how to use take a given sparse A matrix and store the LU components and use the same factorization for multiple backsolves at https://www.mapleprimes.com/posts/41191-Solving-Sparse-Linear-Systems-In-Maple#comment200817
When PDEs are solved, we are calling the A matrix at every time step (with some discretizations in x) and the factorization is done and stored at every time step (this is time-consuming and memory-consuming). Is it possible to call UMFPACK using only the sparse storage and entries? The main routine seems to provide the option
https://people.sc.fsu.edu/~jburkardt/f77_src/umfpack/umfpack.html
This would mean that the pattern is found only once for the Jacobian at t= 0, then only the non-zero sparse entries (vector/row, not a matrix) are updated at every time step.
To be clear, what I am asking for is create a random sparse matrix (say 4x4 or 10x10)
create a b Vector.
Solve AZ =b with method = SparseDirect. (This should internally create and store R, CC, X as at https://people.sc.fsu.edu/~jburkardt/f77_src/umfpack/umfpack.html)
Store R, CC, X and update only X for a different A matrix with the same sparsity pattern and solve for Z using stored (R, CC), and updated X.
j'ai deux spheres concentriques s1 et s2  de centre O(-1,-1,-1) de rayon respectivement 3 et 2. mais maple donne que FindAngle(s1,s2)=arcos(31/12). comment expliquez ceçi et merci beaucoup.
PDETWOSTEPVARIAMETHOD.mwPDETWOSTEPVARIAMETHOD.mw
Pls i need help to correct this iteration code, I wrote but is not given the correct answer. find attached the worksheet
Hi again everybody,
I hope this can help in some classrooms.
This procedure has some warnings.  Someone else can clean it up.
Also, the ithprime() command can make it a bit slicker.
I did work with prime constelations project, and you can see my web page at mattanderson.fun  .
Refference oeis.org/A40 .
Some prime constelations, and k-tuples, are not of 'general intrest' yet, so they are not in the OEIS encyclopedia YET!
But prime numbers are exciting.  I like doing calculations.
Hopefully someone in the next generation will take up an intrest and do what I did.
pairs_procedure.mw
pairs_procedure.pdf
I wish the best on all of you.
Matt C. Anderson
which kind of input is DeepLearning:-Optimizer(GradientDescent()) suppose to take? Nummeric value or function?
I am fairly new to maple and needing to use it for my project this year. I have been advised to use it to help solve the following integral:
int(2/(1-x^p)^(1/p), x=0..1)
It will give me the answer I am looking for, however I cannot get it to explain the steps to get the answer. I have tried Student Calculus1 and ShowSolution but neither of them seem to be working.
Any help would be really appreiacted!
When plotting for exampe 1/x, can I make the x-axis show 1/10, 2/10, 3/10 and so forth instead of 0.1, 0.2, 0.3?
i wanna build an integrated circuit by digital block of electrical in maplesim. i know the input of digital items should be a vector, but i dont know how to build a vector in maplesim. for example, how to build a simple gate circuit in maplesim? Maybe i should use the modelica to do it?
 i use maplesim 2020.
Hello Sir
Hope you are fine. I am facing issues in integration evaluations. I have attched code and pic as well. Kindly guide me. I am waiting for your kind response.
question.mw
restart; printlevel := 4; kernelopts(version)
{--> enter Terminate, args =
<-- exit Terminate (now at top level) = }
{--> enter ModuleUnload, args =
<-- exit ModuleUnload (now at top level) = }
{--> enter OnUnload, args =
<-- exit OnUnload (now at top level) = }
`Maple 2015.0, X86 64 WINDOWS, Feb 17 2015, Build ID 1022128`
L[time] := 1:
ff11 := cos(1.0*k*(p+q+x+t)):
JJx11 := QQ*(int(int(p*ff11/`&gamma;&gamma;Exact`, p), q))/m;
175631174533.479692645444566411*(int(int(0.273299999999999999999999999999e-21*p*cos(.50*p+.50*q+.50*x+.50*t)/(p^2+q^2+0.746928900000000000000000000000e-43)^(1/2), p), q))
evalf(IntegrationTools:-Expand(%));
int(int(p*ff11/`&gamma;&gamma;Exact`, p = 0 .. 1), q = 0 .. 1); evalf(IntegrationTools:-Expand(%))
int(int(0.273299999999999999999999999999e-21*p*cos(.50*p+.50*q+.50*x+.50*t)/(p^2+q^2+0.746928900000000000000000000000e-43)^(1/2), p = 0 .. 1), q = 0 .. 1)
0.273299999999999999999999999999e-21*(Int(Int(p*cos(.50*p)*cos(.50*q)*cos(.50*x)*cos(.50*t)/(p^2+q^2+0.746928900000000000000000000000e-43)^(1/2)-1.*p*cos(.50*p)*cos(.50*q)*sin(.50*x)*sin(.50*t)/(p^2+q^2+0.746928900000000000000000000000e-43)^(1/2)-1.*p*cos(.50*p)*sin(.50*q)*sin(.50*x)*cos(.50*t)/(p^2+q^2+0.746928900000000000000000000000e-43)^(1/2)-1.*p*cos(.50*p)*sin(.50*q)*cos(.50*x)*sin(.50*t)/(p^2+q^2+0.746928900000000000000000000000e-43)^(1/2)-1.*p*sin(.50*p)*sin(.50*q)*cos(.50*x)*cos(.50*t)/(p^2+q^2+0.746928900000000000000000000000e-43)^(1/2)+p*sin(.50*p)*sin(.50*q)*sin(.50*x)*sin(.50*t)/(p^2+q^2+0.746928900000000000000000000000e-43)^(1/2)-1.*p*sin(.50*p)*cos(.50*q)*sin(.50*x)*cos(.50*t)/(p^2+q^2+0.746928900000000000000000000000e-43)^(1/2)-1.*p*sin(.50*p)*cos(.50*q)*cos(.50*x)*sin(.50*t)/(p^2+q^2+0.746928900000000000000000000000e-43)^(1/2), p = 0. .. 1.), q = 0. .. 1.))
Download question.mw
i use dslove command to solve system of differential equations but got an error, i checked the error but i don't know where i went wrong, please help me!
error: Error, (in dsolve/numeric/process_input) system must be entered as a set/list of expressions/equations
HOI.mw
In Maple what is the fastest way to convert a directed line segment into a vector? Please help me. Thank you a lot.
I have an assignment for my class but I don't know how to get the answer without getting an error. Maple_2.mw
Vector Valued Functions
Level Sets of Scalar Valued Functions
This worksheet is meant to give you some tools that you can use to
explore vector valued functions and scalar valued functions of several variables.
We will use the Student[VectorCalculus]  and the plots  packages.
First we load the packages with a restart at the beginning.  That is
meant to make it easier to check what happens when you run your
solutions.
with(Student:-VectorCalculus);
BasisFormat(false):
with(plottools):
Deivatives and integrals for vector valued functions
Plotting velocity and acceleration along a curve
Plotting functions of two variables and contours.
Exercises
Download Maple_2.mw
First 338 339 340 341 342 343 344 Last Page 340 of 2429
